1424T
1424T
    HAMMONDMANUFACTURING
    DOLLYHEAVYDUTY4-2.0"DIAMETER
1424T 数据手册
Heavy Duty - Welded (DNRR Series) FEATURES • Suitable for many 19” or 23” rack mount applications, providing complete access to equipment • Nothing to assemble • 10-gauge steel - welded construction • Provides an economical option to an enclosed rack • Engineered for use as a solid, single, freestanding unit • Choice of front flange or both flanges - drilled & tapped • Universal EIA hole spacing (5/8 - 5/8 - 1/2 inch) • Weight load tested (DNRR84HDW) to 1,530 pounds • Tough textured black powder finish paint Tapped - Front Flange Only Par t Number DNRR42HDW DNRR63HDW DNRR70HDW DNRR77HDW DNRR84HDW Panel Height I nches Units 42 63 70 77 84 24 36 40 44 48 Tapped - Front & Rear Flange Overall Panel Hole Height Width Thread (I nches) (I nches) 48.13 19 10-32 69.13 19 10-32 76.13 19 10-32 83.13 19 10-32 90.13 19 10-32 Par t Number DNRR77HDWB DNRR84HDWB DNRR2377HDWB DNRR2384HDWB Panel Height I nches 77 84 77 84 Units 44 48 44 48 Overall Panel Hole Height Width Thread (I nches) (I nches) 83.13 90.13 83.13 90.13 19 19 23 23 10-32 10-32 12-24 12-24 ACCESSORIES • Rack panels Page 82 • Ventilated rack panels Page 84 • Panel mount doors & chassis Page 86 • Shelves & slides Page 87 • Drawers Page 93 16 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 • Cable management Page 94 • Rack mount outlet strips Page 102 • Hardware Page 119 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Heavy Duty - Accessories HEAVY DUTY DOLLY • For use only with “heavy duty” relay racks (pages 16 & 17) • 10 gauge folded and welded steel • Rack mounting holes are offset to counter act equipment weight on rear of rack (ie..dolly is photographed from the rear) • Complete with quantity four - 2” diameter casters • Caster manufacturer’s specified capacity of 600 lbs. • Finished in textured black powder paint Pa r t Nu mb e r 1424T Wheel Di amet er 2 Inches Capacity 6 0 0 l b s. GANGING KIT • For use only with “Heavy Duty Welded” relay racks • Kit contains enough hardware to join two relay racks • Used to join relay racks side by side • No drilling required • Connects through supplied 6 holes (2 in top, middle & bottom) of frame • Part Number RRALJK VERTICAL WIRE MANAGER • For use only with “heavy duty” & aluminum relay racks • Used to organize bundles of connecting wire • Manufactured in 16 Ga. steel • Mounts to either side of open relay rack (includes mounting hardware) • Front of units include a hinged door secured with magnets • Finished in rugged black textured powder paint • Two units shown here, with a heavy duty - open relay rack • Can be used with top wire management accessories on the next page (except aluminum relay racks) Pa r t Nu mb e r RRCM44UD RRCM48UD 18 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Pa n e l He i g h t Inches Units 77 44 84 48 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Heavy Duty - Accessories TOP WIRE MANAGEMENT • For use only with “heavy duty” relay racks • 16 gauge steel construction • Usable with an infinite combination and number of ganged or single relay racks • Top of cable manager contains square knockouts (one shown knocked out in photo below) for use with optional chimneys • Hinged access door with magnetic catches to keep wires neat and easy access • Use either joining kits or end panels (see below) in any combination to fit your needs • Finished in textured black powder paint Top Horizontal Manager Pa r t Nu mb e r Descr iption RR19TMS RR19TMD RR19TMDD RR19TMDT 1 R a ck - S i n g l e 2 6 . 5 " L o n g 1 R a ck - D o u bl e 3 2 . 5 " L o n g 2 R a ck - D o u bl e 5 3 " L o n g 2 Ra ck - Tr i p l e 5 9 " L o n g Number of Rel ay Racks Used 1 1 2 2 Application N u m b e r o f Ve r t i c a l Manager s Used 1 2 2 3 L o c a t i o n o f Ve r t i c a l Manager s Lef t or Ri ght Lef t and Ri ght Lef t and Ri ght , No Cent er Lef t , Ri ght and Cent er Chimney • For use only with “heavy duty” relay racks & top manager • 16 gauge steel construction • Mounts to square knockouts in top manager • For routing wire bundles up & out of the top manager (above) - through the ceiling • Finished in textured black powder paint Pa r t Nu mb e r RRCH20 RRCH24 RRCH30 Height 20" 24" 30" End Plates & Joining Kit • For use only with “heavy duty” relay racks & top manager • 16 gauge steel construction • Mounts to ends of top manager (above) • Use end plates to close the ends of top managers • Use the joining kit to join multiple top managers • Finished in textured black powder paint Pa r t Nu mb e r RRTMEP RRTMJK © Descr iption En d Pl a t e ( Pa i r ) Joi ni ng Ki t Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 End Plates ww w.h am mo ndm fg.c om Joining Kit Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 19 Heavy Duty - Accessories HEAVY DUTY SHELF - DUAL CHANNEL MOUNT • For use only with relay racks (DNRR series) - tapped front & rear • Permits front and rear access to modems on open relay racks • Side brackets allow mounting to either 3" OR 8" deep channel (see photos) • The vented unit is shown assembled for 8" deep channel, the unvented unit is shown assembled for 3" deep channel • Uses 5.25" (3U) of vertical panel space • Choice of 19" or 24" deep (19" deep shown) • The vented version provides a sturdy shelf without obstructing upward heat movement • 14-gauge steel construction with a rugged black powder paint finish • Weight load tested (DNRMU2324BK1) to 300 pounds • Requires mounting hardware Unvented Pa r t Nu mb e r DNRMU19BK1 DNRMU1924BK1 DNRMU23BK1 DNRMU2324BK1 Wi dt h ( I nches) 19 19 19 19 23 23 Depth (Inches) 19 19 24 24 19 24 Vented Pa r t Nu mb e r DNRMV19BK1 DNRMV1924BK1 DNRMV23BK1 DNRMV2324BK1 Wi dt h ( I nches) 19 19 19 19 23 23 Depth (Inches) 19 19 24 24 19 24 MONITOR SHELF - DUAL CHANNEL MOUNT Pa r t Nu mb e r DNRMM19BK1 DNRMM23BK1 Wi dt h Depth (Inches) (Inches) 19 19 19 19 23 19 • For use only with relay racks (DNRR series) - tapped front & rear • Mounts to panel rails using 5.25" (3U) of vertical panel space • Side brackets allow mounting to either 3" OR 8" deep channel. Unit in photo is shown assembled for 3" deep channel • Uses 5.25" (3U) of vertical panel space • Overall 19" deep • Front & rear lip to reduce chance of monitor being pushed off of shelf • Available in either 19" or 23" rack panel width • Includes an accessory compartment welded to the front, bottom of the shelf • 14 Ga. steel construction • Finished in rugged black textured powder paint • Weight load tested (DNRMM23BK1) to 300 pounds • Requires mounting hardware DON’T FORGET TO CHECK OUT OUR UNIVERSAL ACCESSORY SECTION FOR PANEL MOUNT SHELVES PAGE 87 20 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
1424T 价格&库存
很抱歉,暂时无法提供与“1424T”相匹配的价格&库存,您可以联系我们找货
