1421F25
1421F25
    HAMMONDMANUFACTURING
    MACH SCRW FLAT PHIL 10-32 25/PK
1421F25 数据手册
Hardware Part #: 1421 Part #: 1421E25W (package of 4 screws & 4 metal cup washers) (package of 25) Part #: 1421E100W (package of 100) • 10-32 x 0.625" • Slotted oval head screws • Steel cup washers (0.60" outside diameter) • Nickel plated • Metal cup washers • 0.60" outside diameter • Use with 10-32 countersunk screws • Nickel plated Part #: 1421A Part #: 1421A25W (package of 4 screws & 4 plastic cup washers) (package of 25) Part #: 1421A100W (package of 100) • 10-32 x 0.625" • Slotted & phillips combina tion oval head screws • Nickel plated screws • Black plastic cup washers (0.58" outside diameter) • Black plastic cup washers • 0.58" outside diameter • Use with 10-32 countersunk screws Part #: 1421A25B Part #: 1421B (package of 25) (package of 4 screws & 4 nylon washers) Part #: 1421A100B (package of 100) • 10-32 x 0.625" • Slotted & phillips combina tion oval head screws • Nickel plated © • 10-32 x 0.5" thumb screws • With captivated nylon washers • Nickel plated • Works with panels up to 0.09" thick • Head is 0.62" dia. x 0.37" high Part #: 1421F25 Part #: 1421D (package of 25) (package of 25) • 10-32 x 1.25" • Phillips oval head screws • Nickel plated • 10-32 x 0.5" • Slotted & phillips combination pan head screws • Use where economy is important OR for close panel spacing. • Zinc plated Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om 119 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Hardware Part #: H1224S20 Part #: 1421CNC25 (package of 20 screws) (package of 25) Part #: 1421CNC100 • 12-24 x 5/8" • Slotted & phillips combina tion pan head screws • Zinc plated • Used mainly on our aluminum open relay racks (RRAL series) (package of 100) Part #: 1421N25 Part #: 1421CNB25 (package of 25) (package of 25) Part #: 1421N100 Part #: 1421CNB100 (package of 100) (package of 100) • 10-32 clip nuts • USE ON ROUND HOLE PUNCHED RAILS ONLY • Has the holding strength of a 10-32 nut • Black finish • M6 cage nuts • USE ON SQUARE HOLE PUNCHED RAILS ONLY • Has the holding strength of a M6 nut • Zinc plated Part #: 1421NP25 Part #: RCNIT (package of 25) (cage nut insertion tool) • 12-24 cage nuts • USE ON SQUARE HOLE PUNCHED RAILS ONLY • Has the holding strength of a 12-24 nut • Zinc plated Part #: 1421NP100 (package of 100) • 10-32 clip nuts • USE ON ROUND HOLE PUNCHED RAILS ONLY • Has the holding strength of a 10-32 nut • Zinc plated Part #: 1421CNA25 Part #: 1463S (package of 25) (package of 3 bolts, spring nuts & washers) Part #: 1421CNA100 (package of 100) • 10-32 cage nuts • USE ON SQUARE HOLE PUNCHED RAILS ONLY • Has the holding strength of a 10-32 nut • Zinc plated 120 © • Allows for easy installation of cage nuts in square rail hole • Spring steel tool Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om • 3/8 x 16 spring loaded nuts (for Rack "C" channels) • 0.75" hex head bolts & washers • used to mount one rack rail (used in racks with Amhal strut rail mounting) Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
1421F25 价格&库存
很抱歉,暂时无法提供与“1421F25”相匹配的价格&库存,您可以联系我们找货
