1451-30
1451-30
    HAMMONDMANUFACTURING
    COVER FOR CHASSIS 17X10X5.2" GRY
1451-30 数据手册
8 7 6 5 4 3 2 1 D D 252.15 mm [9.927 in] 9.53 mm [.375 in] TOP VIEW OF ASSEMBLY C C 434.01 mm [17.087 in] 254.00 mm [10.000 in] 414.96 mm [16.337 in] 132.59 mm [5.220 in] 143.79 mm [5.661 in] n4.76 mm 4X [.188 in] 4.76 mm [.188 in] B .91 mm [.036 in] TYP. MATERIAL THICKNESS SIDE VIEW OF ASSEMBLY 9.53 mm [.375 in] 17.70 mm [.697 in] 215.85 mm [8.498 in] 9.53 mm [.375 in] 251.26 mm [9.892 in] 414.53 mm [16.320 in] 234.95 mm [9.250 in] B Note: END VIEW OF ASSEMBLY Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES Format. 1451-30 Material: 20ga. W elded Steel, Gray color Cover: Perforated Steel Screws: 4 Supplied (#6-32 X 1/4" self tap) For use with 1441 and 1444 series chassis. 250.80 mm [9.874 in] A A 1451-30 432.18 mm [17.015 in] BOTTOM VIEW OF ASSEMBLY 8 7 6 5 4 3 2 1
1451-30 价格&库存
很抱歉,暂时无法提供与“1451-30”相匹配的价格&库存,您可以联系我们找货
