RSVS1926CG1
RSVS1926CG1
    HAMMONDMANUFACTURING
    SHELF SLIDE 26.1X16.6X1.5" BE/GY
RSVS1926CG1 数据手册
1 2 2X RAIL MTG DISTANCE MIN 16" - MAX 27.75" 24.31 in 618 mm 4.81 in 122 mm 14.50 in 368 mm 6.50 in 165 mm .84 in 21 mm TOP VIEW 1.07 in 27 mm 26.12 in 663 mm DETAIL A 3.62 in 92 mm Item Number O0.24 X 1.50 VENTING SLOT DETAIL A 2:1 TYPICAL 18.89 in 480 mm 18.36 in 466 mm MTG 16.64 in 423 mm SHELF .44 in 11 mm 1.06 in 27 mm Quantity 1 RS - VENTED SHELF 1 2 SLIDE - 26" FULL TRAVEL 2 3 SLIDE MTG BRACKET 4 RSVS1926BK1 RSVS1926CG1 3.64 in 92 mm 1.68 in 43 mm 6.10 in 155 mm Title PART NUMBERS PAINTED BLACK TEXTURED PAINTED GREY/BEIGE TEXTURED NOTES Maximum Weight 120 lb Some Assembly Required Slide Assembly Hardware Omitted for Clarity Data subject to change without notice. Isometric drawing not to scale. B 1.50 in 38 mm B FRONT VIEW 3 4X 2.68 in 68 mm 1.00 in 25 mm SECTION B-B 4X in O .19 5 mm SLIDE MTG HOLE www.hammondmfg.com PART NO. RSVS1926
RSVS1926CG1 价格&库存
很抱歉,暂时无法提供与“RSVS1926CG1”相匹配的价格&库存,您可以联系我们找货
