RSLIDE22
RSLIDE22
    HAMMONDMANUFACTURING
    SLIDE RAIL MOUNTED 22X19" PAIR
RSLIDE22 数据手册
ASSEMBLED VIEW .54 in 14 mm .27 in 7 mm 5X O0.25X 0.31 SLOT 1.75 in 44 mm O0.19 X 1.50 SLOT 4.00 in 102 mm 2.69 in 68 mm 2.07 in 52 mm 2.18 in 55 mm .22 in 6 mm .94 in 24 mm .50 in 13 mm .18 in 4 mm SLIDE RAIL MOUNT BRACKETS 21.06 in 535 mm .44 in 11 mm 1.18 in 30 mm O .17 in 4 mm 1.02 in 26 mm 1.95 in 50 mm 2.98 in 76 mm 11.44 in 291 mm INSIDE VIEW .38 in 10 mm TYP 7.56 in 192 mm 10.04 in 255 mm 3.48 in 88 mm .36 in 9 mm TYP 6X O0.17 X 0.37 SLOT .50 in 13 mm NOTES Long life ball bearing slides Sold in Pairs Maximum Weight 120 lbs (Pair) Comes with assembly hardware. 2 slides, 4 brackets Some Assembly Required 1.26 in 32 mm Data subject to change without notice. Isometric drawing not to scale. O .18 in 5 mm TYP O .25 in 6 mm TYP 21.88 in 556 mm CLOSED LENGTH 1.26 in 32 mm .94 in 24 mm .50 in 13 mm OUTSIDE VIEW 22.64 in 575 mm EXTENSION LENGTH www.hammondmfg.com PART NO. RSLIDE22
RSLIDE22 价格&库存
很抱歉,暂时无法提供与“RSLIDE22”相匹配的价格&库存,您可以联系我们找货
