RCSCATIP
RCSCATIP
    HAMMONDMANUFACTURING
    BRACKETS ANTI-TIP
RCSCATIP 数据手册
SOHO Rack Cabinet (RCSC Series) For complete drawing information link here to our website covering this series. FEATURES • Perfect for SOHO (Small Office, Home Office) applications for servers, storage & networking. • Supplied unassembled (four cabinet pieces & four rails), requires only a phillips screwdriver to assemble. • Simple assembly using one bolt in each corner to lock the sides to the top and bottom (hardware included) - see assembly instructions. • Shipped in a flat pack container for handling ease & protection (see photo below). • Heavy duty construction, 16-gauge steel, 19” rack mount cabinet. • Choice of two panel heights 21” (12U) or 42” (24U) panel height. • The 21” 12U version is 25” high overall (no casters) and is designed to fit under most desks. • Expandable in the future - easily stacks and/or gangs to other RCSC units (see accessories). Requires baying kit (RCSCBAY) to lock cabinets together. • Panel rails are custom made, 14 gauge steel - infinitely adjustable (front to back), square hole punched for cagenuts to full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing), painted with smooth black powder paint. • Includes two pairs of panel rails (for rear support of heavier equipment), a starter pack of (50) 10-32 cagenuts & matching 1421ABK black screws. • Overall width of 24” (610 mm) provides ample space for most cabling requirements. • Generous cable-entry “punch-outs” with gasket strip material included. • Optional doors (three versions available), fans and casters (see accessories). • Perforated door suggested for most server applications. Perforated doors meet server manufacturer Free-Air-Ratio (FAR) requirements of 65%. • Front & back lip is .75” (19.1 mm) so usable depth is reduced by 1.5” (38.1 mm). • Recommended maximum weight - 1,500 pounds (682 kg). • Rugged textured black powder paint finish. 32 CANADA Guelph, Ontario (519) 822-2960 St. Laurent, Quebec (514) 343-9010 © USA Cheektowaga, NY (716) 630-7030 ww w.h a EUROPE mm ond Basingstoke, UK 01256 812812 mfg .co m AUSTRALIA Queenstown SA, Australia 61-8-8240-2244 SOHO Rack Cabinet (RCSC Series) 24.5” (622 mm) Deep Usable Mounting Depth = 23” (584 mm) Panel Height Part Number RCSC1902124BK1 RCSC1904224BK1 Overall Dimensions Height Inches Units (No Casters) 21.00 12U 25.28” (642 mm) 42.00 24U 46.28” (1,176 mm) Weight Width Depth 24.0” (610 mm) 24.0” (610 mm) 24.5” (622 mm) 24.5” (622 mm) 86# (39.1 kg) 120# (54.5 kg) 31.5” (800 mm) Deep Usable Mounting Depth = 30.0” (762 mm) Panel Height Part Number Inches Units RCSC1902131BK1 RCSC1904231BK1 21.00 42.00 12U 24U Overall Dimensions Height (No Casters) 25.28” (642 mm) 46.28” (1,176 mm) Weight Width Depth 24.0” (610 mm) 24.0” (610 mm) 31.5” (800 mm) 31.5” (800 mm) 100# (45.5 kg) 145# (65.9 kg) 36” (914 mm) Deep - Extended Rear Cable Space Version Usable Mounting Depth = 30.0” (762 mm) Panel Height Part Number Inches Units RCSC1902136BK1 RCSC1904236BK1 21.00 42.00 12U 24U Overall Dimensions Height (No Casters) 25.28” (642 mm) 46.28” (1,176 mm) Weight Width Depth 24.0” (610 mm) 24.0” (610 mm) 36.0” (914 mm) 36.0” (914 mm) 110# (50.0 kg) 135# (61.4 kg) RCSC SERIES ACCESSORIES Casters (Sold in sets of four) Locking Doors • Doors are available in three versions. Perforated (to meet server manufacturer Free-Air-Ratio (FAR) requirements of 65%), solid and vented versions. • Doors can be added later even if rack is fully loaded - as mounting uses a unique “snap-in” secure hinge mount from the outside. • Rack assembly screws are behind the door for complete security. • 16-gauge steel construction. • Front & back of “RCSC” rack cabinet is pre-punched to accept these doors. Includes mounting hardware. • Mounts either right or left hand hinge (door & cabinet are symmetrical). • Includes installed lock and two keys • Finished in rugged textured black powder paint. Part Number RCSC19021PDBK1 RCSC19021SDBK1 RCSC19021VDBK1 RCSC19042PDBK1 RCSC19042SDBK1 RCSC19042VDBK1 Part Number Rated Weight Load Description 1425P 1425BH 400# (182 kg) 1,050# (477 kg) Light Duty (stem mount) Heavy Duty (four bolt mount) RSRC Option Kits Part Number RCSCATIP RCSCBAY RCSCFAN Description Description Anti-Tip brackets - mount to front (or back) of unit Required to connect two RCSC units together - allows units to be stacked vertically or ganged horizontally. 2 (two) 115 VAC fan kit with power cord 12U Perforated Door & lock 12U Solid Door & lock 12U Vented Door & lock 24U Perforated Door & lock 24U Solid Door & lock 24U Vented Door & lock UNIVERSAL ACCESSORIES • Rack panels Page 90 • Ventilated rack panels Page 92 • Panel mount doors & chassis Page 94 • Shelves & slides Page 95 • Drawers Page 101 EUROPE Basingstoke, UK 01256 812812 AUSTRALIA Queenstown SA, Australia 61-8-8240-2244 • Cable management Page 102 • Cooling & ventilating Page 105 • Rack mount outlet strips Page 110 • Hardware Page 127 • Visit our web site for our most recent accessories ww w.h a 33 CANADA mm ond mfg .co Guelph, Ontario (519) 822-2960 St. Laurent, Quebec (514) 343-9010 m USA Cheektowaga, NY (716) 630-7030 ©
RCSCATIP 价格&库存
很抱歉,暂时无法提供与“RCSCATIP”相匹配的价格&库存,您可以联系我们找货
