Cable Management (Horizontal)
STEEL RING PANELS
• Standard 19" or 23” rack mount
• Five steel rings welded to a folded (for extra strength) rack panel
• Rings extend 3.5" from panel front
• Rugged textured black powder paint finish
• Requires mounting hardware
Pa n e l
Wi dt h
19
19
23
23
Pa r t Nu mb e r
PCMBS19001BK1
PCMBS19003BK1
PCMBS23001BK1
PCMBS23003BK1
Pa n e l He i g h t
Inches
Units
1.75
1
3.50
2
1.75
1
3.50
2
VELCRO STRAP PANELS
• Five velcro strap panel, folded (for extra strength)
• Includes five velcro straps
Pa r t Nu mb e r
PCMBV19001BK1
PCMBV23001BK1
Pa n e l
Wi dt h
19
23
Pa n e l He i g h t
Inches
Units
1.75
1
1.75
1
METAL FINGER PANELS
Front View (Door Open)
• Standard 19" rack mount
• Snap open, hinged rear door
• Rack mount side has five slotted openings
• Extends 3" (not including snap door buttons) from rack rails
Par t Number
Rear View (Rack Mount Side)
PCMDS19001BK1
PCMDS19003BK1
PCMDS19005BK1
Panel Height
I nches
Units
1.75
1
3.50
2
5.25
3
HINGED CABLE GUIDE
• Mounts to standard 19” rack rails
• Steel construction
• Includes mounting hardware & tie wraps
Par t Number
CGUI DE
94
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
ww
w.h
am
mo
ndm
fg.c
om
Panel Height
I nches
Units
3.50
2
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
METAL ENCLOSED PANEL
• Continuous hinged door with magnetic closure strip
• Four 3.5” x 0.75” oblong openings top & bottom - allowing for cable exit top
and/or bottom
• Extends 1.88" from rack rails
Pa r t Nu mb e r
PCMDE19001BK1
PCMDE19003BK1
Height
Inches
Units
1.75
1
3.00
2
Pa n e l
Wi dt h
19"
19"
Front View (Door Closed)
CABLE TROUGH
• Choice of 19” or 23" rack mount
• Provides support for horizontal runs of heavy cable bundles
• Uses 3.5" (2U) of panel space
Pa r t Nu mb e r
PCMT19003BK1
PCMT23003BK1
Pa n e l Wi d t h
19"
23"
VELCRO STRAP KIT
• Perfect for bundling cables where repeated changes are required or to
avoid over compression of cables from plastic cable ties
• Package of five velcro straps
• 1” wide, 12” long strap
• Holds a maximum of 3.5” diameter bundle
• Black velcro straps with buckle
• Part Number CMSTRAP5
CABLE ACCESS PANEL
• Formed 16 gauge steel construction
• 15" x 2" cutout opening, with a protected edge
• Allows for easy entry of cables through 19" panel opening
• Rugged textured powder paint finish
Par t Number
Black Textured
Grey/ Beige
DNCE19BK1
DNCE19CG1
Panel Height
I nches
Units
3.5
2
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
95
Cable Management (Vertical)
SINGLE CABLE RING
• Mounts to standard 19” rack rails & relay racks
• 3.5" long X 1.25" wide
Pa n e l He i g h t
Inches
Units
1.75
1
3.50
2
Pa r t Nu mb e r
CMRBK1
CMR3BK1
VERTICAL CABLE ORGANIZER
• Mounts to depth amhal rack struts, vertically inside rack cabinet
• Used on 24” 19” Extra Wide rack cabinets so as not to interfere with rack
mounted equipment
• Heavy duty - steel body with steel hinged door and 5” plastic pull handle
• Door includes full height magnetic closure strip
• Rounded openings are 3” x 2” - allowing for cable exit from sides and/or
back of organizer
• Extends 2.5” from amhal struts
• Includes strut mounting hardware
• Rugged black powder paint finish
Pa r t Nu mb e r
VCMDS70BK1
VCMDS78BK1
Door Closed
Pa n e l He i g h t
Inches
Units
70.00
40
78.75
45
Door Open
• Low profile - designed for use on 19” rack cabinets so as not to interfere
with rack mounted equipment
• Heavy duty - 16 gauge steel
• Rounded openings are 2” x 2” - allowing for cable exit from sides and/or
back of organizer along with 1.5” oblong cable tie-off cutouts
• Extends only 0.5” from amhul struts
Pa r t Nu mb e r
Top End
View
96
VCT70
VCT78
ww
w.h
am
mo
ndm
fg.c
om
Pa n e l He i g h t
Inches
Units
70.00
40
78.75
45
256 Sonwil Dr.
USA
很抱歉,暂时无法提供与“PCMT19003BK1”相匹配的价格&库存,您可以联系我们找货
