150.00 mm
[5.906 in]
8-32 HEX NUT
(4pcs supplied)
#8 EXT. TOOTH
(4pcs supplied)
n16.00 mm
[.630 in]
10 TINNERMAN'S NUT
(4pcs supplied)
OPTION #1
#10-32 X 5/8" TRILOBE
SCREW (FOR FAN)
(4pcs supplied)
150.00 mm
[5.906 in]
OPTIONAL FAN
CUT-OUT PER TEMPLATE
120mm GASKET
BASE
OPTION #2
8-32 X 2 IN MS PAN PHIL STEEL
(4pcs supplied)
FRONT VIEW OF ASSEMBLY
FILTER MEDIA
COVER
BOTTOM VIEW OF ASSEMBLY
105.00 mm
[4.134 in]
2.30 mm
[.091 in]
GASKET THICKNESS
n6.00 mm
NOTE
Purchased assembly includes snap-together Cover and Base (FRABS
UL94-V0), foam EVA gasket, stainless steel mounting hardware, filter
media and installation template.
[.236 in]
105.00 mm
[4.134 in]
PART NUMBERS
XPFA120 Filte r Fa n Grill
Bla ck
Be ige - RAL7032
Gra y - ANSI 61
Light Gra y - RAL7035
Acce ssories
Sta nda rd Filte r Me dia (Pkg of 5)
Ple a te d Filte r Me dia (Pkg of 5)
PRE-INSTALLED
FOAM GASKET
XPFA120BK
XPFA120CG
XPFA120GY
XPFA120LG
24.00 mm
[.945 in]
REAR VIEW OF ASSEMBLY
* HARDWARE OPTIONS:
- #10-32 X 5/8" TRILOBE SCREW WILL SELF-TAP INTO HOLES ON
OPTIONAL FAN, OR CAN BE USED WITH #10 TINNERMANS NUT WITH
GRILL ONLY.
- 8-32 X 2" SCREW TO BE USED WITH OPTIONAL FAN.
SIDE VIEW OF ASSEMBLY
XPFA120
PFF2000
PLFF2000
很抱歉,暂时无法提供与“XPFA120LG”相匹配的价格&库存,您可以联系我们找货
