SRTHERMDUCT
SRTHERMDUCT
    TRIPPLITE
    42U-48URACKENCLOSURECABINET
SRTHERMDUCT 数据手册
SmartRack Thermal Duct Kit for SmartRack Enclosures MODEL NUMBER: SRTHERMDUCT Highlights ● Improves cooling efficiency in Tripp Lite standard rack enclosures ● Adjustable roof-mounted thermal duct moves air upward and out of the rack enclosure ● Compatible with standard 4248U SmartRack Enclosures System Requirements Standard 42-48U Tripp Lite Rack Enclosure Package Includes Need to help your equipment perform at its peak while reducing your facility's cooling and energy cost? The SRTHERMDUCT kit can change a standard Tripp Lite SmartRack 42-48U enclosure into sealed passive cooling structure that allows heat that is exhausted from equipment to be vented upwards into the facility CRAC / HVAC air return system. Description The SRTHERMDUCT Thermal Duct Kit can change a standard SmartRack 42-48U enclosure into a sealed passive cooling structure that allows heat built up inside a rack to be directed up and into the facility CRAC / HVAC return air system. Features ● Improves cooling efficiency of standard Tripp Lite rack enclosures ● Adjustable roof-mount thermal duct connects to HVAC return air system ● Included gaskets and panels help seal enclosure for proper airflow management through thermal duct ● Compatible with standard 42-48U SmartRack Enclosures Specifications OVERVIEW UPC Code 037332154903 Accessory Type Duct Kit Accessory Class Rack Accessories COOLING Cooling Type Passive PHYSICAL 1/2 ● Height-adjustable roof-mount thermal duct ● Roof-mount cable access panel ● Enclosure bottom ● Door gasket seals ● (16) Magnetic vinyl sheet rear door seals ● (4) M8 screws ● (4) M4 screws ● (16) M4 nuts ● Owner's manual Housing Color Black Roof Thermal duct adjusts between 20.5-34.5 inches when assembled. Shipping Dimensions (hwd / cm) 37.01 x 59.99 x 121.01 Shipping Dimensions (hwd / in.) 14.57 x 23.62 x 47.64 Shipping Weight (kg) 30.39 Shipping Weight (lbs.) 67.00 FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRTHERMDUCT 价格&库存
很抱歉,暂时无法提供与“SRTHERMDUCT”相匹配的价格&库存,您可以联系我们找货
