SmartRack Enclosure Skirt Kit - use with 3 in.
casters
MODEL NUMBER: SRSKIRT3
Highlights
To be used with heavy duty 3"
casters
Brush strip blocks unwanted
airflow under rack enclosure
Improves cooling efficiency
Segregates cold aisle from hot
aisle
Package Includes
Description
Tripp Lite's SmartRack SRSKIRT3 is a brush strip that blocks unwanted airflow under rack enclosure
cabinets that are using the heavy duty 3" casters. The SRSKIRT3 improves cooling efficiency by
segregating cold aisle from hot aisle.
Features
Brush strip blocks unwanted airflow under rack enclosure cabinets that are using the heavy duty 3"
casters
Improves cooling efficiency by segregating cold aisle from hot aisle
Specifications
OVERVIEW
UPC Code
037332180797
Accessory Type
Enclosure Skirt Kit
Accessory Class
Cooling Accessories
COOLING
Cooling Type
Passive
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
2.54 x 62.48 x 10.67
Shipping Dimensions (hwd / in.)
1.00 x 24.60 x 4.20
1/2
1 Piece of SRSKIRT3
Mounting Hardware
Shipping Weight (kg)
1.00
Shipping Weight (lbs.)
2.20
Unit Dimensions (hwd / in.)
3.5 x 23.6 x .4
Unit Dimensions (hwd / cm)
16.1 x 59.9 x 1
Unit Weight (lbs.)
1.6
Unit Weight (kg)
0.73
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“SRSKIRT3”相匹配的价格&库存,您可以联系我们找货
