CONTEMPRA 2 - SERIES
ASSEMBLY INSTRUCTIONS FOR
CCE - CABLE ENTRY DOOR ADAPTER
BUL10283
REV. A
PAGE 1 OF 1
B
1
A
Placement of CCE
DETAIL B
Holes to knock out
ASSEMBLY INSTRUCTIONS:
A) Ensure all parts are available. See BOM list.
B) Remove the 4 knock out holes located at the bottom of frame
opening (use proper striking tool). Detail A shows location of knock
out holes
C) Line up CCE at the base of the cabinet so the holes line up with
the K.O. holes. Install screws supplied from the inside of the CCE
and fasten using nut supplied (Detail B).
DETAIL A
PARTS LIST
ITEM No.
DESCRIPTION
CCE----BK1
1
SCREW 8-32 X 1/2 LG
2
NUT 8-32 KEPS
3
TOOL BOX
Flat Head
Screw Driver
Hammer
QTY
1
6
6
Striking
Tool
D) If additional support is desired, then drill one 1/4" hole on each
side using CCE as a template and fasten additional hardware
supplied
HAMMOND
MANUFACTURING
TM
ELECTRONICS GROUP
visit our website @ www.hammondmfg.com
很抱歉,暂时无法提供与“CBA1975CG1”相匹配的价格&库存,您可以联系我们找货
