www.hammondmfg.com
Eclipse Series - NEMA 4, 12
Accessories
Eclipse Inner Panel
• Larger than standard NEMA panel used in same sized enclosure.
• 12 gauge steel construction (see chart, below).
• Larger sizes have 2 or 4 formed flanges for added strength.
Industrial Enclosures
Wallmount Enclosures
Mild Steel
Part No.
EP1212
EP1224
EP1612
EP1616
EP1620
EP2012
EP2016
EP2020
EP2024
EP2412
EP2416
EP2420
EP2424
EP2430
EP2442
EP2448
EP3012
EP3016
EP3020
EP3024
EP3030
Galvanized
Part No.
EPG1212
EPG1224
EPG1612
EPG1616
EPG1620
EPG2012
EPG2016
EPG2020
EPG2024
EPG2412
EPG2416
EPG2420
EPG2424
EPG2430
EPG2442
EPG2448
EPG3012
EPG3016
EPG3020
EPG3024
EPG3030
Size
D
E Gauge
10.2 10.2
12
10.2 22.2
12
14.2 10.2
12
14.2 14.2
12
14.2 18.2
12
18.2 10.2
12
18.2 14.2
12
18.2 18.2
12
18.2 22.2
12
22.2 10.2
12
22.2 14.2
12
22.2 18.2
12
22.2 22.2
12
22.2 28.2
12
22.2 40.2
12
22.2 46.2
12
28.2 10.2
12
28.2 14.2
12
28.2 18.2
12
28.2 22.2
12
28.2 28.2
12
Mild Steel
Part No.
EP3036
EP3042
EP3048
EP3060
EP3624
EP3630
EP3636
EP3642
EP3648
EP3660
EP4224
EP4230
EP4236
EP4824
EP4830
EP4836
EP4848
EP6036
EP7230
EP7236
Galvanized
Part No.
EPG3036
EPG3042
EPG3048
EPG3060
EPG3624
EPG3630
EPG3636
EPG3642
EPG3648
EPG3660
EPG4224
EPG4230
EPG4236
EPG4824
EPG4830
EPG4836
EPG4848
EPG6036
EPG7230
EPG7236
Size
D
E Gauge
28.2 34.2
12
28.2 40.2
12
28.2 46.2
12
28.2 58.2
12
34.2 22.2
12
34.2 28.2
12
34.2 34.2
12
34.2 40.2
12
34.2 46.2
12
34.2 58.2
12
40.2 22.2
12
40.2 28.2
12
40.2 34.2
12
46.2 22.2
12
46.2 28.2
12
46.2 34.2
12
46.2 46.2
12
58.2 34.2
12
70.2 28.2
12
70.2 34.2
12
Eclipse Swing Panel
Hinged panel allows access to internally mounted equipment.
12 gauge steel construction.
Slotted quarter turn latches provide closure.
Adding optional locking quarter turn latches (Part Number
EQTRL...see page 31) convert this to a dead front panel.
• Complete with 4-6" depth adjustment channels.
• Hardware kit maintains UL, CSA and NEMA ratings when field
installed.
• Finished in white.
Part No.
ESP1212
ESP1612
ESP1616
ESP1620
ESP2016
ESP2020
ESP2024
Fits Enclosure
Size (A x B)
12 x 12
16 x 12
16 x 16
16 x 20
20 x 16
20 x 20
20 x 24
Part No.
ESP2416
ESP2420
ESP2424
ESP3020
ESP3024
ESP3030
ESP3624
Fits Enclosure
Size (A x B)
24 x 16
24 x 20
24 x 24
30 x 20
30 x 24
30 x 30
36 x 24
Part No.
ESP3630
ESP3636
ESP4236
ESP4824
ESP4836
ESP6036
Fits Enclosure
Size (A x B)
36 x 30
36 x 36
42 X 36
48 X 24
48 X 36
60 X 36
Eclipse Replacement Hinge Pins
• These are supplied with enclosure but offered
here as replacements should originals be
Part No.
misplaced.
• Packaged in quantities of 5.
EPINSS
Technical references and CAD downloads available at www.hammondmfg.com
29
Material
Stainless steel hinge pin
All dimensions in inches unless specified otherwise
Quality Products. Service Excellence.
© Hammond Manufacturing
Canada: 519.822.2960 or 905.456.3770
USA: 716.630.7030
Data Subject to change without notice
www.hammondmfg.com
Accessories
Eclipse Swing Frame
Part No.
ESF2424
ESF3024
ESF3624
Fits Enclosure
Size (A x B)
24 x 24
30 x 24
36 x 24
• Order package of 25 clip nuts separately
(Part No. 1421N25…see page 430 ).
NEMA ratings when field installed.
• Finished in black.
• Provides 19" rack mounting with full EIA
spacing (punched holes).
• Hinges allow easy equipment access.
• Slotted quarter turn latches provide
closure.
• Adding optional locking quarter turn
latches (EQTRL...see page 31 ) provides
added security.
channels.
Rack Spacing
Width Height (Units)
19
11
19
14
19
17
DIN Rail Mounting Kit
Part No.
2DMK12
2DMK16
2DMK20
2DMK24
2DMK30
A
10
14
18
22
28
B
1.25
0.75
0.88
1.00
0.88
• Field installable.
• Mounts directly to panel collar studs
(panel not required).
• Accepts optional DIN rails, see below.
• DIN rails available separately.
• Zinc plated.
C
7
11
14
17
22
DIN Rails
• Includes a set of 3 plated rails.
• Available in 3 industry standard profiles DIN 1, DIN 3, and CENELEC.
• DIN rail mounting kit required for
installation (see above).
• Rails have a 0.28 x 1.25 oblong slot on
each end.
• Zinc plated.
Asymmetric Din 1
Symmetric Din 3
Cenelec Profile
Profile Part No.
Profile Part No.
Part No.
2D1K12
2D2K12
2DCK12
2D1K16
2D2K16
2DCK16
2D1K20
2D2K20
2DCK20
2D1K24
2D2K24
2DCK24
2D1K30
2D2K30
2DCK30
For sizing, refer to master selection table...see page 20
Length
9.25
13.25
17.25
21.25
27.25
USA: 716.630.7030
30
www.hammondmfg.com
Eclipse Series- NEMA 4, 12
Accessories
Quarter Turn Inserts and Keys
• Field installable inserts replace standard
quarter turn slot.
• Available in 7mm square and triangle formats,
as well as slotted.
• Square and triangle inserts provide extra
security since standard screw drivers cannot
open.
• Keys sold separately from inserts.
• Maintains NEMA, UL and CSA 12, 4 and 4X
ratings.
Part No.
2SQI7
2SQK7
2TRI7
2TRK7
2SLI
Description
7mm square insert, black
7mm square key, fits 2SQI7
7mm triangle insert, black
7mm triangle key, fits 2TRI7
Slotted insert, black
Replacement Quarter Turn Assemblies
• Interchangeable with standard quarter turn latches.
• Maintains NEMA, UL and CSA ratings as noted.
2QPL
EQTRL
2WKL
2SSQTR
Part No.
EQTRL1
2QTR
2SSQTR
2WKL
2QPL
1
EHTL
Material
Zinc Die/Chrome
Zinc Die/Black
Stainless steel
Zinc Die/Black
Zinc Die/Black
NEMA Rating
n/a (internal use only)
12, 4
12, 4, 4X
12, 4
12, 4
For use with Swing Frame/Panel. ..see page 29. All others for use with enclosures.
Handles
EHLPL
EHLPLSS
Description
Locking Qtr Turn
Slotted Qtr Turn
Slotted Qtr Turn
Wing knob lock
Padlockable quarter turn latch
EHLNLSS
EHLL
• Maintain NEMA, UL and CSA ratings as noted.
Part No.
EHTL
EHLL
EHLPL
EHLPLSS
EHLNLSS
EHLLSS
Description
Locking T Handle
Locking L Handle
Padlockable L Handle
Non Locking L Handle
Locking L Handle
Material
Zinc Die/Black
Zinc Die/Black
Zinc Plated
316 Stainless Steel
316 Stainless Steel
316 Stainless Steel
NEMA Rating
12, 4
12, 4
12
12, 4, 4X
12, 4, 4X
12, 4, 4X
Eclipse Mounting Foot Kit
Maintains UL, CSA and NEMA ratings.
Field installable.
New triangular flanges prevent the foot from rotating
Foot can still be mounted sideways as well as top/bottom
Available in mild, 304SS and 316SS
Packaged in quantities of four
Part No.
EZPMFHD
ESSMFHD
ES16MFHD
Material
Clear Zinc Plated, mild steel
Type 304 Stainless
Type 316 Stainless
31
USA: 716.630.7030
www.hammondmfg.com
Accessories
Eclipse Rear Mounting Hole Plugs
Part No.
• Used to plug rear mounting holes for
Eclipse series
• Snap in plug designed for rear .50"
mounting hole
• Packaged in quantities of 40
EN4PLUG40
USA: 716.630.7030
32
很抱歉,暂时无法提供与“EPG4848”相匹配的价格&库存,您可以联系我们找货
