www.hammondmfg.com
UHDM Modular Disconnect Enclosures - NEMA 12
ABB Controls, Allen Bradley, Cutler Hammer, General Electric, Siemens I-T-E Max-Flex™, Square D
Disconnect
Freestanding Enclosures
Application
Standards
Designed to bolt together in any number
of units for maximum flexibility and ease
of transportation. The UHDM system
consists of a Master enclosure to house
the flange mounted disconnect switch
and interlocking Slave enclosures which
may be added or removed as required.
Master enclosure units will accept the
following disconnect switches and circuit
breakers:
• ABB Controls flange mounted
• UL 508 Type 12
• CSA Type 12
• Complies with
• NEMA Type 12
• JIC EGP-1-1967 and EMP-11967
• IEC 60529, IP54
• Appropriate components are
required to maintain these
standards.
variable depth operating mechanism
for disconnect switches and circuit
breakers.
Allen Bradley 1494F flange mounted
disconnect switches and 1494D flange
mounted operators for circuit breakers.
Allen Bradley 1494V variable depth
flange operated disconnect switches
and circuit breaker mechanisms.
C-H Westinghouse Type C361
disconnect switches and operator
mechanism. Cutler Hammer Type C371
circuit breaker operating mechanisms.
Flex ShaftTM handle operators for circuit
breakers.
General Electric Type STDA flange
handles and variable depth operating
mechanisms for disconnect switches
and circuit breakers. Also Spectra-Flex™
cable operators for circuit breakers.
I-T-E Max-Flex™ flange mounted
variable depth operating handles
breakers.
Square D disconnect switches and
circuit breakers used with Class 9422
flange mounted variable depth operating
mechanisms or cable mechanisms.
These enclosures will not receive Class
9422 bracket mounted disconnect
devices or Class 9422TG1 or TG2
devices.
Note:
• Disconnect switches, circuit breakers
and operators are not provided with
the enclosure, and must be ordered
separately from the manufacturer.
Construction
• Formed from 10 gauge steel with
smooth continuously welded seams.
• Body stiffeners are provided in the
larger enclosures for extra rigidity.
• Heavy duty lifting eyes are
anchored into reinforced top
corners.
• Removable doors are secured with
heavy duty lift off hinges.
• Flange trough collar (FTC)
around door excludes liquids and
contaminants.
• Formed 10 gauge steel inner panels
are provided on collar studs.
• Panel supports are provided.
• Center post is removable, providing
easy panel installation.
• Heavy duty three point latching door
mechanism.
• Side openings are reinforced
to provide structural strength,
smooth edges and preset gasket
compression.
• Oil resistant gaskets on doors and
side openings are permanently
secured. No gasket kit is provided.
• Master door handle complete with
Technical references and CAD downloads available at www.hammondmfg.com
177
screw defeater and padlock hasp.
• Slave door handle complete with
padlock hasp.
• A mechanical interlock activated by
the master door prevents the auxiliary
door from being opened first.
• The universal flange cutout provides
mounting for disconnect operators
by use of the appropriate operator
adaptor kit.
• A bonding stud is provided in
the door and a grounding stud is
provided in the enclosure for each
door.
• A literature pocket is provided.
Finish
• Door and enclosure are
phosphatized and finished in ANSI
61 gray recoatable powder coating
on the outside.
• Interior - white powder coating.
• Inner panel is finished in white
powder coating.
Accessories
Additional inner panels...contact factory
Air conditioners...see page 349-367
Blank adaptor plates...see page 182
Operator adaptor kits...see page 182
Blowers...see page 392
Breather kits...see page 400-401
Doorstop kits...see page 453
Enclosure stabilizers...see page 456
Filter fans...see page 371-384
Floor stand kits...see page 453
Heaters...see page 393-396
Light kits...see page 452
Thermostats...see page 397
Window kits...see page 449
All dimensions in inches unless specified otherwise
Quality Products. Service Excellence.
© Hammond Manufacturing
Canada: 519.822.2960 or 905.456.3770
USA: 716.630.7030
Data Subject to change without notice
www.hammondmfg.com
Disconnect
Master Enclosures
Part No.
UHDM724118MFTC
UHDM844118MFTC
UHDM844124MFTC
UHDM727918MFTC
UHDM847918MFTC
UHDM847924MFTC
Overall Dimensions
A
B
C
72.13 40.75 18.13
84.13 40.75 18.13
84.13 40.75 24.13
72.13 79.00 18.13
84.13 79.00 18.13
84.13 79.00 24.13
D
60
72
72
60
72
72
E
33.75
33.75
33.75
72.00
72.00
72.00
F
9.06
9.06
12.06
9.06
9.06
12.06
G
38.06
44.06
44.06
38.06
44.06
44.06
H
63.13
75.13
75.13
63.13
75.13
75.13
I
36.5
36.5
36.5
36.5
36.5
36.5
K
34.75
34.75
34.75
34.75
34.75
34.75
Ship Wt.
lbs.
506
573
658
918
1050
1150
Description
Single Door Disconnect
Left side open
Two Door Disconnect
Left side open
USA: 716.630.7030
178
www.hammondmfg.com
Disconnect
Slave Enclosures
Part No.
UHDM724118SFTC
UHDM844118SFTC
UHDM844124SFTC
UHDM727818SFTC
UHDM847818SFTC
UHDM847824SFTC
Overall Dimensions
A
B
C
72.13 40.25 18.13
84.13 40.25 18.13
84.13 40.25 24.13
72.13 78.50 18.13
84.13 78.50 18.13
84.13 78.50 24.13
D
60
72
72
60
72
72
E
33.75
33.75
33.75
72.00
72.00
72.00
F
9.06
9.06
12.06
9.06
9.06
12.06
G
38.06
44.06
44.06
38.06
44.06
44.06
179
H
63.13
75.13
75.13
63.13
75.13
75.13
I
36.5
36.5
36.5
36.5
36.5
36.5
K
34.75
34.75
34.75
34.75
34.75
34.75
Ship Wt.
lbs.
473
550
570
888
1010
1060
Description
Single Door Slave
Both sides open
Two Door Slave
Both sides open
USA: 716.630.7030
www.hammondmfg.com
C-H Westinghouse
I-T-E Siemens
Type C361 disconnect switch:
• Disconnect switch with an operating
mechanism
• Operating handle: C361H1 or C361H3
• In 24.13" deep enclosures, platform
must be used with shaft (not included)
Disconnect switch:
• Basic switch (right-hand)
• Fuse or no-fuse kit
• Flange mounted handle: FHOHS
• Switch operator
• Operating cable: FHOEC048
Type C371 circuit breaker operating
mechanism with a C-H Westinghouse
circuit breaker:
• Circuit breaker
• Operating mechanism
• Long operating rod (if required)
• Operating handle:
• 150 amp - C371H1 or C371H3
• 250 through 1200 amp - C371H5 or
C371H7
Circuit breaker:
• Circuit breaker
• Pressure wire connectors
• 100 to 600 - FHOH
• 800 to 2000 - FHOHN
• Circuit breaker operator mechanism
• Operating cable:
• 18.13" deep enclosures accept 36" or
48" cables;
• 24.13" deep enclosures require a 48"
cable
• These items are available from Siemens
I-T-E as a complete mechanism with a
36" operating cable only Order items
separately when using a 48" cable
Allen Bradley
Bulletin 1494F flange mounted
disconnect switch:
• Disconnect switch
• Fuse block adaptor (if required)
• Line and load connectors (if required)
1494D flange mounted circuit breaker
operating mechanism:
• Circuit breaker: C-H Westinghouse
• Flange mounted operating mechanism
• Slide mechanism
Bulletin 1494V flange mounted
disconnect switch:
• Disconnect switch
• Operating handle
• Connecting rod/rods (long)
• Trailer fuse block kit (if required)
• Fuse clip kit (if required)
Bulletin 1494V flange mounted circuit
breaker operating mechanism:
• Operating handle
• Connecting rod (long)
Flex-Shaft™ handle mechanism:
• Circuit breaker
• Complete Flex-Shaft™ handle mechanism
General Electric
Disconnect switch:
• Disconnect switch: Type QMR or QMW
• Fuse clip kit or no-fuse kit
• Flange handle: STDA1 or STDA2
• Variable depth operating mechanism
• Extended length drive rod (if required)
Square D
Disconnect switch:
• Disconnect switch with operating
mechanism
• Universal handle mechanism: Type A-1
Circuit breaker:
• Circuit breaker
Circuit breaker:
• Circuit breaker
Circuit breaker with a Spectra-Flex™
cable operator:
• Circuit breaker
• Flange mounted handle mechanism:
• 150 to 600 amps - STDA1
• SK1200 - STDA3
• Breaker mounted mechanism
• Operating cable
Class 9422 Type T disconnect switch
with a cable mechanism:
mechanism: Class 9422, Type T
• Handle mechanism: Class 9422, Type
A-1
• Cable mechanism: Class 9422 CFT_O,
3, 5, or 10 foot
Circuit breaker with a cable mechanism:
• Circuit breaker: Square D
• Handle mechanism: Class 9422, type
A-1
3, 5, or 10 foot
ABB Controls
Disconnect switch:
• Flange operated switch (fusible or nonfusible)
• Shaft:
• 18.13" deep enclosures use DSFHS17
• 24.13" deep enclosures, platform
• Handle: DSFHN-HS12
Circuit breaker:
• Circuit breaker: ABB
• Shaft:
• 18.13" deep enclosures use K7FHDS17
• Handle mechanism: K7FHD-HS12
Disconnect
Disconnect Ordering Information
USA: 716.630.7030
180
www.hammondmfg.com
Disconnect
Formed End Plates and Flat End Plates
Flat Barrier Plate
• Formed from 12 gauge steel.
• Used to enclose the open end(s) of
one or more modular enclosures.
• Two types are available. No separate
gasket kit is required.
• Formed from 14 gauge steel.
• May be used to provide a barrier
between modular enclosures. They
are supplied complete with gasket.
Flat Barrier Plate
Panel Bridge Kit
• Formed from 10 gauge steel.
• May be used to join back panels together
between modular enclosures to provide a
continuous panel surface.
Accessories for Heavy Duty Modular NEMA 12 Enclosures for
Flange Mounted Disconnects
Part No.
UHDM7218ECA
UHDM8418ECA
UHDM8424ECA
UHDM7218EPA
UHDM8418EPA
UHDM8424EPA
UHDM7218BPA
UHDM8418BPA
UHDM8424BPA
UHDMFTC72BK
UHDMFTC84BK
181
A
71.86
83.87
83.87
71.87
83.87
83.87
71.87
83.87
83.87
B
17.87
17.87
23.87
17.87
17.87
23.87
17.87
17.87
23.87
C
60
72
Description
Formed End Plate with
Mounting Hardware
Flat End Plate with
Mounting Hardware
Flat Barrier Plate with
Mounting Hardware
Inner Panel Bridge Kit
USA: 716.630.7030
www.hammondmfg.com
Universal Disconnect Enclosure - Operator Adaptor Kits
• All Universal series enclosures
require one adaptor kit (ordered
separately) to adapt the type of
disconnect and mechanism to be
used.
• Each brand and type requires a
different adaptor kit.
• Each kit contains an adaptor
plate and master door interlocking
mechanism.
• Fully detailed, illustrated
instructions included.
Part No.
AKU
Type
Allen Bradley
Blank Adapter Plate
1494F and D
DSFHN-HS12
K7FHD-HS12
1494V H1
1494V H2
1494V H11
C361H1 or H3
C371H1 or H3
C371H5 or H7
STDA1or STDA2
STDA1or STDA2
STDA1
STDA3
FHOHS
FHOH
FHOHN
9422 type A1
9422 type A1
9422 type A1
9422 type A1
AK1494FD
BPAK
Operator Make
ABB Controls operating handle
Disconnect Switch
Circuit Breaker
Allen Bradley variable depth operating handle
Disconnect Switch
30-200
400-600
Circuit breaker
Cutler Hammer operating handle
Disconnect Switch
Circuit Breaker
• 150A
• 50 to 1200A
Circuit Breaker C371 Flex-Shaft™ handle
mechanism.
General Electric operating handle
Disconnect Switch
Circuit Breaker
Circuit Breaker Spectra-Flex™ cable operators
• 150 to 600A
• K1200
Siemens I-T-E Max-Flex™ operating handle
Disconnect Switch variable depth
Circuit Breaker
• 125 to 600
• 800 to 2000
Square D class 9422 operating mechanism
Circuit Breaker variable depth
Disconnect Switch with cable mechanism
Circuit Breaker with cable mechanism
Disconnect
Space Occupied by Disconnects
Note: Disconnects will occupy space on panel shown by dimensions "K", "L", and
"M". Wiring space "P" is available when disconnect is installed in the enclosure.*The
disconnect information and space occupied tables based on data supplied by
disconnect manufacturer’s bulletins. Hammond Manufacturing not responsible for
dimensional accuracy.
USA: 716.630.7030
182
