1593NIR10
1593NIR10
    HAMMONDMANUFACTURING
    Plastic, Non Specified Panel, End 2.707" L x 0.781" W x 0.059" H (68.76mm x 19.84mm x 1.50mm) Infra-...
1593NIR10 数据手册
75.00 [2.95] 64.00 [2.52] 19.70 [.78] INLAY WIDTH INSIDE HEIGHT B .75 [.03] INLAY DEPTH 103.50 [4.07] 2.25 [.09] 111.25 [4.38] 99.20 [3.91] A INSIDE LENGTH A 4.50 [.18] INLAY LENGTH 25.20 [.99] B TOP VIEW 18.14 [.71] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. SECTION B-B SIDE VIEW (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 65.75 [2.59] .90 [.04] NOTE Enclosure molded from GP ABS (UL94-HB) plastic. Purchased assembly includes top and bottom cover, 4 plastic panels for front and rear (2 types - flat and contoured) and 2 cover screws. Recommended Cover Screw Torque - 57lbf-in ( 40cN-m) 66.40 [2.61] 68.82 [2.71] INSIDE WIDTH END VIEW 1593 12.60 [.50] 1593N Regular Enclosure Black Enclosure Grey Enclosure Translucent Blue Enclosure SECTION A-A END VIEW 61.70 [2.43] ACCESSORIES Cover Screws #4 X 3/4" Self-Tapping (100 Pkg) 102.50 [4.04] 15.35 [.60] 1593NBK 1593NGY 1593NTBU P.C. Board Screws #4 X 1/4" Self-Tapping Nylon Belt Clip Black 14.35 [.57] ACCEPTS #4 SELF-TAPPING SCREW 55.85 [2.20] 46.25 [1.82] 9.95 [.39] 66.14 [2.60] P.C. BOARD (NOT SUPPLIED) 1593N STD FLAT PANEL (SINGLE PANEL) Grey Translucent Blue Infrared 1593N STD CONTOURED PANEL  (SINGLE PANEL) Black Grey Translucent Blue 1593QS100 (Silver) 1593QS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) 1593NLBK‐BULK 1593NLBK‐BULK 1593NLBK‐BULK 1593NIR10 1593NCLBK‐BULK 1593NCLGY‐BULK 1593NCLTBU‐BULK 4.90 [.19] 40.00 [1.57] INSIDE BOTTOM 11.00 [.43] 30.00 [1.18] 3.20 [.13] ® Dimensions: mm [inches] 1593N www.hammondmfg.com
1593NIR10 价格&库存
很抱歉,暂时无法提供与“1593NIR10”相匹配的价格&库存,您可以联系我们找货
