RSLIDE16
RSLIDE16
    HAMMONDMANUFACTURING
    SLIDE RAIL MOUNTED 16X19" PAIR
RSLIDE16 数据手册
ASSEMBLED VIEW .54 in 14 mm .27 in 7 mm 5X O0.25X 0.31 SLOT 1.75 in 44 mm O0.19 X 1.50 SLOT 4.00 in 102 mm 2.69 in 68 mm 2.07 in 52 mm 2.18 in 55 mm .22 in 6 mm .94 in 24 mm .50 in 13 mm .18 in 4 mm SLIDE RAIL MOUNT BRACKETS 15.06 in 383 mm .43 in 11 mm 1.19 in 30 mm O .86 in 22 mm .17 in 4 mm 7.56 in 192 mm INSIDE VIEW O 1.95 in 50 mm .50 in 13 mm O .25 in 6 mm TYP .38 in 10 mm TYP 2.23 in 57 mm 6.30 in 160 mm 3.49 in 89 mm .36 in 9 mm TYP 1.00 in 25 mm 4X O0.17 X 0.37 SLOT NOTES Long life ball bearing slides Sold in Pairs Maximum Weight 130 lbs (Pair) Comes with assembly hardware. 2 slides, 4 brackets Some Assembly Required 1.26 in 32 mm Data subject to change without notice. Isometric drawing not to scale. .18 in 5 mm TYP 1.26 in 32 mm .94 in 24 mm .50 in 13 mm 2.81 in 71 mm 15.88 in 403 mm CLOSED LENGTH OUTSIDE VIEW 16.67 in 423 mm EXTENSION LENGTH www.hammondmfg.com PART NO. RSLIDE16
RSLIDE16 价格&库存
很抱歉,暂时无法提供与“RSLIDE16”相匹配的价格&库存,您可以联系我们找货
RSLIDE16
  • 1+862.573771+111.71207
  • 5+728.029165+94.28717
  • 10+677.1711810+87.70055
  • 25+626.8546725+81.18405
库存:46
