1421S10
1421S10
    HAMMONDMANUFACTURING
    MACH SCRW SLOT 1/4-20 10/PK
1421S10 数据手册
www.hammondmfg.com General Accessories Hardware Window Kits Door Clamping Hardware (Heavy Duty)...................................................282 Junction Box Quick Release Clamp.........................................................282 Junction Box.............................................................................................282 Door Clamping Hardware.........................................................................282 Junction Box Padlock Kit..........................................................................282 Chassis Handles......................................................................................283 Wallmount Quick Release Clamp.............................................................283 Type 12/4, 4X Handle Kits........................................................................284 Type 1 Lock Kit.........................................................................................284 Type 12 Handle Kits.................................................................................285 Type 4 Hardware Kits...............................................................................285 Type 4, 12 Lock Kit...................................................................................285 Ground Lugs.............................................................................................286 Bonding Wire Kits.....................................................................................286 Padlock Adaptor(Eclipse/Series 2000).....................................................286 Padlock Adaptor (EJ Series)....................................................................286 Quarter Turn Inserts and Keys.................................................................287 Quarter Turn Assemblies..........................................................................287 Ground Stud Kit........................................................................................287 Eclipse Replacement Hinge Pins.............................................................288 Hole Plugs................................................................................................288 Hole Plugs (Type 4X Stainless Steel - UR/cUR)......................................289 Hole Plugs (Type 4X Non-metallic - UR/cUR)..........................................289 Eclipse DIN Rail Mounting Kit..................................................................290 Eclipse DIN Rails......................................................................................290 Eclipse Handles........................................................................................290 Eclipse Mounting Foot Kit.........................................................................291 Eclipse Rear Mounting Hole Plugs...........................................................291 PJU/PCJ Replacement Polycarbonate Flange.........................................291 PJU/PCJ Replacement Polycarbonate Feet...........................................292 PJ Stainless Replacement Mounting Feet...............................................292 M6 Screw with Hex/Phillips Head.............................................................292 Washdown Quarter Turn Assemblies.......................................................293 Wallmount Stand-offs...............................................................................293 PJ/PJU/PCJ Replacement Hardware Kits................................................293 Mechanical Interlock.................................................................................294 Mild Steel and Stainless Steel Window Kits.............................................308 Frameless Window Kits............................................................................308 Deep Hinged Window Kits........................................................................309 HMI Cover Prop Arm (PJHMI)..................................................................309 Polycarbonate HMI Hinged Cover Kits.....................................................310 Polycarbonate Inspection Window Kit......................................................311 Deep Hinged HMI Cover Kits...................................................................311 Inner Panels (1414/EJ/HJ/PJ)..................................................................294 Inner Panels (1418/1447/PJW/PHW).......................................................295 Inner Panels (Eclipse)..............................................................................296 Inner Panels (1420)..................................................................................297 Inner Panels (HN4FM/1422)....................................................................297 Inner Panels (PCJ)...................................................................................298 Inner Panels (N1J)...................................................................................298 Inner Panels (N1A)...................................................................................299 Perforated Inner Panels (1418/1447/PJW/PHW).....................................299 Inner Panels (1418FS/HN4FS)................................................................300 Perforated Inner Panels (N1A).................................................................301 Perforated Inner Panels (N1J)..................................................................301 Swing Panel Kit........................................................................................302 Terminal Straps and Brackets (1414/EJ/PJ).............................................302 Terminal Straps and Brackets (1418).......................................................303 Eclipse Swing Panel.................................................................................304 Swing Panel (PJ/PJU)..............................................................................304 Swing Panel (PCJ)...................................................................................305 Mounting Rack Rail Swing Frame (Eclipse).............................................305 Mounting Rack Rail Swing Frame (1418FS/HN4FS)...............................306 Freestanding Enclosure Center Panel Supports (1418FS/HN4FS).........306 Eclipse Rack Panel..................................................................................307 NEMA Enclosure Rack Rails (1418FS/HN4FS).......................................307 Miscellaneous DIN Mount Receptacle.............................................................................313 Door Support Guide.................................................................................314 Gland Plates.............................................................................................314 Gland Plates.............................................................................................315 Liquid-Tight Cordgrips (Nylon)..................................................................315 Liquid-Tight Cord Grips (Nickel Plated Brass)..........................................316 Liquid-Tight, Strain Relief Cordgrips.........................................................316 Stack Lights..............................................................................................317 Flange Disconnect Operator Adaptor Kits................................................318 Drip Shield Kit...........................................................................................319 Pedestal and Base...................................................................................319 Floor Stand Kit..........................................................................................320 Door Stop Kit............................................................................................320 Touch-Up Spray Paint..............................................................................321 Literature Pocket......................................................................................321 Enclosure Stabilizers................................................................................322 Rack and Cabinet Caster Set...................................................................322 Panel Lifting Handles...............................................................................323 Wash Down Floor Stand Kit.....................................................................323 Waterfall Series Accessory.......................................................................323 Gasket Kits...............................................................................................323 Fold Down Shelf.......................................................................................324 Pole Mounting Kit (PJ/PJU)......................................................................324 Pole Mounting Kit Junction and Wallmount Style.....................................325 Top Hat Cable Modules............................................................................326 Barrier Kits for Type 4 Wallmount.............................................................327 Barrier Kits for Type 4 Floormount............................................................327 Corrosion Inhibitors..................................................................................328 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Window Kits Fluorescent Light Kit & Accessories.........................................................312 LED Light Kit............................................................................................312 Compact LED Light Kit.............................................................................313 Remote Door Switches.............................................................................313 General Accessories Panels & Panel Accessories Lighting USA: 716.630.7030 Data Subject to change without notice 281 www.hammondmfg.com Door Clamping Hardware Door Clamping Hardware Junction Box Padlock Kit Features Features Features Heavy Duty General Accessories • Replacement hardware for use on all 1418 and 1447 Series enclosures • Formed heavy gauge stainless steel clamp with stainless steel hardware • Sold in sets of two Part No. 1481HC18 • Replacement hardware for use on 1414, HJ, 1485, 1486, and 1487 Hammond enclosures. • Formed heavy gauge stainless steel. • Set of two Part No. 1481C14 Part No. 14PLKS16 Junction Box Quick Release Clamp Junction Box Features Hardware • Installs easily on standard clamp bracket allowing for quick access. • Compatible with 1414 and HJ Series junction boxes. Also 1485 Series wireway and 1486 trough. • Available in plated or stainless steel. • Sold Individually. Part No. Material 14QR Plated Steel 14QRSS 304 SS 14QRS16 316 SS Technical references and CAD downloads available at www.hammondmfg.com 282 • Field installed kit requires drilling of only 4 holes • Compatible with 1414 and HJ Series junction boxes. • Only available in 316 Stainless Steel. • Sold Individually. • Installation instructions provided. All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Chassis Handles Features • • • • Material is round steel. Available in Chrome Plated or Black Powder Coated. Sold individually or in pairs (see table). Hardware included. With Studs, Washers and Nuts Chrome Black Black Part No. Part No. Part No. Mounting Handle Handle Handle Stud Panel (Sold Individually) (Sold Individually) (Sold in Pairs) Height Hole Centers Depth Diameter Thread 1427N3 3.50 2.06 0.38 1/4-20 8.75 1427M3 5.25 2.06 0.38 1/4-20 12.25 With Screws Black Part No. Part No. Mounting Handle Handle Screw Panel (Sold Individually) (Sold Individually) (Sold in Pairs) Hole Centers Depth Diameter Thread Height 1427B 1427B1BK 1.25 0.62 0.19 4-40 1.75 1427B2 1427B2BK-1 1427B2BK 1.25 1.00 0.19 6-32 1.75 1.75 0.75 0.19 4-40 5.25 1427E1BK-1 1427E1BK 2.00 1.00 0.19 6-32 5.25 2.25 1.00 0.25 6-32 5.25 1427P1BK-1 1427P1BK 2.80 1.00 0.25 6-32 5.25 1427D 1427E 1427Q 1427P Handle 1427G2 1427G2BK 3.00 1.00 0.19 4-40 8.75 1427G3 1427G3BK 3.00 1.50 0.31 10-32 8.75 3.00 1.75 0.25 8-32 8.75 1427N1BK 3.50 1.20 0.38 10-32 8.75 1427G 1427N 1427N2 1427N2BK 3.50 1.50 0.25 8-32 8.75 1427C1 1427C1BK 4.00 1.30 0.38 10-32 8.75 1427S3 1427S3BK 1427S 4.00 1.50 0.31 10-32 8.75 4.00 1.50 0.25 8-32 8.75 1427S2 1427S2BK 4.00 1.75 0.25 8-32 8.75 1427U3 1427U3BK 4.50 1.50 0.31 10-32 8.75 1427T3 1427T3BK 1427T 10-32 12.25 8-32 12.25 5.00 1.75 0.25 8-32 12.25 1.20 0.38 10-32 12.25 6.00 1.50 0.25 8-32 12.25 1427W3BK 6.00 1.75 0.31 10-32 12.25 6.00 1.75 0.25 8-32 12.25 1427L1BK 7.00 1.30 0.38 10-32 14.00 8.00 1.63 0.38 10-32 14.00 1427W2 1427L 0.31 0.25 5.30 1427W 1427W3 1.50 1.50 1427M1BK 1427T2 1427M 5.00 5.00 1427H Hardware Black Part No. General Accessories Chrome Wallmount Quick Release Clamp Wallmount Enclosure Features • Provides fast access to conventional screw clamp type enclosures. • Installs on clamp bracket in place of screw on 1418, 1418N4, 1447N4, and 1422N4 Series enclosures. • Entire assembly is 304 stainless steel. • Set of two. Part No. 1418QR Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 283 www.hammondmfg.com Type 12/4, 4X Handle Kits Features • • • • • • • Durable zinc die-cast or stainless steel Removable handle stop for clockwise / counter-clockwise operation Textured powder coat Black finish on zinc cast handle Maintains NEMA rating of the enclosure Padlock “trigger” design for security requirements Optional key lock or defeater available (key lock versions include 2 keys) The handle can be used on Hammond enclosures as field installation (1418, 1422, UHD, HN4, HWHK) or installed on these or other series at the factory … contact Hammond Part No. Description MHK1 6” PADLOCKING 1PT. LATCH Zinc 12, 4 MHK2 6” PADLOCKING 3PT < 60” Zinc 12, 4 NEMA Rating 12, 4 General Accessories MHK3 6” PADLOCKING 3PT > 60” Zinc MHKD1 6” PADLOCKING DEFEATER 1PT LATCH Zinc 12, 4 MHKD2 6” PADLOCKING DEFEATER 3PT < 60” Zinc 12, 4 MHKD3 6” PADLOCKING DEFEATER 3PT > 60” Zinc 12, 4 MHKL1 6” KEYED PADLOCKING 1PT LATCH Zinc 12, 4 MHKL2 6” KEYED PADLOCKING 3PT < 60” Zinc 12, 4 MHKL3 6” KEYED PADLOCKING 3PT > 60” Zinc 12, 4 MHK1SS 6” SS PADLOCKING 1PT LATCH 316 SS 4X MHK2SS 6” SS PADLOCKING 3PT LATCH < 60” 316 SS 4X MHK3SS 6” SS PADLOCKING 3PT LATCH > 60” 316 SS 4X MHKD1SS 6” SS PADLOCKING DEFEATER 1PT LATCH 316 SS 4X 4X MHKD2SS 6” SS PADLOCKING DEFEATER 3PT < 60” 316 SS MHKD3SS 6” SS PADLOCKING DEFEATER 3PT > 60” 316 SS 4X MHKL1SS 6” SS KEYED PADLOCKING 1PT LATCH 316 SS 4X MHKL2SS 6” SS KEYED PADLOCKING 3PT < 60” 316 SS 4X MHKL3SS 6” SS KEYED PADLOCKING 3PT > 60” 316 SS 4X Hardware Type 1 Lock Kit Features • Installs in place of the existing slotted latch, or in cutout hole provided. • Reversible cam position for other applications. • Maintains NEMA1 rating. Part No. Fits Enclosure Series 1427LKN1 1420, N1A N1JLK N1J, N1W, CHKO, N1WF, SWB Technical references and CAD downloads available at www.hammondmfg.com 284 Material All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Type 12 Handle Kits Features Description THK1 1 point latch THK2 3 point latch 48” and under THK3 3 point latch 60” and over Locking Handle Handle Rotation Non-Locking Handle Handle Rotation AHKL1 counter clockwise AHK1 clockwise AHKL2 counter clockwise AHK2 clockwise AHKL3 counter clockwise AHK3 clockwise Features • When used as instructed, kits maintain the UL/CSA Type rating of Hammond enclosures which unapproved hardware will not. • Screws require hex driver making them virtually tamper proof. • Kit includes 50 stainless steel screws, sealing washers and nuts with one hex driver per kit. • Offered in 8-32, 10-32 and ¼-20 at various lengths. Type 4, 12 Lock Kit Part No. Description 1421N4AA50 8-32 x ½” Kit 1421N4AB50 8-32 x 1” Kit 1421N4BA50 10-32 x ½” Kit 1421N4BB50 10-32 x 1” Kit 1421N4CA50 ¼-20 x 5/8” Kit 1421N4CB50 ¼-20 x 1” Kit General Accessories Type 4 Hardware Kits Tee Locking Handle Hardware • Designed for field installation on most 1418 Series single door enclosures (does not fit 1418 J Series). • Available with key locking and non-locking handles. • Single point kits include a handle and latch cam. • Three point kits include a handle, latch cam, latch rods and adjustable rod guides. • Latch rod ends have rollers for easier door closing. • All parts are plated or painted for corrosion resistance. • Note: AHK handle design shown - see individual CAD images for exact representation of each version. Features • Designed for installation on most 1418 Series single door enclosures (does not fit 1418 J Series). • Wing knob design is easy to open once latch unlocked. • Black, zinc diecast wing knob. • Requires a drilled or punched hole to receive cylinder lock. • Internal “0” ring provides dust and water tight construction. • Maintains enclosure’s Type 12/4 UL/CSA rating when installed per instructions. Part No. 2WKL18 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 285 www.hammondmfg.com Ground Lugs Features • • • • • Dual L16 type aluminum lug. Provides excellent grounding. Accepts wire sizes from 1/0 to 14. Packaged individually. Mounting hardware not included (requires drilling of bus bar). Overall Dimensions Part No. Width Length Diameter 0.66 1.13 1.23 0.26 DNGL Bonding Wire Kits General Accessories Padlock Adaptor Features • • • • • 12”, 16”, or 22” long - 10 Gauge Copper Wire. Terminated with crimped on terminals. Terminal hole is 0.256” diameter. Includes mounting hardware for both 1/4-20 or 10-32 ground studs. Includes stick-on grounding symbols (two for each jumper). Part No. Description GRDKIT01 Includes (2) ground cables. 12” GRDKIT02 Includes (6) ground cables. 16” GRDKIT03 Includes (1) ground cable with #10 hardware only. 12” GRDKIT04 Includes (4) ground cables with quick disconnecting terminals. 12” GRDKIT05 Includes (1) ground cable with quick disconnecting terminals. 22” Hardware EJ Series • Designed for use with EN4SD /2000 Series Enclosures. Also compatible with C2, C4 and HWM rack cabinets. • Easily installed in the field. • The padlock adaptor fits directly over the quarter-turn lock or slot preventing access. • Constructed in 14-gauge 316 stainless steel. • Includes stainless steel mounting hardware. • Once installed, the bolts cannot be removed without the door open. • The padlock is not included. • Maintains UL/CSA Type 4, 4X rating. EPA Features • • • • • • • • For use with Eclipse Junior (EJ) Series enclosures. Padlock adapter fits directly over the slotted quarter turn preventing access. 2mm thick 14 gauge stainless steel. Stainless steel mounting hardware provided. Once installed, the bolts cannot be removed without the door open. Easy installed in the field. Padlock not included. Maintains UL/CSA Type 4, 4X rating. Part No. EJPA Technical references and CAD downloads available at www.hammondmfg.com 286 Length Features Part No. Padlock Adaptor Mounting Hole Height All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Quarter Turn Inserts and Keys Features For Eclipse Series Enclosures Field installable inserts replace standard quarter turn slot. Available in double bit, square and triangle formats, as well as slotted. Maintains NEMA, UL and CSA 12, 4 and 4X ratings. Non-slot inserts provide extra security since standard screw drivers cannot open. • Keys sold separately from inserts. Description 2SQI7 7mm square insert, black 2SQK7 7mm square key, fits 2SQI7 2TRI7 7mm triangle insert, black 2TRK7 7mm triangle key, fits 2TRI7 2SLI Slotted insert, black 2DBI3 Double bit insert, 3mm pin, black 2DBI3SS Double bit insert, 3mm pin, stainless PMKEY Double bit key, fits 2DBI3/2DBI3SS Quarter Turn Assemblies Features • Field installable. • Interchangeable with standard quarter turn latches on Eclipse/Eclipse Jr series. • Maintains NEMA, UL and CSA ratings as noted. Part No. Description Material EQTRL ¹ Locking Qtr Turn Zinc Die/Chrome NEMA Rating 2QTR Slotted Qtr Turn Zinc Die/Black 12, 4 EN4SD Series 2SSQTR Slotted Qtr Turn Stainless steel 12, 4, 4X EN4SD Series 2WKL Wing knob lock Zinc Die/Black 12, 4 EN4SD Series 2QPL Padlockable quarter turn latch Zinc Die/Black 12, 4 EN4SD Series EJQTR Slotted Qtr Turn Zinc Die/Black 12, 4 EJ Series EJSSQTR Slotted Qtr Turn Stainless Steel 12, 4, 4X EJ Series EJWKL Key Locking Wing Knob Latch Zinc Die/Black 12, 4 EJ Series EJWKNL Non-Locking Wing Knob Latch Zinc Die/Black 12, 4 EJ Series n/a For Use With ESP Swing Panel (internal use only) General Accessories Part No. Hardware • • • • • ¹ For use with Swing Frame/Panel Ground Stud Kit Features • • • • • Ground Lug provides continuous ground through enclosure body O-ring seals securely within a precision groove outside dimension 0.875” Brass 3/8-16 thread both ends 1” threaded portion Mounting hardware included (requires drilling of .425” hole) Part No. GRDT375 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 287 www.hammondmfg.com Eclipse Replacement Hinge Pins • These are supplied with enclosure but offered here as replacements should originals be misplaced. • Stainless steel • Packaged in quantities of 5. Part No. EPINSS General Accessories Hole Plugs Features Hardware • Designed to seal unused push­button holes, conduit openings and knock­out holes against dust, oil and water. • Standard Pushbutton size is 30.5mm; Mini Pushbutton size is 22.5mm • Steel Hole Plug • Available in 12 sizes. • Finished in 2 color options - ANSI 61 gray or RAL7035 Light Gray • Oil resistant gasket. • Secured with an 10-24 x 0.55” threaded stud and plated wing nut. • Recognized component UR & cUR Type 1, 3, 3R, 4, 12 and 13 • Stainless Steel Hole Plugs • Available in 8 sizes. • Finished in brushed natural 304 stainless steel finish. • Oil resistant gasket. • Secured with an 10-24 x 0.55” threaded stud and plated wing nut. • Recognized component UR & cUR Type 1, 3, 3R, 4, 4X, 12 and 13 Stainless Steel Steel Max Hole Diameter Plug Diameter 22mm Pushbutton 0.88 1.22 HP50SS .5” Conduit 0.88 1.38 HP75SS .75” Conduit 1.06 1.56 HPBSS Std. Pushbutton 1.25 1.75 HP100SS 1” Conduit 1.38 1.88 HP125SS 1.25” Conduit 1.69 2.19 HP150SS 1.5” Conduit 2.00 2.50 HP200SS 2” Conduit 2.50 3.00 Part No. Description HP22SS ANSI 61 Gray RAL7035 Lt Gray Part No. Part No. Description Max Hole Diameter Plug Diameter HP22 HP22LG 22mm Mini Pushbutton 0.88 1.22 HP50 HP50LG .5” Conduit 0.88 1.38 HP75 HP75LG .75” Conduit 1.06 1.56 HPB HPBLG Std. Pushbutton 1.25 1.75 HP100 HP100LG 1” Conduit 1.38 1.88 HP125 HP125LG 1.25” Conduit 1.69 2.19 HP150 HP150LG 1.5” Conduit 2.00 2.50 HP200 HP200LG 2” Conduit 2.50 3.00 HP250 HP250LG 2.5” Conduit 3.00 3.50 HP300 HP300LG 3” Conduit 3.62 4.12 HP350 HP350LG 3.5” Conduit 4.12 4.62 HP400 HP400LG 4” Conduit 4.62 5.12 Technical references and CAD downloads available at www.hammondmfg.com 288 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Hole Plugs Type 4X Stainless Steel - UR/cUR Features Plug Diameter Diameter 22mm Pushbutton 0.88 1.22 .5” Conduit 0.88 1.38 HP75SSN4 .75” Conduit 1.06 1.56 HPBSSN4 30mm Pushbutton 1.25 1.75 HP100SSN4 1” Conduit 1.38 1.88 HP125SSN4 1.25” Conduit 1.69 2.19 HP150SSN4 1.5” Conduit 2.00 2.50 HP200SSN4 2” Conduit 2.50 3.00 Description HP22SSN4 HP50SSN4 Hole Plugs Type 4X Non-metallic - UR/cUR Features • Designed to seal unused push­button holes, conduit openings and knock­out holes against dust, oil and water. • Standard Pushbutton size is 30.5mm • Available in 11 sizes. • Available in 2 color options - ANSI 61 Gray (GY) & RAL7035 Light Gray (LG) • Compatible with enclosure wall thickness from 16 gauge to 1/4” • Self centering, anti-rotational design for fast and easy one person installation, no tools required • Recognized component for use with UL & CSA listed enclosures • Type 1, 3, 3R, 4, 4X​ • Molded in polycarbonate with neoprene/EPDM gasket material RAL7035 ANSI 61 Part No. Part No. HP12PCLG HP12PCGY Pilot Light (.50) 0.50 - 0.81 0.06 - 0.25 1.12 HP50PCLG HP50PCGY .5” Conduit (.875) 22mm PB (.886) 0.81 - 0.94 0.06 - 0.25 1.25 HP75PCLG HP75PCGY .75” Conduit (1.109) 30mm PB (1.21) 1.00 - 1.31 0.06 - 0.25 1.62 HP100PCLG HP100PCGY 1” Conduit (1.375) 1.38 - 1.62 0.06 - 0.25 1.92 HP125PCLG HP125PCGY 1.25” Conduit (1.734) 1.69 - 1.88 0.06 - 0.25 2.18 HP150PCLG HP150PCGY 1.5” Conduit (1.984) 2.00 - 2.19 0.06 - 0.25 2.50 HP200PCLG HP200PCGY 2” Conduit (2.469) 2.50 - 2.75 0.06 - 0.25 3.12 HP250PCLG HP250PCGY 2.5” Conduit (2.969) 2.88 - 3.12 0.06 - 0.25 3.50 HP300PCLG HP300PCGY 3” Conduit (3.594) 3.50 - 3.75 0.06 - 0.25 4.12 HP350PCLG HP350PCGY 3.5” Conduit (4.125) 4.00 - 4.25 0.06 - 0.25 4.62 HP400PCLG HP400PCGY 4” Conduit (4.641) 4.50 - 4.75 0.06 - 0.25 5.12 Description Technical references and CAD downloads available at www.hammondmfg.com Plugged Hole Wall Thickness Diameter Range Range External Dia. All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Max Hole Part No. Hardware • Designed to seal unused push­button holes, conduit openings and knock­out holes against dust, oil and water. • Standard Pushbutton size is 30.5mm • Available in 8 sizes. • Finished in brushed natural 304 stainless steel. • Oil resistant gasket. • Secured with an 10-24 x 0.55” threaded stud and stainless steel wing nut. • Recognized component UR & cUR • Type 1, 3, 3R, 4, 4X, 12 and 13 USA: 716.630.7030 Data Subject to change without notice 289 www.hammondmfg.com Eclipse DIN Rail Mounting Kit • • • • • Field installable. Mounts directly to panel collar studs (panel not required). Accepts optional DIN rails. DIN rails available separately. Zinc plated, yellow dichromate. Part No. Length 2DMK12 10.00 2DMK16 14.00 2DMK20 18.00 2DMK24 22.00 2DMK30 28.00 General Accessories Eclipse DIN Rails • • • • • • Field installable. Includes a set of 3 plated rails. Available in 3 industry standard profiles - DIN 1, DIN 3, and CENELEC. DIN rail mounting kit required for installation. Rails have an oblong slot on each end for ease of mounting. Zinc plated. Accessories Asymmetric DIN 1 Profile DIN Part• No. Hardware Eclipse Handles Symmetric DIN 3 Profile Cenelec Profile Rail MountingPart Kit... See Page 290 No. Length 2D2K12 2DCK12 9.75 2D1K16 2D2K16 2DCK16 13.75 2D1K20 2D2K20 2DCK20 17.75 2D1K24 2D2K24 2DCK24 21.75 2D1K30 2D2K30 2DCK30 27.75 • • • • Field installable. Interchangeable with standard quarter turn latches. Maintain NEMA, UL and CSA ratings as noted. Swing Adjustment Kit - provides a set of 3 replacement rollers when an Eclipse single door needs to swing in the opposite direction. For enclosures with handles up to 60” high, use one kit. For 72” enclosures, 2 kits required. Part No. Description Material EHTL Locking T Handle Zinc Die/Black EHLL Locking L Handle Zinc Die/Black 12, 4 EHLNL Non Locking L Handle Zinc Die/Black 12, 4 NEMA Rating 12, 4 EHLPL Padlockable L Handle Zinc Plated EHLPL2 Padlockable L Handle Zinc Plated EHLPLSS Padlockable L Handle Stainless Steel 12, 4, 4X EHLNLSS Non Locking L Handle Stainless Steel 12, 4, 4X EHLLSS Locking L Handle Stainless Steel 12, 4, 4X EHLLSAK Swing Adjustment Kit - package includes 3 reverse rollers Nylon Technical references and CAD downloads available at www.hammondmfg.com 290 Part No. 2D1K12 12 12 internal All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Eclipse Mounting Foot Kit Part No. Material EZPMFHD Clear Zinc Plated, mild steel ESSMFHD Type 304 Stainless ES16MFHD Type 316 Stainless Eclipse Rear Mounting Hole Plugs • Used to plug rear mounting holes for Eclipse series • Snap in plug designed for rear .50” mounting hole • Packaged in quantities of 40 Part No. EN4PLUG40 PJU/PCJ Replacement Polycarbonate Flange • Sold in pairs. • For use with PJU and PCJ non-metallic enclosures. Part No. PJU/PCJ Flange Fits PJFPUWM6 6x6, 8x6 PJFPUWM108 10x8 PJFPUWM1210 12x10 PJFPUWM1412 14x12 PJFPUWM1614 16x14 PJFPUWM1816 18x16 PJFPUWM2016 20x16 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Hardware Maintains UL, CSA and NEMA ratings. Field installable. New triangular flanges prevent the foot from rotating Foot can still be mounted sideways as well as top/bottom Available in mild, 304SS and 316SS Packaged in quantities of four General Accessories • • • • • • USA: 716.630.7030 Data Subject to change without notice 291 www.hammondmfg.com PJU/PCJ Replacement Polycarbonate Feet • Sold in sets of 4. • For use with PJU and PCJ non-metallic enclosures. Part No. PJU Feet Fits PJW4NUFS 6x6 through 14x12 PJW4NULFS 16x14 through 20x16 General Accessories PJ Stainless Replacement Mounting Feet • 316 Stainless sold in sets of 4. • For use with PJ Series non-metallic enclosures. Part No. 316 SS PJ Feet Fit PJW4NFS 6x6 through 20x16 PJW4NLS 24x20 through 30x24 Hardware M6 Screw with Hex/Phillips Head Features • • • • M6 x 0.4724 inch (12mm) length steel screws. 25/64 (10mm) Hex Phillips head screws. Zinc plated finish. Designed for use with the HMEGS but can be used for rack mount applications. • Please note that when used for rack mount applications, the screw head exceeds rack unit space. • Packaged in a reusable jar. Part No. 1421HPM625 Qty Included Screw Head Diameter 25 Screws 0.51 Technical references and CAD downloads available at www.hammondmfg.com 292 Screw Head Height Screw Length 0.23 0.47 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Washdown Quarter Turn Assemblies Waterfall Series Accessory Latch Features • • • • • Replaces standard quarter turn provided with enclosure Unique no-crevice design ideal for food and beverage applications 316L stainless steel construction Red, silicon O-Ring Sold individually Latch Key Features • Hollow, female key designed for use with EQTFG • Sold individually Part No. Description EQTFG Quarter Turn Latch (ea.) EFGK Key (ea.) Waterfall Series Accessory Features • • • • • Provides space between enclosure and mounting surface Installs into pre-drilled mounting holes in rear of enclosure Offered in several lengths 316L stainless steel construction Set of 4 Part No. Description ST1MFSS316 1” Stand-off ST2MFSS316 2” Stand-off ST4MFSS316 4” Stand-off ST6MFSS316 6” Stand-off PJ/PJU/PCJ Replacement Hardware Kits Part No. Quantity Description PJLKIT316 1 Snap latch for PJ series with rivets and screws PJTKIT316 1 Twist latch for PJ series with rivets and screws PJSKIT316 20 Cover screws for PJ, PJU, PCJ PCJLLPSH 1 Snap latch 316 for PJU & PCJ series with moulded keeper PCJLTPSH 1 Twist latch 316 for PJU & PCJ series with moulded keeper PCJLLPNH 1 Snap latch non-metallic for PJU & PCJ series with moulded keeper PCJHINGECLIP 2 Hinge clips for PCJ Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Wallmount Stand-offs Hardware *Maintains NSF Rating when installed on NSF Rated Enclosures USA: 716.630.7030 Data Subject to change without notice 293 www.hammondmfg.com Mechanical Interlock Application • Designed to mechanically interlock doors on 2 door cabinets featuring handles and a center-post design. Cam on slave door held in place until Master door opened. Either door can be made master door with this kit. • Ideal for use with Hammond series that do not include a mechanical interlock as standard. • Can be installed on 1422N4 (mild or stainless steel), HN4FM (mild or stainless steel), HN4WM (mild or stainless steel), and HN4FS 2 door units (mild or stainless steel). Standards • Does not compromise approval rating of enclosure. Construction General Accessories • Kit includes: Base plate, spring, right and left slave bracket (user chooses appropriate), mounting hardware • Formed from 10 gauge 304 stainless steel • Finish is unpainted Part No. MIKIT Inner Panels 1414, EJ, HJ and PJ Series Enclosures Features • • • • • • • Hardware Steel panels are 14 gauge steel and are finished in white. Fiberglass panels (off-white) in NEMA sizes. Aluminum panels are 0.080 type 5052 H-32 aluminum, unpainted. Galvanized panels are 14 gauge unpainted galvanized steel. Stainless steel panels are 14 gauge and are brushed 304 SS. Mounting hardware is included with the enclosure. Steel panels and mounting hardware are included with 1414 Series enclosures. • Galvanized panels and mounting hardware are included with the EJ Series enclosures. • Mounting hardware is included with PJ Series enclosures, order panel separately. Steel Fiberglass Part No. Part No. 14R0503 14R0505 14F0505 14R0705 14F0705 14R0707 14R0907 14F0907 Aluminum Galv. Steel Stainless Steel For Use with 1414 and EJ For Use with PJ Series Part No. Part No. Part No. L W H W H 14A0503 14G0503 14R0503SS 4.88 2.88 6.00 4.00 - - 14A0505 14G0505 14R0505SS 4.88 4.88 6.00 6.00 7.04 7.04 W 7.06 14A0705 14G0705 14R0705SS 6.75 4.88 8.00 6.00 8.94 14A0707 14G0707 14R0707SS 6.75 6.88 8.00 8.00 - - 14A0907 14G0907 14R0907SS 8.75 6.88 10.00 8.00 11.08 9.20 14R0909SS - 14R0909 14A0909 14G0909 14R1105 14A1105 14G1105 8.75 8.88 10.00 10.00 - 10.75 4.88 12.00 6.00 - - 8.88 13.08 11.20 14R1109 14F1109 14A1109 14G1109 14R1109SS 10.75 12.00 10.00 14R1111 14F1111 14A1111 14G1111 14R1111SS 10.75 10.88 12.00 12.00 - - 14A1307 14G1307 12.75 8.00 - - 12.75 10.88 14.00 12.00 15.08 13.20 14.75 16.00 10.00 - - 14.75 12.88 16.00 14.00 17.22 15.34 14R1307 14R1311 14F1311 14R1509 14R1513 14F1513 14A1311 14G1311 14A1509 14G1509 14A1513 14G1513 14R1311SS 14R1513SS 6.88 8.88 14.00 P1868 F1868 A1868 16.88 14.88 - - 19.34 17.34 P2068 F2068 A2068 18.44 14.44 - - 20.94 16.94 Technical references and CAD downloads available at www.hammondmfg.com 294 Panel All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Inner Panels 1418, 1447, PJW, and PHW Wallmount Enclosures Features Steel Galv. Steel Stainless Steel Aluminum Part No. Part No. Part No. Part No. 18P0909 18G0909 Panel For Use With Enclosure L W H W 9.00 9.00 12.00 12.00 18P1309 18G1309 18P1309S16 18A1309 13.00 9.00 16.00 12.00 18P1313 18G1313 18P1313S16 18A1313 13.00 13.00 16.00 16.00 18P1515 18G1515 15.00 15.00 18.00 18.00 18P1709 18G1709 17.00 9.00 20.00 12.00 18P1713 18G1713 18P1713S16 18A1713 17.00 13.00 20.00 16.00 18P1717 18G1717 18P1717S16 18A1717 17.00 17.00 20.00 20.00 18P2109 18G2109 21.00 18P2113 18G2113 18P2113S16 18P2117 18G2117 18P2117S16 18P2121 18G2121 18P2121S16 18P2709 18P2713 18P2717 18G2717 18P2717S16 18P2721 18G2721 18P2721S16 18P2727 18G2727 18P2727S16 18P3321 18G3321 18P3321S16 18A3321 18P3327 18G3327 18P3327S16 18A3327 18P3333 18G3333 18P3333S16 18P3921 18G3921 18P3927 18G3927 18P3933 18G3933 18P4521 9.00 24.00 12.00 21.00 13.00 24.00 16.00 18A2117 21.00 17.00 24.00 20.00 18A2121 21.00 21.00 24.00 24.00 18G2709 27.00 9.00 30.00 12.00 18G2713 27.00 13.00 30.00 16.00 27.00 17.00 30.00 20.00 27.00 21.00 30.00 24.00 27.00 27.00 30.00 30.00 33.00 21.00 36.00 24.00 33.00 27.00 36.00 30.00 33.00 33.00 36.00 36.00 39.00 21.00 42.00 24.00 18P3927S16 39.00 27.00 42.00 30.00 18P3933S16 39.00 33.00 42.00 36.00 18G4521 45.00 21.00 48.00 24.00 18P4527 18G4527 45.00 27.00 48.00 30.00 18P4533 18G4533 45.00 33.00 48.00 36.00 18P5721 18G5721 57.00 21.00 60.00 24.00 18P5733 18G5733 57.00 33.00 60.00 36.00 18P6927 18G6927 69.00 27.00 72.00 30.00 18P6933 18G6933 69.00 33.00 72.00 36.00 18A2721 18P4533S16 18A4533 18P5733S16 18A5733 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Panels and Panel Accessories Steel panels are 12 gauge steel and are finished in white. Galvanized panels are 12 gauge unpainted galvanized steel. Stainless steel panels are 12 gauge and are brushed 316 SS. Aluminum panels are 5052-H32 aluminum alloy. Larger panels have two or four formed flanges. Some larger panels are 10 gauge. Panel mounting hardware not included (provided with enclosure). General Accessories • • • • • • • USA: 716.630.7030 Data Subject to change without notice 295 www.hammondmfg.com Inner Panels Eclipse Series Enclosures Features General Accessories • Larger than standard NEMA panel used in same sized enclosure. • 12gauge steel construction. • Larger sizes have 2 or 4 formed flanges for added strength. • Slotted corner design for easier mounting. • Finished in white or unpainted galvanized. Mild Steel Galvanized Panels and Panel Accessories Mild Steel Galvanized Part No. Part No. D Size E Gauge Part No. Part No. Size EP1210 EPG1210 10.20 8.20 12 EP3030 EPG3030 28.20 28.20 12 EP1212 EPG1212 10.20 10.20 12 EP3036 EPG3036 28.20 34.20 12 EP1224 EPG1224 10.20 22.20 12 EP3042 EPG3042 28.20 40.20 12 EP1612 EPG1612 14.20 10.20 12 EP3048 EPG3048 28.20 46.20 12 EP1616 EPG1616 14.20 14.20 12 EP3060 EPG3060 28.20 58.20 12 EP1620 EPG1620 14.20 18.20 12 EP3624 EPG3624 34.20 22.20 12 EP2012 EPG2012 18.20 10.20 12 EP3630 EPG3630 34.20 28.20 12 EP2016 EPG2016 18.20 14.20 12 EP3636 EPG3636 34.20 34.20 12 EP2020 EPG2020 18.20 18.20 12 EP3642 EPG3642 34.20 40.20 12 EP2024 EPG2024 18.20 22.20 12 EP3648 EPG3648 34.20 46.20 12 EP2412 EPG2412 22.20 10.20 12 EP3660 EPG3660 34.20 58.20 12 EP2416 EPG2416 22.20 14.20 12 EP4224 EPG4224 40.20 22.20 12 EP2420 EPG2420 22.20 18.20 12 EP4230 EPG4230 40.20 28.20 12 EPG4236 40.20 34.20 12 D Gauge EP2424 EPG2424 22.20 22.20 12 EP4236 EP2430 EPG2430 22.20 28.20 12 EP4824 EPG4824 46.20 22.20 12 EP2442 EPG2442 22.20 40.20 12 EP4830 EPG4830 46.20 28.20 12 EP2448 EPG2448 22.20 46.20 12 EP4836 EPG4836 46.20 34.20 12 EP3012 EPG3012 28.20 10.20 12 EP4848 EPG4848 46.20 46.20 12 EP3016 EPG3016 28.20 14.20 12 EP6036 EPG6036 58.20 34.20 12 EP3020 EPG3020 28.20 18.20 12 EP7230 EPG7230 70.20 28.20 12 EP3024 EPG3024 28.20 22.20 12 EP7236 EPG7236 70.20 34.20 12 Technical references and CAD downloads available at www.hammondmfg.com 296 E All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Inner Panels 1420 Series Enclosures Features • Panels and mounting hardware are included with 1420 Series enclosures. • 12 gauge steel finished in white. For Use With Enclosure W H W 20P1410 14.00 10.00 16.00 12.00 20P1814 18.00 14.00 20.00 16.00 20P1818 18.00 18.00 20.00 20.00 20P2218 22.00 18.00 24.00 20.00 20P2222 22.00 22.00 24.00 24.00 20P2818 28.00 18.00 30.00 20.00 20P2822 28.00 22.00 30.00 24.00 20P3422 34.00 22.00 36.00 24.00 20P3428 34.00 28.00 36.00 30.00 20P4022 40.00 22.00 42.00 24.00 20P4028 40.00 28.00 42.00 30.00 20P4034 40.00 34.00 42.00 36.00 20P4634 46.00 34.00 48.00 36.00 Panels and Panel Accessories L Inner Panels HN4FM/1422 Series Floormount Enclosures Features • 22P5038 is formed from 12 gauge steel, all others are 10 gauge steel. • Panels and mounting hardware are included with 1422 and HN4FM Series enclosures. • Finished in white. Panel Part No. L For Use With Enclosure W H W 22P5038 50.00 38.00 54.00 42.00 22P5644 56.00 44.00 60.00 48.00 22P5656 56.00 56.00 60.00 60.00 22P6856 68.00 56.00 72.00 60.00 22P6868 68.00 68.00 72.00 72.00 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Panel Part No. USA: 716.630.7030 Data Subject to change without notice 297 www.hammondmfg.com Inner Panels PCJ Series Enclosures Features • • • • 14 gauge steel panels are finished in white Aluminum panels are 0.080 type 5052 H-32 aluminum, unpainted Steel and Aluminum panels are sold separate for the PCJ Series enclosures PVC (Polyvinyl Chloride) back panels are 0.188 material dark gray finish. Temperature up to 140° (60°C) • Mounting hardware is included with PCJ Series enclosures, order panel separately General Accessories Mild Steel Aluminum Part No. Part No. PCJR0505 PVC For Use With PCJ Series Length Width A B PCJA0505 14PVC0505 4.81 4.81 5.93 6.16 PCJR0705 PCJA0705 14PVC0705 6.75 4.88 7.94 6.16 PCJR0808 PCJA0808 14PVC0707 6.75 6.88 7.94 8.15 PCJR0907 PCJA0907 14PVC0907 8.75 6.88 9.93 8.15 PCJR1109 PCJA1109 14PVC1109 10.75 8.88 11.92 10.15 PCJR1111 PCJA1111 14PVC1111 10.75 10.88 11.92 12.16 PCJR1311 PCJA1311 14PVC1311 12.75 10.88 13.94 12.16 14R1513 14A1513 14PVC1513 14.75 12.88 15.98 13.98 P1868 A1868 14PVC1715 16.88 14.88 18.04 16.04 Inner Panels Panels and Panel Accessories N1J Series Enclosures Features • • • • Replacement panels for N1J Series enclosures. Optional panels for C3R HCR SM Series enclosures. Made from 16 ga steel White powder finish Panel For Use with Enclosure Part No. L W H W # Folds N1JP64 4.25 2.25 6.00 4.00 0 N1JP66 4.25 4.25 6.00 6.00 0 N1JP86 6.25 4.25 8.00 6.00 0 N1JP88 6.25 6.25 8.00 8.00 0 N1JP108 8.25 6.25 10.00 8.00 0 N1JP1010 8.25 8.25 10.00 10.00 0 N1JP1210 10.25 8.25 12.00 10.00 0 N1JP1212 10.25 10.25 12.00 12.00 0 N1JP1412 12.25 10.25 14.00 12.00 0 N1JP1612 14.25 10.25 16.00 12.00 0 N1JP2012 18.25 10.25 20.00 12.00 0 Technical references and CAD downloads available at www.hammondmfg.com 298 Panel Part No. All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Inner Panels N1A Series Enclosures Features • 14 gauge steel finished in white. • Panels and mounting hardware are included with NIA Series enclosures. For Use with Enclosure W H W AP1612 13.00 10.50 16.00 12.00 AP1616 13.00 14.50 16.00 16.00 AP1620 13.00 18.50 16.00 20.00 AP2016 17.00 14.50 20.00 16.00 AP2020 17.00 18.50 20.00 20.00 AP2024 17.00 22.50 20.00 24.00 AP2416 21.00 14.50 24.00 16.00 AP2420 21.00 18.50 24.00 20.00 AP2424 21.00 22.50 24.00 24.00 AP3020 26.00 18.50 30.00 20.00 AP3024 26.00 22.50 30.00 24.00 AP3030 26.00 28.50 30.00 30.00 AP3624 32.00 22.50 36.00 24.00 AP3630 32.00 28.50 36.00 30.00 AP4224 38.00 22.50 42.00 24.00 AP4230 38.00 28.50 45.00 30.00 AP4236 38.00 34.50 42.00 36.00 AP4836 44.00 34.50 48.00 36.00 Panels and Panel Accessories L Perforated Inner Panels 1418, 1447, PJW, and PHW Wallmount Enclosures Features • For use with 1418, 1447, PJW and PHW enclosures • Made from 16 ga steel • Accepts self tapping screws, eliminating time-consuming measurement, marking, and drilling of component mounting holes • 1/8” dia holes on 1/4” staggered centers • ANSI 61 gray powder finish Panel Part No. For Use with Enclosure L W H W 18P1309PP 13.00 9.00 16.00 12.00 # Folds 0 18P1313PP 13.00 13.00 16.00 16.00 0 18P1515PP 15.00 15.00 18.00 18.00 0 18P1713PP 17.00 13.00 20.00 16.00 0 18P1717PP 17.00 17.00 20.00 20.00 0 18P2117PP 21.00 17.00 24.00 20.00 0 18P2121PP 21.00 21.00 24.00 24.00 4 18P2721PP 27.00 21.00 30.00 24.00 4 18P2727PP 27.00 27.00 30.00 30.00 4 18P3321PP 33.00 21.00 36.00 24.00 4 18P3327PP 33.00 27.00 36.00 30.00 4 18P3333PP 33.00 33.00 36.00 36.00 4 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Panel Part No. USA: 716.630.7030 Data Subject to change without notice 299 www.hammondmfg.com Inner Panels 1418FS and HN4FS Series Enclosures • • • • • Formed from 10 gauge or 12 gauge steel. All double door width panels are 10 gauge steel. Width panels are available in full or half height. Depth panels are available in full height only. Depth and width panels are provided with all mounting hardware and center support where required. • Half panel can be mounted in the top or bottom half of the enclosure. • Finished in white. General Accessories Depth Panels Encl. Encl. Panel Part No. Height Min Depth W H 60FD14 60.00 18.00 14.00 48.00 72FD9 72.00 18.00 9.00 60.00 72FD14 72.00 18.00 14.00 60.00 72FD20 72.00 24.00 20.00 60.00 72FD26 72.00 36.00 26.00 60.00 90FD9 90.00 18.00 9.00 78.00 90FD14 90.00 18.00 14.00 78.00 90FD20 90.00 24.00 20.00 78.00 90FD26 90.00 36.00 26.00 78.00 Single Door Width Panels Double Door Width Panels Panels and Panel Accessories Steel Galv. Steel Steel Galv. Steel Part No. Part No. Description Enclosure Panel Size Part No. Part No. Description 60TWFW 60TWFWG Full Panel 60 x 24 48.00 x 20 60AWFW 60AWFWG Full Panel 60TWHW 60TWHWG Half Panel 24.87 x 20 60AWHW 60AWHWG Half Panel 72WFW 72WFWG Full Panel 72WHW 72WHWG Half Panel 90YWFW 90YWFWG Full Panel 90YWHW 90YWHWG Half Panel 72XFW 72XFWG Full Panel 72XHW 72XHWG Half Panel 60TYFW 60TYFWG Full Panel 60TYHW 60TYHWG Half Panel 72YFW 72YFWG Full Panel 72YHW 72YHWG Half Panel 90YFW 90YFWG Full Panel 90YHW 90YHWG Half Panel 72 x 24 90 x 24 72 x 30 60 x 36 72 x 36 90 x 36 60.00 x 20 72ZWFW 72ZWFWG Full Panel 30.87 x 20 72ZWHW 72ZWHWG Half Panel 78.00 x 20 72ZXFW 72ZXFWG Full Panel 39.87 x 20 72ZXHW 72ZXHWG Half Panel 60.00 x 26 72ZYFW 72ZYFWG Full Panel 30.87 x 26 72ZYHW 72ZYHWG Half Panel 48.00 x 32 90BWFW 90BWFWG Full Panel 24.87 x 32 90BWHW 90BWHWG Half Panel 60.00 x 32 90BYFW 90BYFWG Full Panel 30.87 x 32 90BYHW 90BYHWG Half Panel Enclosure 60 x 48 Panel Size 48.00 x 44 24.88 x 44 72 x 48 60.00 x 44 30.88 x 44 72 x 60 60.00 x 56 30.88 x 56 72 x 72 60.00 x 68 30.88 x 68 90 x 48 78.00 x 44 39.88 x 44 90 x 72 78.00 x 68 39.88 x 68 78.00 x 32 39.87 x 32 Technical references and CAD downloads available at www.hammondmfg.com 300 Panel All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Perforated Inner Panels N1A Series Enclosures Features • Made from 16 ga steel • Accepts self tapping screws eliminating timely measurement, marking and drilling of component mounting holes • 1/8” dia holes on 1/4” staggered centers • ANSI 61 gray powder finish For Use with Enclosure W H W # Folds AP1612PP 13.00 10.50 16.00 12.00 0 AP1616PP 13.00 14.50 16.00 16.00 0 AP1620PP 13.00 18.50 16.00 20.00 0 AP2016PP 17.00 14.50 20.00 16.00 0 AP2020PP 17.00 18.50 20.00 20.00 0 AP2024PP 17.00 22.50 20.00 24.00 0 AP2416PP 21.00 14.50 24.00 16.00 0 AP2420PP 21.00 18.50 24.00 20.00 0 AP2424PP 21.00 22.50 24.00 24.00 4 AP3020PP 26.00 18.50 30.00 20.00 4 AP3024PP 26.00 22.50 30.00 24.00 4 AP3030PP 26.00 28.50 30.00 30.00 4 AP3624PP 32.00 22.50 36.00 24.00 4 AP3630PP 32.00 28.50 36.00 30.00 4 AP4224PP 38.00 22.50 42.00 24.00 4 Panels and Panel Accessories L Perforated Inner Panels N1J Series Enclosures Features • Made from 16 ga steel • Accepts self tapping screws eliminating timely measurement, marking and drilling of component mounting holes • 1/8” dia holes on 1/4” staggered centers • ANSI 61 gray powder finish Panel Part No. For Use with Enclosure L W H W # Folds N1JP66PP 4.25 4.25 6.00 6.00 0 N1JP86PP 6.25 4.25 8.00 6.00 0 N1JP88PP 6.25 6.25 8.00 8.00 0 N1JP108PP 8.25 6.25 10.00 8.00 0 N1JP1010PP 8.25 8.25 10.00 10.00 0 N1JP1210PP 10.25 8.25 12.00 10.00 0 N1JP1212PP 10.25 10.25 12.00 12.00 0 N1JP1412PP 12.25 10.25 14.00 12.00 0 N1JP1612PP 14.25 10.25 16.00 12.00 0 N1JP2012PP 18.25 10.25 20.00 12.00 0 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Panel Part No. USA: 716.630.7030 Data Subject to change without notice 301 www.hammondmfg.com Swing Panel Kit Features • • • • • Kits are used as accessory to standard Hammond panels (sold separately) Allows panel to be mounted in front part of enclosure Hinge permits access behind panel Sealing washers preserve approval rating of enclosure Panel not included. General Accessories Part No. For Use With SPB1 1414 Series where AxB is 8”x6” or larger (not compatible with 1414 screw cover series) SPB1 EJ Series where AxB is 8”x6” or larger SPB1 C3R-HCLO Series where AxB is 16x12 or smaller SPB2 1418 Wallmount Series, HW Series SPB2 C3R-HCLO Series where AxB is 16x16 or larger SPB2 C3R-HCR Series where AxB is 16x12 or larger Terminal Straps and Brackets 1414/EJ/PJ Series Enclosures Features • Used to provide convenient mounting for terminal blocks in 1414 Series enclosures and some sizes of “PJ” Series enclosures. • Finished in white. Panels and Panel Accessories Bracket Assembly • Each kit consists of two brackets. • “C” channel construction provides easy alignment of terminal straps. Terminal Strap • 1.5” wide x 0.187” thick steel. • Each strap includes spring locking hardware. • Countersunk holes in straps provide extra terminal mounting space. How to Order • Each enclosure requires one bracket assembly kit and the required number of straps (Strap Part No. corresponds to enclosure dimension “A” and is mounted parallel to same, Bracket Part No. corresponds to enclosure dimension “B” and is mounted parallel to same). • Example: For a PJ864L enclosure, order one 14B6 bracket assembly and a minimum of one 14B8 terminal strap kits. Additional terminal strap kits will provide additional mounting space. Single Strap Usable Bracket (Pair) L Mounting Space Part No. W A B C 14S8 6.19 4.30 14B6 6.00 5.00 4.25 1.55 PJ864...¹ 14S10 8.19 6.30 14B8 8.00 7.00 6.25 1.55 PJ1086...¹ 14S12 10.19 8.30 14B10 10.00 9.00 8.25 2.79 PJ12106...¹ 14S14 12.19 10.30 14B12 12.00 11.00 10.25 2.79 PJ14126...¹ 14S16 14.19 12.30 14B14 14.00 13.00 12.25 2.79 PJ16148...¹ Part No. Fits PJ Enclosure ¹ Compatible with all latch types Technical references and CAD downloads available at www.hammondmfg.com 302 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Terminal Straps and Brackets 1418 Series Enclosures Features • Used to provide convenient mounting for terminal blocks, pneumatic controls or small relays in 1418 wallmount enclosures. • Brackets may be installed horizontally or vertically in an enclosure if the size corresponds to enclosure length or width. • Finished in white. Terminal Strap • 1.5” wide x 0.187” thick steel. • Each strap includes spring locking hardware. • Countersunk holes in straps provide extra terminal mounting space. How to Order • Each enclosure requires one bracket assembly kit and the required number of straps (order separately). • Determine if strap will be mount­ed parallel to dimension “A” or “B”. Choose the part number that corresponds to enclosure dimensions “A” or “B”. • When choosing a bracket assembly to be parallel to dimension “B” in an enclosure of 24”, 30” or 36” width, determine if a two or three bracket assembly is required. When enclosures are 48” or greater on “A” dimension, 6 collar studs are used. • Choose strap kit to correspond to the other enclosure dimensions. • Order the number of kits equal to the number of straps required. Bracket Assembly Strap # of Parallel Usable Mounting Part No. Brackets L B Enclosure Dim 18B212 2 8.50 7.25 12 18S12 9.50 7.60 18B216 2 12.50 11.25 16 18S16 13.50 11.60 18B220 2 16.50 15.25 20 18S20 17.50 15.60 18B224 2 20.50 19.25 24 18S24 21.50 19.60 18B324 3 20.50 19.25 24 18S30 27.50 25.60 18B230 2 26.50 25.25 30 18S36 33.50 31.60 18B330 3 26.50 25.25 30 18S42 39.50 37.60 18B236 2 32.50 31.25 36 18S48 45.50 43.60 18B336 3 32.50 31.25 36 18S60 57.50 55.60 18S72 69.50 67.60 Technical references and CAD downloads available at www.hammondmfg.com Part No. L Space (L) All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories • Each kit consists of two or three brackets per assembly. • Brackets combined with collar stud length provide 3” minimum clearance from the rear of the enclosure. • “C” channel construction provides easy alignment of terminal straps. Panels and Panel Accessories Bracket Assembly USA: 716.630.7030 Data Subject to change without notice 303 www.hammondmfg.com Eclipse Swing Panel • • • • • General Accessories • • • • Hinged panel allows access to internally mounted equipment. Can be hinged from either side. 12 gauge steel construction. Slotted quarter turn latches provide closure. Adding optional locking quarter turn latches (Part Number EQTRL) convert this to a dead front panel. Complete with 4 depth adjustment brackets. Hardware kit maintains UL, CSA and NEMA ratings when field installed. Finished in white. (Note: Not compatible with DSTOPK door stop kit.) Part No. Fits Enclosure Size (A x B) Part No. Fits Enclosure Size (A x B) ESP3020 30 x 20 ESP1212 12 x 12 ESP3024 30 x 24 ESP1612 16 x 12 ESP3030 30 x 30 ESP1616 16 x 16 ESP3624 36 x 24 ESP1620 16 x 20 ESP3630 36 x 30 ESP2016 20 x 16 ESP3636 36 x 36 ESP2020 20 x 20 ESP4236 42 X 36 ESP2024 20 x 24 ESP4824 48 X 24 ESP2416 24 x 16 ESP4836 48 X 36 ESP2420 24 x 20 ESP6030 60 X 30 ESP2424 24 x 24 ESP6036 60 X 36 Panels and Panel Accessories Swing Panel • Hinged aluminum panel. • Mounts at front of enclosure body. • Field installed with no drilling required. Use with PJU Series Enclosures Panel Dimensions Panel Dimensions Height Width Part No. Height Width PJSPU108 9.64 7.87 PJSP108 9.50 7.50 PJSPU1210 11.64 9.86 PJSP1210 11.50 9.50 PJSPU1412 13.64 11.86 PJSP1212 11.50 11.37 PJSPU1614 15.64 13.86 PJSP1412 13.50 11.50 PJSPU1816 17.90 15.99 PJSP1614 15.50 13.50 PJSPU2016 19.65 15.55 PJSP1816 17.63 15.63 PJSP2016 19.25 15.25 PJSP2420 23.25 19.38 PJSP2424 23.38 23.25 PJSP3024 29.25 23.38 Part No. Technical references and CAD downloads available at www.hammondmfg.com 304 Use with PJ Series Raised Lid Enclosures All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Swing Panel PCJ Series Accessory Features Enclosure Base Part No. H W PCJHFPP66 PCJ664 5.44 5.61 PCJHFPP86 PCJ864 7.44 5.61 PCJHFPP88 PCJ884 7.44 7.63 PCJHFPP108 PCJ1084 9.43 7.69 PCJHFPP1210 PCJ12106 11.55 9.58 PCJHFPP1412 PCJ14126 13.10 11.25 PCJHFPP1614 PCJ16148 14.75 12.88 PCJHFPP1816 PCJ181610 16.88 14.88 Replacement Hardware Part Number Description PCJCB4 Corner block set of 4 (for 14”H enclosures and smaller) PCJCB4L Corner block set of 4 (for 16” & 18”H enclosures) PCJHFH Hinge and screws set of 2 Mounting Rack Rail Swing Frame For use with the Eclipse Enclosure Series • • • • • • • • • • • Provides 19” rack mounting with full EIA spacing (punched holes). Hinges allow easy equipment access. Can be hinged from either side. Slotted quarter turn latches provide closure. Optional locking quarter turn latch available by ordering Part No. EQTRL Adding optional locking quarter turn latches provides added security. Complete with 4 depth adjustment brackets. Mounting hardware sold separately. Hardware kit maintains UL, CSA and NEMA ratings when field installed. (Note: Not compatible with DSTOPK door stop kit.) Finished in RAL9005 black powder paint finish. Fits Enclosure Size Rack Spacing Rack Part No. (AxB) Width Units ESF2424 24x24 19.00 11U ESF3024 30x24 19.00 14U ESF3624 36x24 19.00 17U Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories HFPP Kit Part No. Panels and Panel Accessories • Hinged aluminum panel installed on corner sliders allowing adjustable depth setting • Can be installed hinged either right or left swing • Field installed with no drilling required • Mounting Hardware Included • Material thickness 0.09” USA: 716.630.7030 Data Subject to change without notice 305 www.hammondmfg.com Mounting Rack Rail Swing Frame For use with the 1418FS and HN4FS Series General Accessories • Formed from 10 gauge steel, frames are drilled and tapped to EIA requirements for mounting standard 19” rack accessories. • Designed for installation in 72” and 90” high enclosures. The swing frame pivots on 0.5” pins within the enclosure for easy access to the rear of rack mounted equipment. • The frame positions at any depth within the enclosure and is fastened in the closed position with quarter turn fasteners. • Swing frames may be mounted in 30” and 36” wide enclosures, or in 60” and 72” wide enclosures with an optional center panel support. • One or two frames may be mounted in 30” and 36” wide enclosures with dual access, and 1,2,3 or 4 frames may be mounted in 60” and 72” wide dual access enclosures. • Finished in black. Part No. A B C Enclosure Width Height Single Door 1418SFYY 78.50 31.80 12.14 44 90.00 36.00 1418SFY 60.50 31.80 12.14 33 72.00 36.00 1418SFX 60.50 25.82 33 72.00 30.00 6.14 Freestanding Enclosure Center Panel Supports Panels and Panel Accessories 1418FS and HN4FS Series Enclosures • Adapts panels, swing frames, and panel rails from single door enclosures so they can be used on double door enclosures. • Suitable for single or dual access double door enclosures. • Center panel support mounts into front to back mounting channels (top and bottom) found in two door enclosures. • Allows a combination of two 20” panels in a 48” wide enclosure, two 26” panels in a 60” wide enclosure, or two 32” panels in a 72” wide enclosure. • Width is adjustable from 1.91” to 2.34”. • Support may be positioned at any depth within the enclosure. • Finished in white. Part No. Enclosure Ht. 1418ACS 60.00 1418ZCS 72.00 1418BCS 90.00 Technical references and CAD downloads available at www.hammondmfg.com 306 Rack Units All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Eclipse Rack Panel For use with Eclipse Enclosure Series Features • Mount to internal mounting studs. • Can be used whether an inner panel is installed or not. HLP Panel Mounting Brackets • Rack mounting units available in 4U (7.00”), 6U (10.50”) and 8U (14.00”). • Rails pivot 180 degrees for easy equipment mounting. • Includes starter pack of mounting hardware and panel installation hardware. Compatible Enclosure Dimensions ERP Brackets HLP Swivel Rack Mount Brackets H W D Part No. 4U Part No. 6U Part No. 8U Part No. 24.00 24.00 12.00 ERP2424 HLP4UR n/a n/a 24.00 24.00 16.00 ERP2424 HLP4UR HLP6UR n/a 24.00 24.00 20.00 ERP2424 HLP4UR HLP6UR HLP8UR 30.00 24.00 12.00 ERP3024 HLP4UR n/a n/a 30.00 24.00 16.00 ERP3024 HLP4UR HLP6UR n/a 30.00 24.00 20.00 ERP3024 HLP4UR HLP6UR HLP8UR 30.00 24.00 24.00 ERP3024 HLP4UR HLP6UR HLP8UR 36.00 24.00 12.00 ERP3624 HLP4UR n/a n/a NEMA Enclosure Rack Rails 1418FS and HN4FS Series Enclosures • • • • • • Provides 19” or 24” mounting capability. Sold in pairs. Formed from 10 gauge steel. Drilled and tapped 10-32 to EIA spacing of 0.5” - 0.63” - 0.63” - 0.5”. Compatible with 1418FS and HN4FS enclosures. Finished in white. Part No. Panel Description 1418TFHP Full Height 1418THHP Half Height 1418WFHP Full Height 1418WHHP Half Height 1418XFHP Full Height 1418XHHP Half Height 1418YYFHP Full Height 1418YYHHP Half Height Technical references and CAD downloads available at www.hammondmfg.com Enclosure Width Height Panel U V 60 x 24 19.00 49.00 3.78 7.78 26.25 3.59 7.59 72 x 24 19.00 61.25 3.66 7.66 31.50 3.97 7.67 72 x 30 24.00 61.25 3.66 7.66 31.50 3.97 7.67 90 x 24 19.00 78.75 3.91 7.91 40.25 4.09 8.09 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories ERP Brackets Panels and Panel Accessories • Provides internal 19” rack mounting with full EIA spacing (punched holes). • Compatible with specific sizes of the Eclipse Series (EN4SD and ST versions) • This is a 2 component system • Must order ERP brackets • Must order HLP swivel panel mounting components • Maintains UL, CSA and NEMA ratings when field installed. • Smooth black powder paint finish. USA: 716.630.7030 Data Subject to change without notice 307 www.hammondmfg.com Mild Steel and Stainless Steel Window Kits Features • Maintain environmental protection level of Type 4, 4X (for stainless steel) as noted • Window is 0.25” thick, UV resistant Polycarbonate. • Frame is heavy gauge steel, or 304 stainless steel with integral weld studs and compression clips. • Oil resistant neoprene gasket ensures a watertight seal. • Finished in ANSI 61 gray recoatable powder or natural brushed stainless steel. Window Dimensions Part No. Material 1481WN40503¹ General Accessories B Steel 5.00 3.00 6.69 4.69 1481WN40905¹ Steel 9.00 5.50 10.69 7.19 1481WN41303¹ Steel 13.00 3.00 14.69 4.69 1481WN41308¹ Steel 13.00 8.00 14.69 9.69 1481WN41705¹ Steel 17.00 5.50 18.69 7.19 1481WN41711¹ Steel 17.00 11.00 18.69 12.69 1481WN42315¹ Steel 23.00 15.00 24.69 16.69 1481WN42919¹ Steel 29.00 19.00 30.69 20.69 1481WN43523¹ Steel 35.00 23.00 36.69 24.69 1481WN4SS0503² Stainless Steel 5.00 3.00 6.69 4.69 1481WN4SS0905² Stainless Steel 9.00 5.50 10.69 7.19 1481WN4SS1308² Stainless Steel 13.00 8.00 14.69 9.69 1481WN4SS1711² Stainless Steel 17.00 11.00 18.69 12.69 1481WN4SS2315² Stainless Steel 23.00 15.00 24.69 16.69 1481WN4SS2919² Stainless Steel 29.00 19.00 30.69 Cut-Out Size 20.69 ¹ UL/ CSA Type 12 and Type 4 ² UL/ CSA Type 12, Type 4 and Type 4x Window Kits Frameless Window Kits Features • • • • Designed for indoor use on Type 12 and 13 enclosures. Scratch resistant polycarbonate window is 0.125” thick. Double sided tape is on the window for easy installation. Mounting hardware and template are included. Window Dimensions Part No. Maximum A B 1481WFL52 5.50 3.00 4.50 2.00 1481WFL133 13.88 3.88 12.88 2.88 1481WFL96 9.62 7.19 8.62 6.19 Technical references and CAD downloads available at www.hammondmfg.com 308 Recommended A Cut-Out Size All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Deep Hinged Window Kits Painted Steel 316 Stainless Steel Part No. Part No. 1481WDH1418¹ 1481WDH1612¹ 1481WDH1620¹ Overall Dimensions Viewing Area Latch Maximum H W Qty Cut-Out Size 14.56 8.00 9.17 1.00 9.19 8.14 10.00 2.75 1.00 11.19 5.14 16.14 10.00 10.75 1.00 11.19 13.14 17.14 H W 1481WSSDH1418² 12.19 1481WSSDH1612² 14.19 1481WSSDH1620² 14.19 11.56 1481WDH1624¹ 1481WSSDH1624² 14.19 20.14 10.00 14.75 1.00 11.19 1481WDH2016¹ 1481WSSDH2016² 18.19 12.14 14.00 6.75 1.00 15.19 9.14 1481WDH2024¹ 1481WSSDH2024² 18.19 20.14 14.00 14.75 1.00 15.19 17.14 1481WDH2416¹ 1481WSSDH2416² 22.19 12.14 18.00 6.75 1.00 19.19 9.14 1481WDH2420¹ 1481WSSDH2420² 22.19 16.14 18.00 10.75 1.00 19.19 13.14 23.14 1481WDH2430¹ 1481WSSDH2430² 22.19 26.14 18.00 20.75 1.00 19.19 1481WDH3024¹ 1481WSSDH3024² 28.19 20.14 24.00 14.75 2.00 25.19 17.14 1481WDH3624¹ 1481WSSDH3624² 34.19 20.14 30.00 14.75 2.00 31.19 17.14 ¹ UL/ CSA Type 12 and Type 4 ² UL/ CSA Type 12, Type 4 and Type 4x HMI Cover Prop Arm PJHMI Series Features General Accessories • Extra deep kits are designed to provide protection and easy access to components and equipment installed inside an enclosure. • Frame is 14 gauge mild steel or 316L stainless steel. • Maintain environmental protection level of enclosure. Painted mild steel maintain Type 4 and 12. Stainless Steel maintain Type 4, 4X and 12. • Quarter turn latch for easy access. • 2.5 inches of extra usable depth • Oil resistant neoprene gasket ensures a watertight seal. • Hinges can be oriented in any direction. • Window is 0.25” thick, UV Resistant Polycarbonate. • Conveniently sized to allow mounting on the door of any Hammond Wallmount Series enclosure, or in any other Hammond enclosure with a suitable mounting surface. • Mounting hardware and template are included. • Finished in ANSI 61 gray recoatable powder or natural brushed stainless steel. Window Kits Features • Stainless steel construction. • When HMI Cover mounted with hinge along top edge, prop arm unfolds to provide hands-free support. • Mounts on right or left side of HMI Cover. • Easily field installable. • Choose appropriate Prop Arm for the size of HMI Cover used (PJHMI Series.) Part No. Fits Window Kit PJHMIPROP88 PJHMI88... PJHMIPROP108 PJHMI108... PJHMIPROP1210 PJHMI1210... PJHMIPROP1412 PJHMI1412... PJHMIPROP1614 PJHMI1614 PJHMIPROP2016 PJHMI2016 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 309 www.hammondmfg.com Polycarbonate HMI Hinged Cover Kits Features General Accessories • Provides protection for instruments or electronics requiring routine attention or detail. • Available in light gray solid opaque or polycarbonate thermoplastic clear covers. • Cover Latching Options - hinged screw cover, tamper proof screw cover, and snap latch with pad lock feature. • Listed UL component for use with enclosures rated Types 1, 3, 3R, 4, 4X, 12 or 13. • CSA listed Type 1, 3, 3R, 4, 4X, 12 or 13. • 316 stainless steel hinge pin. • UV stabilized for outdoor use. • Formed-In-Place (FIP) polyurethane gasket in continuous channel. • Designed for use with wall thicknesses from 16 gauge through 1/4” • #10-32 threaded brass inserts with plated steel mounting fasteners. • Service temperature -31°F (-35°C) to 266°F (130°C) Accessories • HMI Cover Prop Arm...See Page 309 Frame Size Dimensions Clear Cover Opaque Cover Optional Prop Arm Closure Style PJHMI66CCH PJHMI66H PJHMIPROP66 Screw Cover W D H W 6.50 6.72 2.27 4.47 4.69 PJHMI66CCHTP PJHMI66HTP PJHMIPROP66 Tamper proof Screw Cover 6.50 6.72 2.27 4.47 4.69 PJHMI66CCL PJHMI66L PJHMIPROP66 Snap Latch Cover 6.50 6.72 2.27 4.47 4.69 PJHMI86CCH PJHMI86H PJHMIPROP86 Screw Cover 8.50 6.72 2.27 6.47 4.69 PJHMI86CCHTP PJHMI86HTP PJHMIPROP86 Tamper proof Screw Cover 8.50 6.72 2.27 6.47 4.69 PJHMI86CCL PJHMI86L PJHMIPROP86 Snap Latch Cover 8.50 6.72 2.27 6.47 4.69 PJHMI88CCH PJHMI88H PJHMIPROP88 Screw Cover 7.93 8.15 2.27 6.47 6.69 PJHMI88CCHTP PJHMI88HTP PJHMIPROP88 Tamper proof Screw Cover 7.93 8.15 2.27 6.47 6.69 PJHMI88CCL PJHMI88L PJHMIPROP88 Snap Latch Cover 7.93 8.15 2.27 6.47 6.69 Window Kits PJHMI108CCH PJHMI108H PJHMIPROP108 Screw Cover 9.93 8.15 2.27 8.47 6.69 PJHMI108CCHTP PJHMI108HTP PJHMIPROP108 Tamper proof Screw Cover 9.93 8.15 2.27 8.47 6.69 PJHMI108CCL PJHMI108L PJHMIPROP108 Snap Latch Cover 9.93 8.15 2.27 8.47 6.69 PJHMI1210CCH PJHMI1210H PJHMIPROP1210 Screw Cover 11.93 10.15 2.27 10.47 8.69 PJHMI1210CCHTP PJHMI1210HTP PJHMIPROP1210 Tamper proof Screw Cover 11.93 10.15 2.27 10.47 8.69 PJHMI1210CCL PJHMI1210L PJHMIPROP1210 Snap Latch Cover 11.93 10.15 2.27 10.47 8.69 PJHMI1412CCH PJHMI1412H PJHMIPROP1412 Screw Cover 13.95 12.07 2.20 12.49 10.71 PJHMI1412CCHTP PJHMI1412HTP PJHMIPROP1412 Tamper proof Screw Cover 13.95 12.07 2.20 12.49 10.71 PJHMI1412CCL PJHMI1412L PJHMIPROP1412 Snap Latch Cover 13.95 12.07 2.20 12.49 10.71 PJHMI1614CCH PJHMI1614H PJHMIPROP1614 Screw Cover 16.01 14.23 2.27 14.49 12.71 PJHMI1614CCHTP PJHMI1614HTP PJHMIPROP1614 Tamper proof Screw Cover 16.01 14.23 2.27 14.49 12.71 PJHMI1614CCL PJHMI1614L PJHMIPROP1614 Snap Latch Cover 16.01 14.23 2.27 14.49 12.71 PJHMI2016CCH PJHMI2016H PJHMIPROP2016 Screw Cover 20.50 16.72 2.27 18.49 14.71 PJHMI2016CCHTP PJHMI2016HTP PJHMIPROP2016 Tamper proof Screw Cover 20.50 16.72 2.27 18.49 14.71 PJHMI2016CCL PJHMI2016L PJHMIPROP2016 Snap Latch Cover 20.50 16.72 2.27 18.49 14.71 Technical references and CAD downloads available at www.hammondmfg.com 310 Viewing Area H All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Polycarbonate Inspection Window Kit Features • Clear polycarbonate thermoplastic. • Provides visibility and easy viewing access to equipment and components installed in an enclosure. • Recognized UL component for use with enclosures rated Types 1, 3, 3R, 4, 4X, 12 or 13. • CSA listed Type 1, 3, 3R, 4, 4X, 12 or 13 • UV stabilized for outdoor use. • Formed-In-Place (FIP) polyurethane gasket in continuous channel. • Designed for use with wall thicknesses from 16 gauge through 1/4” • #10-32 threaded brass inserts with plated steel mounting fasteners • Service temperature -31°F (-35°C) to 266°F (130°C) Viewing Area A B C D E PJHMI66CX 6.50 6.50 0.60 5.64 5.64 PJHMI95CX 10.00 7.25 0.60 9.14 6.39 PJHMI138CX 14.70 9.70 0.60 13.84 8.84 Window Kits Overall Dimensions Part No. Deep Hinged HMI Cover Kits • Extra deep kits are designed to provide protection and easy access to components and equipment installed inside an enclosure. • Frame is 14 gauge mild steel or 316L stainless steel. • Maintain environmental protection level of enclosure. Painted mild steel maintain Type 4 and 12. Stainless Steel maintain Type 4, 4X and 12. • Quarter turn latch for easy access. • 2.5 inches of extra usable depth • Oil resistant neoprene gasket ensures a watertight seal. • Hinges can be oriented in any direction. • Conveniently sized to allow mounting on any enclosure with a suitable mounting surface. • Mounting hardware and template are included. • Finished in ANSI 61 gray recoatable powder or natural brushed stainless steel. Painted Steel 316 Stainless Steel Part No. Part No. Overall Dimensions H W Latch Maximum Qty Cut-Out Size 1481SDH1418 1481SSDH1418 12.19 14.56 1.00 9.19 1481SDH1612 1481SSDH1612 14.19 8.14 1.00 11.19 5.14 1481SDH1620 1481SSDH1620 14.19 16.14 1.00 11.19 13.14 17.14 11.56 1481SDH1624 1481SSDH1624 14.19 20.14 1.00 11.19 1481SDH2016 1481SSDH2016 18.19 12.14 1.00 15.19 9.14 1481SDH2024 1481SSDH2024 18.19 20.14 1.00 15.19 17.14 1481SDH2416 1481SSDH2416 22.19 12.14 1.00 19.19 9.14 1481SDH2420 1481SSDH2420 22.19 16.14 1.00 19.19 13.14 1481SDH2430 1481SSDH2430 22.19 26.14 1.00 19.19 23.14 1481SDH3024 1481SSDH3024 28.19 20.14 2.00 25.19 17.14 1481SDH3624 1481SSDH3624 34.19 20.14 2.00 31.19 17.14 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Features USA: 716.630.7030 Data Subject to change without notice 311 www.hammondmfg.com Fluorescent Light Kit & Accessories Features • • • • • • • • • Light kits are offered in 18”, 24” and 48” widths. CSA and UL component recognized. Operating voltage 115 AC 60Hz 115V AC, features a manually operated switch, 115V convenience outlet, durable plastic lens, and 6 foot power cord (without plug). Can mount into light mounting channel, bolt through enclosure or by using magnet strip (available separately - see chart below.) 1¾” high x 4½” deep. Finished in white. Use standard 18”, 24” or 48” T8 fluorescent bulb (not included) Magnet mount • Can be used with mild steel enclosures only. Accessories • Remote Door Switches...See Page 313 General Accessories Magnetic Mount Kit Part No. Description FLK18T8¹ Part No. 18” Fluorescent Light Kit 115V FLK18MM FLK18LENSE FLK24T8¹ 24” Fluorescent Light Kit 115V FLK18MM FLK24LENSE FLK48T8¹ 48” Fluorescent Light Kit 115V FLK48MM FLK48LENSE ¹ T8 fluorescent bulb not included LED Light Kit Features Lighting • Available in 9”, 17.5”, 26”, 34.5”, and 38.5” lengths • Operating voltage 120V AC5 (50/60Hz). Operating temperature -20C to +50C (-4F to +122F) • Provides 175 lumens per LED module • Long lamp life of 60,000 hours in warm white color temperature • No remote power supplies as unit comes with its own integral LED drivers • Hardwired via multiple knockouts in lightweight extruded aluminum frame, finished white with manual operated switch • Hinged glass diffuser allows easy access to replaceable LED module • Certified by ETL to UL and CSA Luminaires standards Accessories • Remote Door Switches...See Page 313 Part Number Description Number LED Modules Lumens FLK5LED 9” LED Light Kit 1 175 4.4 w FLK7LED 17.5” LED Light Kit 2 350 7.2 w Energy Use FLK10LED 26” LED Light Kit 3 525 9.8 w FLK15LED 34.5” LED Light Kit 4 700 15.0 w FLK17LED 38.5 LED Light Kit 5 875 17.0 w Technical references and CAD downloads available at www.hammondmfg.com 312 Replacement Lens Kit Part No. All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Compact LED Light Kit Our compact LED light kit provides efficient lighting solution for most enclosure applications without taking up valuable interior space. Available in magnet or screw mounting and AC or DC power options. Features • • • • Housing constructed in transparent plastic. Screw or magnet mounting. Available with rocker switch or motion sensor. Easily connect up to ten (10) light kits together in a daisy chain using LEDXXCORDCON cords. • Connection: 2-pole plug with snap lock; AC: max. 2.5 A / AC 240 V, white connector; DC: max. 2.5 A / DC 60 V, blue connector. • Requires hard-wired connection using LEDXXCORDPOWR power cord with leads and plug or power brick (not included). Part No. LEDACSWMAG Voltage On/Off Mount 90-260V AC Switch Magnet Magnet LEDACMSMAG 90-260V AC Sensor LEDACSWSCR 90-260V AC Switch Screw LEDACMSSCR 90-260V AC Sensor Screw LEDDCSWMAG 20-60V DC Switch Magnet LEDDCMSMAG 20-60V DC Sensor Magnet LEDDCSWSCR 20-60V DC Switch Screw LEDDCMSSCR 20-60V DC Sensor Screw • LED provide 400 Lm at 120° (1,200 Lm at 360° or equivalent 95W light bulb). • LED temperature 6,000 to 7,000 K. • Operating / Storage temperature: -22 to +140 °F (-30 to +60 °C) / -40 to +185 °F (-40 to +85 °C). • Operating / Storage humidity: max. 90 %RH (non-condensing). • Service life: 60,000 hrs. at 68 °F (20 °C). • Max. 5 W power consumption (~ 75 W incandescent bulb) • Protection class / Protection type: II (double insulated) / IP20 Note that the cord on this product is intended to be hard-wired. There are currently no standard plug types for this product. Remote Door Switches Features • Permits convenient door activated on-off function of air conditioners. • Can be wired normally open or normally closed. • 115/230 V AC Part No. For use with FLKDS 1418, 1422, 1447, 2UD, UHD, HN4, HWST FDS1 Eclipse, HME General Accessories LED Light Kits Lighting Specifications DIN Mount Receptacle Features • • • • 125V/15A max. receptacle Mounts to 35mm DIN rail (not included) 3.6”H x 2.4”W x 1.9”D CE, UL/cUL component recognized Part No. SSD03504001 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 313 www.hammondmfg.com Door Support Guide Features • Designed for use when heavy loads or uneven mounting surfaces changes door alignment. • Field installable kit. • Can be used on Hammond Eclipse and 1418 Series wall mount enclosures, all freestanding and floor mount enclosures - both painted and stainless steel • Kit includes all necessary hardware and installation instructions Sealing washers included maintain enclosure integrity Part No. DSG1 General Accessories Gland Plates Features • 14 gauge mild steel gland plate allows for easy cable entry into enclosure • Maintains NEMA 12, 4 rating • Hardware and cutout template included Finish • Available in ANSI 61 Gray and RAL 7035 Light Gray Overall Dimensions Part No. Finish GP063LG RAL 7035 Light Gray W H W 6.31 2.75 5.06 1.50 Miscellaneous GP134LG RAL 7035 Light Gray 13.00 3.56 11.75 2.31 GP136LG RAL 7035 Light Gray 13.38 5.88 12.13 4.63 GP216LG RAL 7035 Light Gray 20.88 5.88 19.63 4.63 GP063GY ANSI 61 Gray 6.31 2.75 5.06 1.50 GP134GY ANSI 61 Gray 13.00 3.56 11.75 2.31 GP136GY ANSI 61 Gray 13.38 5.88 12.13 4.63 GP216GY ANSI 61 Gray 20.88 5.88 19.63 4.63 Technical references and CAD downloads available at www.hammondmfg.com 314 Fits Opening H All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Gland Plates Features • • • • 14 gauge steel gland plate allows for easy cable entry into enclosure Maintains NEMA 12, 4 rating, Stainless plates hold type 4X rating Hardware and cutout template included Modified sizes are available: • 16 gauge mild or stainless 76” x 18” • 14 gauge mild or stainless 76” x 25” • 12 and 10 gauge mild or stainless 76” x 40” • 0.081 aluminum 76” x 18” • 0.100 aluminum 76” x 25” Finish • Available in ANSI 61 Gray and RAL 7035 Light Gray • Stainless Plates are 316 with a number 4 brush finish GP1507LG Fits Opening H W H W RAL 7035 Light Gray 15.00 7.50 12.00 4.50 4.50 GP2207LG RAL 7035 Light Gray 22.00 7.50 19.00 GP1507GY ANSI 61 Gray 15.00 7.50 12.00 4.50 GP2207GY ANSI 61 Gray 22.00 7.50 19.00 4.50 GP1507S16 316 STAINLESS 15.00 7.50 12.00 4.50 GP2207S16 316 STAINLESS 22.00 7.50 19.00 4.50 Liquid-Tight Cordgrips (Nylon) IP68, UL Listed. PG & Metric Features • • • • 14 gauge steel gland plate allows for easy cable entry into enclosure Maintains NEMA 12, 4 rating, Stainless plates hold type 4X rating Hardware and cutout template included Modified sizes are available: • 16 gauge mild or stainless 76” x 18” • 14 gauge mild or stainless 76” x 25” • 12 and 10 gauge mild or stainless 76” x 40” • 0.081 aluminum 76” x 18” • 0.100 aluminum 76” x 25” Finish • Available in ANSI 61 Gray and RAL 7035 Light Gray • Stainless Plates are 316 with a number 4 brush finish PG Threads (Standard Length) Outer Length Inner Thread Length Material Thread Size (D) Min Max (L) (T) 1427NCGPG7B Nylon PG7 3 7 21 8 1427NCGPG9G 1427NCGPG9B Nylon PG9 4 8 22 8 1427NCGPG11G 1427NCGPG11B Nylon PG11 5 10 25 8 1427NCGPG13G 1427NCGPG13B Nylon PG13.5 6 12 27 9 1427NCGPG16G 1427NCGPG16B Nylon PG16 10 14 28 10 1427NCGPG19G 1427NCGPG19B Nylon PG19 12 15 30 12 1427NCGPG21G 1427NCGPG21B Nylon PG21 13 18 31 11 1427NCGPG29G 1427NCGPG29B Nylon PG29 18 25 37 11 1427NCGPG36G 1427NCGPG36B Nylon PG36 22 32 48 13 1427NCGPG42G 1427NCGPG42B Nylon PG42 32 38 49 13 1427NCGPG48G 1427NCGPG48B Nylon PG48 37 44 49 14 Part Number (Grey) Part Number (Black) 1427NCGPG7G Wire Diameter Miscellaneous Finish General Accessories Overall Dimensions Part No. Note: Table dimensions in mm. Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 315 www.hammondmfg.com Liquid-Tight Cord Grips (Nickel Plated Brass) IP68, UL Listed. PG & Metric Features • Liquid-tight cord grip made from nickel plated brass • Used where cable is entering or leaving an enclosure. • Accepts a wide range of cable diameters due to large opening and NBR (nitrile rubber) seal. • The strain relief elements tighten in a circular sequence on the sealing ring to give outstanding strain relief without twisting or damaging the cable. • Use the cord grip with the smallest maximum diameter that will fit your application. • Locknut and EPDM O-ring included. • Protection to IP68. Designed to meet NEMA Type 4, 4X, 6, 6P, 12 & 13. • UL listed. PG Threads General Accessories Thread Size Outer Length Inner Thread Length Part Number Material (D) Min Max (L) (T) 1427BCGPG7 Nickel Plated Brass PG7 3 4 19 5 1427BCGPG9 Nickel Plated Brass PG9 4 8 21 6 1427BCGPG11 Nickel Plated Brass PG11 5 10 22 6 1427BCGPG13 Nickel Plated Brass PG13 6 12 23 7 1427BCGPG16 Nickel Plated Brass PG16 10 14 24 7 1427BCGPG21 Nickel Plated Brass PG21 13 18 24 7 1427BCGPG29 Nickel Plated Brass PG29 18 25 31 8 1427BCGPG36 Nickel Plated Brass PG36 22 32 37 8 1427BCGPG42 Nickel Plated Brass PG42 32 38 37 9 1427BCGPG48 Nickel Plated Brass PG48 37 44 38 10 Note: Table dimensions in mm. Miscellaneous Liquid-Tight, Strain Relief Cordgrips Features • Black nylon, liquid-tight cord grip. • Used where cable is entering or leaving an enclosure. • Accepts a wide range of cable diameters due to large opening and highly flexible strain relief elements, together with a TPE sealing ring. • The strain relief elements tighten in a circular sequence on the sealing ring to give outstanding strain relief without twisting or damaging the cable. • Use the cord grip with the smallest maximum diameter that will fit your application (see table below). • Nylon locknut included (as shown). • Designed to meet NEMA Type 4, 4X, 6, 6P, 12 & 13 - Protection to IP68. • UL94-V2 flammability rating. • UL, CSA & VDE listed. • For a wider selection of cord grips, try our updated product lines: • 1427NCG - nylon cord grips • 1427BCG - brass cord grips Use With Wire Diameter Mounting Hole Part No. Min Max Diameter 1427CG7 0.10 0.26 0.49 1427CG9 0.14 0.32 0.60 1427CG13 0.24 0.47 0.80 1427CG16 0.35 0.55 0.89 1427CG21 0.51 0.71 1.11 Technical references and CAD downloads available at www.hammondmfg.com 316 Wire Diameter All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Stack Lights • • • • Modular design for all indoor and outdoor applications. Provides warning signals and displays machine status. High level of protection against electric shock with IP 54 rating. Separate components for easy ordering to suit every installation application. Base and Tubes Description L1 L2 PBR50BC Base & End Module - - PBR50S100 Tubular Stand/Plinth 3.46 - PBR50S250 Tubular Stand/Plinth 9.37 - PBR50T100 Threaded tubular stand/bracket - 3.07 PBR50T250 Threaded tubular stand/bracket - 8.98 PBR50T400 Threaded tubular stand/bracket - 14.13 Part No. Description PBR50CLCL Continuous beam module, transparent PBR50CLYE Continuous beam module, yellow PBR50CLAM Continuous beam module, amber PBR50CLRE Continuous beam module, red PBR50CLGR Continuous beam module, green PBR50CLBL Continuous beam module, blue PBR50BLYE24V Blinking module, yellow PBR50BLRE24V Blinking module, red PBR50BLGR24V Blinking module, green Miscellaneous Modules Gaskets, Bulbs and Accessories Part No. Description PBR50MG Replacement gasket for light module & base module PBR50TG Replacement gasket for mounting tube with plinth PBR50BG Replacement gasket for direct mounting IP 65 PBR50LED24 LED light bulb 24V/BA 15d PBR50LED115 LED light bulb 115V/BA 15d PBR50L24 Light bulb 24V DC/BA 15d 7W PBR50L115 Light bulb 115V CD/BA 15d 7W PBR50LS Bulb Remover/Installer Modular Data Continuous Beam Blinking Light Modular Colors Yellow, Red, Green, Amber, Blue, Transparent Yellow, Red, Green Modular Stages Max. 5 Max. 5 ) Angle of Beam 360 degrees 360 degrees Percentage Duty Cycle 1 1 Rated Power, max. 7W 7W 5W Rated Power with 5 stages 5W Lamp Socket BA 15d BA 15d Service life of light bulb/tube approx. 1500h approx. 1500h AC Voltage Rating 230 V, 50/60 Hz, -15% to + 10% 230 V, 50/60 Hz, -15% to +10% Current Capacity Rating 0.035 A 0.08 A DC Voltage Rating 24 V, -15% to +20% 24 V, -15% to +20% Current Capacity Rating 0.3 A 0.25 A Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Part No. USA: 716.630.7030 Data Subject to change without notice 317 www.hammondmfg.com Flange Disconnect Operator Adaptor Kits Features • Used to adapt flange mounted operating mechanisms to all Hammond enclosures with universal cutouts. • Kits include an adaptor plate and all of the required parts (with instructions) to interlock the master door with the operator mechanism. • Blank plates are used to cover the flange cutouts in Hammond universal type disconnect enclosures. Part No. Operator Make & Type Manufacturer Part No. AK1494FD Allen Bradley 1494F and D BPAK Blank plate General Accessories Part No. Operator Make & Type AKU ABB Controls -  operating handle Manufacturer Part No. Disconnect  Switch DSFHN-HS12 Circuit Breaker K7FHD-HS12 Allen Bradley - 1494V variable depth operating handle Disconnect Switch 30 to 200 1494V H1 for 2UD, UHD, UHDM 400 to  600 1494V H2 for UHD 400 1494V H2 for UHDM Circuit Breaker 1494V H11 Cutler Hammer  - operating handle Disconnect Switch C361H1 or H3 Circuit Breaker 150 A C371H1 or H3 250 to 600 A C371H5 or H7 for 2UD 250 to 1200 A C371H5 or H7 for UHD, UHDM Circuit Breaker C371 Flex-Shaft™ handle mechanism Miscellaneous General Electric  - operating handle Disconnect Switch STDA1or STDA2 Circuit Breaker STDA1or STDA2 Circuit  Breaker Spectra-Flex™  cable operators 150 to 600 A STDA1 SK1200 A STDA3 Siemens I.T.E. Max-Flex™  - operating handle Disconnect Switch variable depth FHOHS Circuit Breaker 125 to 600 A FHOH 800 to 2000 A FHOHN Square D - class 9422 operating mechanism Disconnect Switch variable depth 9422 type A1 Circuit Breaker  variable depth 9422 type A1 Disconnect  Switch with cable mechanism 9422 type A1 Circuit Breaker  with cable mechanism 9422 type A1 Technical references and CAD downloads available at www.hammondmfg.com 318 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Drip Shield Kit Features • Easily installed on Type 12, 4 and 4X wall-mount enclosures using stainless steel bolts and sealing washers (included). • Designed not to interfere with door clamps. • Protects door from dripping water and settling dust. • Constructed in 14 gauge mild steel (painted) or 316 stainless steel. • Maintains enclosure rating. Part Numbers Type 316 Stainless Steel Fits Enclosure Width (inches) DK12GY DK12LG DK12S16 12.00 DK16GY DK16LG DK16S16 16.00 DK20GY DK20LG DK20S16 20.00 DK24GY DK24LG DK24S16 24.00 DK30GY DK30LG DK30S16 30.00 DK36GY DK36LG DK36S16 36.00 DK42GY DK42LG DK42S16 42.00 DK48GY DK48LG DK48S16 48.00 DK60GY DK60LG DK60S16 60.00 DK72GY - DK72S16 72.00 Pedestal and Base Features • Used for floor mounting for many types of enclosures, consolets or pushbutton boxes • Provides wiring feature through the column. • Meets NEMA Type 12 and 13 requirements. • Finished in ANSI 61 gray. Pedestal Column • Columns are formed from 14 gauge steel with 10 gauge flanges. • Column access opening with gasketed cover. • Columns include flange gaskets and a box connector. Pedestal Base • Bases are formed from 10 gauge steel with additional reinforcing. • Bases include leveling screws. Part No. Description H W D 1495C35 Pedestal Column 36.00 4.00 4.00 1495D35 Pedestal Column 36.00 6.00 6.00 1495XK Pedestal Base 1.13 18.00 18.00 1495XN Pedestal Base 1.13 24.00 24.00 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Miscellaneous Painted Steel (Lt. Gray) General Accessories Painted Steel (Gray) USA: 716.630.7030 Data Subject to change without notice 319 www.hammondmfg.com Floor Stand Kit Features • Kit includes two mounting feet and hardware kit. • Pre-punched mounting feet may be used as a template to drill holes on bottom of enclosure. • Finished in gray or natural brushed stainless steel. Steel Stainless Steel Part No. Part No. Foot Enclosure Height Depth A B C 1481FA8K 6.00 8.00 6.00 6.00 8.00 1481FA10K 6.00 10.00 6.00 8.00 10.00 1481FA12K 6.00 12.00 6.00 8.00 12.00 1481FA16K 6.00 16.00 6.00 10.00 16.00 1481FA18K 6.00 18.00 6.00 8.00 1481FA20K 6.00 20.00 6.00 10.00 20.00 18.00 12.00 6.00 12.00 5.00 1481FC8K 1481FC8KSS 12.00 8.00 12.00 6.00 8.00 1481FC10K 1481FC10KSS 12.00 10.00 12.00 8.00 10.00 1481FC12K 1481FC12KSS 12.00 12.00 12.00 8.00 12.00 1481FC16K 1481FC16KSS 12.00 16.00 12.00 10.00 16.00 1481FC18K 1481FC18KSS 12.00 18.00 12.00 10.00 18.00 1481FC20K 1481FC20KSS 12.00 20.00 12.00 10.00 20.00 1481FC24K 1481FC24KSS 12.00 24.00 12.00 10.00 24.00 1481FE6K 15.00 6.00 15.00 5.00 1481FE8K 15.00 8.00 15.00 6.00 8.00 1481FE10K 15.00 10.00 15.00 8.00 10.00 1481FE12K 15.00 12.00 15.00 8.00 12.00 1481FE16K 15.00 16.00 15.00 10.00 16.00 1481FE18K 15.00 18.00 15.00 10.00 18.00 1481FE24K 15.00 24.00 15.00 10.00 24.00 1481FG6K 18.00 6.00 18.00 5.00 1481FG8K 18.00 8.00 18.00 8.00 8.00 1481FG10K 18.00 10.00 18.00 8.00 10.00 1481FG12K 18.00 12.00 18.00 8.00 12.00 1481FG16K 18.00 16.00 18.00 10.00 16.00 1481FK6K 24.00 6.00 24.00 5.00 1481FK8K 24.00 8.00 24.00 8.00 8.00 8.00 10.00 General Accessories 1481FC6K 6.00 6.00 6.00 Miscellaneous 6.00 1481FK10K 1481FK10KSS 24.00 10.00 24.00 1481FK12K 1481FK12KSS 24.00 12.00 24.00 10.00 12.00 24.00 16.00 24.00 12.00 16.00 1481FK16K Door Stop Kit Dimensions (each) Features • Provides for door opening in fixed position as required. • Prevents door swing that can occur in field maintenance situations. • Minimum enclosure width of 20” for single door and 48” for two-door is required • This door stop kit maintains NEMA 4x, 4, 3R and 12 ratings when installed correctly using the hardware and directions provided. • (Note: Not compatible with Eclipse swing panel/frame accessories.) Part No. DSTOPK - Door Stop Kit Part No. DSTOPKHD - Heavy Duty Door Stop Kit Technical references and CAD downloads available at www.hammondmfg.com 320 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Touch-Up Spray Paint • Touch-up paint is ideal for dealing with minor paint chips or blemishes sometimes caused by shipping or while installing equipment. When accidents happen, our touch-up paint is formulated to match the powder coat finish from the factory. Features Literature Pocket Part No. Finish RAL/ANSI Compatibility 1413BKLGS Low Gloss Black RAL9005 BK, BK1 BK2 1413BKS Gloss Black RAL9005 1413CGRALS Beige RAL7032 CG1, CG2 1413LRS Gray ANSI 61 GY1, GY2 1413NS White n/a 1413LGS Gray RAL7035 LG, LG1, LG2 1413WH9003 White RAL9003 WH, WH1 Miscellaneous Indoor/outdoor. Fast-drying. Premium high-end finish. Available in 300g (10.5 oz) spray cans. Manufactured in North America. PROP65 WARNING: This product can expose you to chemicals, including Toluene, Menthanol, Carbon Black which is known to the State of California to cause cancer. For more information, go to: www.P65Warnings.ca.gov. Not Compliant with California Air Resources Board (Carb) Regulations. Features • For use as additional or replacement literature and document pockets. • Kit includes pocket, high strength two-sided adhesive tape and surface preparation swab. • Plastic pocket is black. • Packaged individually. Part No. H W D 6.00 6.00 0.75 PKT99 6.00 9.00 0.75 PKT1212S 12.00 12.00 1.25 PKT1212 12.00 12.00 2.50 PKT66 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories • • • • • • USA: 716.630.7030 Data Subject to change without notice 321 www.hammondmfg.com Enclosure Stabilizers Features • Prevents floor mounted enclosures from falling over while being worked on before they are bolted to the floor. • Install by slipping under enclosure mounting foot and tightening two thumb screws. • 8” x 30” overall dimensions • Sold in pairs • Finished in gray. Part No. 1481ES General Accessories Rack and Cabinet Caster Set Up to 1,050 lbs (475 kg) Weight Capacity Features • Ball bearing, swivel wheels. • Includes mounting hardware. • Plated zinc finish. Miscellaneous Wheel Diameter Overall Height Added to Cabinet Hole Mounting Pattern Qty Included In Set Qty with Brakes Included Part No. Strength Style/ Material Width Depth 1425BLSOFT Light Duty Soft Thermoplastic 2.95 3.50 1.75 3.00 660 lbs (299 kg) 4 4 1425BM Medium Duty Hard Composition 3.00 3.81 1.75 3.00 700 lbs (318 kg) 4 0 1425BH Heavy Duty Hard Composition 3.00 3.81 1.75 3.00 1,050 lbs (476 kg) 4 0 1425BHLOCK Heavy Duty Hard Composition 3.00 3.81 1.75 3.00 1,050 lbs (476 kg) 4 4 Technical references and CAD downloads available at www.hammondmfg.com 322 Caster Set Weight Capacity All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Panel Lifting Handles Features • Used for lifting, transporting, and installing panel assemblies in enclosures that are positioned horizontally. Wash Down Floor Stand Kit Waterfall Series Accessory Features • • • • • • Gasket Kits Attach to bottom enclosure for floor mounting applications Permits easy access for cleaning beneath enclosure Adds 12” height to enclosure Adjustable model has 1” of adjustment – ideal as a leveling foot 316L stainless steel construction Sold in pairs Part No. Description AKIT316ST Adjustable Height Floor Stand (pair) FKIT316ST12 12” Fixed Floor Stand (pair) NEMA 12 Enclosures • Self-adhesive, black, cellular neoprene gasket for NEMA 12 enclosures. • Supplied in 10 foot rolls, 0.19” x 0.75”. NEMA 4, 4X Enclosures • Self-adhesive, black, neoprene blend gasket for NEMA 4, 4X enclosures. • Supplied in 10 foot rolls, 0.25” x 0.75”. Miscellaneous 1481H General Accessories Part No. NEMA 4, 4X Enclosures - Extreme Temperature • Self-adhesive, black, silicone foam gasket for NEMA 4, 4X enclosures. • Temperature range -67° to +392°F (-55° to +200°C) • Designed for use on the following Hammond Series: EJ, HJ, 1414, Eclipse, 1418 and HW • Original gasket must be properly removed and replaced with the silicone strip gasket according to instructions provided. • Supplied in 10 foot rolls, 0.25” x 0.75”. Part No. Material For NEMA Type 1481DJ10 Neoprene 12 1481DJN410 Neoprene/EPDM/SBR 4, 4X 1481DJSIL10 Silicone 4, 4X Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 323 www.hammondmfg.com Fold Down Shelf Features • Supports various equipment used temporarily to service/program switchgear inside enclosures. • Mounts with bolts through doors or sides. • Supports up to 100 lbs weight capacity. Work Surface Part No. Finish FDS1212GY ANSI 61 Gray D 12.00 FDS1818GY ANSI 61 Gray 18.00 18.00 FDS2424GY ANSI 61 Gray 24.00 24.00 FDS1212LG RAL 7035 Light Gray 12.00 12.00 FDS1818LG RAL 7035 Light Gray 18.00 18.00 General Accessories FDS2424LG RAL 7035 Light Gray 24.00 24.00 FDS1212S16 316 Stainless Steel 12.00 12.00 FDS1818S16 316 Stainless Steel 18.00 18.00 FDS2424S16 316 Stainless Steel 24.00 24.00 Pole Mounting Kit PJ/PJU - Non Metallic Series Features • • • • • Eight sizes cover PJU & PJ up to 30x24 Adjustable steel band allows mounting on pole diameters up to 15” Adaptable pole mounting on round, square, and rectangular shapes Minimal assembly with fewer parts for installation Corrosion protection for long outdoor life Miscellaneous Pole Mount Kit Part Number Use with PJ Series (including all variations) Use with PJU Series Use with PCJ Series (including all variations) (including all variations) PJPOLEMNT6 PJ - 664, 864 PJU - 664, 864 PCJ - 664, 864 PJPOLEMNT8 PJ - 1084,1086 PJU - 1084, 1086 PCJ - 884, 1082, 1084, 1086 PJPOLEMNT10 PJ - 12106 PJU - 12106 PCJ - 12106, 12126 PJPOLEMNT12 PJ - 1214, 12126, 14126 PJU -14126 PCJ - 14126 PJPOLEMNT14 PJ - 16148 PJU -16148 PCJ - 16148 PJPOLEMNT16 PJ - 18168, 20168 PJHD -181610 PJU - 181610, 201610 PCJ - 181610 PJPOLEMNT20 PJ - 242010 - - PJPOLEMNT24 PJ - 242410, 302410 - - PJPOLEMNT30 PJEC - 363012 PJW - 363014, 483610, 483614, 603610, 603614 - - Technical references and CAD downloads available at www.hammondmfg.com 324 W 12.00 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Pole Mounting Kit Junction and Wallmount Style - Steel Features • Designed to mount outdoor rated enclosures - Hammond 1414N4, Eclipse, Eclipse Junior, HWHK, 1418N4 and EN4DH Series • Individual components allow user to choose mounting configuration and/or components to purchase • Note: Eclipse Series enclosures require use of external Eclipse Mounting Foot Kit (sold separately) • This pole mount kit is a 2 or 3 part system. Choose Vertical Channel: • Horizontal steel channels (sold in pairs) come with all hardware needed to secure the enclosure Choose Straps (Optional): • Stainless steel straps sold separately in quantities of 4 • PMSTRAP40 straps are rated for 450 lbs each and can be used for pole diameters up to 10” • PMSTRAP55 straps are rated for 250 lbs each and can be used for pole diameters up to 15” Vertical Channel Use with Hammond Series Part No. Description 1414N4 Eclipse Junior (EJ) PMV1216GY 1418N4/HWHK Eclipse (EN4SD) Qty 1 - Vertical Steel Channel 12”-16” encl height 12”-16” encl height 12”-16” encl height 12”-16” encl height PMV2024GY Qty 1 - Vertical Steel Channel - - 20”-24” encl height 20”-24” encl height PMV3036GY Qty 1 - Vertical Steel Channel - - 30”-36” encl height 30”-36” encl height PMV4248GY Qty 1 - Vertical Steel Channel - - 42”-48” encl height 42”-48” encl height Horizontal Channel Use with Hammond Series Part No. Description 1414N4 Eclipse Junior (EJ) 1418N4/HWHK PMH15GY Qty 2 - Horizontal Steel Channel 12”-16” encl width 12”-16” encl width 12”-20” encl width Eclipse (EN4SD) 12”-16” encl width PMH25GY Qty 2 - Horizontal Steel Channel - - 24”-30” encl width 20”-24” encl width PMH35GY Qty 2 - Horizontal Steel Channel - - 36” encl width 30”-36” encl width General Accessories Choose Horizontal Channel: Miscellaneous • Vertical channel can be lagged directly to pole or attached using optional stainless steel straps • Vertical channel prevents enclosure from twisting. Can be used on pole diameters from 4” and up Stainless Steel Straps Part No. Description PMSTRAP40 Qty 4 - 0.50” x 39” length 316 stainless strap, supports up to 450 lbs, pole diameters up to 10” PMSTRAP55 Qty 4 - 0.31” x 55” length 316 stainless strap, supports up to 250 lbs, pole diameters up to 15” Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 325 www.hammondmfg.com Top Hat Cable Modules Features • • • • • • Provides for cable management and slack storage space Pre-drilled for simple assembly onto top of freestanding enclosures Easily removable front panels Sturdy 12 gauge construction Constructed to Type 4, 12 and 3R protection levels Painted ANSI 61 gray Cover Plate Openings Part # A B C Gauge D E Cutout Opening General Accessories F G HTH124818 12.00 48.06 18.06 12 8.50 20.53 14.06 39.06 HTH124820 12.00 48.06 20.06 12 8.50 20.53 16.06 39.06 HTH124824 12.00 48.06 24.06 12 8.50 20.53 20.06 39.06 HTH126018 12.00 60.06 18.06 12 8.50 26.53 14.06 51.06 HTH126020 12.00 60.06 20.06 12 8.50 26.53 16.06 51.06 HTH126024 12.00 60.06 24.06 12 8.50 26.53 20.06 51.06 HTH126036 12.00 60.06 36.06 12 8.50 26.53 32.06 51.06 HTH127218 12.00 72.06 18.06 12 8.50 32.53 14.06 63.06 HTH127220 12.00 72.06 20.06 12 8.50 32.53 16.06 63.06 HTH127224 12.00 72.06 24.06 12 8.50 32.53 20.06 63.06 HTH127236 12.00 72.06 36.06 12 8.50 32.53 32.06 63.06 Miscellaneous Technical references and CAD downloads available at www.hammondmfg.com 326 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Barrier Kits for Type 4 Wallmount Features Description BKWM2408 For use with 24H x 8D BKWM3010 For use with 30H x 10D BKWM3612 For use with 36H x 12D BKWM4212 For use with 42H x 12D BKWM4812 For use with 48H x 12D Barrier Kits for Type 4 Floormount Features • Barrier kits are designed to provide 2 vertical sections within 2 door, Type 4 enclosures. • For use with HN4FM Series,1422N4 Series and 2STFSD Series • For application example, can provide separation between power and control sections within one cabinet. • Does NOT provide complete physical separation as there is space above and below the barrier to run wiring. • Depth mounted - bolted to the inner panel at rear and the center post at front. • Certain sizes are depth adjustable • Panels are steel and painted white. • Mounting hardware included. Part No. Description BKFM6012 For use with 60H x 10/12D BKFM6018 For use with 60H x 18D BKFM7218 For use with 72H x 12/18D BKFM7224 For use with 72H x 24D Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 General Accessories Part No. Miscellaneous • Barrier kits are designed to provide 2 vertical sections within 2 door, Type 4 enclosures. • For use with HN4WM Series. • For application example, can provide separation between power and control sections within one cabinet. • Does NOT provide complete physical separation as there is space above and below the barrier to run wiring. • Depth mounted - bolted to the inner panel at rear and the center post at front. • Panels are steel and painted white. • Mounting hardware included. USA: 716.630.7030 Data Subject to change without notice 327 www.hammondmfg.com Corrosion Inhibitors Emitter Devices • Emitters are designed to protect electrical and electronic components within non-ventilated enclosures. • These products emit a vapor into the interior of the enclosure which deposits on the metal surfaces forming a protective molecular layer. This layer provides multi-metal protection and helps reduce corrosion in the enclosure. HVPCI-101 Pads • • • • Patented VpCI impregnated foam affixed via self adhesive backing. Provides protection for 1 cubic foot of enclosed space Sold in carton of 50 pads Full technical details available on separate data sheet HVPCI-105 Cups General Accessories • • • • Cup with one way Tyveck release membrane affixed via self adhesive. Provides protection for 5 cubic feet of enclosed space. Sold in carton of 20 cups Full technical details available on separate data sheet HVPCI-111 Cups • • • • Cup with one way Tyveck release membrane affixed via self adhesive. Provides protection for 11 cubic feet of enclosed space. Sold in carton of 10 cups Full technical details available on separate data sheet HVPCI-150 Tape • VpCI impregnated foam tape affixed via self adhesive backing. • Each linear inch of tape provides protection for 0.4 cubic foot of enclosed space • Sold in carton of 6 x 12 foot rolls • Full technical details available on separate data sheet Miscellaneous HVPCI-170 Tape • VpCI impregnated foam tape affixed via self adhesive backing. • Each linear inch of tape provides protection for 1 cubic foot of enclosed space • Sold in carton of 1 x 20 foot roll • Full technical details available on separate data sheet Spray • • • • • Instant corrosion/oxidation protection without CFC’s. Displaces moisture and is anti-static. Up to 2 year indoor protection. Sold in carton of 6 cans. Full technical details available on separate data sheet Part No. Description HVPCI-101 Pad 3.0”x1.25”x0.25” - Package of 50 HVPCI-105 Cup 2.25” Dia x 0.75” - Package of 20 HVPCI-111 Cup 2.25” Dia x 1.27” - Package of 10 HVPCI-150 Tape 12’ roll x 0.75” x 0.25” - Package of 6 rolls HVPCI-170 Tape 20’ roll x 2.0” x 0.25” - Single Roll HVPCI-238 Spray - Package of 6 cans Technical references and CAD downloads available at www.hammondmfg.com 328 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice
1421S10 价格&库存
很抱歉,暂时无法提供与“1421S10”相匹配的价格&库存,您可以联系我们找货
