1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack Roof-Mounted Cable Trough Vertical
Expansion Plates - Requires SRCABLETRAY
MODEL NUMBER: SRCABLETRAYEXP
Highlights
Adds an additional level of cable
routing to the SRCABLETRAY
When used with the
SRCABLETRAY these
expansion plates allow
dedicated, separate paths for
power, data and fiber cables
Helps eliminate cable stress
Organizes cables outside of
SmartRack enclosure
Toolless mounting on the
SmartRack enclosure's top
panel
Package Includes
Description
Tripp Lite's SmartRack SRCABLETRAYEXP adds an additional level of cable routing to the
SRCABLETRAY (required part). When used with the SRCABLETRAY these expansion plates allow
dedicated, separate paths for power, data and fiber cables. The SRCABLETRAYEXP helps eliminate
cable stress by organizing cables outside of the SmartRack enclosure. Convenient, toolless mounting on
the top panel of the SmartRack enclosure.
Features
When used with the SRCABLETRAY these expansion plates allow dedicated, separate paths for power,
The SRCABLETRAYEXP helps eliminate cable stress by organizing cables outside of the SmartRack
enclosure
Convenient, toolless mounting on the top panel of the SmartRack enclosure
Specifications
OVERVIEW
UPC Code
037332140791
Accessory Type
Cable Management Accessories
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
3.30 x 12.10 x 21.80
Shipping Dimensions (hwd / cm)
8.38 x 30.73 x 55.37
1/2
SRCABLETRAYEXP expansion
sections (2)
#8-32 x 1/4 Phillips Screws (8)
Cleveland, OH 44122
United States
Shipping Weight (lbs.)
8.80
Shipping Weight (kg)
3.99
Unit Dimensions (hwd / in.)
2.200 x 12.130 x 21.140
Unit Dimensions (hwd / cm)
5.59 x 30.81 x 53.70
Unit Weight (lbs.)
4
Unit Weight (kg)
1.81
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SRCABLETRAYEXP”相匹配的价格&库存,您可以联系我们找货
