SRSHELF4PSLHD
SRSHELF4PSLHD
    TRIPPLITE
    RACK ENCLOSURE CABINET
SRSHELF4PSLHD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartRack Heavy-Duty Sliding Shelf (200 lbs / 90.7 kgs capacity; 28.3 in/719 mm Deep) MODEL NUMBER: SRSHELF4PSLHD Highlights ● Heavy Duty Sliding Shelf supports up to 200 lbs (90.7 kgs) ● Designed for 4 post rack mounting ● 28.3 inch / 72 cm shelf depth ● Extendible shelf accommodates tower units, monitors, and other equipment ● Cold rolled steel with black finish ● Required mounting hardware included Package Includes ● Description Tripp Lite's SmartRack SRSHELF4PSLHD is a heavy duty sliding shelf for installation in rack cabinets. The SRSHELF4PSLHD has a 28.3 in. / 72 cm depth (29.5 in. / 74.9cm including handle) and can support up to 200 lbs (90.7 kgs). This extendible shelf can accommodate tower units, monitors and other equipment. It is designed for 4 post rack mounting and the required mounting hardware is included. Expandable mounting rails supports installation in racks with front to rear rail distances between 28 in. / 71cm minimum and 46 in. / 117cm maximum. Features ● Heavy duty sliding shelf for installation in rack cabinets ● 28.3 in. / 72.4cm depth (29.5 in. / 74.9cm including handle) ● Supports up to 200 lbs (90.7 kgs) ● This extendable shelf can accommodate tower units, monitors and other equipment ● Designed for 4 post rack mounting and the required mounting hardware is included ● Expandable mounting rails supports installation in racks with front to rear rail distances between 28 in. / 71cm minimum and 46 in. / 117cm maximum Specifications OVERVIEW UPC Code 037332140654 Accessory Type Rack Shelves Accessory Class Rack Accessories PHYSICAL Shipping Dimensions (hwd / in.) 3.00 x 20.20 x 31.00 1/2 Shelf and mounting hardware 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 7.62 x 51.31 x 78.74 Shipping Weight (lbs.) 23.60 Shipping Weight (kg) 10.70 Unit Dimensions (hwd / in.) 2.360 x 19.000 x 30.000 Unit Dimensions (hwd / cm) 5.99 x 48.21 x 76.48 Unit Weight (lbs.) 24 Unit Weight (kg) 10.89 FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SRSHELF4PSLHD 价格&库存
很抱歉,暂时无法提供与“SRSHELF4PSLHD”相匹配的价格&库存,您可以联系我们找货
SRSHELF4PSLHD
  • 1+4884.729981+630.52215
库存:11
