CBB63
CBB63
    HAMMONDMANUFACTURING
    BARCPPERBUSUSEW/FRAMC2F1963
CBB63 数据手册
Miscellaneous GROUND BUS BAR • Full Length copper bar - mounts vertically 0.13" thick x 0.63" wide • Mounts to amhal struts of "C2" Contempra racks or REFK racks • For maximum versatility - contains no holes (other than mounting holes) • Includes strut mounting hardware Use Wi t h Rac k ( Pa n e l S p a c e ) 35" 42" 49" 56" 63" 70" 78.75" Pa r t Nu mb e r CBB35 CBB42 CBB49 CBB56 CBB63 CBB70 CBB78 GROUND LUGS • Dual L16 type aluminum lug • 1 1/8" wide x 1 3/16" long • Provides excellent grounding • Accepts wire sizes from 1/0 to 14 • Usually used in conjunction with bus bar (above) • Packaged individually • Mounting hardware not included (requires drilling of bus bar) Pa r t Nu mb e r DNGL Pa c k a g e Quanti ty 1 LIGHT KIT • Designed to fit inside the cabinets • Features a manually operated switch, 115VAC convenience outlet, durable plastic lens (replacement lens below) and 6' power cord (without plug) • Finished in white • CSA & UL component recognized • Installs with 1/4-20 bolts placed through holes (user drilled) in top of cabinet (or use magnet mount below) • Screws and sealing washers provided • Uses standard 15 watt - 18" florescent lamps (NOT INCLUDED) • 1 3/4" high x 4 1/2" deep • Includes mounting hardware Pa r t Nu mb e r FLK18 FLK18LENSE Descr iption 18" Fl or escent Li ght Ki t Re p l a c e me n t p l a s t i c l e n s LIGHT KIT MAGNET MOUNT • Designed to allow solid mounting of light kit (above) without drilling • Also allows light to be easily moved within the rack • Full length of light kit Pa r t Nu mb e r FLK18MM 122 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Descr iption Fl o r e s c e n t l i g h t k i t - ma g n e t mo u n t ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Miscellaneous TOUCH UP PAINT • For use in matching standard Hammond Mfg. colors • Supplied in 12 oz. spray cans Pa r t Nu mb e r 1413BKLGS 1413BKS 1413CGRALS 1413GFS 1413LRS 1413NS Color B l a ck - L ow G l o s s B l a ck Co n t e mp ra Be i g e Gul f Bl ue A S A 6 1 G r ey Wh i t e LITERATURE POCKET KIT • Typically applied inside the door or side panels of the rack • For literature storage • Kit includes plastic pocket, high strength two-sided adhesive tape and surface preparation swab • Plastic pocket is black Pa r t Nu mb e r PKT66 PKT99 Height 6" 6" Wi dt h 6" 9" SIDE PANEL LOCK KIT • For higher security, the quarter turn fasteners on our side panels can be replaced with this key locking version • Kit contains 4 quarter turn locks and 8 keys (all keyed alike) • Good for 1 rack (ie...2 locks per side panel) Par t Number Use With CSPQTRL For "C2" Contempra 2 Rack Side Panels C3SPQTRL For "C3" (NEMA 12) Contempra 3 Rack Side Panels EXTRA CAM FLUSH LOCK • Quarter turn fastener • Mounts flush in a 0.760" x 0.655" double D hole or alternately a 0.75" diameter hole • Kit contains 1 quarter turn lock and 2 keys (all keyed alike) • Chrome plated brass housing with reversible cam Pa r t Nu mb e r 1427BK © Use Wi t h Fl u s h mo u n t d o o r s o r p a n e l s Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om 123 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
CBB63 价格&库存
很抱歉,暂时无法提供与“CBB63”相匹配的价格&库存,您可以联系我们找货
CBB63
    • 1+954.056831+118.72235
    • 5+815.576945+101.48998
    • 10+762.3025510+94.86054
    • 25+758.8813425+94.43481
    库存:1
