FERM18S
FERM18S
    HELLERMAN(海尔曼太通)
    18/24 UNLOADED
FERM18S 数据手册
855-49200 Article Number: 855-49200 Description: Rack Mount Fiber Enclosure-Unloaded, Accepts 3 LGX Adapter Panels, 1U, BK, 1/pkg Base Data Local Order Number FERM18S Type FERM18S Color Black (BK) Features and Benefits ‡Removable front and rear covers provide easy access to cables. ‡Slide-out tray with easy-to-grip raised edge. ‡Cable management spools for effective slack management. ‡Optional splice trays to assist with cable splicing. ‡Panel positioning for easier patch cords access. ‡Round edge plastic fiber saddles for easier patch-cord routing. ‡Meet ANSI/TIA/EIA 568-C standards. Quantity Per EA Product Description HellermannTyton¶s rack mount fiber enclosures are the ideal direct termination and splice solution of LAN applications capable of supporting up to 72 fibers. While offering easy-to-use front slide-out trays for effortless access to connections, enclosures are equipped with cable management and cable routing accessories to limit bend radius and add strain relief control. HellermannTyton¶s Rack Mount Fiber Enclosures easily fit into 19" or 23" racks. Technical Description Rack Mount Fiber Enclosure-Unloaded, Accepts 3 Adapter Panels for Fiber Counts 18/24, 1U, BK Short Description Rack Mount Fiber Enclosure-Unloaded, Accepts 3 LGX Adapter Panels, 1U, BK, 1/pkg Length L (Imperial) 12.14" Length L (Metric) 308.4mm Height in Units 1U Width W (Imperial) 17.0" Width W (Metric) 431.8mm Height H (Imperial) 1.75" Height H (Metric) 44.5mm Depth D (imperial) 12.14" Depth D (metric) 308.36mm Product Dimensions generated on: 2/24/2017 855-49200 Logistic and Packaging generated on: Package Quantity (Imperial) 1 Package Quantity (Metric) 1 Customs Number(Schedule B) 8538907080 Weight (imperial) 15.0lbs 2/24/2017
FERM18S 价格&库存
很抱歉,暂时无法提供与“FERM18S”相匹配的价格&库存,您可以联系我们找货
