Miscellaneous
GROUND BUS BAR
• Full Length copper bar - mounts vertically 0.13" thick x 0.63" wide
• Mounts to amhal struts of "C2" Contempra racks or REFK racks
• For maximum versatility - contains no holes (other than mounting holes)
• Includes strut mounting hardware
Use Wi t h Rac k
( Pa n e l S p a c e )
35"
42"
49"
56"
63"
70"
78.75"
Pa r t Nu mb e r
CBB35
CBB42
CBB49
CBB56
CBB63
CBB70
CBB78
GROUND LUGS
• Dual L16 type aluminum lug
• 1 1/8" wide x 1 3/16" long
• Provides excellent grounding
• Accepts wire sizes from 1/0 to 14
• Usually used in conjunction with bus bar (above)
• Packaged individually
• Mounting hardware not included (requires drilling of bus bar)
Pa r t Nu mb e r
DNGL
Pa c k a g e
Quanti ty
1
LIGHT KIT
• Designed to fit inside the cabinets
• Features a manually operated switch, 115VAC convenience outlet, durable
plastic lens (replacement lens below) and 6' power cord (without plug)
• Finished in white
• CSA & UL component recognized
• Installs with 1/4-20 bolts placed through holes (user drilled) in top of
cabinet (or use magnet mount below)
• Screws and sealing washers provided
• Uses standard 15 watt - 18" florescent lamps (NOT INCLUDED)
• 1 3/4" high x 4 1/2" deep
• Includes mounting hardware
Pa r t Nu mb e r
FLK18
FLK18LENSE
Descr iption
18" Fl or escent Li ght Ki t
Re p l a c e me n t p l a s t i c l e n s
LIGHT KIT MAGNET MOUNT
• Designed to allow solid mounting of light kit (above) without drilling
• Also allows light to be easily moved within the rack
• Full length of light kit
Pa r t Nu mb e r
FLK18MM
122
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
Descr iption
Fl o r e s c e n t l i g h t k i t - ma g n e t mo u n t
ww
w.h
am
mo
ndm
fg.c
om
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
Miscellaneous
TOUCH UP PAINT
• For use in matching standard Hammond Mfg. colors
• Supplied in 12 oz. spray cans
Pa r t Nu mb e r
1413BKLGS
1413BKS
1413CGRALS
1413GFS
1413LRS
1413NS
Color
B l a ck - L ow G l o s s
B l a ck
Co n t e mp ra Be i g e
Gul f Bl ue
A S A 6 1 G r ey
Wh i t e
LITERATURE POCKET KIT
• Typically applied inside the door or side panels of the rack
• For literature storage
• Kit includes plastic pocket, high strength two-sided adhesive tape and
surface preparation swab
• Plastic pocket is black
Pa r t Nu mb e r
PKT66
PKT99
Height
6"
6"
Wi dt h
6"
9"
SIDE PANEL LOCK KIT
• For higher security, the quarter turn fasteners on our side panels can be
replaced with this key locking version
• Kit contains 4 quarter turn locks and 8 keys (all keyed alike)
• Good for 1 rack (ie...2 locks per side panel)
Par t Number
Use With
CSPQTRL
For "C2" Contempra 2 Rack Side Panels
C3SPQTRL
For "C3" (NEMA 12) Contempra 3 Rack Side Panels
EXTRA CAM FLUSH LOCK
• Quarter turn fastener
• Mounts flush in a 0.760" x 0.655" double D hole or alternately a 0.75"
diameter hole
• Kit contains 1 quarter turn lock and 2 keys (all keyed alike)
• Chrome plated brass housing with reversible cam
Pa r t Nu mb e r
1427BK
Use Wi t h
Fl u s h mo u n t d o o r s o r p a n e l s
ww
w.h
am
mo
ndm
fg.c
om
123
256 Sonwil Dr.
USA
很抱歉,暂时无法提供与“CBB56”相匹配的价格&库存,您可以联系我们找货
