1598
Instrument Enclosures
Accessories
Key Features
• Desk top electronic instrument enclosure, ideally
suited for mounting printed circuit boards.
• Molded from flame retardant ABS plastic (material
carries a UL flammability rating of 94V-0).
• Designed to meet IP54.
• An RFI/EMI shielded version is also available - the
1598R series.
• Two sets of vertical 1.5 mm (0.062”) P.C. board
guides are molded into case halves front and rear.
• Front and rear panels are 1.6 mm (0.064”) brushed
aluminum with protective paper on one side.
• Cases halves are secured with M3 x 0.5” x 10
mm (0.39”) Philips machine screws threaded into
tapped integral brass bushings. Perfect for applications with repetitive assembly and disassembly are
required.
• Integral horizontal P.C. card mounts on Eurocard
centers.
• P.C. card standoffs molded into top & bottom half
of enclosure - require #6 x 1/4” (6.4mm) screws part number 1598ATS100
• Stocked in matte textured black and grey.
Tilt Bails
Extra
Aluminum
End Panels
Extra Plastic
End Panels
Replacement Machine Screws
1591MS100 (100-pack)
Replacement Self-Tapping
Screws
1591TS100 (100-pack)
• If EMI/ RFI shielding is required, try “1598R” on page
51
PC Board Screws
198ATS100 (100-pack)
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
24
1598
Enclosures feature PC board
guides and integral mounting
bosses.
Shown here with tilt bail installed
Standard
Version
Economy
Version
Economy w/
Black Plastic
Panels
1598BSGY
1598BSGYPBK
1598ASGY
1598ASGYPBK
1598BBK
1598BGY
1598ABK
1598AGY
1598EGY
1598ESGYPBK
1598BBSGY
1598BBSGYPBK
1598CSGY
1598CSGYPBK
1598BBBK
1598BBGY
1598DGY
1598DSGYPBK
1598FSGY
1598FSGYPBK
1598GSGY
1598GSGYPBK
1598HSGY
1598HSGYPBK
1598JSGY
1598JSGYPBK
1598FBK
1598FGY
6.3
160
6.3
160
3.38
86
1598TH1
1598PLE-AL
1598PLEBK
Inches
mm
7.05
179
6.06
154
1.42
36
1598TH1
1598PLBB-AL
1598PLBBBK
Inches
mm
7.09
180
6.1
155
2.04
52
1598TH1
1598PLC-AL
1598PLCBK
Inches
mm
7.09
180
8.11
206
2.52
64
1598TH2
1598PLD-AL
1598PLDBK
Inches
mm
9.84
250
6.3
160
1.58
40
1598TH1
1598PLF-AL
1598PLFBK
Inches
mm
9.84
250
6.3
160
3.00
76
1598TH1
1598PLG-AL
1598PLGBK
Inches
mm
11.02
280
7.87
200
1.58
40
1598TH2
1598PLH-AL
1598PLHBK
Inches
mm
11.02
280
7.87
200
3.00
76
1598TH2
1598PLJ-AL
1598PLJBK
Inches
mm
6.18
157
Inches
mm
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Grey
Black
www.hammondmfg.com
1598PLABK
5.31
135
Black
1598JBK
1598JGY
1598PLA-AL
5.28
134
Black
1598HBK
1598HGY
1.42
36
Inches
mm
Grey
Black
1598GBK
1598GGY
3.7
94
Black
Black
1598DSGY
1598PLBBK
Height
Black
1598DBK
1598PLB-AL
Width
Black
1598CBK
1598CGY
1.96
50
Length
Black
1598ESGY
Plastic End
Panels
(pair)
Units
Black
1598EBK
Aluminum
End Panels
(pair)
Color
Grey
Tilt Bail
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
25
很抱歉,暂时无法提供与“1598PLBBK”相匹配的价格&库存,您可以联系我们找货
