Hardware
Part #: 1421
Part #: 1421E25W
(package of 4 screws & 4
metal cup washers)
(package of 25)
Part #: 1421E100W
(package of 100)
• 10-32 x 0.625"
• Slotted oval head screws
• Steel cup washers (0.60"
outside diameter)
• Nickel plated
• Metal cup washers
• 0.60" outside diameter
• Use with 10-32 countersunk
screws
• Nickel plated
Part #: 1421A
Part #: 1421A25W
plastic cup washers)
(package of 25)
Part #: 1421A100W
(package of 100)
• 10-32 x 0.625"
• Slotted & phillips combina
tion oval head screws
• Nickel plated screws
• Black plastic cup washers
(0.58" outside diameter)
• 0.58" outside diameter
screws
Part #: 1421A25B
Part #: 1421B
(package of 25)
nylon washers)
Part #: 1421A100B
(package of 100)
• 10-32 x 0.625"
• Nickel plated
• 10-32 x 0.5" thumb screws
• With captivated nylon
washers
• Nickel plated
• Works with panels up to
0.09" thick
• Head is 0.62" dia. x 0.37"
high
Part #: 1421F25
Part #: 1421D
(package of 25)
(package of 25)
• 10-32 x 1.25"
• Phillips oval head screws
• Nickel plated
• 10-32 x 0.5"
combination pan
head screws
• Use where economy
is important OR for
close panel spacing.
• Zinc plated
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
ww
w.h
am
mo
ndm
fg.c
om
119
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
Hardware
Part #: H1224S20
Part #: 1421CNC25
(package of 20 screws)
(package of 25)
Part #: 1421CNC100
• 12-24 x 5/8"
tion pan head screws
• Zinc plated
• Used mainly on our
aluminum open relay racks
(RRAL series)
(package of 100)
Part #: 1421N25
Part #: 1421CNB25
(package of 25)
(package of 25)
Part #: 1421N100
Part #: 1421CNB100
(package of 100)
(package of 100)
• 10-32 clip nuts
• USE ON ROUND HOLE
PUNCHED RAILS ONLY
• Has the holding strength of
a 10-32 nut
• Black finish
• M6 cage nuts
• USE ON SQUARE HOLE
PUNCHED RAILS ONLY
a M6 nut
• Zinc plated
Part #: 1421NP25
Part #: RCNIT
(package of 25)
(cage nut insertion tool)
• 12-24 cage nuts
PUNCHED RAILS ONLY
a 12-24 nut
• Zinc plated
Part #: 1421NP100
(package of 100)
• 10-32 clip nuts
• USE ON ROUND HOLE
PUNCHED RAILS ONLY
a 10-32 nut
• Zinc plated
Part #: 1421CNA25
Part #: 1463S
(package of 25)
(package of 3 bolts, spring
nuts & washers)
Part #: 1421CNA100
(package of 100)
• 10-32 cage nuts
PUNCHED RAILS ONLY
a 10-32 nut
• Zinc plated
120
• Allows for easy installation
of cage nuts in square rail
hole
• Spring steel tool
ww
w.h
am
mo
ndm
fg.c
om
• 3/8 x 16 spring loaded nuts
(for Rack "C" channels)
• 0.75" hex head bolts &
washers
• used to mount one rack rail
(used in racks with Amhal
strut rail mounting)
256 Sonwil Dr.
USA
很抱歉,暂时无法提供与“1421CNABK100”相匹配的价格&库存,您可以联系我们找货
