CBDK4
CBDK4
    HAMMONDMANUFACTURING
    BOLTDOWNKIT
CBDK4 数据手册
NEMA 12 Frames (C3 Series) NEMA 12 YL N O E M - FRA L RAILS E N ED A D P U L C N I NOT 19” Extra Wide NEMA 12 Rack Cabinet Front View Side View Rear View (optional cover installed) By using our 24” to 19” rail width adaptors (page 74) you can convert our 24” cabinets to 19” Extra Wide Panel Mount This additional space allows for large bundles of wire that would not fit in standard 19” rack cabinets 70 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Top View ww w.h am mo ndm fg.c om Bottom View Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 NEMA 12 Frames (C3 Series) FEATURES • NEMA 12 rated - ideal for use in harsh factory floor situations • CSA & UL listed • Oil resistant gaskets are permanently secured on all openings • Sides and doors are easily removable for easy internal access • Heavy duty - welded rack (1,500 lb even load rating) • Choice of standard 19” panel width (23” overall) or 24" panel width (28" overall) • By using panel width adaptors (page 74) - this system can be converted to 19” rack mount with extra wiring area on both sides of equipment. Allows space for vertical cable managers (page 96) • Choice of two depths: - usable depth of 21.63" (23.63” overall) - usable depth of 29.50" (31.50” overall) • Unit is shipped as welded frame only with 4 levelling feet • Panel rails are NOT included allows maximum flexibility of panel rail quantity & options (ie..tapped or square hole) • Heavy duty: 14 gauge steel frame • Frame ships with reinforced lifting eyes • Finished in a rugged, textured beige powder paint • See ordering guide (next page) 19” Rack Mount Versions 23.63” Deep (Usable Depth = 21.63”) Panel Height Overall Dimensions (I nches) Strut Center Par t Number Panel Width I nches Units A B Depth H O C3F196323CG1 C3F197023CG1 C3F197823CG1 19.00 19.00 19.00 63 70 78 36 40 45 70.31 77.31 86.06 23.00 23.00 23.00 23.63 23.63 23.63 63.06 70.06 78.81 29.50 33.00 37.38 Panel Height Overall Dimensions (I nches) Strut Center Par t Number Panel Width I nches Units A B Depth H O C3F196331CG1 C3F197031CG1 C3F197831CG1 19.00 19.00 19.00 63 70 78 36 40 45 70.31 77.31 86.06 23.00 23.00 23.00 31.50 31.50 31.50 63.06 70.06 78.81 29.50 33.00 37.38 NEMA 12 31.5” Deep (Usable Depth = 29.5”) 24” Rack Mount Versions 23.63” Deep (Usable Depth = 21.63”) Panel Height Overall Dimensions (I nches) Strut Center Par t Number Panel Width I nches Units A B Depth H O C3F246323CG1 C3F247023CG1 C3F247823CG1 24.00 24.00 24.00 63 70 78 36 40 45 70.31 77.31 86.06 28.00 28.00 28.00 23.63 23.63 23.63 63.06 70.06 78.81 29.50 33.00 37.38 31.5” Deep (Usable Depth = 29.5”) © Panel Height Overall Dimensions (I nches) Strut Center Par t Number Panel Width I nches Units A B Depth H O C3F246331CG1 C3F247031CG1 C3F247831CG1 24.00 24.00 24.00 63 70 78 36 40 45 70.31 77.31 86.06 28.00 28.00 28.00 31.50 31.50 31.50 63.06 70.06 78.81 29.50 33.00 37.38 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 71 Ordering Guide - NEMA 12 (C3 Series) Doors (Page 76) NEMA 12 Side Panels (Page 74) Welded Frame (Page 70) Mounting Rails (Page 73) 72 © Caster Assembly (Page 75) Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Contempra 3 Accessories (Page 73) Universal Accessories (Page 80) Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Panel Rails - NEMA 12 (C3 Series) TAPPED RAILS • SOLD IN PAIRS • Drilled and tapped (10-32) • Heavy duty construction - formed from 10 gauge steel • Full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing) • Bolts vertically in rack to amhal struts • Includes strut mounting hardware, panel mounting hardware available on page 119 • Zinc plated finish • Front of rail allows for 19” or 24” panel rack mounting (depending on the width of the cabinet frame ordered) • By using panel width adaptors (next page) - the 24” rack mount frames can be converted to 19” rack mount with extra wiring area on both sides of equipment • Rear of rail flange for rear support or accessory mounting Pa n e l He i g h t Pa r t Nu mb e r ( S o l d i n Pa i r s ) I n c h e s Un i t s CCR35TZPL 35.00 20 CCR42TZPL 42.00 24 CCR49TZPL 49.00 28 CCR56TZPL 56.00 32 CCR63TZPL 63.00 36 CCR70TZPL 70.00 40 CCR78TZPL 78.75 45 CCR85TZPL 85.75 49 SQUARE HOLE RAILS Pa n e l He i g h t Pa r t Nu mb e r ( S o l d i n Pa i r s ) I n c h e s Un i t s CPR35SZPL 35.00 20 CPR42SZPL 42.00 24 CPR49SZPL 49.00 28 CPR56SZPL 56.00 32 CPR63SZPL 63.00 36 CPR70SZPL 70.00 40 CPR78SZPL 78.75 45 CPR85SZPL 85.75 49 NEMA 12 • SOLD IN PAIRS • Square hole punched - allowing choice of hardware for 10-32 or 12-24 or M6 thread cage nuts), Full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing) • Includes a starter quantity (25) of 10-32 cage nuts • Heavy duty construction - formed from 12 gauge steel, zinc plated finish • Bolts vertically in rack to amhal struts • Includes strut mounting hardware, panel mounting hardware available on page 119 • Front of rail allows for 19” or 24” panel rack mounting (depending on the width of the cabinet frame ordered) • By using panel width adaptors (next page) - the 24” rack frames can be converted to 19” rack mount with extra wiring area on both sides of equipment • 23” mount rails ONLY work in 24” rack cabinet frames • Rear "L" of rail for rear support or accessory mounting 23” Mount Rails Cage Nut Installation Tool • Allows for easy installation of cage nuts in square rail hole • Spring steel tool • Part Number RCNIT © Additional Cage Nuts Pa r t Nu mb e r 1421CNA25 1421CNA100 1421CNC25 1421CNC100 1421CNB25 1421CNB100 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Q t y. P e r Pa c k a g e 25 100 25 100 25 100 Thread 10-32 10-32 12-24 12-24 M6 M6 ww w.h am mo ndm fg.c om Pa n e l He i g h t Pa r t Nu mb e r ( S o l d i n Pa i r s ) I n c h e s Un i t s C P R 2 3 7 0 S Z P L 70.00 40 C P R 2 3 7 8 S Z P L 78.75 45 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 73 Width Adaptors & Side Panels (C3 Series) RAIL WIDTH ADAPTORS (24” Rack Frames ONLY) • NOT REQUIRED FOR 19” RACK FRAMES • SOLD IN SETS OF 6 - ENOUGH FOR ONE PAIR OF RAILS • Converts 24” rack cabinets to 19” rack mount (extra wide) • Provides additional wiring space along both sides of 19" rack mounted equipment • Allows space for vertical cable managers (page 96) • Fits between panel rail and three horizontal channels (amhal struts) • Constructed of black anodized extruded aluminum • Kit includes six adaptor brackets, extender bolts and washers - required hardware for one pair of rails • Part Number CAK1924 SIDE PANELS • SOLD IN PAIRS • Constructed of 16 gauge steel • Panels fit flush with frame • Features quick release 1/4 turn cam fasteners providing a tight seal against gasket on the frame • Finished in beige textured powder paint (matches frame) For 23.63” Deep Frame NEMA 12 Pa r t Nu mb e r C3SP6323CG1 C3SP7023CG1 C3SP7823CG1 Rack Depth (Inches) 23.63 23.63 23.63 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F246323CG1 C3F197023CG1 or C3F247023CG1 C3F197823CG1 or C3F247823CG1 For 31.5” Deep Frame Pa r t Nu mb e r C3SP6331CG1 C3SP7031CG1 C3SP7831CG1 Rack Depth (Inches) 31.50 31.50 31.50 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196331CG1 or C3F246331CG1 C3F197031CG1 or C3F247031CG1 C3F197831CG1 or C3F247831CG1 • For higher security, the quarter turn fasteners on the side panels can be replaced with this key locking version • Order part number C3SPQTRL • Kit contains 4 quarter turn locks and 8 keys. • Good for 1 rack (ie...2 locks per side panel) 74 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Casters & Plinths - NEMA 12 (C3 Series) CASTER BASE ASSEMBLY • Casters and adaptor base provide heavy duty caster capability • Complete assembly with four casters, mounts to rack frame without drilling • 3” non-static rockite caster wheels with ball bearing pivots • 1,080 lb. Mfg's specified weight capacity • Not compatible with plinth (below) • Hardware included For 19” Rack Mount Frames For 24” Rack Mount Frames Pa r t Nu mb e r A Pa r t Nu mb e r A C3CRS19 19.88 C3CRS24 24.88 LOCKING CASTERS • These are exterior mount casters that mount outside of rack frame perimeter to allow foot access of locking pedals • Medium Duty - 560# Mfg's specified weight capacity (Set of 4) • Available in either locking or non-locking format • Sold in pairs allowing for mix of locking and nonlocking on same cabinet • 3.5” diameter wheels add 4.88” to cabinet height • No drilling required as casters fit into built-in caster mounts • Part Number CCSTL for a PAIR of locking casters • Part Number CCSTN for a PAIR of non-locking casters PLINTH NEMA 12 • Adds 4” to overall rack height • 14 gauge steel construction • Features 4 corner units and 4 removable fill panels • By removing both front & rear panels, easy access to bottom cabling and forklift lifting/transport are achieved • Not compatible with levelling feet or casters For 19” Rack Mount Frames Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d CPL19423BK1 CPL19423CG1 CPL19431BK1 CPL19431CG1 Pa n e l Wi dt h 19" 19" For 24” Rack Mount Frames Use with Fr a me D e p t h 23.63" 31.50" Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d CPL24423BK1 CPL24423CG1 CPL24431BK1 CPL24431CG1 Pa n e l Wi dt h 24" 24" Use with Fr a me D e p t h 23.63" 31.50" BOLT DOWN KIT • Fixes rack to floor • Kit includes set of four - 3/8” x 5 1/2” bolts with flat washers and nuts • Can be used with or without plinths • Part Number: CBDK4 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 75 Doors - NEMA 12 (C3 Series) SOLID DOOR • Heavy Duty 14 gauge steel construction • Smooth action handle provides solid NEMA 12 seal • Quick release hinge design allows for easy removal • Can be used on front or rear of frame • Allows full access to space between panel rails when open • Finish matches “C3” type rack frame in the same rugged beige textured powder paint For 19” Rack Mount Frames Pa r t Nu mb e r C3DS1963HCG1 C3DS1970HCG1 C3DS1978HCG1 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F196331CG1 C3F197023CG1 or C3F197031CG1 C3F197823CG1 or C3F197831CG1 For 24” Rack Mount Frames Pa r t Nu mb e r C3DS2463HCG1 C3DS2470HCG1 C3DS2478HCG1 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F246323CG1 or C3F246331CG1 C3F247023CG1 or C3F247031CG1 C3F247823CG1 or C3F247831CG1 PLEXI - GLASS DOOR NEMA 12 • Surface mount • UL/CSA listed polycarbonate window • Heavy Duty 14 gauge steel frame construction • Slimline handle design allows maximum window viewing area & provides a solid NEMA 12 seal • Quick release hinge design allows for easy removal • Can be used on front or rear of frame • Allows full access to space between panel rails when open • Frame matches “C3” type rack frame in the same rugged beige textured powder paint finish For 19” Rack Mount Frames Pa r t Nu mb e r C3DS1963PCG1 C3DS1970PCG1 C3DS1978PCG1 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F196331CG1 C3F197023CG1 or C3F197031CG1 C3F197823CG1 or C3F197831CG1 For 24” Rack Mount Frames Pa r t Nu mb e r C3DS2463PCG1 C3DS2470PCG1 C3DS2478PCG1 76 © Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F246323CG1 or C3F246331CG1 C3F247023CG1 or C3F247031CG1 C3F247823CG1 or C3F247831CG1 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Doors - NEMA 12 (C3 Series) QUARTER TURN - LATCHING SOLID DOOR • Surface mount • Heavy Duty 14 gauge steel construction • 3 quarter turn latches provide solid NEMA 12 seal • Latches are close to door edge allowing for maximum door mounting area • Quick release hinge design allows for easy removal • Can be used on front or rear of frame • Allows full access to space between panel rails when open • Finish matches “C3” type rack frame in the same rugged beige textured powder paint For 19” Rack Mount Frames Pa n e l He i g h t Pa r t Nu mb e r C3DS1963QCG1 C3DS1970QCG1 C3DS1978QCG1 Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F196331CG1 C3F197023CG1 or C3F197031CG1 C3F197823CG1 or C3F197831CG1 For 24” Rack Mount Frames Pa n e l He i g h t Pa r t Nu mb e r C3DS2463QCG1 C3DS2470QCG1 C3DS2478QCG1 Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F246323CG1 or C3F246331CG1 C3F247023CG1 or C3F247031CG1 C3F247823CG1 or C3F247831CG1 SOLID SURFACE COVER NEMA 12 • Surface mount • 16 gauge steel construction • Screws to frame to provide a solid NEMA 12 seal • Normally used to cover & seal the rear of the rack • Finish matches “C3” type rack frame in the same rugged beige textured powder paint For 19” Rack Mount Frames Pa r t Nu mb e r C3CS1963SCG1 C3CS1970SCG1 C3CS1978SCG1 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F196331CG1 C3F197023CG1 or C3F197031CG1 C3F197823CG1 or C3F197831CG1 For 24” Rack Mount Frames Pa r t Nu mb e r C3CS2463SCG1 C3CS2470SCG1 C3CS2478SCG1 © Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F246323CG1 or C3F246331CG1 C3F247023CG1 or C3F247031CG1 C3F247823CG1 or C3F247831CG1 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 77 Exclusive Accessories For NEMA 12 (C3 Series) RACK JOINING KIT • Easily installed joining kit provides alignment and strength for modular multi-bay installations • Finish matches “C3” type rack frame in the same rugged beige textured powder paint • When installed properly, this kit maintains UL/CSA NEMA 12 listing For 23.63” Deep Frame Pa r t Nu mb e r NEMA 12 C3JK6323 C3JK7023 C3JK7823 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196323CG1 or C3F246323CG1 C3F197023CG1 or C3F247023CG1 C3F197823CG1 or C3F247823CG1 For 31.5” Deep Frame Pa r t Nu mb e r C3JK6331 C3JK7031 C3JK7831 Pa n e l He i g h t Inches Units U s e Wi t h Fr a me Pa r t Nu mb e r 63 70 78 36 40 45 C3F196331CG1 or C3F246331CG1 C3F197031CG1 or C3F247031CG1 C3F197831CG1 or C3F247831CG1 DON’T FORGET TO CHECK OUT OUR UNIVERSAL ACCESSORY SECTION - NEXT PAGE 78 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
CBDK4 价格&库存
很抱歉,暂时无法提供与“CBDK4”相匹配的价格&库存,您可以联系我们找货
