1555FFPL
1555FFPL
    HAMMONDMANUFACTURING
    INNER PANEL STEEL 16 GA.
1555FFPL 数据手册
120.00 [4.72] 107.00 [4.21] 52.00 [2.05] (INSIDE HEIGHT) B 82.91 [3.26] 3.00 [.12] 90.00 [3.54] 77.00 [3.03] 78.91 [3.11] A A (INSIDE WIDTH) B TOP VIEW 15.00 [.59] 3.00 [.12] .50 [.02] 60.50 [2.38] SECTION B-B SIDE VIEW 2.50 [.10] 108.41 [4.27] UL O C 16.66 45.00 [1.77] 6.00 [.24] POLYCARBONATE VERSION ONLY 19.38 [.76] [.66] STEEL PANEL ORDER SEPARATELY 38.71 [1.52] 77.47 [3.05] 112.91 [4.45] ® US LISTED FILE #E65324 NEMA 4, 4X Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE (INSIDE LENGTH) SECTION A-A SIDE VIEW Purchased assembly includes box, styled lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 91.74 [3.61] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 114.88 [4.52] 95.88 [3.77] 107.00 [4.21] 77.00 [3.03] 68.00 [2.68] 84.88 [3.34] 45.88 [1.81] 57.00 [2.24] M3 BRASS INSERTS ACCEPTS #6 SELF-TAPPING SCREW 100.00 [3.94] INSIDE BOX 92.00 [3.62] 4X 4.00 [4X .16] MOUNTING HOLES 1555F 111.00 [4.37] 1555F Regular Enclosure General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 1555FGY 1555F2GY ACCESSORIES 83.00 [3.27] 42.00 [1.65] R7.50 [.30] Steel Inner Panels Steel Panel / P.C. Board Machine Screw [M3 x 8mm Plated] Steel Panel / P.C. Board Self Tapping Screw [#6 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] Silicone Pre-formed Gasket Black 1554FPL 1591MM100 1598ATS100 SC1554 1554FGASKET 34.00 [1.34] M4 STAINLESS STEEL INSERTS INSIDE LID Dimensions: mm [inches] 1555F www.hammondmfg.com ®
1555FFPL
1. 物料型号: - 1555FGY(ABS材质) - 1555F2GY(Polycarbonate材质)
2. 器件简介: - Hammond 1555F®是一种多功能塑料外壳,适用于多种应用场合。外壳由ABS或Polycarbonate材质制成,具有多种安装孔和固定方式。
3. 引脚分配: - 4个安装孔,接受#6自攻螺丝。
4. 参数特性: - ABS材质:UL94 - HB - Polycarbonate材质:UL94 - 5VA @ 3mm - 推荐盖螺丝扭矩:2.5 lbf-in (30 cN-m),仅限Polycarbonate版本。
5. 功能详解: - 外壳可以进行工厂修改(铣削、钻孔、印刷等),具体报价请联系工厂。 - 提供STEP或IGES格式的实体模型。 - 外壳包括盒子、风格化的盖子、4个盖子螺丝和预成型的硅胶垫圈。 - ABS版本的通用外壳不是UL认证的,而Polycarbonate版本是UL 508认证的。
6. 应用信息: - 外壳符合NEMA 4, 4X标准,美国UL LISTED FILE #E65324®。
7. 封装信息: - 提供钢制内嵌件和M3黄铜内嵌件。 - 提供M4不锈钢螺丝。
1555FFPL 价格&库存
很抱歉,暂时无法提供与“1555FFPL”相匹配的价格&库存,您可以联系我们找货
