RSUS2431BK1
RSUS2431BK1
    HAMMONDMANUFACTURING
    SHELF SLIDE 31X21.6X1.5" BLACK
RSUS2431BK1 数据手册
Shelves (Sliding) - Panel Mount (Two Pair of Panel Rails) Path: Home > Rack Index > Shelves (Sliding) - Panel Mount - Two Pair of Panel Rails Rail Mounted Sliding Shelf (Unvented) z z z z z click to enlarge z z Attach to both pair of 19” rack rails Heavy duty ball bearing slides included Heavy duty, 14 Ga. steel construction Weight load tested (RFUS2426BK1) to 120 pounds. Folded on all four sides for extra strength Rugged textured powder paint finish MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) UNVENTED - 19" Rack Mount Part Number 3D AutoCAD Solid Model Slide Color Reader .dxf File Shelf Depth .stp files Travel File (zipped) (zipped) RSUS1918BK1 Black RSUS1918CG1 Beige* 164K 82K 79K RSUS1921BK1 Black RSUS1921CG1 Beige* 163K 82K 78K RSUS1926BK1 Black RSUS1926CG1 Beige* 167K 82K 80K RSUS1931BK1 Black RSUS1931CG1 Beige* 173K 91K 18" 18" 21" 20" 26" 26" 31" 28" 106K *Note: "CG2" (Beige color) is being phased out from stock UNVENTED - 24" Rack Mount Part Number 3D AutoCAD Solid Model Slide Color Reader .dxf File Shelf Depth .stp files Travel File (zipped) (zipped) RSUS2418BK1 Black RSUS2418CG1 Beige* 162K 82K 79K RSUS2421BK1 Black RSUS2421CG1 Beige* 161K 82K 78K RSUS2426BK1 Black RSUS2426CG1 Beige* 162K 82K 80K RSUS2431BK1 Black RSUS2431CG1 Beige* 171K 90K 105K 18" 18" 21" 20" 26" 26" 31" 28" *Note: "CG2" (Beige color) is being phased out from stock Note2: Weight load tested (RFUS2426BK1) to 120 pounds. Rail Mounted Sliding Shelf (Vented) z z z click to enlarge z z z z z Attach to both pair of 19” rack rails Provides a sturdy shelf without obstructing upward heat movement Heavy duty ball bearing slides included Heavy duty, 14 Ga. steel construction Weight load tested (RFUS2426BK1) to 120 pounds. Folded on all four sides for extra strength Rugged textured powder paint finish MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) VENTED - 19" Rack Mount Part Number 3D AutoCAD Solid Model Slide Color Reader .dxf File Shelf Depth .stp files Travel File (zipped) (zipped) RSVS1918BK1 Black RSVS1918CG1 Beige* 239K 206K 309K RSVS1921BK1 Black RSVS1921CG1 Beige* 238K 206K 307K RSVS1926BK1 Black RSVS1926CG1 Beige* 341K 241K 387K RSVS1931BK1 Black RSVS1931CG1 Beige* 262K 250K 413K 18" 18" 21" 20" 26" 26" 31" 28" *Note: "CG2" (Beige color) is being phased out from stock VENTED - 24" Rack Mount Part Number 3D AutoCAD Solid Model Slide Color Reader .dxf File Shelf Depth .stp files Travel File (zipped) (zipped) RSVS2418BK1 Black RSVS2418CG1 Beige* 235K 197K 310K RSVS2421BK1 Black RSVS2421CG1 Beige* 234K 197K 307K RSVS2426BK1 Black RSVS2426CG1 Beige* 340K 230K 387K RSVS2431BK1 Black RSVS2431CG1 Beige* 260K 241K 18" 18" 21" 20" 26" 26" 31" 28" 413K *Note: "CG2" (Beige color) is being phased out from stock Note: Weight load tested (RSVS2426BK1) to 120 pounds. Shelves & Slides - catalog pages (5) - Adobe Reader .pdf format (198K) all accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K) Mail Link To Our Catalog Department Provide full mailing address here for your FREE CATALOG via snail mail... Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor Home | Products | Distributors | Technical | Contact Us | Other Options Copyright; © 1998-2011 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RSUS2431BK1 价格&库存
很抱歉,暂时无法提供与“RSUS2431BK1”相匹配的价格&库存,您可以联系我们找货
