SR42SIDEPT
SR42SIDEPT
    TRIPPLITE
    SIDE PANEL FOR SR42UB RACK ENCL
SR42SIDEPT 数据手册
SmartRack Pass-Through Side Panel with KeyLocking Latches for Tripp Lite 42U Server Rack Cabinet, 2 Panels Highlights ● Pre-installed latches lock securely with included keys to protect equipment from theft ● Brushed slots reduce dust ingress and allow easy cable routing in and out of the rack ● Made from heavy-duty steel engineered to stand up to busy IT environments ● Designed for use with 42 in. (1050 mm) depth, 42U rack enclosures ● Fits models based on the SR42UB frame design, including SR42UBEXP and SR42UBWD MODEL NUMBER: SR42SIDEPT Package Includes Locking pass-through steel panels attach to the sides of your SR42UB-based server rack enclosure. Features Steel Pass-Through Side Panels for Installation on Your Tripp Lite 42U Rack Cabinet The SmartRack® SR42SIDEPT side panels feature pre-installed key-locking latches for securing your rack equipment against tampering and theft. Designed for Tripp Lite’s standard-depth SR42UB rack frame, this panel can also be added to the side of an expansion cabinet (SR42UBEXP) when application needs have changed or onto a wide cabinet (SR42UBWD) as the depth remains the same. They can also be used as replacements for existing side panels. Convert an Expansion Cabinet into a Cabinet with Side Panels When needs change and you want to separate your expansion rack cabinets (such as Tripp Lite’s SR42UBEXP), add four** SR42SIDEPT heavy-duty steel panels to the sides of them to convert the racks into standard cabinets with additional cable management functionality. Note: This package includes two (2) singular panels. You will need to purchase four SR42SIDEPT panels total to completely populate an expandable rack. Specifications OVERVIEW UPC Code 037332179128 Accessory Type Side Panel Accessory Class Rack Accessories PHYSICAL Shipping Dimensions (hwd / cm) 91.44 x 10.16 x 105.41 Shipping Dimensions (hwd / in.) 36.00 x 4.00 x 41.50 1/2 ● (2) Side panels with locking latches ● (2) Keys Shipping Weight (kg) 19.50 Shipping Weight (lbs.) 43.00 Unit Dimensions (hwd / in.) 38 x 32.5 x .75 Unit Dimensions (hwd / cm) 96.52 x 82.55 x 1.91 Unit Weight (lbs.) 19.5 Unit Weight (kg) 8.85 WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SR42SIDEPT 价格&库存
很抱歉,暂时无法提供与“SR42SIDEPT”相匹配的价格&库存,您可以联系我们找货
