1598PLBBBK
1598PLBBBK
    HAMMONDMANUFACTURING
    PANEL END USE WITH 1598BB SERIES
1598PLBBBK 数据手册
1598 Instrument Enclosures Accessories Key Features • Desk top electronic instrument enclosure, ideally suited for mounting printed circuit boards. • Molded from flame retardant ABS plastic (material carries a UL flammability rating of 94V-0). • Designed to meet IP54. • An RFI/EMI shielded version is also available - the 1598R series. • Two sets of vertical 1.5 mm (0.062”) P.C. board guides are molded into case halves front and rear. • Front and rear panels are 1.6 mm (0.064”) brushed aluminum with protective paper on one side. • Cases halves are secured with M3 x 0.5” x 10 mm (0.39”) Philips machine screws threaded into tapped integral brass bushings. Perfect for applications with repetitive assembly and disassembly are required. • Integral horizontal P.C. card mounts on Eurocard centers. • P.C. card standoffs molded into top & bottom half of enclosure - require #6 x 1/4” (6.4mm) screws part number 1598ATS100 • Stocked in matte textured black and grey. Tilt Bails Extra Aluminum End Panels Extra Plastic End Panels Replacement Machine Screws 1591MS100 (100-pack) Replacement Self-Tapping Screws 1591TS100 (100-pack) • If EMI/ RFI shielding is required, try “1598R” on page 51 PC Board Screws 198ATS100 (100-pack) www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 24 1598 Instrument Enclosures Enclosures feature PC board guides and integral mounting bosses. Shown here with tilt bail installed Standard Version Economy Version Economy w/ Black Plastic Panels 1598BSGY 1598BSGYPBK 1598ASGY 1598ASGYPBK 1598BBK  1598BGY 1598ABK  1598AGY 1598EGY 1598ESGYPBK 1598BBSGY 1598BBSGYPBK 1598CSGY 1598CSGYPBK 1598BBBK 1598BBGY 1598DGY 1598DSGYPBK 1598FSGY 1598FSGYPBK 1598GSGY 1598GSGYPBK 1598HSGY 1598HSGYPBK 1598JSGY 1598JSGYPBK 1598FBK  1598FGY 6.3 160 6.3 160 3.38 86 1598TH1 1598PLE-AL 1598PLEBK Inches mm 7.05 179 6.06 154 1.42 36 1598TH1 1598PLBB-AL 1598PLBBBK Inches mm 7.09 180 6.1 155 2.04 52 1598TH1 1598PLC-AL 1598PLCBK Inches mm 7.09 180 8.11 206 2.52 64 1598TH2 1598PLD-AL 1598PLDBK Inches mm 9.84 250 6.3 160 1.58 40 1598TH1 1598PLF-AL 1598PLFBK Inches mm 9.84 250 6.3 160 3.00 76 1598TH1 1598PLG-AL 1598PLGBK Inches mm 11.02 280 7.87 200 1.58 40 1598TH2 1598PLH-AL 1598PLHBK Inches mm 11.02 280 7.87 200 3.00 76 1598TH2 1598PLJ-AL 1598PLJBK Inches mm 6.18 157 Inches mm Grey Grey Grey Grey Grey Grey Grey Grey Black www.hammondmfg.com 1598PLABK 5.31 135 Black 1598JBK  1598JGY 1598PLA-AL 5.28 134 Black 1598HBK  1598HGY 1.42 36 Inches mm Grey Black 1598GBK  1598GGY 3.7 94 Black Black 1598DSGY 1598PLBBK Height Black 1598DBK  1598PLB-AL Width Black 1598CBK  1598CGY 1.96 50 Length Black 1598ESGY Plastic End Panels (pair) Units Black 1598EBK  Aluminum End Panels (pair) Color Grey Tilt Bail USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 25
1598PLBBBK 价格&库存
很抱歉,暂时无法提供与“1598PLBBBK”相匹配的价格&库存,您可以联系我们找货
