Shelves & Slides - Dual Pair Rail Mount
FIXED CHASSIS/SHELF
• Shelf can be used as a permanently mounted support shelf or as a pull
out chassis
• Will also accept type "RSLIDE" equipment slides (see below) for pull out
applications
• If used with our square hole rails you will need to order P/N CPRSA rail
adaptor for each shelf ordered
• 18-gauge steel shelf and 14-gauge brackets
• Weight load tested to 85 pounds
• Shelf is 16.8” wide and 0.5” high
• Finished in white powder paint for high visibility
• MOUNTS ON TWO PAIR OF MOUNTING RAILS (FRONT & BACK)
Par t Number
RASC1912WH2
RASC1916WH2
RASC1922WH2
RASC2412WH2
RASC2416WH2
RASC2422WH2
Shelf Depth
19" Width
11.9"
15.9"
21.9"
24" Width
11.9"
15.9"
21.9"
Bracket Depth
13.2"
14.9"
20.9"
13.2"
14.9"
20.9"
EQUIPMENT SLIDES
• SOLD IN PAIRS
• Slide travel equals length plus 1”
• Heavy duty - double rail, ball bearing type
• Requires mounting hardware
Par t Number
Length
RSLI DE12
RSLI DE16
RSLI DE22
Capacity
(Pair)
EQUIPMENT SIDE SUPPORT ANGLES
• SOLD IN PAIRS
• Angles mount along side of rack to both front & rear rack mounting rails
• Supplies side support for heavy equipment (relieving stress from the front
panel) or as an aid in installation of deep equipment
• Slots allow up/down and front/back adjustments
• Made of 14 gauge steel, with dimensions of 1.75" x 1.75"
• Finished in rugged textured black powder paint
adaptor for each support pair ordered
Pa r t Nu mb e r
RASA12BK3
RASA16BK3
RASA22BK3
RASA28BK3
90
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
ww
w.h
am
mo
ndm
fg.c
om
Length
9.97"
14.95"
20.95"
28.00"
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
Angles & Supports
REAR SUPPORT BAR
• Standard 19" rack mountable
• Heavy duty 14 gauge steel support mounts to rear rack rails
• Supports the rear of heavy or deep equipment (relieving stress from the
front panel and/or as an aid for equipment mounting & removing)
• Folded top edge for extra deep edge & extra strength
• Uses only 1U (1.75") of panel space
• Includes slots for easy installation of cable ties or velcro belts for cable
organizing
• Rugged textured black powder paint finish
• Requires panel mounting hardware
Pa r t Nu mb e r
RASB19BK1
Length
19"
EQUIPMENT HOLD DOWN BRACKETS
• Standard 19" & 23" rack mountable
• Designed mainly for our relay racks but can be used on any rack
• Heavy duty 16 gauge steel bracket fastens between rails for support
across equipment
• Perfect for stabilizing shelf mounted P.C. towers & monitors
organizing in between brackets
• Includes four hold down brackets (enough for two side by side towers)
• Includes rubber bracket feet to keep from marking equipment
• Includes mounting hardware
Pa r t Nu mb e r
DNTB19BK1
DNTB23BK1
Pa n e l Wi d t h
19"
23"
SQUARE HOLE PANEL RAIL ADAPTOR
• Used in conjunction with square hole panel rails to allow use of dual rail
mount accessories
• Use with our RASA, RASC, RFUS, RFVS series accessories
• Set of four
Pa r t Nu mb e r
CPRSA
Adapts
1 Shel f
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
91
很抱歉,暂时无法提供与“DNTB23BK1”相匹配的价格&库存,您可以联系我们找货
