SRVRTBAR45
SRVRTBAR45
    TRIPPLITE
    RACKENCLOSURECABINET
SRVRTBAR45 数据手册
SmartRack 45U Vertical Cable Management Bars Highlights ● Provides additional mounting for vertical cable management and Zero U PDU products ● Rapid installation of devices and accessories with toolless mounting keyhole slots ● Two, black, vertical cable management / accessory bars included ● Supports all Tripp Lite SmartRack 45U floor-standing enclosures MODEL NUMBER: SRVRTBAR45 System Requirements Supports all Tripp Lite SmartRack 45U floor-standing enclosures Package Includes Ideal for high density cable installations in network, data center, wiring closet and telecom environments that need additional vertical mounting capacity for PDUs, accessories and cabling in a Tripp Lite 45U rack enclosure. Description Do you need to improve, increase or re-organize the cable management of your Tripp Lite 45U SmartRack enclosure? Then Tripp Lite’s 45U Vertical Cable Management Bars accessory is the solution for you! It provides two additional vertical cable management / accessory bars that can easily be attached to any Tripp Lite 45U rack enclosure. These accessory bars provide additional mounting for PDU's, cable management or any other accessories to be mounted vertically into a Tripp Lite rack enclosure. These accessory bars were designed to be adapted to a wide variety of cable management needs. Quick and easy installation of devices and accessories is accomplished with toolless mounting keyhole slots. The classic black finish is both attractive and seamlessly matches most currently installed rack enclosures. Features ● Provides additional mounting for vertical cable management and Zero U PDU products ● Keyhole slots for toolless device and accessory installation ● Color: black ● Supports all Tripp Lite SmartRack 45U floor-standing enclosures ● RoHS compliant Specifications OVERVIEW UPC Code 037332185587 Accessory Type Cable Management Accessories PHYSICAL Color Black 1/2 ● (2) Vertically mounted bars ● Mounting Hardware Cable Jacket Color Black Shipping Dimensions (hwd / cm) 13.46 x 22.10 x 216.92 Shipping Dimensions (hwd / in.) 5.30 x 8.70 x 85.40 Shipping Weight (kg) 6.80 Shipping Weight (lbs.) 15.00 Unit Dimensions (hwd / in.) 81.25 x 4.625 x 1.625 Unit Dimensions (hwd / cm) 206.38 x 11.75 x 4.13 Unit Weight (lbs.) 8 Unit Weight (kg) 3.63 Cable Manager Form Factor Vertical FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRVRTBAR45 价格&库存
很抱歉,暂时无法提供与“SRVRTBAR45”相匹配的价格&库存,您可以联系我们找货
SRVRTBAR45
  • 1+1729.301321+223.73129
