www.hammondmfg.com
Polyester Modular Enclosures - NEMA 4X
R130 Series Enclosures
Corrosion Resistant
Junction Boxes
Application
Construction
Finish
• Designed for use as instrument
enclosures, electrical junction boxes
or terminal wiring enclosures.
• Provide outstanding protection
against dust, oil and pressurized
water.
• Impervious to atmospheric and
marine corrosion.
• Two piece molded fiberglass
reinforced polyester construction.
• Captive polyfibre cover screws are
provided with a standard slot head.
• Cover screws fasten into
pre-threaded holes.
• The threaded cover screw holes
also provide single channel access
to rear mounting positions.
• Recessed neoprene gasket with
tongue and groove construction is
oil and petroleum resistant.
• Threaded stainless steel inserts
provide for internal mounting.
• Spring loaded stainless steel hinge
pins are standard, allowing for quick
lid removal.
• Light beige RAL 7032
Standards
• CSA Type 4, 4X
• Complies with
• NEMA 1, 2, 3, 3R, 4, 4X, 5, 12,
13
• IEC 60529, IP66
• VO Flammability Rating
Part No.
Series Units
R130-120-000 PD-120
R130-122-000 PD-122
R130-124-000 PD-124
R130-160-000 PD-160
R130-162-000 PD-162
R130-164-000 PD-164
R130-200-000 PD-200
R130-202-000 PD-202
inch
Width Length Height
A
B
C
4.72
5.51
3.94
D
4.65
E
3.86
F
4.33
G
4.25
I
2.81
External mounting feet...see next page
Inner panels...see next page
Cross rails...see next page
Bonded acrylic glass windows are
available on special request.
J
3.82
K
3.74
mm
120
140
100
118
98
110
108
92
71.5
97
95
inch
4.72
7.87
3.94
7.01
3.86
6.69
4.25
5.98
2.81
6.18
3.74
mm
120
200
100
178
98
170
108
152
71.5
157
95
inch
4.72
10.24
3.94
9.37
3.86
9.06
4.25
8.35
2.81
8.54
3.74
mm
120
260
100
238
98
230
108
212
71.5
217
95
inch
6.30
7.09
3.94
6.22
5.43
5.91
5.83
5.20
4.39
5.39
5.31
mm
160
180
100
158
138
150
148
inch
6.30
10.24
3.94
9.37
5.43
9.06
5.83
100
238
138
230
mm
160
260
inch
6.30
13.39
3.94 12.52
5.43 12.20
148
132 111.5
137
135
4.39
8.54
5.31
212 111.5
217
135
4.39 11.69
5.31
8.35
5.83 11.50
mm
160
340
100
318
138
310
148
inch
7.87
8.66
4.72
7.80
7.01
7.46
7.38
6.73
120
198
178 189.5 187.5
171
mm
200
220
inch
7.87
12.60
mm
200
320
4.72 11.73
120
298
7.01 11.40
292 111.5
7.38 10.67
178 289.5 187.5
Technical references and CAD downloads available at www.hammondmfg.com
113
H
3.62
Accessories
297
135
5.94
6.97
6.89
151
177
175
5.94 10.91
6.89
271
151
277
175
K1
L
2.28
58 M6
2.28
58 M6
2.28
58 M6
3.86
98 M6
3.86
98 M6
3.86
98 M6
5.43
138 M6
5.43
138 M6
M
N
P
2.76 3.62 0.28
70
92
7
2.76 3.62 0.28
70
92
7
2.76 3.62 0.28
70
92
7
2.76 3.62 0.28
70
92
7
2.76 3.62 0.28
70
92
7
2.76 3.62 0.28
70
92
7
3.54 4.41 0.28
90
112
7
3.54 4.41 0.28
90
112
7
All dimensions in inches unless specified otherwise
Quality Products. Service Excellence.
© Hammond Manufacturing
Canada: 519.822.2960 or 905.456.3770
USA: 716.630.7030
Data Subject to change without notice
www.hammondmfg.com
Corrosion Resistant
Part No.
R130-120-000
R130-122-000
R130-124-000
R130-160-000
R130-162-000
R130-164-000
R130-200-000
R130-202-000
External Feet (Set of 4)
Stainless Steel
Inner Panel (1.5 mm)
Steel, Zinc Plated
Cross Rail (Pair)
(Low Bottom Part)
R501-000-001
R501-000-001
R501-000-001
R501-000-001
R501-000-001
R501-000-001
R501-000-001
R501-000-001
R530-120-000
R530-122-000
R530-124-000
R530-160-000
R530-162-000
R530-164-000
R530-200-000
R530-202-000
R531-120-000
R531-120-000
R531-120-000
R531-160-000
R531-160-000
R531-160-000
R531-200-000
R531-200-000
Junction Boxes
Accessories
USA: 716.630.7030
114
很抱歉,暂时无法提供与“R530-160-000”相匹配的价格&库存,您可以联系我们找货
