Relay Racks - HEAVY DUTY Versions
(DNRR Series) - Accessories
Path: Home > Rack Index > Open Frame Relay Racks (DNRR) > Relay Rack H.D. Accessories
Accessories for:
z
z
Usable with heavy duty relay racks...
Either knockdown or welded versions...
DNRR__HD Series
Part Number RRLDCASTER
z
z
z
z
z
z
z
z
z
z
SOLD IN A SET OF 4
Light Duty
800# Mfg's specified weight capacity (Set of 4)
Features ball bearing swivel and hard composition wheels
Stud is 1.5" long and 1/2"-13 thread
All four casters are lockable
Wheels are black & 3" wheel diameter
Includes mounting hardware
Weight - 4.5# (2.1 kg)
CAUTION: Care should be taken in moving rack as it
may be unstable depending on equipment loading pattern.
Ensure weight distribution is safe for mobile use.
Part Number
AutoCAD .dxf
File
Reader
(zipped)
File
RRLDCASTER
86K
39K
Part Number RRLPDOL
z
z
z
z
z
z
z
z
z
Low profile dolly - works with any width relay rack
High stability design (see PDF drawing below)
Heavy duty
1,080# Mfg's specified weight capacity (Set of 4 casters pair per side)
Wheels are blue & 3" wheel diameter
Includes all mounting hardware for casters & rack
Weight - 32# (14.5 kg)
Part Number
AutoCAD .dxf
File
Reader
(zipped)
File
RRLPDOL
74K
69K
Part Number RRHDDOL
z
z
z
z
z
Heavy duty dolly - for 19" relay racks
1,500# Mfg's specified weight capacity (Set of 4 casters
under dolly plate)
Weight - 35# (15.9 kg)
Part Number
AutoCAD .dxf
File
Reader
(zipped)
File
RRHDDOL
56K
105K
NOTE: This dolly will ONLY work
with 19" DNRR Relay Racks
Light Duty Dolly
z
z
z
z
z
z
z
For 19" relay racks
Light duty casters, 10 gauge folded & welded steel plate
Finished in rugged textured black (BK1) powder paint
For use with DNRR__HD racks ONLY
Assembled with 4 - 2.0" diameter casters (manufacturer’s
specified capacity of 600 lbs.)
Comes with mounting hardware
Part Number
AutoCAD .dxf
Reader & .dwg Files
(zipped)
File
1424T
33K
36K
Ganging Kit
z
z
z
z
z
z
Kit contains enough hardware to join two relay racks
Used to join relay racks side by side
No drilling required
Connects through supplied 6 holes (2 in top, middle & bottom)
of frame
Part Number RRALJK
Vertical Wire Manager
z
z
z
z
z
Used to organize bundles of connecting wire
Manufactured in 16 Ga. steel
Mounts to either side of open relay rack (includes mounting
hardware)
Models with doors include a front facing hinged door secured
with magnets
z
z
z
Finished in rugged black textured powder paint
Two units shown here, with a heavy duty - open relay rack
Can be used with top wire management accessories below (except
on aluminum relay racks)
Part Number
Profile
Includes
Door
6" x 5"
Yes
RRCM44UD
6" x 5"
Yes
RRCM48UD
8" x 6"
Yes
RRCM844UD
8" x 6"
Yes
RRCM848UD
Yes
RRCM1244UD 12" x 6"
Yes
RRCM1248UD 12" x 6"
6" x 5" No - Open
RRCMS48
6" x 5" No - Open
RRCMS72
6" x 5" No - Open
RRCMS84
RRCMD84
Use with Rack
Panel Height
Inches Units
77/78.75 44/45
84
48
77/78.75 44/45
84
48
77/78.75 44/45
84
48
42
24
66.5
38
77/78.75 44/45
6" x 5" 2
No - Open 77/78.75 44/45
Piece
Top Wire Management
z
z
z
z
z
Top Manager (Double Shown)
z
z
For use with 19" rack mount DNRR__HD racks
ONLY
16 gauge steel construction
Usable with an infinite combination and number
of ganged or single relay racks
Top of cable manager contains square knockouts
(one shown knocked out in photo below) for use
with optional chimneys
Hinged access door with magnetic catches to keep
wires neat and easy access
Use either joining kits or end panels (see below)
in any combination to fit your needs
Finished in textured black powder paint
Application
Number
Number
Location
of
Part Number Description of Relay
of
Vertical
Vertical
Racks
Managers
Managers
Used
Used
1 rackLeft or
1
1
RR19TMS Single
Right
(26.5" long)
1 rackDouble
(32.5" long)
2 racksRR19TMDD Double
(53" long)
2 racksRR19TMDT Triple (59"
long)
RR19TMD
1
2
2
2
2
3
Left and
Right
Left and
Right,
No Center
Left,
Right and
Center
DNRR_HD Relay Rack with:
Installed top manager (Double).
With left & right vertical mangers.
Chimney through ceiling.
Top Wire Chimney
z
z
z
z
z
Mounts to square knockouts in top manager
For routing wire bundles up & out of the top
manager (above) - through the ceiling
Part Number
Profile
Height
RRCH20
RRCH24
RRCH30
RRCMCH65
RRCMCH86
RRCMCH126
6" x 5"
20"
6" x 5"
24"
6" x 5"
30"
6" x 5"
36"
8" x 6"
36"
12" x 6"
36"
Top Wire End Plates & Joining Kit
z
z
z
z
z
z
Mounts to ends of top manager (above)
Use end plates to close the ends of top managers
Use the joining kit to join multiple top managers
End Plates
Part Number
Description Instructions
RRTMEP
End Plate
RRTMJK
Joining Kit
Joining Kit
DUAL - Channel Rail Mounted
Shelves - For DNRR Relay Racks
(Vented or Unvented)
z
z
z
Vented
z
z
z
z
z
z
Designed ONLY for relay racks (DNRR series) tapped on
both front & rear flange
Dual modem shelf permits front and rear access to modems on
open relay racks
Side brackets allow mounting to either 3" OR 8" deep channel
(see photos). The Vented unit is shown assembled for 8" deep
channel and the Unvented unit is shown assembled for 3"
deep channel.
Uses 5.25" (3U) of vertical panel space
Choice of 19" or 24" deep (19" deep shown)
The vented version provides a sturdy shelf without obstructing
upward heat movement
14-gauge steel construction
Rugged powder paint finish
Requires mounting hardware
Unvented
VENTED
Part Number
DNRMV19BK1
DNRMV1924BK1
Paint
Texture
19" Rack Mount
Black
Textured
Black
Textured
23" Rack Mount
Color
Panel
Width
Shelf
Depth
19"
19"
19"
24"
DNRMV23BK1
DNRMV2324BK1
Black
Textured
Black
Textured
23"
23"
19"
24"
UNVENTED
Part Number
Color
Paint
Panel Shelf
Texture Width Depth
19" Rack Mount
DNRMU19BK1 Black
DNRMU1924BK1 Black
Textured
Textured
19"
19"
19"
23"
23"
19"
24"
23" Rack Mount
DNRMU23BK1 Black
DNRMU2324BK1 Black
Textured
Textured
24"
Note: Weight load tested (DNRMU2324BK1) to 300 pounds.
Monitor Shelf - For DNRR Relay Racks
z
z
z
z
z
z
z
z
z
z
Mounts to panel rails using 5.25" (3U) of vertical panel space
channel. Unit in photo is shown assembled for 3" deep
channel.
Overall 19" deep
Front & rear lip to reduce chance of monitor being pushed off
of shelf
Available in either 19" or 23" rack panel width
Includes an accessory compartment welded to the front,
bottom of the shelf
14 Ga. steel construction
Part Number
DNRMM19BK1
DNRMM23BK1
Color
Black
Black
Panel Width
19"
23"
Note: Weight load tested (DNRMM23BK1) to 300 pounds.
Other Universal Accessories:
z
z
Casters & Dollies (RR series)
Aluminum rack panels (PBPA series)
z
z
z
z
z
z
z
z
z
z
z
z
Steel rack panels (PBPS series)
Formed steel rack panels (PBFS series)
Ventilated & Access Panels (Louvers, slots, baffles etc.)
Doors & Chassis - Panel Mount (Hinged & fixed)
Cable Organizing (Panel mount rings, velcro strap panels & guides)
Shelves - Panel Mount (Fixed, solid & vented)
Keyboard Shelves & Drawers (Vertical rail mount)
Rack mount power bars (1582 & 1583 series)
Cooling Accessories (Fan Panels, Fans, Grills & Baffles)
Blowers (BSP series)
Fan Trays (FT series)
Mounting hardware (Hardware)
DNRR catalog pages (5) - Adobe Reader .pdf format (155K) - From our catalog
rack cabinet accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K) - From our
catalog
Mail Link To Our Catalog Department
Provide full mailing address here for your FREE CATALOG via snail mail...
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check and
ordering!!!
Order from your favorite distributor
HOME PAGE
Copyright; © 1998-2011 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
很抱歉,暂时无法提供与“RRCMS72”相匹配的价格&库存,您可以联系我们找货
