1590Z160PL
1590Z160PL
    HAMMONDMANUFACTURING
    PANEL INNER STEEL 5.8X5.7
1590Z160PL 数据手册
140.00 [5.51] 81.70 [3.22] 160.00 [6.30] 4.05 [.16] (INSIDE DEPTH) (AVERAGE WALL THICKNESS) A 140.00 [5.51] B B 149.01 [5.87] (INSIDE WIDTH) 160.00 [6.30] 89.75 [3.53] A 20.00 [.79] TOP VIEW 140.00 [5.51] 9.00 [.35] 4.37 [.17] (AVERAGE WALL THICKNESS) SECTION A-A END VIEW 1.80 [.07] 5.60 [.22] 71.55 [2.82] UL O C 117.51 [4.63] 146.00 [5.75] 84.00 [3.31] 149.03 [5.87] 140.00 [5.51] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE SECTION B-B SIDE VIEW ACCEPTS M6 MACHINE GROUND SCREW 119.81 [4.72] ACCEPTS M6 - 1 MACHINE SCREW Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. 114.50 [4.51] 146.00 [5.75] Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) INSIDE LID C 1590Z160 1590Z160 Enclosure Basic Enclosure 38.00 [1.50] Black Enclosure Grey Enclosure - RAL7001 Gloss 21.12 [.83] 110.00 [4.33] 89.51 [3.52] C INSIDE BOX DRAWINGS AVALIBLE FOR STEEL INNER PANEL 1590Z160 1590Z160BK 1590Z160GY ACCESSORIES 151.31 [5.96] 131.00 [5.16] 140.00 [5.51] US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (INSIDE LENGTH) 153.25 [6.03] ® FILE #E65324 NEMA 4, 4X 11.69 [.46] 20.50 [.81] Steel Inner Panel 1590Z160PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z160G SCGM6 7.00 [.28] SECTION C-C MOUNTING HOLE ® Dimensions: mm [inches] 1590Z160 www.hammondmfg.com
1590Z160PL 价格&库存
很抱歉,暂时无法提供与“1590Z160PL”相匹配的价格&库存,您可以联系我们找货
