RSLIDE28
RSLIDE28
    HAMMONDMANUFACTURING
    SLIDE RAIL MOUNTED 28X19" PAIR
RSLIDE28 数据手册
ASSEMBLED VIEW .54 in 14 mm .27 in 7 mm 5X O0.25X 0.31 SLOT 1.75 in 44 mm O0.19 X 1.50 SLOT 4.00 in 102 mm 2.68 in 68 mm 1.96 in 50 mm 1.96 in 50 mm .21 in 5 mm .50 in 13 mm .96 in 24 mm .18 in 4 mm SLIDE RAIL MOUNT BRACKETS 27.06 in 687 mm .62 in 16 mm O .18 in 5 mm .37 in 9 mm .62 in 16 mm 1.38 in 35 mm 1.84 in 47 mm 13.86 in 352 mm 10.08 in 256 mm 6X O0.17 X 0.37 SLOT .50 in 13 mm I/S VIEW - SLIDE EXTENDED .63 in 16 mm TYP O .18 in 5 mm TYP 7.56 in 192 mm O 5.04 in 128 mm 6.30 in 160 mm 2.52 in 64 mm 1.38 in 35 mm .94 in 24 mm .25 in 6 mm TYP 28.00 in 711 mm CLOSED LENGTH O/S VIEW - SLIDE EXTENDED 28.00 in 711 mm EXTENSION LENGTH NOTES Long life ball bearing slides Sold in Pairs Maximum Weight 130 lbs (Pair) Comes with assembly hardware. 2 slides, 4 brackets Some Assembly Required Data subject to change without notice. Isometric drawing not to scale. www.hammondmfg.com PART NO. RSLIDE28
RSLIDE28 价格&库存
很抱歉,暂时无法提供与“RSLIDE28”相匹配的价格&库存,您可以联系我们找货
RSLIDE28
  • 1+813.985171+97.29914
  • 5+695.859665+83.17909
  • 10+650.3966910+77.74471
  • 25+632.5116925+75.60684
库存:65
