SRSHELF4PSL
SRSHELF4PSL
    TRIPPLITE
    CABINET STANDARD SLIDING SHELF
SRSHELF4PSL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartRack Standard Sliding Shelf (50 lbs / 22.7 kgs capacity; 28.3 in/719 mm Deep) MODEL NUMBER: SRSHELF4PSL Highlights ● Sliding Shelf mountable rack accessory ● Designed for 4 post rack mounting ● 28.3 in. / 72cm shelf depth, supports up to 50 lbs (22.7 kgs) ● Extendable shelf accommodates tower units, monitors, and other equipment ● Cold rolled steel with black finish ● Required mounting hardware included Package Includes Description Tripp Lite's SmartRack SRSHELF4PSL is a standard sliding shelf for installation in rack cabinets. The SRSHELF4PSL has a 28.3 in. / 72cm depth (29.5 in. / 74.9cm including handle) and can support up to 50 lbs (22.7 kgs). This extendable shelf can accommodate tower units, monitors and other equipment. It is designed for 4 post rack mounting and the required mounting hardware is included. Expandable mounting rails supports installation in racks with front to rear rail distances between 28 in. / 71cm minimum and 46 in. / 117cm maximum. Features ● Standard sliding shelf for installation in rack cabinets ● 28.3 in. / 72cm depth (29.5 in. / 74.9cm including handle) ● Supports up to 50 lbs (22.7 kgs) ● Extendable shelf can accommodate tower units, monitors and other equipment ● Designed for 4 post rack mounting and the required mounting hardware is included ● Expandable mounting rails supports installation in racks with front to rear rail distances between 28 in. / 71cm minimum and 46 in. / 117cm maximum Specifications OVERVIEW UPC Code 037332144171 Accessory Type Rack Shelves Accessory Class Rack Accessories PHYSICAL Color Black 1/2 ● Shelf ● Mounting hardware 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Device Depth (cm) 116.33 Maximum Device Depth (in.) 45.8 Maximum Device Depth (mm) 1,163 Minimum Device Depth (cm) 71.88 Minimum Device Depth (in.) 28.3 Minimum Device Depth (mm) 719 Shipping Dimensions (hwd / in.) 3.00 x 19.70 x 31.00 Shipping Dimensions (hwd / cm) 7.62 x 50.04 x 78.74 Shipping Weight (lbs.) 20.70 Shipping Weight (kg) 9.39 Unit Dimensions (hwd / in.) 1.750 x 19.000 x 29.500 Unit Dimensions (hwd / cm) 4.45 x 48.21 x 76.48 Unit Weight (lbs.) 18.6 Unit Weight (kg) 8.44 FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SRSHELF4PSL
物料型号为SRSHELF4PSL,是Eaton旗下的Tripp Lite品牌产品。
以下是该产品的中文分析:
器件简介: - 这是一款标准滑动架,适用于机架式安装。
- 具有28.3英寸(720毫米)的深度(包括手柄为29.5英寸),能够支撑高达50磅(22.7公斤)的重量。
- 可扩展的架子可以容纳塔式单元、显示器和其他设备。
引脚分配: - 该产品为机架式安装设计,需要4个立柱。
- 扩展安装导轨支持在机架中安装,前后导轨距离在28英寸(710毫米)到46英寸(1170毫米)之间。
参数特性: - UPC代码:037332144171 - 配件类型:机架架 - 配件类别:机架配件 - 颜色:黑色 - 最大设备深度:45.8英寸(116.33厘米,1,163毫米) - 最小设备深度:28.3英寸(71.88厘米,719毫米) - 运输尺寸:3.00x19.70x31.00英寸(7.62x50.04x78.74厘米) - 运输重量:20.70磅(9.39公斤) - 单位尺寸:1.750x19.000x29.500英寸(4.45x48.21x76.48厘米) - 单位重量:18.6磅(8.44公斤)
功能详解: - 标准滑动架,适用于机架式安装。
- 28.3英寸(720毫米)深度(包括手柄为29.5英寸)。
- 支撑高达50磅(22.7公斤)的重量。
- 为4个立柱的机架式安装设计,包含所需的安装硬件。
应用信息: - 适用于需要扩展机架空间以容纳更多设备的场合。
封装信息: - 包装包括架子和安装硬件。
其他信息: - 产品符合RoHS标准。
- 提供5年有限保修期。
SRSHELF4PSL 价格&库存
很抱歉,暂时无法提供与“SRSHELF4PSL”相匹配的价格&库存,您可以联系我们找货
SRSHELF4PSL
  • 1+2861.058581+370.25787
库存:69
