VCT70
VCT70
    HAMMONDMANUFACTURING
    VERT CABLE LOW PROFILE 70X3"
VCT70 数据手册
Cable Management (Horizontal) STEEL RING PANELS • Standard 19" or 23” rack mount • Five steel rings welded to a folded (for extra strength) rack panel • Rings extend 3.5" from panel front • Rugged textured black powder paint finish • Requires mounting hardware Pa n e l Wi dt h 19 19 23 23 Pa r t Nu mb e r PCMBS19001BK1 PCMBS19003BK1 PCMBS23001BK1 PCMBS23003BK1 Pa n e l He i g h t Inches Units 1.75 1 3.50 2 1.75 1 3.50 2 VELCRO STRAP PANELS • Standard 19" or 23” rack mount • Five velcro strap panel, folded (for extra strength) • Includes five velcro straps • Rugged textured black powder paint finish • Requires mounting hardware Pa r t Nu mb e r PCMBV19001BK1 PCMBV23001BK1 Pa n e l Wi dt h 19 23 Pa n e l He i g h t Inches Units 1.75 1 1.75 1 METAL FINGER PANELS Front View (Door Open) • Standard 19" rack mount • Snap open, hinged rear door • Rack mount side has five slotted openings • Extends 3" (not including snap door buttons) from rack rails • Rugged textured black powder paint finish • Requires mounting hardware Par t Number Rear View (Rack Mount Side) PCMDS19001BK1 PCMDS19003BK1 PCMDS19005BK1 Panel Height I nches Units 1.75 1 3.50 2 5.25 3 HINGED CABLE GUIDE • Mounts to standard 19” rack rails • Steel construction • Includes mounting hardware & tie wraps • Rugged textured black powder paint finish Par t Number CGUI DE 94 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Panel Height I nches Units 3.50 2 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Cable Management (Horizontal) METAL ENCLOSED PANEL • Standard 19" rack mount • Continuous hinged door with magnetic closure strip • Four 3.5” x 0.75” oblong openings top & bottom - allowing for cable exit top and/or bottom • Extends 1.88" from rack rails • Rugged textured black powder paint finish • Requires mounting hardware Pa r t Nu mb e r PCMDE19001BK1 PCMDE19003BK1 Height Inches Units 1.75 1 3.00 2 Pa n e l Wi dt h 19" 19" Front View (Door Closed) Rear View (Rack Mount Side) CABLE TROUGH • Choice of 19” or 23" rack mount • Provides support for horizontal runs of heavy cable bundles • Uses 3.5" (2U) of panel space • Rugged textured black powder paint finish • Requires mounting hardware Pa r t Nu mb e r PCMT19003BK1 PCMT23003BK1 Pa n e l Wi d t h 19" 23" VELCRO STRAP KIT • Perfect for bundling cables where repeated changes are required or to avoid over compression of cables from plastic cable ties • Package of five velcro straps • 1” wide, 12” long strap • Holds a maximum of 3.5” diameter bundle • Black velcro straps with buckle • Part Number CMSTRAP5 CABLE ACCESS PANEL • Standard 19" rack mount • Formed 16 gauge steel construction • 15" x 2" cutout opening, with a protected edge • Allows for easy entry of cables through 19" panel opening • Rugged textured powder paint finish • Requires mounting hardware Par t Number Black Textured Grey/ Beige DNCE19BK1 DNCE19CG1 © Panel Height I nches Units 3.5 2 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 95 Cable Management (Vertical) SINGLE CABLE RING • Mounts to standard 19” rack rails & relay racks • Steel construction • 3.5" long X 1.25" wide • Rugged textured black powder paint finish • Requires mounting hardware Pa n e l He i g h t Inches Units 1.75 1 3.50 2 Pa r t Nu mb e r CMRBK1 CMR3BK1 VERTICAL CABLE ORGANIZER • Mounts to depth amhal rack struts, vertically inside rack cabinet • Used on 24” 19” Extra Wide rack cabinets so as not to interfere with rack mounted equipment • Heavy duty - steel body with steel hinged door and 5” plastic pull handle • Door includes full height magnetic closure strip • Rounded openings are 3” x 2” - allowing for cable exit from sides and/or back of organizer • Extends 2.5” from amhal struts • Includes strut mounting hardware • Rugged black powder paint finish Pa r t Nu mb e r VCMDS70BK1 VCMDS78BK1 Door Closed Pa n e l He i g h t Inches Units 70.00 40 78.75 45 Door Open VERTICAL CABLE ORGANIZER • Mounts to depth amhal rack struts, vertically inside rack cabinet • Low profile - designed for use on 19” rack cabinets so as not to interfere with rack mounted equipment • Heavy duty - 16 gauge steel • Rounded openings are 2” x 2” - allowing for cable exit from sides and/or back of organizer along with 1.5” oblong cable tie-off cutouts • Extends only 0.5” from amhul struts • Includes strut mounting hardware • Rugged black powder paint finish Pa r t Nu mb e r Top End View 96 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 VCT70 VCT78 ww w.h am mo ndm fg.c om Pa n e l He i g h t Inches Units 70.00 40 78.75 45 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
VCT70 价格&库存
很抱歉,暂时无法提供与“VCT70”相匹配的价格&库存,您可以联系我们找货
