R530-162-000
R530-162-000
    HAMMONDMANUFACTURING
    PANEL INNER 0.059"
R530-162-000 数据手册
www.hammondmfg.com Polyester Modular Enclosures - NEMA 4X R130 Series Enclosures Corrosion Resistant Junction Boxes Application Construction Finish • Designed for use as instrument enclosures, electrical junction boxes or terminal wiring enclosures. • Provide outstanding protection against dust, oil and pressurized water. • Impervious to atmospheric and marine corrosion. • Two piece molded fiberglass reinforced polyester construction. • Captive polyfibre cover screws are provided with a standard slot head. • Cover screws fasten into pre-threaded holes. • The threaded cover screw holes also provide single channel access to rear mounting positions. • Recessed neoprene gasket with tongue and groove construction is oil and petroleum resistant. • Threaded stainless steel inserts provide for internal mounting. • Spring loaded stainless steel hinge pins are standard, allowing for quick lid removal. • Light beige RAL 7032 Standards • CSA Type 4, 4X • Complies with • NEMA 1, 2, 3, 3R, 4, 4X, 5, 12, 13 • IEC 60529, IP66 • VO Flammability Rating Part No. Series Units R130-120-000 PD-120 R130-122-000 PD-122 R130-124-000 PD-124 R130-160-000 PD-160 R130-162-000 PD-162 R130-164-000 PD-164 R130-200-000 PD-200 R130-202-000 PD-202 inch Width Length Height A B C 4.72 5.51 3.94 D 4.65 E 3.86 F 4.33 G 4.25 • • • • I 2.81 External mounting feet...see next page Inner panels...see next page Cross rails...see next page Bonded acrylic glass windows are available on special request. J 3.82 K 3.74 mm 120 140 100 118 98 110 108 92 71.5 97 95 inch 4.72 7.87 3.94 7.01 3.86 6.69 4.25 5.98 2.81 6.18 3.74 mm 120 200 100 178 98 170 108 152 71.5 157 95 inch 4.72 10.24 3.94 9.37 3.86 9.06 4.25 8.35 2.81 8.54 3.74 mm 120 260 100 238 98 230 108 212 71.5 217 95 inch 6.30 7.09 3.94 6.22 5.43 5.91 5.83 5.20 4.39 5.39 5.31 mm 160 180 100 158 138 150 148 inch 6.30 10.24 3.94 9.37 5.43 9.06 5.83 100 238 138 230 mm 160 260 inch 6.30 13.39 3.94 12.52 5.43 12.20 148 132 111.5 137 135 4.39 8.54 5.31 212 111.5 217 135 4.39 11.69 5.31 8.35 5.83 11.50 mm 160 340 100 318 138 310 148 inch 7.87 8.66 4.72 7.80 7.01 7.46 7.38 6.73 120 198 178 189.5 187.5 171 mm 200 220 inch 7.87 12.60 mm 200 320 4.72 11.73 120 298 7.01 11.40 292 111.5 7.38 10.67 178 289.5 187.5 Technical references and CAD downloads available at www.hammondmfg.com 113 H 3.62 Accessories 297 135 5.94 6.97 6.89 151 177 175 5.94 10.91 6.89 271 151 277 175 K1 L 2.28 58 M6 2.28 58 M6 2.28 58 M6 3.86 98 M6 3.86 98 M6 3.86 98 M6 5.43 138 M6 5.43 138 M6 M N P 2.76 3.62 0.28 70 92 7 2.76 3.62 0.28 70 92 7 2.76 3.62 0.28 70 92 7 2.76 3.62 0.28 70 92 7 2.76 3.62 0.28 70 92 7 2.76 3.62 0.28 70 92 7 3.54 4.41 0.28 90 112 7 3.54 4.41 0.28 90 112 7 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Polyester Modular Enclosures - NEMA 4X R130 Series Enclosures Corrosion Resistant Part No. R130-120-000 R130-122-000 R130-124-000 R130-160-000 R130-162-000 R130-164-000 R130-200-000 R130-202-000 External Feet (Set of 4) Stainless Steel Inner Panel (1.5 mm) Steel, Zinc Plated Cross Rail (Pair) (Low Bottom Part) R501-000-001 R501-000-001 R501-000-001 R501-000-001 R501-000-001 R501-000-001 R501-000-001 R501-000-001 R530-120-000 R530-122-000 R530-124-000 R530-160-000 R530-162-000 R530-164-000 R530-200-000 R530-202-000 R531-120-000 R531-120-000 R531-120-000 R531-160-000 R531-160-000 R531-160-000 R531-200-000 R531-200-000 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Junction Boxes Accessories USA: 716.630.7030 Data Subject to change without notice 114
R530-162-000 价格&库存
很抱歉,暂时无法提供与“R530-162-000”相匹配的价格&库存,您可以联系我们找货
