RRCMD84
RRCMD84
    HAMMONDMANUFACTURING
    WIRE MANAGER 79X6X5" BLACK
RRCMD84 数据手册
Relay Racks - HEAVY DUTY Versions (DNRR Series) - Accessories Path: Home > Rack Index > Open Frame Relay Racks (DNRR) > Relay Rack H.D. Accessories Accessories for: z z Usable with heavy duty relay racks... Either knockdown or welded versions... DNRR__HD Series Part Number RRLDCASTER z z z z z z z z z z SOLD IN A SET OF 4 Light Duty 800# Mfg's specified weight capacity (Set of 4) Features ball bearing swivel and hard composition wheels Stud is 1.5" long and 1/2"-13 thread All four casters are lockable Wheels are black & 3" wheel diameter Includes mounting hardware Weight - 4.5# (2.1 kg) CAUTION: Care should be taken in moving rack as it may be unstable depending on equipment loading pattern. Ensure weight distribution is safe for mobile use. Part Number AutoCAD .dxf File Reader (zipped) File RRLDCASTER 86K 39K Part Number RRLPDOL z z z z z z z z z Low profile dolly - works with any width relay rack High stability design (see PDF drawing below) Heavy duty 1,080# Mfg's specified weight capacity (Set of 4 casters pair per side) Features ball bearing swivel and hard composition wheels Wheels are blue & 3" wheel diameter All four casters are lockable Includes all mounting hardware for casters & rack Weight - 32# (14.5 kg) Part Number AutoCAD .dxf File Reader (zipped) File RRLPDOL 74K 69K Part Number RRHDDOL z z z z z Heavy duty dolly - for 19" relay racks 1,500# Mfg's specified weight capacity (Set of 4 casters under dolly plate) Features ball bearing swivel and hard composition wheels Includes mounting hardware Weight - 35# (15.9 kg) Part Number AutoCAD .dxf File Reader (zipped) File RRHDDOL 56K 105K NOTE: This dolly will ONLY work with 19" DNRR Relay Racks Light Duty Dolly z z z z z z z For 19" relay racks Light duty casters, 10 gauge folded & welded steel plate Finished in rugged textured black (BK1) powder paint For use with DNRR__HD racks ONLY Assembled with 4 - 2.0" diameter casters (manufacturer’s specified capacity of 600 lbs.) Comes with mounting hardware Weight - 32# (14.5 kg) Part Number AutoCAD .dxf Reader & .dwg Files (zipped) File 1424T 33K 36K NOTE: This dolly will ONLY work with 19" DNRR Relay Racks Ganging Kit z z z z z z For use with DNRR__HD racks ONLY Kit contains enough hardware to join two relay racks Used to join relay racks side by side No drilling required Connects through supplied 6 holes (2 in top, middle & bottom) of frame Part Number RRALJK Vertical Wire Manager z z z z z For use with DNRR__HD racks ONLY Used to organize bundles of connecting wire Manufactured in 16 Ga. steel Mounts to either side of open relay rack (includes mounting hardware) Models with doors include a front facing hinged door secured with magnets z z z Finished in rugged black textured powder paint Two units shown here, with a heavy duty - open relay rack Can be used with top wire management accessories below (except on aluminum relay racks) Part Number Profile Includes Door 6" x 5" Yes RRCM44UD 6" x 5" Yes RRCM48UD 8" x 6" Yes RRCM844UD 8" x 6" Yes RRCM848UD Yes RRCM1244UD 12" x 6" Yes RRCM1248UD 12" x 6" 6" x 5" No - Open RRCMS48 6" x 5" No - Open RRCMS72 6" x 5" No - Open RRCMS84 RRCMD84 Use with Rack Panel Height Inches Units 77/78.75 44/45 84 48 77/78.75 44/45 84 48 77/78.75 44/45 84 48 42 24 66.5 38 77/78.75 44/45 6" x 5" 2 No - Open 77/78.75 44/45 Piece Top Wire Management z z z z z Top Manager (Double Shown) z z For use with 19" rack mount DNRR__HD racks ONLY 16 gauge steel construction Usable with an infinite combination and number of ganged or single relay racks Top of cable manager contains square knockouts (one shown knocked out in photo below) for use with optional chimneys Hinged access door with magnetic catches to keep wires neat and easy access Use either joining kits or end panels (see below) in any combination to fit your needs Finished in textured black powder paint Application Number Number Location of Part Number Description of Relay of Vertical Vertical Racks Managers Managers Used Used 1 rackLeft or 1 1 RR19TMS Single Right (26.5" long) 1 rackDouble (32.5" long) 2 racksRR19TMDD Double (53" long) 2 racksRR19TMDT Triple (59" long) RR19TMD 1 2 2 2 2 3 Left and Right Left and Right, No Center Left, Right and Center DNRR_HD Relay Rack with: Installed top manager (Double). With left & right vertical mangers. Chimney through ceiling. Top Wire Chimney z z z z z For use with DNRR__HD racks ONLY 16 gauge steel construction Mounts to square knockouts in top manager For routing wire bundles up & out of the top manager (above) - through the ceiling Finished in textured black powder paint Part Number Profile Height RRCH20 RRCH24 RRCH30 RRCMCH65 RRCMCH86 RRCMCH126 6" x 5" 20" 6" x 5" 24" 6" x 5" 30" 6" x 5" 36" 8" x 6" 36" 12" x 6" 36" Top Wire End Plates & Joining Kit z z z z z z For use with DNRR__HD racks ONLY 16 gauge steel construction Mounts to ends of top manager (above) Use end plates to close the ends of top managers Use the joining kit to join multiple top managers Finished in textured black powder paint End Plates Part Number Description Instructions RRTMEP End Plate RRTMJK Joining Kit Joining Kit DUAL - Channel Rail Mounted Shelves - For DNRR Relay Racks (Vented or Unvented) z z z Vented z z z z z z Designed ONLY for relay racks (DNRR series) tapped on both front & rear flange Dual modem shelf permits front and rear access to modems on open relay racks Side brackets allow mounting to either 3" OR 8" deep channel (see photos). The Vented unit is shown assembled for 8" deep channel and the Unvented unit is shown assembled for 3" deep channel. Uses 5.25" (3U) of vertical panel space Choice of 19" or 24" deep (19" deep shown) The vented version provides a sturdy shelf without obstructing upward heat movement 14-gauge steel construction Rugged powder paint finish Requires mounting hardware Unvented VENTED Part Number DNRMV19BK1 DNRMV1924BK1 Paint Texture 19" Rack Mount Black Textured Black Textured 23" Rack Mount Color Panel Width Shelf Depth 19" 19" 19" 24" DNRMV23BK1 DNRMV2324BK1 Black Textured Black Textured 23" 23" 19" 24" UNVENTED Part Number Color Paint Panel Shelf Texture Width Depth 19" Rack Mount DNRMU19BK1 Black DNRMU1924BK1 Black Textured Textured 19" 19" 19" 23" 23" 19" 24" 23" Rack Mount DNRMU23BK1 Black DNRMU2324BK1 Black Textured Textured 24" Note: Weight load tested (DNRMU2324BK1) to 300 pounds. DUAL - Channel Rail Mounted Monitor Shelf - For DNRR Relay Racks z z z z z z z z z z Designed ONLY for relay racks (DNRR series) tapped on both front & rear flange Mounts to panel rails using 5.25" (3U) of vertical panel space Side brackets allow mounting to either 3" OR 8" deep channel. Unit in photo is shown assembled for 3" deep channel. Overall 19" deep Front & rear lip to reduce chance of monitor being pushed off of shelf Available in either 19" or 23" rack panel width Includes an accessory compartment welded to the front, bottom of the shelf 14 Ga. steel construction Finished in rugged black textured powder paint Requires mounting hardware Part Number DNRMM19BK1 DNRMM23BK1 Color Black Black Panel Width 19" 23" Note: Weight load tested (DNRMM23BK1) to 300 pounds. Other Universal Accessories: z z Casters & Dollies (RR series) Aluminum rack panels (PBPA series) z z z z z z z z z z z z Steel rack panels (PBPS series) Formed steel rack panels (PBFS series) Ventilated & Access Panels (Louvers, slots, baffles etc.) Doors & Chassis - Panel Mount (Hinged & fixed) Cable Organizing (Panel mount rings, velcro strap panels & guides) Shelves - Panel Mount (Fixed, solid & vented) Keyboard Shelves & Drawers (Vertical rail mount) Rack mount power bars (1582 & 1583 series) Cooling Accessories (Fan Panels, Fans, Grills & Baffles) Blowers (BSP series) Fan Trays (FT series) Mounting hardware (Hardware) DNRR catalog pages (5) - Adobe Reader .pdf format (155K) - From our catalog rack cabinet accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K) - From our catalog Mail Link To Our Catalog Department Provide full mailing address here for your FREE CATALOG via snail mail... Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor HOME PAGE Copyright; © 1998-2011 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RRCMD84 价格&库存
很抱歉,暂时无法提供与“RRCMD84”相匹配的价格&库存,您可以联系我们找货
