Hammond Mfg. - Rack Cabinet Intake Blowers (HB Series)
Page 1 of 3
Rack Cabinet - Intake Blowers
(HB Series)
Path: Home > Rack Index > Rack Cabinet Intake Blowers (HB Series)
Features:
Free
Flow
Part
Running RPM
Air
Number
Amps Nominal
Delivery
(CFM)
HB2160A
HB3250A
HB4500A
145 /
125
0.7
155 /
200
1.2
405 /
465
2.5
Standard 19" rack mount
Air delivery from more than 50% of their 17" width
Internal neoprene isolation mounts reduce transmission of
vibration to the rack
Air intake only, to pressurize the rack with filtered air
Heavy steel construction
Attractive 19" stainless steel grille included
115 VAC, 50/60 Hz. motor is UL recognized, CSA
certified, ball bearing type, cooled by incoming air
Includes permanent filter (replacement filters available
below)
Comes with 6' STJW 3- wire cord
Control your rack temperature with our economical,
compact thermostat
Link here to photo tables of each part number.
3D
Solid
Panel
Ambient
AutoCAD Model
Height
Blower
Shipping
Temperature Reader .dwg File .stp
Type
Weight
(F)
File (zipped) & .iges
files
Inches Units
(zipped)
2500 / Transverse
-20 to +250
3000
Flow
2750 /
Double
-20 to +250
3000 Centrifugal
2750 /
Double
-20 to +250
3300 Centrifugal
369K
672K
3.4M
245K
766K
5.3M
418K
875K
6.5M
10
3.50
2
15
5.25
3
21
7.00
4
Accessories:
EXTRA REPLACEMENT FILTERS
http://www.hammondmfg.com/rackblo.htm
Sold in a package of five
Same permanent filters that are included with blowers above
3/19/2013
Page 2 of 3
For extra filtering see our filter coating (below)
(click to enlarge)
Part Number
Use With Blower
Part Number
HB2UFILTER
HB3UFILTER
HB4UFILTER
HB2160A
HB3250A
HB4500A
Description
5 Pack of 2U (3.5") Filters
5 Pack of 3U (5.25") Filters
5 Pack of 4U (7.0") Filters
FILTER COAT - Part Number 1475Q
Provides a filter adhesive coating with a grease-like consistency
which absorbs and traps dust particles.
10 oz. bottle with environmentally friendly trigger spray.
Partial Height Door Blower Adaptor Kit
(Contempra Rack)
Adaptor Kit
Color
Use only with "Contempra" rack series...
Mounts to the bottom of the rack panel opening,
door mounts above it..
Kit mounts flush with both the rack frame and the
door...
Allows use of 5.25" (3U) blowers...
Use the chart below to determine what rack door is
required for your rack size panel opening with this
kit...
Includes all rack & blower mounting hardware...
For Rack Panel Height of:
Use With Flush Door
3/19/2013
Part Number
Part Number
Page 3 of 3
Inches
Units
CBA1975BK1 Black
CBA1975CG1 Gray/Beige
CDF or C2DF1935...
42
24
Same as above
Same as above
Same as above
Same as above
CDF or C2DF1942...
CDF or C2DF1949...
CDF or C2DF1956...
CDF or C2DF1963...
49
56
63
70
28
32
36
40
CDF or C2DF1970...
78.75
45
Same as above
Same as above
Same as above
Same as above
CBA1985BK1 Black
CBA1985CG1 Gray/Beige
all accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K)
Mail Link To Our Catalog Department
Provide full mailing address here for your FREE CATALOG via snail mail...
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check and
ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 1998-2011 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
3/19/2013
很抱歉,暂时无法提供与“HB3UFILTER”相匹配的价格&库存,您可以联系我们找货
