SRGROUNDPANELBC
SRGROUNDPANELBC
    TRIPPLITE
    CABINET COPPER BUS GROUNDING BAR
SRGROUNDPANELBC 数据手册
SmartRack 1U ESD Grounding Panel Highlights ● Mounts to rack enclosures and open frame racks ● Compatible with EIA-standard 19 in. racks ● Grounding for banana-plug and alligator-clip ESD bands ● 48 in. ground wires for easy connection ● Includes all mounting hardware MODEL NUMBER: SRGROUNDPANELBC Package Includes Mounts to EIA-standard 19 in. rack to provide ground contact for ESD bands. Ideal for factories, warehouses and anywhere else static discharge could damage equipment. Description The SRGROUNDPANELBC SmartRack 1U ESD Grounding Panel attaches to rack enclosures and open frame racks to provide ground contact and prevent static discharge. It’s ideal for factories, warehouses and anywhere else static discharge could damage expensive and delicate electronic equipment. Compatible with all EIA-standard 19-inch racks, the panel includes grounding for both banana-plug and alligator-clip ESD bands. Ground wires are 48 inches for easy connection. All mounting hardware is included. Features Prevents Static Discharge While Handling Delicate Electronics ● Mounts to 1U of space in rack enclosures and open frame racks ● Ideal for factories, warehouses and anywhere else static discharge could damage equipment ● Compatible with EIA-standard 19 in. racks ● Provides ground contact for banana-plug and alligator-clip ESD bands ● 48 in. ground wires for easy connection ● Includes all mounting hardware Specifications OVERVIEW UPC Code 037332191731 Accessory Type Grounding Bars & Panels Accessory Class Rack Accessories PHYSICAL 1/2 ● SRGROUNDPANELBC SmartRack 1U ESD Grounding Panel ● (2) M6 screws ● (2) M6 cage nuts ● (2) M6 cup washers Shipping Dimensions (hwd / cm) 7.87 x 7.87 x 55.12 Shipping Dimensions (hwd / in.) 3.10 x 3.10 x 21.70 Shipping Weight (kg) 0.64 Shipping Weight (lbs.) 1.40 Unit Dimensions (hwd / in.) 1.72 x 2.00 x 19.00 Unit Dimensions (hwd / cm) 4.37 x 5.08 x 48.26 Unit Weight (lbs.) 0.50 Unit Weight (kg) 0.23 WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRGROUNDPANELBC 价格&库存
很抱歉,暂时无法提供与“SRGROUNDPANELBC”相匹配的价格&库存,您可以联系我们找货
