24560157
24560157
    SCHROFF.PENTAIR.
    SCREW 2.5X7.3 100 PCS
24560157 数据手册
Main Catalog 24th Edition Main Catalog Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM 39601-641 © 2012 Pentair Equipment Protection 18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1 Equipment Protection Solutions 04 Desk-top cases 24th Edition | October 2012 . 10.10.2012 11:15:02 5_00_Gehäuse_overview_e.fm Seite 0 Mittwoch, 12. September 2012 8:04 08 PROLINE Main Catalogue Overview . . . . . 0 Desk-top cases Cabinets . . . . . . 1 Y The universal case with 19" compatible dimensions e.g. for CompactPCI and VME64x applications - Aluminium case - Height 2 ... 7 U - High EMC shielding Wall mounted cases . . . . . . . . 2 Accessories for cabinets and wall mounted cases 3 Climate control 4 Desk-top cases 5 Subracks/ 19" chassis . . . 6 Front panels, plug-in units . . 7 Systems . . . . . . 8 i The robust case for 19" compatible or custom electronics assemblies - Aluminium case with aluminium frame front - Height 2 ... 6 U - High EMC shielding Power supply units . . . . . . . . . 9 Backplanes . . 10 Connectors, front panel component system . . . . . . 11 Downloads und weitere wichtige Informationen finden Sie im Internet unter www.schroff.biz Appendix . . . . 12 361009005 (12304003 10005004 05802001 06803006 05809001) 5.0 Main Catalogue E 10/2012 MicroTCA 5_00_Gehäuse_overview_e.fm Seite 1 Mittwoch, 12. September 2012 8:04 08 Desk-top cases Overview . . . . 5.0 Main Catalogue b Introduction . . 5.2 Desk-top or portable case Design alternative to propacPRO - Front and rear frame in aluminium - Aluminium case - Height 2 ... 6 U - For 19" components or individual electronics assemblies ServicePLUS . . 5.4 ratiopacPRO . . 5.6 propacPRO . . . 5.44 compacPRO . . 5.76 comptec . . . . . . 5.100 Accessories Handles . . . . . . . . 5.108 Strap handles . . . 5.111 Tip-up carrying handles . . . . . . . . 5.112 J Case to house 19" subracks or 19" chassis - Case with aluminium frame to front and rear - High stability - Height 3 ... 12 U - Identical front and rear - Internal mounting up to 40 kg - Protection class IP 20 Folding handles 5.113 Tray handles . . . 5.114 Feet . . . . . . . . . . 5.115 ServicePLUS . . 5.4 Accessories 36109006 (02004001 02202003 05806006 02992004 05806008) Main Catalogue E 10/2012 5.1 5_00_Gehäuse_overview_e.fm Seite 2 Mittwoch, 12. September 2012 8:04 08 Desk-top cases – Introduction Case types: Desk-top enclosure/19" case IntroductionMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days Desk-top enclosures Our desk-top cases are used to house PCBs (euroboards) or individual components The choice is yours: 쮿 ratiopacPRO, the universal case with 19" compatible dimensions and high EMC shielding, e.g. for CompactPCI and VME64x applications 01810002 Desk-top enclosure, ratiopacPRO 02202004 19" case, comptec 쮿 propacPRO, the robust case with high EMC shielding for 19"-compatible or custom electronics assemblies 쮿 compacPRO, Desk-top or portable case for unshielded applications 19" cases Our comptec cases are comparable with small cabinets and are used to house 19" components such as subracks, 19" fan trays or 19" front panels All desk-top enclosures have a very low weight owing to the materials used and are also suitable for mobile use Applications for desk-top enclosures Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days The most important user domains for desk-top enclosures are: 쮿 Fitting with euroboards in accordance with IEC 60297 쮿 Fitting with individual electrical or mechanical components, e.g.on mounting plates 02004079 05809004 05809004 Example above: for euroboards, below: for individual installation One product platform and extensive accessories Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Practical technology without time-consuming assembly. The modular product platform of these cases allows a wide range of possible uses with only a small number of components. The intelligent design of all components results in an astonishingly quick and easy assembly of the components. 05806008 05806006 With our PRO product platform we offer you full compatibility of all individual components and accessories, also with our europacPRO subracks. Standard desk-top enclosures can also be adapted easily and with little effort for mobile applications. 02005003 5.2 Main Catalogue E 10/2012 02005006 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_00_Gehäuse_overview_e.fm Seite 3 Mittwoch, 12. September 2012 8:04 08 Desk-top cases – Introduction Forms of delivery for desk-top enclosures IntroductionMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days Supplied in space-saving packs. Simply unpack parts and screw together - done. Depending on the kit chosen the threaded insert, the perforated rail or the EMC gasket is pre-assembled on the horizontal rail. We offer you three forms of delivery: 쮿 Pre-assembled kit for use with 160 mm deep euroboards, frame fitted, cladding parts and guide rails supplied loose. 쮿 Pre-assembled kit for individual configuration, frame assembled, cladding parts supplied loose. 쮿 Ready assembled cases to your specifications. With our ServicePLUS option you can order ready-assembled cases, with drilled holes and cut-outs and individual front panels if necessary even by express service. 06104001 Flat pack delivery to save space Guide rail Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Guide rails form the interface between the mechanics of the case and the electronics assembled (PCBs, plug-in units, frame type plug-in units, drive unit modules, etc.). Robust snap-in fixings on the plastic rails assure that the components are held securely, even when exposed to vibrations. 11 7 79 3 77 81 Guide rails can also be screwed on. 1 75 5 73 9 1 83 06108084 EMC and ESD dB 120 Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Our case product platforms offer standard solutions for achieving electromagnetic compatibility (EMC) and to avoid electrostatic interference (ESD) 100 쮿 Shielding on the front and rear of the case is effected by front panels with EMC gaskets 80 60 쮿 To prevent electrostatic discharge when inserting PCBs, ESD contacts are clipped into the guide rails. These provide a conductive connection between board and case earth/ground 40 20 쮿 Test reports are available on our website www.schroff.biz for download 0 30 400 800 1200 1600 2000 Mhz 06108081 Shielding 04503050 Position of the ESD clip Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.3 5_00_Gehäuse_overview_e.fm Seite 4 Mittwoch, 12. September 2012 8:04 08 Desk-top cases – ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely assembly 쮿 Online configuration: www.schroff.co.uk/configuration Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists modification 쮿 Professional and reliable, without extra costs 쮿 Ready for despatch within 10 working days Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 CAD data are available for you to download and further modify from our website www.schroff.biz 쮿 Ready for despatch within 10 working days solution Simple. Fast. From one source. Integration and custom developments 쮿 Flowtherm simulation to calculate heat paths; verification in our own climate lab 쮿 Special sizes, custom solutions express When fast has to be faster. Delivery time to customer's request 쮿 ServicePLUS assembly ready for despatch within 10 working days 쮿 ServicePLUS modification and ServicePLUS solution ready for despatch within 15 working days academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars held centrally or at your site. 쮿 CAD drawings, test reports, user manuals ServicePLUSMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 5.4 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_00_Gehäuse_overview_e.fm Seite 5 Mittwoch, 12. September 2012 8:04 08 Desk-top cases – ServicePLUS Application examples Text 01809001 Application: ratiopacPRO-air case in special colour, shielded board cage, filter mat top and bottom 01809003 Application: ratiopacPRO-air case with processed front and rear panels 02009001 Application: compacPRO case, modified 02009003 Application: compacPRO case with fitted horizontal rail with lip and hinged front panel 02009002 Application: compacPRO case with fitted horizontal rail with lip and folding front panel 02009004 Application: compacPRO with tip-up carrying handle and front panel (without visible screws) 02109001 Application: inpac case with hinged and modified front and rear panels Main Catalogue E 10/2012 05809005 Application: propacPRO, EMC case in special colour with mounting plates for individual construction Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.5 5_1_ratiopacPRO_e.fm Seite 6 Montag, 17. September 2012 7:04 19 YMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days Overview . . . . . 0 Desk-top cases – Y Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . 2 Accessories for cabinets and wall mounted cases 3 Climate control 4 Desk-top cases 5 06800002 Subracks/ 19" chassis . . . 6 Front panels, plug-in units . . 7 06801005 Systems . . . . . . 8 Power supply units . . . . . . . . . 9 Backplanes . . 10 Connectors, front panel component system . . . . . . 11 ratiopacPRO Designed for insertion/extractor handles in accordance with IEC 60297-3-102 and IEEE 1101.10 for CompactPCI and VME64x applications Standards 쮿 Inner and outer dimensions in accordance with: IEC 60297-3-101 / IEEE 1101.1 IEC 60297-3-102 / IEEE 1101.10/11 쮿 Type of protection IP20 in accordance with IEC 60529 쮿 Earthing connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A1 06812001 Case with mounting plate 쮿 EMC testing in accordance with VG 95373 part 15 Downloads and further important information can be found on the Internet under www.schroff.biz Appendix . . . . 12 5.6 ratiopacPRO air Designed for insertion/extractor handles in accordance with IEC 60297-3-102 and IEEE 1101.10 for CompactPCI and VME64x applications; 1 U extra for ventilation (1/2 U top, 1/2 U bottom) Main Catalogue E 10/2012 06800015 Prepared for CompactPCI and VME64x applications MicroTCA 5_1_ratiopacPRO_e.fm Seite 7 Montag, 17. September 2012 7:04 19 Desk-top cases – Y Overview . . . . 5.6 YMain Catalogue The universal case with 19" compatible dimensions e.g. for CompactPCI, VME64x and other applications 쮿 Base level of shielding in basic versions upwards, additional EMC shielding can be retrofitted 쮿 Symmetrical construction, identical front and rear (identical board cage for ratiopacPRO and ratiopacPRO air) ratiopacPRO 쮿 Converts simply from desktop to 19" rack-mounted case and back Complete cases . 5.8 Dimensions . . . . . 5.9 Cases . . . . . . . . . . 5.10 Tower cases . . . . 5.12 쮿 No visible screws; cladding parts removable without tools ratiopacPRO air ratiopacPRO Cases . . . . . . . . . 5.14 Complete cases . 5.13 Dimensions . . . . . 5.16 Radial fan units . 5.17 EMC gasketing . . 5.18 쮿 Case with cover strip, front handles or 19" brackets (height 2 U ... 6 U) Accessories 쮿 Complete case with cover strip and pre-mounted components, with basic shielding (height 3 U, 6 U), additional EMC shielding retrofittable 쮿 Tower case (width 4 U) 06800005 ratiopacPRO air 쮿 ratiopacPRO air with additional 1 U height for ventilation 쮿 Case with cover strips, front handles or 19" brackets (height 4 U, 5 U, 7 U) 쮿 Complete case with cover strips and pre-mounted components, with basic shielding (height 4 U, 7 U), additional EMC shielding retrofittable 06800005 ServicePLUS from page 5.4 Front panels . . . . 5.21 Rear panels . . . . . 5.22 Feet . . . . . . . . . . . 5.23 Air filters . . . . . . . 5.23 GND/earthing kit 5.24 Front handles . . . 5.24 19" brackets . . . . 5.25 Cable holder. . . . 5.26 Compartment seals. . . . . . . . . . . 5.26 Strap handles . . . 5.26 Tip-up carrying handles . . . . . . . . 5.27 Assembly kit. . . . 5.28 Fitting position of horizontal rails ........... 5.29 Horizontal rails. . 5.31 Threaded inserts, perforated strips, insulation strips . 5.35 Z-rails, perforated rails. . 5.35 Divider plates . . . 5.36 Mounting plates . 5.37 Horizontal board assembly . . . . . . 5.38 Combined mounting . . . . . . 5.39 Guide rails and ESD clips . . . . . . 5.40 ServicePLUS . . 5.4 e.g. modifications (special colours or sizes) e.g. custom solutions (cut-outs in top cover, base plate or side panels) e.g. assembly service from 1 piece www.schroff.biz/ServicePLUS 30407004 Main Catalogue E 10/2012 5.7 5_1_ratiopacPRO_e.fm Seite 8 Montag, 17. September 2012 7:04 19 Desk-top cases – Y ratiopacPRO complete cases YMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Desk-top enclosure with pre-configured components, in accordance to IEC 60297-3-101; prepared for 19" components, e.g. plug-in units and euroboards 쮿 Ventilation slit in base plate 쮿 Rear panel perforated Delivery comprises (in kit form) 06812003 11 15 Item Qty without EMC 1 2 2 2 3 4 with EMC 2 2 4 Description 4 4 4 5 6 7 2 1 6/8 2 1 6/8 8 9 10 11 – 4 1 2 4 4 1 2 12 4 4 14 – 1 15 – 4 16 17 – 1 4 1 10 “X” 4, 7, 8,16 “Y” “Z” 5, 7, 9 6, 7, 9 1 2 3 15 11 12 01802050 “X” “Y” 9 4 9 7 7 16 “Z” 7 5 8 6 01808055 A-A H A W W - 21.4 D - 20 7.5 A D 01808051 3U A-A A W W - 21.4 7.5 H A Order Information Height H Width W Depth D Unshielded U 3 3 3 3 3 3 3 6 6 6 6 6 HP 28 42 42 63 84 84 84 42 63 84 84 84 mm 255.5 255.5 315.5 315.5 315.5 375.5 435.5 315.5 315.5 315.5 375.5 435.5 Part no. EMC shielded Part no. 24572-001 24572-002 24572-003 24572-004 24572-005 24572-006 24572-007 24572-015 24572-016 24572-017 24572-018 24572-019 24572-050 24572-051 24572-052 24572-053 24572-054 24572-055 24572-056 24572-064 24572-065 24572-066 24572-067 24572-068 Note D - 20 D 01808052 6U Side panel, AI, 2 mm, passivated Side plate, Al, 1 mm, visible surfaces RAL 9006 Cover strip, Al die-cast, RAL 7016, pre-fitted only on EMC version Horizontal rail, type H-LD, Al, visible surfaces RAL 7016 Horizontal rail, centre (top/bottom), type H-ST, Al Horizontal rail, centre (on 6 U only), type ST, Al 3 U/6 U: threaded inserts, St, pre-mounted, for indirect backplane mounting with insulation strips Perforated strip, Al, 1 mm, pre-fitted Insulation strip, PBT, UL 94 V-0 Rear panel, perforated, Al, 2.5 mm Top cover and base plate, Al, 1 mm, internal surfaces conductive, visible surfaces RAL 9006, with GND/earthing connection, base plate with honeycomb grid ventilation Case foot with anti-slip protection, UL 94 V-0, PC black EMC support profile for side panel, pre-mounted (kit) EMC contact strip for cover plate, pre-mounted (kit) EMC contact strip front panel - horizontal rails GND/earthing kit, assembly kit 쮿 쮿 쮿 쮿 Dimension drawings and mounting depths see page 5.9 Components see page 5.18 Front handles and 19" mounting brackets from page 5.24 Guide rails from page 5.40 ServicePLUS see page 5.4 5.8 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – Y Dimension drawings ratiopacPRO Text rppr6637 RatiopacPRO with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle Dimensions table ratiopacPRO Height Width H in U in mm 2 3 4 5 6 88.10 132.55 177.00 221.45 265.90 h in mm 67.90 112.35 156.80 201.25 245.70 w W w1 Depth w2 w in HP in mm in mm in mm in mm 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 28 42 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 63 342.42 355.42 375.92 320.62 84 448.90 462.10 482.60 427.30 D d Total depth in mm Useable depth in mm 255.5 235.5 315.5 295.5 375.5 355.5 435.5 415.5 495.5 475.5 D1 Plug-in depth in mm 175.5 235.5 175.5 235.5 295.5 175.5 235.5 295.5 355.5 175.5 235.5 295.5 355.5 175.5 235.5 295.5 355.5 d2 Board depth in mm 160 220 160 220 280 160 220 280 340 160 220 280 340 160 220 280 340 Components mountable in 15 mm depth grid Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.9 Desk-top cases – Y RatiopacPRO case YMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Cases for individual assembly with 19" standard components or specific internal mounting, e.g. with mounting plate 쮿 Unshielded (EMC shielding retrofittable) 쮿 Symmetrical design, identical front and rear side 01805050 3a: Bezel 01805051 01805052 01813051 3b: Front handle 3c: 19" mounting 3d: 19" mounting bracket bracket with front handle 쮿 Four versions: – Bezels – Front handles – 19" mounting brackets – 19" mounting brackets with front handles 쮿 For board depth 160 mm, 220 mm, 280 mm, and 340 mm (depending on case depth) Delivery comprises (kit) Item 1 2 Qty 2 2 3 3a 3b 3c 2 2 2 2 3d 2 3 4 4 1 11 2 2 12 13 4 1 11 4 Description Side panel, AI, 2 mm, chromated Side plate, Al, 1 mm, visible surfaces powder-coated, RAL 9006 Rear trim, Al die-cast, powder-coated, RAL 7016 Bezel, Al die-cast, powder-coated, RAL 7016 Front handle, Al die-cast, powder-coated, RAL 7016 19" mounting bracket, Al diecast, powder-coated, RAL 7016 19" mounting bracket with front handle, Al diecast, powder-coated, RAL 7016 Horizontal rail, type H-LD, Al, visible surfaces powdercoated, RAL 7016 Top cover and base plate, Al, 1 mm, inner sides conductive, visible surfaces powder-coated, RAL 9006, with GND/earthing connections, base plate with honeycomb grid ventilation Case foot with anti-slip protection, UL 94 V-0, PC black Fixing materials kit 3a, 3b, 3c or 3d according to selection 3a (3b/3c/3d) 11 12 01813065 Drawing with front cover strip ServicePLUS see page 5.4 Note 쮿 Order information, see following page Order Information Accessories Earthing kit CU wire, 1.5 mm2, PVC sleeve, green/yellow, 1 kit Al diecast foot with tip-up silver, 1 piece (SPQ 10) Plastic tip-up foot silver, similar to RAL 9006, PU 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces Stacking aid silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid anthracite, similar to RAL 7016, PA, UL 94 V-0, PU 4 pieces 24571-380 10603-002 20603-001 20603-002 20603-004 20603-003 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.10 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – Y RatiopacPRO case Cover strips RPPR6629 Front handles 01805050 19" mounting brackets Width W Depth D HP mm 28 28 42 42 42 63 63 63 84 84 84 84 84 Case height H 2U Part no. Part no. Part no. 255.5 315.5 255.5 315.5 255.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 495.5 24572-500 24572-503 24572-510 24572-513 24572-514 24572-520 24572-523 24572-524 24572-530 24572-533 24572-534 24572-535 24572-536 24571-002 24571-005 24571-014 24571-017 24571-018 24571-026 24571-029 24571-030 24571-038 24571-041 24571-042 24571-043 24571-044 24571-050 24571-053 24571-062 24571-065 24571-066 24571-074 24571-077 24571-078 24571-086 24571-089 24571-090 24571-091 24571-092 24572-117 24572-120 24572-129 24572-132 24572-133 24572-141 24572-144 24572-145 24572-153 24572-156 24572-157 24572-158 24572-159 24572-261 24572-264 24572-273 24572-276 24572-277 24572-285 24572-288 24572-289 24572-297 24572-300 24572-301 24572-302 24572-303 24571-098 24571-101 24571-110 24571-113 24571-114 24571-122 24571-125 24571-126 24571-134 24571-137 24571-138 24571-139 24571-140 28 28 42 42 42 63 63 63 84 84 84 84 84 255.5 315.5 255.5 315.5 375.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 495.5 – – – – – – – – – – – – – 24571-702 24571-705 24571-714 24571-717 24571-718 24571-726 24571-729 24571-730 24571-738 24571-741 24571-742 24571-743 24571-744 24571-750 24571-753 24571-762 24571-765 24571-766 24571-774 24571-777 24571-778 24571-786 24571-789 24571-790 24571-791 24571-792 24572-213 24572-216 24572-225 24572-228 24572-229 24572-237 24572-240 24572-241 24572-249 24572-252 24572-253 24572-254 24572-255 24572-357 24572-360 24572-369 24572-372 24572-373 24572-381 24572-384 24572-385 24572-393 24572-396 24572-397 24572-398 24572-399 24571-798 24571-801 24571-810 24571-813 24571-814 24571-822 24571-825 24571-826 24571-834 24571-837 24571-838 24571-839 24571-840 84 255.5 24572-570 24571-438 24571-486 24572-201 24572-345 24571-534 84 315.5 24572-573 24571-441 24571-489 24572-204 24572-348 24571-537 84 375.5 24572-574 24571-442 24571-490 24572-205 24572-349 24571-538 84 435.5 24572-575 24571-443 24571-491 24572-206 24572-350 24571-539 84 495.5 24572-576 24571-444 24571-492 24572-207 24572-351 24571-540 84 255.5 24572-620 24572-630 24572-640 – – 24572-660 84 315.5 24572-623 24572-633 24572-643 – – 24572-663 84 375.5 24572-624 24572-634 24572-644 – – 24572-664 84 435.5 24572-625 24572-635 24572-645 – – 24572-665 84 495.5 24572-626 24572-636 24572-646 – – 24572-666 Part no. Side panel subdivision (1 U-3 U-1 U) (3 U-2 U) Part no. 01805052 19" mounting brackets with front handles 01813051 Note 쮿 Dimension drawings and mounting depths see page 5.9 쮿 Components see page 5.18 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.11 5_1_ratiopacPRO_e.fm Seite 12 Montag, 17. September 2012 7:04 19 Desk-top cases – Y ratiopacPRO tower with 4 U width Y 쮿 Symmetrical design, identical front and rear side 쮿 Mounting space 4 U, 84 HP, depth 475 mm 쮿 Case based on ratiopacPRO 쮿 Unshielded (EMC shielding retrofittable) Delivery comprises (in kit form) Item 1 2 Qty 2 4 3 4 4 2 5 1 6 2 7 1 06802001 5 1 Description Base/top cover, Al, 2 mm, passivated Horizontal rail, type H-LD, Al, visible surface powdercoated, RAL 7016 Cover, Al die-cast, RAL 7016 Lateral cover plate, Al, 1 mm, with GND/earthing connection, visible surfaces powder-coated, internal surface conductive, RAL 9006 Top cover plate, Al, 1 mm, visible surface powder-coated, RAL 9006 Case foot with anti-slip protection, Al, powder-coated, RAL 7016 Assembly kit Order Information 3 Width U 4 2 3 Part no. 24571-395 Note 쮿 Components see page 5.18 4 For further information www.schroff.biz/oneclick oneClick search code = Part no. 4 6 495.5 475.5 2) 462.25 448.7 427.3 177 156,81) 221,5 01802054 1) = open space between the horizontal rails 2) = max. mounting depth ServicePLUS see page 5.4 5.12 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 13 Montag, 17. September 2012 7:04 19 Desk-top cases – Y air ratiopacPRO air complete cases airY 쮿 The case has 2 x 1/2 U clearance for ventilation 쮿 Case with cover strip; with pre-mounted components for euroboards and backplane with insulation strip; no visible screws 쮿 Symmetrical design, identical front and rear honeycomb grid ventilation in top cover and base plate 쮿 Available in two versions: – unshielded (EMC shielding retrofittable) – with EMC shielding fitted 06811001 13 Delivery comprises (in kit form) 11 15 10 “X” 4, 7, 8, 16 “Y” “Z” 5, 7, 9 6, 7, 9 14 1 2 17 11 3 15 Item Qty without EMC 1 2 2 2 3 4 4 4 5 6 7 2 1 6/8 8 9 10 11 – 4 1 2 12 4 13 14 15 16 17 2 – – – 1 18 1 12 13 01802052 “X” “Y” 9 4 9 7 7 16 “Z” 7 5 8 6 01808055 A-A h H A Description with EMC 2 Side panel, AI, 2 mm, passivated 2 Side plate, Al, 1 mm, visible surface RAL 9006 4 Cover, die-cast zinc, RAL 7016, pre-mounted on EMC version only 4 Horizontal rail, type H-LD, Al, visible surface RAL 7016 2 Horizontal rail, centre (top/bottom), type H-ST, Al 1 Horizontal rail, centre (on 6 U only), type ST, Al 6/8 4 U/7 U: threaded inserts, St, pre-mounted, for indirect backplane mounting with insulation strips 4 Perforated strip, pre-mounted 4 Insulation strip, PBT, UL 94 V-0 1 Rear panel, Al, 2.5 mm 2 Top cover and base plate with honeycomb grid ventilation, Al, 1 mm, internal surface conductive, visible surface RAL 9006, with GND/earthing connection 4 Case foot with anti-slip protection, UL 94 V-0, PC, black 2 Air filter 1 EMC support profile for side panel, fitted (kit) 4 EMC contact strip for cover plate, pre-mounted (kit) 4 EMC contact strip front panel - horizontal rails 1 Compartment seal, PE foam, self-adhesive, temperature range -20 °C ... +85 °C 1 GND/earthing kit, assembly kit Order Information D w 7.5 A 01808053 3U A-A h w 7.5 A H A D Case height H U 4 4 4 4 4 4 4 7 7 7 7 7 PCB height h Width w U HP 3 28 3 42 3 42 3 63 3 84 3 84 3 84 6 42 6 63 6 84 6 84 6 84 Depth D mm 255.5 255.5 315.5 315.5 315.5 375.5 435.5 315.5 315.5 315.5 375.5 435.5 Unshielded Part no. EMC shielded Part no. 24572-025 24572-026 24572-027 24572-028 24572-029 24572-030 24572-031 24572-040 24572-041 24572-042 24572-043 24572-044 24572-074 24572-075 24572-076 24572-077 24572-078 24572-079 24572-080 24572-088 24572-089 24572-090 24572-091 24572-092 01808054 Note 6U ServicePLUS see page 5.4 Main Catalogue E 10/2012 쮿 쮿 쮿 쮿 Dimension drawings and mounting depths see page 5.16 Components see page 5.18 Front handles and 19" mounting brackets from page 5.24 Guide rails from page 5.40 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.13 Desk-top cases – Y air RatiopacPRO air case airY 쮿 The case has 2 x 1/2 U clearances for ventilation beneath and above the board cage 쮿 Cases for individual assembly with 19" standard components or specific internal mounting, e.g. with mounting plate 쮿 Unshielded (EMC shielding retrofittable) 06801005 쮿 Symmetrical design, identical front and rear side 쮿 For board depth 160 mm, 220 mm, 280 mm, and 340 mm (depending on case depth) 쮿 Online download of 3D CAD data 쮿 Four versions: – Bezels – Front handles – 19" mounting brackets – With 19" mounting brackets and front handles 01805055 3a: Bezel 01805056 01805057 01813057 3b: Front handle 3c: 19" mounting 3d: 19" mounting bracket bracket with front handle 13 11 Delivery comprises (in kit form) Item 1 2 Qty 2 2 3 3a 3b 3c 2 2 2 2 3d 2 4 4 11 2 12 13 14 4 2 1 4 3a (3b/3c/3d) 3 1 2 Description Side panel, AI, 2 mm, chromated Side plate, Al, 1 mm, visible surfaces powder-coated, RAL 9006 Rear trim, Al die-cast, powder-coated, RAL 7016 Bezel, Al die-cast, powder-coated, RAL 7016 Front handle, Al die-cast, powder-coated, RAL 7016 19" mounting angle, Al die-cast, powder-coated, RAL 7016 19" mounting bracket with front handle, Al diecast, powder-coated, RAL 7016 Horizontal rail, type H-LD, Al, visible surfaces powdercoated, RAL 7016 1 Top cover and base plate, Al, 1 mm, internal surfaces conductive,visible surfaces powder-coated, RAL 9006, with GND/earthing connection, top cover and base plate with ventilation comb Case foot with anti-slip protection, UL 94 V-0, PC black Air filters Fixing materials kit 3a, 3b, 3c or 3d according to selection 11 12 13 01813066 Drawing with front cover strip ServicePLUS see page 5.4 Note 쮿 Order information see following page Order Information Accessories Earthing kit CU wire, 1.5 mm2, PVC sleeve, green/yellow, 1 kit Al diecast foot with tip-up silver, 1 piece (SPQ 10) Plastic tip-up foot silver, similar to RAL 9006, PU 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces Stacking aid silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid anthracite, similar to RAL 7016, PA, UL 94 V-0, PU 4 pieces 24571-380 10603-002 20603-001 20603-002 20603-004 20603-003 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.14 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – Y air RatiopacPRO air case Width W Depth D 4U Case height H 5U PCB height h 7U 3 1 HP 28 28 42 42 42 63 63 63 63 84 84 84 84 84 28 28 42 42 42 42 63 63 63 84 84 84 84 84 mm 255.5 315.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 255.5 315.5 375.5 435.5 495.5 255.5 315.5 255.5 315.5 375.5 435.5 315.5 375.5 435.5 255.5 315.5 375.5 435.5 495.5 Part no. Part no. Part no. 24571-146 24571-149 24571-158 24571-161 24571-162 24571-170 24571-173 24571-174 24571-175 24571-182 24571-185 24571-186 24571-187 24571-188 24571-846 24571-849 24571-858 24571-861 24571-862 24571-863 24571-873 24571-874 24571-875 24571-882 24571-885 24571-886 24571-887 24571-888 24571-194 24571-197 24571-206 24571-209 24571-210 24571-218 24571-221 24571-222 24571-223 24571-230 24571-233 24571-234 24571-235 24571-236 24571-894 24571-897 24571-906 24571-909 24571-910 24571-911 24571-921 24571-922 24571-923 24571-930 24571-933 24571-934 24571-935 24571-936 24571-242 24571-245 24571-254 24571-257 24571-258 24571-266 24571-269 24571-270 24571-271 24571-278 24571-281 24571-282 24571-283 24571-284 24571-942 24571-945 24571-954 24571-957 24571-958 24571-959 24571-969 24571-970 24571-971 24571-978 24571-981 24571-982 24571-983 24571-984 84 255.5 24571-582 24571-630 24571-678 84 315.5 24571-585 24571-633 24571-681 84 375.5 24571-586 24571-634 24571-682 84 435.5 24571-587 24571-635 24571-683 01805057 84 495.5 24571-588 24571-636 24571-684 With 19" mounting brackets and front handles 84 255.5 24572-670 – 24572-690 84 315.5 24572-673 – 24572-693 84 375.5 24572-674 – 24572-694 84 435.5 24572-675 – 24572-695 84 495.5 24572-676 – 24572-696 Bezels 01805055 Front handles 01805056 19" mounting brackets 01805057 Note 쮿 Dimension drawings and mounting depths see page 5.16 쮿 Components see page 5.18 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.15 Desk-top cases – Y air RatiopacPRO air dimension drawings Text 01805058 RatiopacPRO air with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle Text Dimensions table RatiopacPRO air Height Width H H in U in mm 4 5 7 177.00 221.45 310.35 in mm 112.35 156.80 245.70 W in HP 28 42 63 84 42 63 84 42 63 84 W1 Depth W2 w in mm in mm in mm in mm 164.42 235.54 342.42 448.90 235.54 342.42 448.90 235.54 342.42 448.90 177.62 248.74 355.42 462.10 248.74 355.42 462.10 248.74 355.42 462.10 198.12 269.24 375.92 482.60 269.24 375.92 482.60 269.24 375.92 482.60 142.82 213.94 320.62 427.30 213.94 320.62 427.30 213.94 320.62 427.30 D d Total depth in mm Usable depth in mm 255.5 235.5 315.5 295.5 375.5 355.5 435.5 415.5 495.5 475.5 D1 d2 Plug-in depth in mm 175 235 175 235 295 175 235 295 355 175 235 Board depth in mm 160 220 160 220 280 160 220 280 340 160 220 295 355 280 340 175 160 235 220 295 355 280 340 Components mountable in 15 mm depth grid 5.16 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 17 Montag, 17. September 2012 7:04 19 Desk-top cases – Y air Radial fan unit for ratiopacPRO air Main Catalogue 쮿 Only 1/2 U height 쮿 Ball-bearing radial fans 쮿 Fan holder in 4 widths and 2 depths 쮿 Air capacity 36 m³/h (free blowing) per fan 쮿 Air exhaust via perforation in cover plate 쮿 No mechanical modification to case necessary 쮿 Simple mounting 2 쮿 No restriction to rear mounting space Delivery comprises (Kit) 1 4 Item 1 Qty 1 2 1-3 3 1 4 5 1 1 3 12309050 W 26,5 Description Fan support, Al, 1.5 mm, with crimp sockets for mounting the fans Radial fan, ball bearing, 12 VDC; airflow volume (50 Hz) 36 m³/h, free blowing; power consumption 6.7 W; connecting cable 300 mm, without plug (AWG 26); noise level in dB (A): 47.0; max. static pressure in Pa: 190; max. ambient temperature: 60 °C; fan housing and rotor: UL 94 V-0 Compartment seal, PE foam, UL 94, self-adhesive, temperature range -20 °C ... +85 °C Terminal clamp, UL 90 V-0 Assembly kit D Order Information 70 8 12309051 Depth D: 129.8 / 189.9 mm for 160 mm / 220 mm euroboards Width Width HP 28 42 63 84 mm 146.87 218.00 324.67 431.35 Number of fans 1 1 2 3 Part no. for PCB depth 160 mm 220 mm 24572-404 24572-405 24572-406 24572-407 24572-408 24572-409 24572-410 24572-411 Note 쮿 Further configurations available on request 쮿 Fans with tacho signal available on request For further information www.schroff.biz/oneclick oneClick search code = Part no. Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.17 5_1_ratiopacPRO_e.fm Seite 18 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air EMC sealing front/rear panel to side panel / -airY 쮿 For vertical EMC shielding between sub-assemblies and side panel 쮿 Scope of delivery sufficient for one case Delivery comprises (kit) 1 Item 1 2 Qty 4 2 2 3 1 Description EMC support profile, Al extrusion EMC sealing (textile), core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information rppr6639 For case height U 2, 3-air 3, 4-air 4, 5-air 6, 7-air 5, 6-air Part no. 24571-334 24571-331 24571-332 24571-333 24571-335 EMC sealing side panel to cover plate / -airY 쮿 For horizontal EMC shielding between side panels and cover plates 쮿 Scope of delivery sufficient for one case Delivery comprises (kit) Item 1 Qty 4 Description Contact strip, stainless steel Order Information Depth mm 255 315 375 435 495 Part no. 24571-338 24571-339 24571-340 24571-341 24571-342 RPPR6640 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.18 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 19 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air EMC sealing front/rear panel to horizontal rail Main Catalogue 쮿 The contact strip is clipped onto the horizontal rail and sets up the contact to front panel or rear panel 쮿 Can be used for rear horizontal rails (H-VT, L-VT) and all front horizontal rails Delivery comprises Item 1 Qty Description 10/100 Stainless steel EMC gasket Order Information rppr6739 Width HP 28 42 63 84 84 Width mm 131.78 202.9 304.8 416.3 416.3 Qty/PU 10 10 10 10 100 Part no. 24560-229 24560-231 24560-233 24560-235 24560-236 For further information www.schroff.biz/oneclick oneClick search code = Part no. EMC sealing horizontal rail to horizontal rail / -airY 쮿 For shielding of two horizontal rails located directly above each other with vertical division of the mounting height Delivery comprises Item 1 2 Qty 1 2 Description Cover strip, Al, 1 mm Contact spring, St, stainless Order Information BPA46548 BZA45877 Length HP 20 28 40 42 63 84 Assembly tool for EMC sealing, St, stainless (horizontal rails),1 piece Part no. 24562-520 24562-528 24562-540 24562-542 24562-563 24562-584 24560-271 For further information www.schroff.biz/oneclick oneClick search code = Part no. aza45937 Assembly tool Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.19 5_1_ratiopacPRO_e.fm Seite 20 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air EMC front/rear panel, slotted, shielded / -airYMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 No screws required for fixing 쮿 Special horizontal rails cover the edges of the front panel (top and bottom) and prevent bowing of the front panel Delivery comprises (Kit) H W Item 1 Qty 1 2 3 4 5 6 2 4 2 3 1 Description Full-width front panel, Al, 2.5 mm, front: anodised, rear: colour passivated Horizontal rail, front; special for this front panel EMC support profile Contact strip horizontal rail - front panel EMC textile gasket Fixing material kit, user manual 01811055 Order Information For case height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air Height H mm 84.0 84.0 84.0 84.0 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 For case width HP 28 42 63 84 28 42 63 84 28 42 63 84 Width W mm 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 Part no. 24572-599 24572-600 24572-601 24572-602 24572-603 24572-604 24572-605 24572-606 24572-607 24572-608 24572-609 24572-610 01811056 Front panel/horizontal rail Note 쮿 To obtain a shielded case, all EMC sealings must be fitted (front panel/rear panel - side panel; side panel - cover plate; front panel/rear panel - horizontal rail; horizontal rail - horizontal rail) 쮿 EMC sealing see from page 5.18 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.20 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 21 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Full-width front panel, slotted, unshielded / -airY 쮿 Front panels can also be used as rear panels 쮿 No screws required for fixing 쮿 Inserted between side panel and castings such as trim, 19" mounting bracket or handle Delivery comprises Item 1 Qty 1 Description Front panel, Al, 2.5 mm, front: anodised, rear: colour passivated Order Information 06801502 For case height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 5, 6-air 5, 6-air 5, 6-air 5, 6-air 6, 7-air 6, 7-air 6, 7-air 6, 7-air Height H mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 217.3 217.3 217.3 217.3 261.8 261.8 261.8 261.8 For case width HP 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 Width W mm 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 Part no. 34571-617 34571-618 34571-619 34571-620 34571-605 34571-606 34571-607 34571-608 34571-609 34571-610 34571-611 34571-612 34571-621 34571-622 34571-623 34571-624 34571-613 34571-614 34571-615 34571-616 Note 쮿 Screw-fixed front panels see chapter Front panels, page 7.4 For further information www.schroff.biz/oneclick oneClick search code = Part no. Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.21 5_1_ratiopacPRO_e.fm Seite 22 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Rear panels with ventilation slots 7,2 쮿 Two versions: unshielded, Al, 2.5 mm; shieldable, Al extrusion (textile EMC seal, retrofittable) ø 5,9 x 3,3 3 3,2 / -airY Z 25 쮿 Mounting on horizontal rails (top and bottom) Delivery comprises B 7,45 W Description Rear panel, Al, 2.5 mm, front: anodised, rear: iridescent green chromated; unshielded or shieldable with EMC seal (textile) Order Information 7,45 2,5 3,7 W - 2,58 3,7 Qty 1 3 H Item 1 01802055 2,5 Shieldable 01804050 Unshielded Height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 5, 6-air 5, 6-air 5, 6-air 5, 6-air 6, 7-air 6, 7-air 6, 7-air 6, 7-air H mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 217.3 217.3 217.3 217.3 261.8 261.8 261.8 261.8 Width W HP mm 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 B mm – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 unshielded Part no. shieldable Part no. 30849-007 30849-014 30849-015 30849-016 30849-008 30849-021 30849-022 30849-023 30849-009 30849-028 30849-029 30849-030 30849-011 30849-171 30849-172 30849-173 30849-010 30849-035 30849-036 30849-037 20848-679 20848-680 20848-681 20848-682 20848-633 20848-634 20848-635 20848-636 20848-656 20848-657 20848-658 20848-659 20848-744 20848-745 20848-746 20848-747 20848-640 20848-641 20848-642 20848-643 쮿 Please order textile EMC seals separately 쮿 Assembly parts see page Chapter 7, Front panels 쮿 Rear/front panels without perforation see Chapter 7, Front panels 쮿 Rear panels with fan available on request Textile EMC seals Front panels Delivery comprises Item 1 Qty Description 10/100 Textile EMC seal, core: foam, sleeve: textile cladding with CuNi coating Order Information 04602054 5.22 Main Catalogue E 10/2012 Height U 2, 3-air 3, 4-air 3, 4-air 4, 5-air 5, 6-air 6, 7-air 6, 7-air Height mm 52 97 97 142 187 232 232 Qty/PU pieces 10 100 10 10 10 100 10 Part no. 21101-857 21101-854 21101-853 21101-858 21101-978 21101-856 21101-855 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 23 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Tip-up feet and stacking aid/design element / -airY 쮿 Can be used instead of standard feet 쮿 Carrying capacity: 25 kg per foot 쮿 Mounting holes in bottom of casing Delivery comprises ((kit)) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information 01802075 Tip-up foot Description Tip-up foot, silver, similar to RAL 9006 Tip-up foot, anthracite, similar to RAL 7016 Stacking aid/design element silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid/design element anthracite, similar to RAL 7016, PA, UL 94 V-0, PU 4 pieces Part no. 20603-001 20603-002 20603-004 20603-003 Note 쮿 Tip-up feet are required to mount the stacking aid For further information www.schroff.biz/oneclick oneClick search code = Part no. 01802076 Stacking aid/design element Air filters for ratiopacPRO air / -airY 쮿 Retrofit mounting without reworking and tools 쮿 Filter replacement without opening the case, IP protection retained Delivery comprises (kit) Item 1 2 3 Qty 1 1 1 Description Filter holder, Al, 1 mm, powder-coated, RAL 9006 Filter mat, synthetic fibre Self-adhesive fixings Order Information For case width HP 28 42 63 84 Air filter Part no. Replacement filter 1 piece Part no. 24571-325 24571-326 24571-327 24571-328 64571-033 64571-034 64571-035 64571-036 쮿 To optimise the air supply, tip-up feet must be fitted to the case, see page 5.23 rppr6658 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.23 Desk-top cases – Y / -air Earthing kit / -airY 쮿 Forms the GND/earthing connections between side panels, base plate, top cover and rear panel 쮿 Protective GND/earthing connections in accordance with: – DIN EN 50178/VDE 0160 – DIN EN 60950/VDE 0805 – DIN EN 61010-1/VDE 0411 part 1 – DIN EN 61010-1A2/VDE 0411 part 1/A1 쮿 VDE tested Order Information Description GND/earthing kit, Cu wire 1.5 mm2, PVC sleeve, green/yellow Part no. 24571-380 aza43284 5.24 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – Y Front handles for retrofitting Y 쮿 For conversion of cases with cover strip, 19" mounting bracket or 19" mounting bracket with front handle Delivery comprises Item 1 Qty 2 Description Front handle, Al die-cast, powder-coated, RAL 7016 Order Information Front handle for RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 5 U RatiopacPRO 6 U RatiopacPRO air 3/4 U RatiopacPRO air 4/5 U RatiopacPRO air 6/7 U RPPR6651 Part no. 24571-301 24571-302 24571-993 24571-303 24571-304 24571-305 24571-306 19" mounting brackets for retrofitting Y 쮿 For conversion of cases with cover strip, front handle or 19" mounting bracket with front handle Delivery comprises Qty 2 Description 19" mounting bracket, Al diecast, powder-coated, RAL 7016 Order Information RPPR6652 19" mounting angle RatiopacPRO 2 U RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 5 U RatiopacPRO 6 U RatiopacPRO air 4 U RatiopacPRO air 5 U RatiopacPRO air 7 U Part no. 24571-994 24571-295 24571-296 24571-992 24571-297 24571-298 24571-299 24571-300 19" mounting bracket with front handle for conversion YMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 For conversion of cases with cover strip, front handle or 19" mounting bracket Delivery comprises Qty 2 Description 19" mounting bracket with front handle, Al diecast, powdercoated, RAL 7016 Order Information 19" mounting angle RatiopacPRO 2 U RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 6 U RatiopacPRO air 4 U RatiopacPRO air 7 U 01813056 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Part no. 24572-700 24572-701 24572-702 24572-704 24572-705 24572-707 5.25 5_1_ratiopacPRO_e.fm Seite 26 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Cable holder Delivery comprises 46 9 26,5 19 14 17 Ø3 Ø4 Item 1 Qty 2 2 1 3 1 Description Cable bracket, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drilled holes each per bracket are needed in rear panel Assembly kit ,4 Ø3 Ø 4,4 Order Information 20,2 02908053 02908052 Description Cable holder Part no. 24575-800 For further information www.schroff.biz/oneclick oneClick search code = Part no. Air baffles for ratiopacPRO air / -airY 쮿 The air baffle (item 1) closes the space (1/2 U) between the rear horizontal rail and base plate Delivery comprises (in kit form) Item 1 Qty 1 Description Compartment seal, PE foam, UL 94 HF 1 + HF 2, self-adhesive, temperature range: -40 °C ... +85 °C Order Information For case width HP 42 63 84 Length mm 218.4 325.1 431.8 Part no. 20833-351 20833-352 20833-353 Note 01805059 쮿 Fan rear panel available on request 쮿 Radial fan unit see page 5.17 Strap handles / -airY 쮿 Retrofittable without mechanical modifications to the case 쮿 Static load-carrying capacity 20 kg per pair Delivery comprises (kit) Item 1 Qty 1 2 3 4 1 2 1 Description Handle, steel spring, plastic-sheathed (flexible plastic), RAL 7016 Side plate, Al, visible surfaces powder-coated, RAL 9006 Adaptor, Al die-cast Assembly kit Order Information For case depth 06801515 5.26 Main Catalogue E 10/2012 mm 315 375 435 For case height 3 U, 4 U air Part no. For case height4 HE, 5 Uair Part no. 24571-308 24571-309 24571-310 24571-314 24571-315 24571-316 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – Y / -air Tip-up carrying handles / -airY 쮿 Retrofittable without mechanical modifications to the case 쮿 Adjustable in 30° increments 쮿 Static load-carrying capacity 30 kg Delivery comprises (kit) Item 1 2 3 4 5 06803006 RPA43897 For case height U 3, 4, 4-air, 5-air 3, 4, 4-air, 5-air 3, 4, 4-air, 5-air For case width HP 42 63 84 A mm 283,4 390,1 496,8 B mm 279,4 386,1 492,8 C mm 247,4 354,1 460,8 D mm 115 195 195 Qty 1 1 2 2 2 Description Carrying bar, Al extrusion, powder coated, RAL 9006 Handle shell, ABS, UL 94 V-0, RAL 7016 Tip-up protection, ABS, UL 94 V-0, RAL 7016 Notch device, Al die-cast Cover cap, ABS, UL 94 V-0, RAL 7016 Order Information For case height For case width For case depth U 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air HP 42 42 42 42 42 63 63 63 63 63 84 84 84 84 84 42 42 42 42 42 63 63 63 63 63 84 84 84 84 84 mm 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 Tip-up carrying handle Part no. Assembly kit 24571-320 24571-320 24571-320 24571-320 24571-320 24571-321 24571-321 24571-321 24571-321 24571-321 24571-322 24571-322 24571-322 24571-322 24571-322 24571-320 24571-320 24571-320 24571-320 24571-320 24571-321 24571-321 24571-321 24571-321 24571-321 24571-322 24571-322 24571-322 24571-322 24571-322 24571-352 24571-353 24571-354 24571-355 24571-356 24571-352 24571-353 24571-354 24571-355 24571-356 24571-352 24571-353 24571-354 24571-355 24571-356 24571-359 24571-360 24571-361 24571-362 24571-363 24571-359 24571-360 24571-361 24571-362 24571-363 24571-359 24571-360 24571-361 24571-362 24571-363 Part no. Note 쮿 Cannot be used in conjunction with front handles 쮿 Assembly kit is required for tip-up carrying handle, please order separately For further information www.schroff.biz/oneclick oneClick search code = Part no. rpa43898 Main Catalogue E 03/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.27 5_1_ratiopacPRO_e.fm Seite 28 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Torx panhead screws / -airY Order Information Description Application Countersunk screw with Torx Countersunk screw with Torx Material Dimension Qty/PU For horizontal rail to side panel, with GND/earthing St, zinc-plated function M4 х 14 100 24571-371 For horizontal rail to side panel, if guide rail is bolted onto slot 1 M4 х 10 100 24571-372 St, zinc-plated Part no. AZA45923 Nut Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days Order Information Description Application Material Dimension Qty/PU Part no. Square nut For fixing: parts to side panels, support profiles, mounting plates St, zinc-plated M4 100 Dimension Qty/PU T8 1 64560-026 T20 1 64560-027 – 1 24560-271 – 1 24560-270 24560-140 AZA45921 Assembly tools Order Information Description Application Part no. Torx screwdriver AZA45925 Assembly tool for horizontal rails Exclusively to fix stainless steel EMC gaskets in horizontal rails aza45938 For mounting stainless steel Assembly tool for front EMC contact strips on front panels panels with lateral slot aza45937 5.28 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 29 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Mounting position ratiopacPRO horizontal rails/central rails front Text rear 2U front rear 3U H-LD H-LD H-LD H-LD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-LD H-LD H-LD H-LD 01805060 01802057 4 U (3 U + 1 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-LD H-LD 01802058 5 U (1 U + 3 U + 1 U) H-LD H-LD H-LD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-LD 5 U (3 U + 2 U) H-KD / H-LD / L-KD H-LD H-LD H-LD H-LD 01805061 6U 01805062 6 U (2 x 3 U) H-LD H-LD H-LD H-LD 233,35 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 ST / VT / MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD H-LD H-LD 01802059 01802060 H-LD H-ST L-ST H-KD H-VT L-VT L-KD H-MZ L-MZ ST VT MZ Horizontal rails can be bolted on in 15 mm depth grid Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 01808050 5.29 5_1_ratiopacPRO_e.fm Seite 30 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Mounting position ratiopacPRO air horizontal rails/central rails front Text rear front rear 4-air U (1/2 U + 3 U + 1/2 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD 01802061 5-air U (1/2 U + 3 U + 1U +1/2 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-LD H-LD 01802062 7-air U (1/2 U + 6 U + 1/2 U) H-LD 7-air U (1/2 U + 3 U + 3U 1/2 U) H-LD H-LD H-LD 233,35 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ ST / VT / MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-KD / H-LD / L-KD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD H-LD H-LD 01802063 01802064 H-LD H-ST L-ST H-KD H-VT L-VT L-KD H-MZ L-MZ ST VT MZ Horizontal rails can be bolted on in 15 mm depth grid 5.30 Main Catalogue E 10/2012 01808050 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 31 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Front horizontal rails Order Information With long lip for insertion/extraction of CompactPCI and VME64x boards "heavy" Type H-LD long lip "heavy" Type H-KD short lip bza44980 Usable length HP Length mm 28 147.32 42 218.44 63 325.12 84 431.80 M4 × 10, St, zinc-plated, necessary if guide rail is screwed to slot 1, PU 100 pieces Threaded inserts see page 06197008 06197009 Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-228 34560-242 34560-263 34560-284 34560-328 34560-342 34560-363 34560-384 24571-372 24571-372 5.35 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.31 5_1_ratiopacPRO_e.fm Seite 32 Montag, 1. Oktober 2012 5:30 05 Desk-top cases – Y / -air Rear horizontal rails Main Catalogue Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 "heavy" Type H-ST standard Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx panhead screw, 4 x 10 Perforated rail for connector mounting with insulation strip see page Z-rail for connector mounting without insulation strip see page Insulation strips see page Threaded inserts see page 04400002 "heavy" Type H-VT long lip 06105074 For direct fixing of connectors to EN 60603-2 (DIN 41612) 06197011 04400003 "heavy" Type H-MZ with Z-rail 06197013 06197015 Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-528 34560-542 34560-563 34560-584 24571-372 34560-728 34560-742 34560-763 34560-784 24571-372 34560-928 34560-942 34560-963 34560-984 24571-372 5.35 – – 5.35 – – 5.35 5.35 – 5.35 – 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg 5.32 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 33 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Horizontal rails rear, centre Main Catalogue Order Information For indirect mounting of backplanes via insulation strip For direct backplane mounting 04400001 Type ST 06108090 For direct fixing of connectors to EN 60603-2 (DIN 41612) 04400002 Type VT 06197016 04400003 Type MZ 06197017 06197018 Al extrusion, finish anodised, Al extrusion, finish anodised, Al extrusion, finish anodised, conductive contact surface; conductive contact surface; conductive contact surface; horizontal rail type AB (AB = support) horizontal rail type AB (AB = support) horizontal rail type AB (AB = support) is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards; without marking without marking without marking Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx panhead screw, 4 x 10 Insulation strips see page Threaded inserts see page 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34561-028 34561-042 34561-063 34561-084 24571-372 34561-128 34561-142 34561-163 34561-184 24571-372 34561-228 34561-242 34561-263 34561-284 24571-372 5.35 5.35 – 5.35 – 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.33 5_1_ratiopacPRO_e.fm Seite 34 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Horizontal rails (type AB) for rear I/O guide rails Main Catalogue Order Information For CompactPCI in rear I/O area 12,75 AB H - ST 9,75 15 12,75 H - KD 3 06108009 Type AB H - ST AB H - KD 06108069 06197009 Al extrusion, finish anodised, conductive contact surface; horizontal rail type AB (AB = support) is required to fix the 80 mm rear I/O boards; without marking Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to side panel 1 piece (SPQ 10)1) 34561-520 34561-528 34561-540 34561-542 34561-563 34561-584 34561-501 24560-130 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 All horizontal rails without print 쮿 1000 mm version without M4 thread in end 5.34 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 35 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Threaded inserts, perforated strips, insulation strips Threaded insert M2.5 M3 Perforated strip (item 1) Insulation strip 5 2 5,0 8 06103056 Required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.64 Usable length HP Length mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) – – – BZA45853 BZ6749 For centring shielded plug-in units, Al, 1 mm, please order fixing grub screw separately Length mm For insulated mounting of backplane; PBT UL 94 V-0, grey Length 1 piece (SPQ 10)1) mm PU 10 pieces2) 28 146.82 147.12 144.20 34561-328 30845-197 24560-828 42 217.94 218.24 210.40 34561-342 30845-211 24560-842 63 324.62 324.92 316.88 34561-363 30845-232 24560-863 84 431.30 431.60 428.64 34561-384 34561-484 30845-253 24560-884 Accessories Grub screw M2.5 x 8, PU – – – 21100-276 100 pieces Grub screw M2.5 x 9, PU – – – 21101-359 100 pieces Grub screw M3 x 8, PU – – – 21100-646 100 pieces 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Z-rails, perforated rails Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 12,7 5 9,7 BZA45850 BZA45848 5 5 12,7 3,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Torx panhead screw, to fix connector to perforated rail,, M2.5 × 7, PU 100 piecesItem 3 Torx panhead screw, to fix perforated rail to horizontal rail, M2.5 × 10, PU 100 pieces Item 2 Main Catalogue E 10/2012 06708051 For connector mounting with ST horizontal rails, please order threaded insert and screw separately For connector mounting with ST horizontal rails, please order threaded insert and screw separately For connector mounting with VT horizontal rails, please order threaded insert and screw separately 1 piece 1 piece – – PU 4 pieces 30822-033 30822-047 30822-065 30822-089 30819-783 30819-808 20822-049 20822-050 20822-047 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.35 5_1_ratiopacPRO_e.fm Seite 36 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Divider plates Order Information Divider plates Mounting position for Mounting position for stainless steel EMC gasket textile EMC gasket front rear front bpa45911 rear 06105078 Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space requirement on component side 2 mm; mounting direction varies with shielding design (EMC stainless steel or textile gasket); retrofitting the divider plate in an already-assembled subrack/case will first require dismantling of the horizontal rails; where front panels are unshielded, both mounting directions are possible bpa45912 Height U 3 3 6 6 5.36 Depth mm 160 220 160 220 Main Catalogue E 10/2012 A mm 158.3 218.3 158.3 218.3 B mm 135.0 195.0 135.0 195.0 H mm 113.5 113.5 246.9 246.9 1 piece 34562-761 34562-762 34562-763 34562-764 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 37 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Mounting plates Order Information Mounting plate Assembly strip for partial widths bpa45875 Al, 1.5 mm; for mounting over partial width, please order assembly strips separately bpa46557 St, 2 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates 06812002 Width Board lengths HP mm mm 28 146.88 160 28 146.88 220 28 146.88 280 28 146.88 340 42 217.99 160 42 217.99 220 42 217.99 280 42 217.99 340 63 324.67 160 63 324.67 220 63 324.67 280 63 324.67 340 84 431.35 160 84 431.35 220 84 431.35 280 84 431.35 340 Assembly kit for mounting plate PU 1 kit (Torx countersunk screw M4 x 5, St, zincplated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for assembly strips of mounting plate Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces 1 piece 1 piece 34562-745 34562-749 34562-753 34562-757 34562-746 34562-750 34562-754 34562-758 34562-747 34562-751 34562-755 34562-759 34562-748 34562-752 34562-756 34562-760 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 24560-184 – – 24560-146 Note 쮿 Please order fixing material for assembly of mounting plate separately 쮿 A guide rail can be mounted on the first and last slot position 쮿 4.4" and "reinforced" guide rails cannot be used Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.37 5_1_ratiopacPRO_e.fm Seite 38 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Horizontal board installation Order Information Horizontal board installation Front frame for EMC shielding Board cage 27 3.9 8= 54 Front frame, unshielded TE w 273 h =5 4T 06102073 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 TE space required; please order front frame for EMC shielding separately E H ,98 bpa45913 bza43061 2 horizontal covers, Al, 2.5 mm, clear anodised; AI, 2.5 mm, front anodised, front frame with cut-out, rear iridescent green chromated; clear internal width w = 266.35 mm 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the subassemblies bpa45914 Height U Usable height h HP 3 Other dimensions and options PU 1 kit PU 1 kit 1 piece 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Assembly tool, for mounting the EMC gasket (stainless steel) Horizontal rail, rear * For direct backplane mounting Note 쮿 Please order front frame separately 5.38 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 39 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Combined mountings (6 U and 2 x 3 U one above the other) Order Information Combined mounting Horizontal and vertical subdivision (incl. front panel for stainless steel EMC gasket) Alternative front panels for combined mounting Unshielded front Front panel for panel, 6 U, 2 HP textile EMC gasket, item 6 6 U, 2 HP item 6 Splitting extrusion For combined mounting Item 2 2 4 2 1,3 1,3 4 6 bpa46549 bza42182 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Countersunk screw with Torx M4 × 14, zinc-plated, PU 100 pieces fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces fixing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer, 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces bpa46549 bpa46549 bza45857 Item 1: 2 front horizontal rails (H-KD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zincplated; item 4: Zn die-cast support member; item 6: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket (84:0 without items 4, 6) Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, die-cast zinc; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 (SPQ 5) 1 piece (SPQ 5)1) 1 piece 24562-420 24562-440 24562-442 24562-463 24562-484 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accept Euroboards (100 mm high) and double Euroboards (233.35 mm high) Note 쮿 Please order EMC gasketing kit for horizontal rails separately, see page 5.19 쮿 Please order perforated strips for horizontal rails separately, see page 5.35 쮿 Please order rear centre horizontal rail separately, see page 5.33 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.39 5_1_ratiopacPRO_e.fm Seite 40 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Standard For plug-in units and frame type plug-in units With DIN connector fixing as standard Storage temperature from -40 °C ... 130 °C 06101001 Board lengths mm 70 70 160 220 280 340 160 220 Groove width mm 2 2 2 2 2 2 2.5 2.5 06101501 Up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards 100 x 160 mm or 100 x 220 mm only PU 10 pieces2) – – 1 pair (SPQ 10)1) – – 24560-351 24560-353 24560-379 24560-380 64560-074 64560-075 Colour mm red grey red red red red red red – – – – – – Accessories Retention screw, PU 100 pieces 24560-141 ESD clip, PU 50 pieces 24560-255 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.41 5.40 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 41 Montag, 1. Oktober 2012 5:51 05 Desk-top cases – Y / -air Guide rails type "accessories", one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plate Guide rail type "Accessories" strengthened "Accessories" For heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... +130 °C 06102002 Board lengths mm 100 160 160 220 220 280 340 400 160 220 280 340 400 Groove width mm 2 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 bza46554 06102005 Up to 220 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94V-0, red; support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces2) – 1 piece (SPQ 50)1) – 24560-373 Colour mm red red grey red grey red/silver red/silver red/silver silver silver silver silver silver 64560-076 1 piece (SPQ 10)1) – – – – 34562-881 24560-374 64560-078 – – – 24560-375 24560-376 64560-080 – – – – – – – – – – – – – 34562-882 34562-883 34562-884 34562-885 34564-881 34564-882 34564-883 34564-884 34564-885 24560-141 24560-141 24560-157 Accessories Retention screw, PU 100 pieces ESD clip, PU 50 pieces Board locking, red, PU 10 pieces Board handle, red, PU 10 piecesdescription Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page 24560-255 – 24560-377 – 24560-378 – 60817-228 – 6.41 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.41 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.41 5_1_ratiopacPRO_e.fm Seite 42 Montag, 17. September 2012 7:04 19 Desk-top cases – Y / -air Guide rails for CompactPCI, VME64x with coding, 4.4" PCBs, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into1.5 mm thick plates For CompactPCI, VME64x with coding In accordance with IEEE 1101.10 Offset 0.1" for power supply units in and IEC 60297-3-103 accordance with IEEE 1101.10 and IEC 60297-3-103 For 4.4" PCBs Storage temperature from -40 °C ... 130 °C 06106001 Board lengths mm 70 70 160 160 160 220 220 220 160 220 220 280 280 340 340 Groove width mm 2 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 2.5 2.5 Colour mm red grey red grey green red grey green red red grey red grey red grey 06106002 06104009 One-piece for groove width 2 mm, PBT, UL 94 V-0; multi-piece at groove width 2,5 mm, end-piece PBT, UL 94 V-0, center piece Al profile PBT, UL 94 V-0, for installation of power supplies in CompactPCI systems or plug-in units with SMD placement One-piece, PBT, UL 94 V-0; for 4.4" PCBs or drive units PU 10 pieces2) PU 10 pieces2) PU 10 pieces 24560-355 24560-360 24560-356 24560-358 – – – – – – – – – – – 24560-359 24560-361 – – 24560-362 24561-330 24561-340 24561-331 24561-341 24561-332 24561-342 – – – – – – – – – – 24560-255 – – 24560-256 24560-256 – 24560-141 20817-501 24560-141 20817-501 24560-158 – – – – – – – – – Accessories ESD clip, PU 50 pieces ESD clips, for alignment pin, PU 50 pieces Retention screw, PU 100 pieces Coding peg, PU 100 pieces – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.41 Note 쮿 Reinforcement for plastic profiles (PVC) > 280 mm depth available on request 5.42 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_1_ratiopacPRO_e.fm Seite 43 Montag, 1. Oktober 2012 5:57 05 Desk-top cases – Y / -air Air baffle for slots Main Catalogue Order Information Air baffle without front panel Air baffle with front panel front panel with lateral U front panel groove for stainless steel for textile EMC gasket EMC gasket 06108085 Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06108087 Air baffle, Al, 1 mm; front panel, Al, 2.5 mm, front anodised, rear conductive; EMC gasket (stainless steel); fixing material kit prevents an air short- circuit where slots are unoccupied; is pushed into the groove of the guide rails 06108088 Air deflector, Al, 1 mm, front panel, Al extrusion, 2.5 mm, front anodised, rear conductive; EMC gasket (textile); fixing material kit prevents an air short-circuit where slots are unoccupied; is pushed into the groove of the guide rails 06101507 Depth Width mm HP 160 4 160 4 160 8 160 8 160 12 160 12 220 4 220 4 220 8 220 8 220 12 220 12 Assembly tool for EMC gasket (stainless steel), 1 piece Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 1 piece 1 piece 34562-823 34562-826 34562-833 34562-836 34562-843 34562-846 34562-824 34562-827 34562-834 34562-837 34562-844 34562-847 20848-712 20848-720 20848-714 20848-722 20848-716 20848-724 20848-713 20848-721 20848-715 20848-723 20848-717 20848-725 20848-728 20848-736 20848-730 20848-738 20848-732 20848-740 20848-729 20848-736 20848-731 20848-739 20848-733 20848-741 – 24560-270 – Note 쮿 Air baffle for 280 mm deep and for 80 mm rear I/O boards available on request Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.43 5_2_propacPRO_e.fm Seite 44 Montag, 17. September 2012 7:46 19 iMain Catalogue Overview . . . . . 0 Desk-top cases – i Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . 2 Accessories for cabinets and wall mounted cases 3 Climate control 4 Desk-top cases 5 05809001 Subracks/ 19" chassis . . . 6 05806052 Front panels, plug-in units . . 7 Easy access provided by removable cladding parts 05806050 Extremely robust one-piece die-cast frame 05806055 Non-sensitive, scratch-resistant finish through powder coating 05806056 Low weight Systems . . . . . . 8 Power supply units . . . . . . . . . 9 05806054 Wide accessory programme with acrylic glass front hoods, carrying handles, ... 05806053 Assembly possibility for euroboards and backplanes 05806051 EMC version noa44075 VDE-compliant GND/earthing Backplanes . . 10 Standards 쮿 Internal dimensions in accordance with IEC 60297-3-101 Connectors, front panel component system . . . . . . 11 쮿 Ingress protection IP 20 in accordance with IEC 60529 쮿 EMC test in accordance with VG 95373 part 15 Downloads and further important information can be found on the Internet under www.schroff.biz Appendix . . . . 12 5.44 쮿 Protective GND/earth connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A1 Main Catalogue E 10/2012 MicroTCA 5_2_propacPRO_e.fm Seite 45 Montag, 17. September 2012 7:46 19 Desk-top cases – i Overview . . . . 5.44 iMain Catalogue Aluminium case for 19" components to IEC 60297-3-100 or individual electronics assemblies 쮿 Front frame and side panels in aluminium 쮿 Extensive accessories, matched to portable applications 쮿 Basic level shielding from basic versions up, extended EMC shielding retrofittable 쮿 Design alternative to compacPRO Desktop cases 쮿 Complete case (pre-assembled) – Prepared for 19" components to IEC 60297 for installation of euroboards – Basic level shielding from basic versions up, extended EMC shielding retrofittable – Height 3 U, 6 U propacPRO Complete cases 3, 6 U, unshielded/ shielded . . . . . . . 5.46 Cases 2, 3 U . . . . 5.50 Cases 4, 6 U . . . . 5.51 Cases for tip-up carrying handle 3, 4 U. . . . . . . . . . 5.52 Dimensions . . . . . 5.53 쮿 Cases – Pre-assembled cases as basis for individual components or 19" components (IEC 60297) – Basic level shielding from basic versions up, extended EMC shielding retrofittable – Height: 2 U, 3 U, 4 U, 6 U – 3 U and 4 U cases prepared for tip-up carrying handle EMC shielding . . 5.55 Accessories Front panels . . . . 5.54 Rear panels . . . . . 5.55 Design elements 5.58 Lateral covers . . 5.59 Handles . . . . . . . . 5.60 Air filters . . . . . . . 5.61 05809003 05806003 Hoods . . . . . . . . . 5.62 Accessories Mounting plates . 5.64 GND/earthing kit 5.65 Cable holder . . . 5.65 Mounting position horizontal/ central rails . . . . 5.66 Horizontal rails . 5.67 Threaded inserts 5.68 Z-rails, perforated rails . 5.69 05809002 Combined mounting . . . . . . 5.70 Horizontal board assembly . . . . . . 5.71 ServicePLUS from page 5.4 e.g. modifications (special colours, special depths, cut-outs in top cover, base plate or side panels) e.g. assembly service from 1 piece Tip-up feet . . . . . 5.72 Guide rails and ESD clips . . . . . . 5.73 Divider plates . . . 5.75 Air flow barrier . . 5.75 www.schroff.biz/ServicePLUS ServicePLUS . . 5.4 30407004 Main Catalogue E 10/2012 5.45 Desk-top enclosure – i Complete case, EMC shielded iMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Rear panel with vent slots Delivery comprises (Items 1-7, 9 and 10 fitted) Item 05809004 1 2 Qty 3U 1 2 6U 1 4 Description 3 1 1 4 1 1 5 2 2 6 7 - 2 2 8 4 4 9 2 2 10a 2 2 10b 2 2 11 2 2 12 - 1 13 1 1 14 2 2 15 10/ 20 10/ 20 16 17 1 1 1 1 3U 13 12 11 3 10 b 14 2 1 9 6 5 15 10 a 4 9 7 8 05806106 Maximale Einbautiefe = D - 45 (Distanz: Frontplatte - Rückwand) Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006, with EMC side panel gasketing Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/ earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot when case is used in vertical position Adaptor bracket (only at 6 U) Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 (20603-002) Lateral trim, Al extrusion, visible surface painted, RAL 7016 with EMC sealing (textile) Horizontal rail, Al extrusion, with threaded insert, St, M2.5; perforated strip, Al, 1 mm, EMC contact strip between front panel - horizontal rail - cover plate Horizontal rail, Al extrusion, with threaded insert, St, M2.5; EMC contact strip between rear panel horizontal rail - cover plate Centre horizontal rail top/bottom, Al extrusion, with threaded insert, St, M2.5 and insulation strip, PBT, UL 94 V-0 (for indirect backplane mounting); enclosed loose Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with perforation, Al, 2.5 mm, anodised, with EMC sealing (textile) affixed EMC support profile rear, Al extrusion, EMC sealing (textile) affixed Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit ServicePLUS see page 5.4 5.46 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top enclosure – i Complete cases, EMC shielded W1 Main Catalogue Order Information 155,5 289,0 112,3 245,7 130,0 262,8 W2 05809051 D 150,9 121,95 32,5 Usable width W2 W2 HP mm 28 147.3 28 147.3 42 218.4 42 218.4 42 218.4 63 325.1 63 325.1 63 325.1 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 Width W1 W1 mm 185.9 185.9 257 257 257 363.7 363.7 363.7 470.3 470.3 470.3 470.3 470.3 470.3 470.3 Depth D D mm 266 326 266 326 386 266 326 386 266 326 386 446 506 326 446 Height U 3 3 3 3 3 3 3 3 3 3 3 3 3 6 6 Part no. 24576-101 24576-102 24576-103 24576-104 24576-105 24576-106 24576-107 24576-108 24576-109 24576-110 24576-111 24576-112 24576-113 24576-121 24576-122 Note 쮿 Dimension drawings of side panel see from page 5.53 For further information www.schroff.biz/oneclick Ø 4,6 7,2 15 oneClick search code = Part no. 4 05806060 3U D 15 7,2 121,95 265,9 284,3 121,95 32,5 Ø 4,6 4 05806062 6U Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.47 Desk-top enclosure – i Complete cases, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Rear panel perforated Delivery comprises (Items 1-7, 9 and 10 fitted) Item 1 2 3 Qty 3U 1 2 1 6U 1 4 1 Description 4 1 1 5 2 2 6 7 - 2 2 8 4 4 9 2 2 10 2 2 11 2 2 12 - 1 7 13 1 1 8 14 15 4 10/ 20 1 1 4 10/ 20 1 1 05809004 3U 13 3 12 11 2 1 9 14 6 5 15 10 4 9 16 17 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/ earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Adaptor bracket (only at 6 U) Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 (20603-002) Lateral trim, Al extrusion, visible surface painted, RAL 7016 with EMC sealing (textile) Horizontal rail, Al extrusion, with threaded insert, St, M2.5 Rear horizontal rail, Al extrusion, with threaded insert, St, M2.5 and insulation strips, PBT, UL 94 V-0 (for indirect backplane mounting) Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with perforation, Al, anodised, 2 mm at 28, 42 and 63 HP, 2.5 mm at 84 HP Support member for rear panel, Zn die-cast Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit 05806105 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) ServicePLUS see page 5.4 5.48 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top enclosure – i Complete cases, unshielded Order Information Main Catalogue W1 155,5 289,0 112,3 245,7 130,0 262,8 W2 05809051 D Width W1 Depth D Height mm 185.9 185.9 257 257 257 363.7 363.7 363.7 470.3 470.3 470.3 470.3 470.3 470.3 470.3 U 3 3 3 3 3 3 3 3 3 3 3 3 3 6 6 mm 266 326 266 326 386 266 326 386 266 326 386 446 506 326 446 Part no. 24576-001 24576-002 24576-003 24576-004 24576-005 24576-006 24576-007 24576-008 24576-009 24576-010 24576-011 24576-012 24576-013 24576-021 24576-022 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) 150,9 121,95 32,5 Usable width W2 W2 HP mm 28 147.3 28 147.3 42 218.4 42 218.4 42 218.4 63 325.1 63 325.1 63 325.1 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 Note 쮿 Dimension drawings of side panel see from page 5.53 Ø 4,6 7,2 15 For further information www.schroff.biz/oneclick 4 oneClick search code = Part no. 05806060 3U D 15 7,2 121,95 265,9 284,3 121,95 32,5 Ø 4,6 4 05806062 6U Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.49 5_2_propacPRO_e.fm Seite 50 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Cases, 2 and 3 U, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing Delivery comprises (kit, items 1 - 5 fitted) 05806001 Item 1 2 3 Qty 1 2 1 4 1 5 2 6 7 4 1 Description Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Order Information 05806057 05806077 Cross-section 2 U, 3 U Usable width Width W1 Depth D 2U W2 W2 Part no. HP mm mm mm 28 147.3 185.9 266 – 28 147.3 185.9 326 – 42 218.4 257 266 14576-021 42 218.4 257 326 14576-023 42 218.4 257 386 – 63 325.1 363.7 266 14576-041 63 325.1 363.7 326 14576-043 63 325.1 363.7 386 14576-045 84 431.8 470.3 266 – 84 431.8 470.3 326 – 84 431.8 470.3 386 – 84 431.8 470.3 446 – 84 431.8 470.3 506 – Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/ yellow, links side panels, base, cover and rear panel, PU 1 piece 3U Part no. 14576-101 14576-103 14576-121 14576-123 14576-125 14576-141 14576-143 14576-145 14576-161 14576-163 14576-165 14576-167 14576-169 21102-001 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) Note 쮿 Case, 3 U with side panel for tip-up carrying handle, see page 5.52 쮿 Dimensions see page 5.48 쮿 Dimensions side panel, see page 5.53 For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806059 2U 05806060 3U ServicePLUS see page 5.4 5.50 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 51 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Cases, 4 and 6 U, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing Delivery comprises (kit, items 1 - 6 fitted) Item 05806003 1 2 3 Qty 4U 1 2 1 6U 1 4 1 Description 4 1 1 5 2 2 6 7 – 2 2 2 8 4 4 9 1 1 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/ earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Adaptor bracket, Al Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Order Information 05806058 05806078 Usable width Width W1 Depth D 4U W2 W2 Part no. HP mm mm mm 42 218.4 257 266 14576-221 42 218.4 257 326 14576-223 63 325.1 363.7 266 14576-241 63 325.1 363.7 326 14576-243 63 325.1 363.7 386 14576-245 63 325.1 363.7 446 14576-247 84 431.8 470.3 326 – 84 431.8 470.3 386 14576-265 84 431.8 470.3 446 14576-267 84 431.8 470.3 506 14576-269 Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/ yellow, links side panels, base, cover and rear panel , PU 1 piece 6U Part no. – – – – – – 14576-463 14576-465 14576-467 14576-469 21102-001 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) Note 쮿 Case, 4 U with side panel for tip-up carrying handle, see page 5.52 쮿 Dimensions side panel, see page 5.53 For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806061 4U 05806062 6U ServicePLUS see page 5.4 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.51 5_2_propacPRO_e.fm Seite 52 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i 3 U and 4 U cases, unshielded, with holes for tip-up carrying handle iMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing 쮿 Prepared for fitting of tip-up carrying handle 05812006 Delivery comprises (kit, items 1 - 6 fitted) Item 1 2 Qty 3U 1 2 4U 1 4 Description 3 1 1 5 4 1 1 2 5 2 2 6 – 2 7 4 4 8 1 1 3 1 4 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006; with drill holes for tip-up carrying handle Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit 7 Order Information 05812050 W1 155,5 200,0 112,3 156,8 130,0 174,0 W2 05812051 D 69,0 D 32,5 69,0 17,0 17,0 Ø 4,6 17,0 17,0 Ø 4,6 195,3 11,4 15 Ø 4,6 7,2 7,2 15 05812052 3U 14577-223 – 14577-243 14577-245 – 14577-265 21102-001 24576-071 24576-072 24576-073 Note Ø 4,6 4 4 4U Part no. 쮿 Dimensions see page 5.48 쮿 Dimensions side panel, see page 5.53 33,05 150,9 121,95 Ø 10,4 Ø 10,4 121,95 32,5 Usable width Width W1 Depth D 3U W2 W2 Part no. HP mm mm mm 42 218.4 257.0 326 14577-123 42 218.4 257.0 386 14577-125 63 325.1 363.7 326 14577-143 63 325.1 363.7 386 14577-145 84 431.8 470.3 326 14577-163 84 431.8 470.3 386 14577-165 Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/ yellow, links side panels, base, cover and rear panel , PU 1 piece Tip-up carrying handle for 42 HP case width, PU 1 kit Tip-up carrying handle for 63 HP case width, PU 1 kit Tip-up carrying handle for 84 HP case width, PU 1 kit For further information www.schroff.biz/oneclick 05812053 4U oneClick search code = Part no. ServicePLUS see page 5.4 5.52 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 53 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Dimensions Extruded side panel 2 U Extruded side panel 3 U Text 05806079 Extruded side panel 4 U, right 05806080 Extruded side panel 4 U, left 05806081 Extruded side panel 6 U 05806082 Dimensions table For case depth D d n mm 266 326 386 446 506 mm 221.6 281.6 341.6 401.6 461.6 mm 210 270 330 390 450 14 18 22 26 30 Note A side panel for case 6 U consists of 2 pieces 3 U extruded side panels Side panel with horizontal rail D 12,25 05806083 Main Catalogue E 10/2012 e = D - 62,1 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 05806107 5.53 5_2_propacPRO_e.fm Seite 54 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Front panel, unshielded, for mounting on case frame Main Catalogue Delivery comprises Item 1 Qty 1 2 1 Description Full-width front panel, Al, 2 mm (on 84 HP = 2.5 mm), anodised, cut edges plain Assembly kit Order Information 05806063 For case height U 2 2 2 3 3 3 3 4 4 4 6 For case width HP 42 63 84 28 42 63 84 42 63 84 84 A B C D Part no. mm 238.7 345.4 452.0 167.6 238.7 345.4 452.0 238.7 345.4 452.0 452.0 mm 230.0 336.7 443.3 158.9 230.0 336.7 443.3 230.0 336.7 443.3 443.3 mm 74.0 74.0 74.0 118.5 118.5 118.5 118.5 162.9 162.9 162.9 251.8 mm 84.0 84.0 84.0 128.5 128.5 128.5 128.5 172.9 172.9 172.9 261.8 20850-128 20850-129 20850-130 20850-134 20850-135 20850-136 20850-137 20850-142 20850-143 20850-144 20850-158 쮿 EMC front panel see chapter Front Panels, page 7.7 PPA43756 Front panel, 1 U, unshielded, for 4 U case, for mounting on horizontal rails Main Catalogue Delivery comprises Item 1 Qty 1 Description Front panel, Al, 2.5 mm, front anodised, rear iridescent green chromated Order Information Width HP 28 42 63 84 A mm 141.9 213.0 319.7 426.4 B mm 127.0 198.1 304.8 411.5 C mm – 101.6 157.5 203.2 Front panel Part no. 20850-423 20850-424 20850-425 20850-426 Note 쮿 Please order items 2, 3 and 4 separately 05806064 Width HP 28 42 63 84 05806065 5.54 Main Catalogue E 10/2012 Item 2 EMC gasket, front panel/ horizontal rail PU 10 pieces Part no. Item 3 EMC gasketing kit horizontal rails, 1 piece Part no. Part no. 24560-229 24560-231 24560-233 24560-235 24562-528 24562-542 24562-563 24562-584 34560-228 34560-242 34560-263 34560-284 Item 4 Horizontal rail type H-KD, 1 piece (SPQ 10)1) 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 55 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Rear panel, perforated, for mounting on horizontal rails 7,2 쮿 Two versions: unshielded, Al, 2.5 mm shieldable, Al extrusion (textile EMC gasketing retrofittable) ø 5,9 x 3,3 3 Delivery comprises Item 1 Qty 1 H 25 3,2 Main Catalogue Z Description Rear panel, Al, 2.5 mm, front: anodised, rear: iridescent green chromated; unshielded or shieldable with EMC sealing (textile) B 7,45 W 3 Order Information 7,45 2,5 01802055 01804050 Unshielded 2,5 3,7 3,7 W - 2,58 01802055 Height U 2 2 2 2 3 3 3 3 4 4 4 4 6 6 6 6 쮿 쮿 쮿 쮿 H mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 261.8 261.8 261.8 261.8 Width W HP mm 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 B mm – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 h mm 78 78 78 78 122.4 122.4 122.4 122.4 166.9 166.9 166.9 166.9 255.8 255.8 255.8 255.8 unshielded Part no. shieldable Part no. 30849-007 30849-014 30849-015 30849-016 30849-008 30849-021 30849-022 30849-023 30849-009 30849-028 30849-029 30849-030 30849-010 30849-035 30849-036 30849-037 20848-679 20848-680 20848-681 20848-682 20848-633 20848-634 20848-635 20848-636 20848-656 20848-657 20848-658 20848-659 20848-640 20848-641 20848-642 20848-643 Please order textile EMC gasket separately EMC gasket rear panel - horizontal rail see page 5.65 Horizontal rails see page 5.67 Assembly parts see page 6.63 Shieldable Textile EMC gasket Main Catalogue 쮿 The textile EMC gasket is glue fixed laterally on the front panel, always in the groove on the right-hand side of the profile 쮿 Temperature range -40 °C ... +70 °C Delivery comprises () Item 1 Qty Description 10/100 Textile EMC gasket, core: foam, sleeve: textile cladding with CuNi coating Order Information 04602054 Main Catalogue E 10/2012 Height U 2 3 3 4 6 6 Height mm 52 97 97 142 232 232 Qty/PU pieces 10 100 10 10 100 10 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Part no. 21101-857 21101-854 21101-853 21101-858 21101-856 21101-855 5.55 5_2_propacPRO_e.fm Seite 56 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Rear panel, unshielded, for mounting on case frame Main Catalogue 쮿 Mounting with support brackets on case (right and left) 쮿 Versions with and without perforation Delivery comprises Item 1 Qty 1 2 3 4 1 Description Full-width rear panel, Al, anodised, cut edges blank 28, 42, 63 HP = 2 mm thickness 84 HP = 2.5 mm thickness Support member, Zn die-cast Assembly kit Order Information 05806066 Height H Width W w U 2 2 2 3 3 3 3 4 4 4 6 HP 42 63 84 28 42 63 84 42 63 84 84 mm 190 298 406 118 190 298 406 190 298 406 406 mm 84 84 84 128.5 128.5 128.5 128.5 172.9 172.9 172.9 261.8 mm 213 320 426 142 213 320 426 213 320 426 426 With perforation Part no. Without perforation Part no. 24576-144 24576-145 24576-146 24576-147 24576-148 24576-149 24576-150 24576-152 24576-153 24576-154 24576-158 24576-044 24576-045 24576-046 24576-047 24576-048 24576-049 24576-050 24576-052 24576-053 24576-054 24576-058 ppa43882 Rear panel, shielded, for mounting on case frame Main Catalogue 쮿 Mounts on case (left, right) 쮿 Without perforation Delivery comprises Item 1 Qty 1 2 2 3 2 4 1 Description Full-width EMC rear panel, Al 1.5 mm, passivated, with GND/earthing connection (Faston 6.3 mm) Textile EMC gasketing, for mounting top and bottom, core: foam, sleeve: textile cladding with CuNi coating Textile EMC gasketing, for mounting left and right, core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information 05806067 5.56 Main Catalogue E 10/2012 Height U 2 2 3 3 3 3 4 4 4 6 H mm 101.5 101.5 146 146 146 146 190.4 190.4 190.4 279.3 Height h mm 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 261.8 Width W HP mm 42 217.9 63 324.6 28 146.8 42 217.9 63 324.6 84 431.3 42 217.9 63 324.6 84 431.3 84 431.3 w mm 213 319.7 141.9 213 319.7 426.4 213 319.7 426.4 426.4 Part no. 24576-244 24576-245 24576-247 24576-248 24576-249 24576-250 24576-252 24576-253 24576-254 24576-258 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 57 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Front panel, hinged, shielded, for mounting on horizontal rails Main Catalogue 쮿 Front panel with textile EMC gasketing 쮿 Hinges can be fitted left or right 쮿 Suitable for europacPRO subrack and ratiopacPRO, compacPRO and propacPRO cases Delivery comprises (kit) 2 1 3 5 05806102 Item 1 Qty 1 2 3 2 1 4 1 Description Front panel, hinged, Al, 2.5 mm, front anodised, rear iridescent green chromated Hinge, Zn die-cast, chrome-plated Textile EMC gasket core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information Height Width H h W w U HP mm mm mm mm 3 84 128.4 89.9 426.4 203.2 6 84 261.8 223.2 426.4 203.2 Item 5, Horizontal rail Type H-VT heavy duty, recessed mounting 84 HP, 1 piece (SPQ 10) Part no. 20848-611 20848-617 34560-784 Note 05806097 쮿 Usable width reduced by 2 HP (hinged side) 쮿 Horizontal rail (item 5) for front panel mounting is required, please order separately 쮿 Lateral trim is necessary, please order separately, see page 5.59 For further information www.schroff.biz/oneclick oneClick search code = Part no. 04602081 EMC side panel gasket Main Catalogue 쮿 For EMC shielding between side panel and top cover or base plate (sufficient for at least 1 case) Order Information Item 1 Description Qty/PU Sealing cord, silicone, silver coated, 1 Ø 2.4 mm, length 2.1 m Part no. 30850-354 For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806068 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.57 Desk-top enclosure – i Design elements Main Catalogue 쮿 To individualise case design Delivery comprises Qty 1 1 Description Design element, Al extrusion, powder-coated Assembly kit Order Information Description Width Form 1 05809002 Light grey RAL 7035 HP Part no. Brilliant blue RAL 5007 Part no. 42 20850-184 20850-299 63 20850-185 20850-300 84 20850-186 20850-301 42 20850-190 20850-315 63 20850-191 20850-316 84 20850-192 20850-317 42 20850-196 20850-331 63 20850-197 20850-332 84 20850-198 20850-333 PPA43761 Form 2 PPA43762 Form 3 PPA43763 Note 쮿 Size 28 HP and further colours available on request 쮿 Cannot be combined with front hood For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.58 Main Catalogue E 11/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 59 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Trim, front, for EMC shielding Main Catalogue 쮿 For lateral covering of frame and for producing a continuous front with front panels and plug-in units 쮿 Serves for lateral shielding of side panels simultaneously Delivery comprises (kit) Item 1 Qty 2 2 3 1 1 Description Lateral trim, Al extrusion, visible surface painted RAL 7016 Textile EMC gasket Assembly kit Order Information 05806069 For case height U 2 3 4 6 h mm 84 128.5 172.9 261.8 Part no. 24576-017 24576-117 24576-217 24576-417 For further information www.schroff.biz/oneclick oneClick search code = Part no. Trim, rear, for EMC shielding Main Catalogue 쮿 For vertical EMC shielding between shielded front panels and side panel Delivery comprises Item 1 2 3 Qty 2 1 1 Description EMC contact strip, Al extrusion Textile EMC gasket Assembly kit Order Information Height U 2 3 4 6 Height mm 65.55 110 154.45 243.35 Part no. 24576-018 24576-118 24576-218 24576-418 05806103 For further information www.schroff.biz/oneclick oneClick search code = Part no. Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.59 5_2_propacPRO_e.fm Seite 60 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Tip-up carrying handle Main Catalogue 쮿 With powder-coated carrying bar 쮿 Can be locked in 30° increments 쮿 Load-carrying capacity 20 kg Delivery comprises (Kit) Item 1 2 Qty 1 2 3 4 2 1 Description Carrying bar, Al extrusion, powder-coated, RAL 7016 Handle side part, Zn, die-cast, powder-coated, length 180 mm Safety insert, St, 1.5 mm, black Assembly kit for side panel mounting Order Information For case width HP 28 42 63 84 Part no. 24576-070 24576-071 24576-072 24576-073 05806101 Note 쮿 To fit the tip-up carrying handle, holes must be drilled in the side panel 쮿 Readily prepared cases (3 U and 4 U), for mounting the tip-up carrying handle see page 5.52 For further information www.schroff.biz/oneclick oneClick search code = Part no. Strap handle Main Catalogue 쮿 Load-carrying capacity: 20 kg Delivery comprises (Kit) Item 1 Qty 1 2 3 2 1 Description Band, spring steel, handle, flexible plastic, grey, RAL 7016 Cover, grey, RAL 7016 Assembly kit Order Information Description Strap handle with adaptor Part no. 20850-249 Note 쮿 Holes must be drilled into the side panels to fix the strap handle 쮿 Side panels with holes already drilled available on request 쮿 Usable from case depth of D = 326 mm 05806098 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.60 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 61 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Air filter Main Catalogue 쮿 Subsequent mounting possible without modification or tools 쮿 Filter change without opening the case, IP protection code not affected Delivery comprises (Kit) Item 1 2 3 Qty 1 1 1 Description Filter holder, Al, 1 mm, powder-coated, RAL 9006 Filter mat, synthetic fibre Velcro Order Information For case width Air filter HP Part no. 28 24576-093 42 24576-094 63 24576-095 84 24576-096 Tip-up foot in plastic silver, similar to RAL 9006, 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces 2 3 1 Replacement filter 1 piece Part no. 64571-033 64571-034 64571-035 64571-036 20603-001 20603-002 Note 05806070 쮿 For optimum ventilation feet must be fixed to the case, please order separately For further information www.schroff.biz/oneclick oneClick search code = Part no. Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.61 5_2_propacPRO_e.fm Seite 62 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Front hood 3 U Main Catalogue 쮿 From acrylic glass, hinged, removable 쮿 Mounting of hinges at top or bottom 쮿 Lock (max. 2) retrofittable 쮿 Lateral cover (item 5) also serves as vertical EMC shielding of side panels Delivery comprises (kit) Item 1 2 3 4 5 Qty 1 2 2 2 2 6 1 Description Hood, PMMA, tinted blue grey, acrylic glass, 3 mm Hinge, PC, UL 94 V-0, RAL 7016 Handle, PC, UL 94 V-0, RAL 7016 Retainer, UL 94 V-0, PC, RAL 7016 Lateral trim, Al extrusion, visible surface painted RAL 7016 Assembly kit Order Information 05806071 16 180 11 ° 14 7,2 3 For case width HP 28 42 63 84 Lock for front hood Locking cylinder, key, assembly kit, PU 1 kit Plastic tip-up foot silver, similar to RAL 9006, 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces Part no. 24576-080 24576-081 24576-082 24576-083 60850-171 20603-001 20603-002 Note 1) 05806072 1) Front panel 쮿 Cannot be combined with design elements 쮿 Other heights available on request 쮿 Before assembly of hood feet must be fixed to case; please order separately For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806073 Lock for front hood 5.62 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 63 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Foot for rear hood iMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Increases the distance between rear panel and parking surface (when used vertically) 쮿 Simplifies cable routing 쮿 Increased shock and vibration damping 쮿 Required for mounting rear hood Delivery comprises Item 1 1 Qty 2 1 Description Foot, PU foam Assembly kit Order Information For cabinet height U 3 4 Height H mm 147.9 192.3 Part no. 24576-393 24576-394 For further information www.schroff.biz/oneclick ppa45113 oneClick search code = Part no. ppa45106 Rear hood Main Catalogue Delivery comprises (kit) Item 1 2 Qty 1 1 Description Hood, Al, 1 mm, RAL 9006, fixing with knurled screws Assembly kit Order Information Height Width A B C D E U HP mm mm mm mm mm 3 42 246 230 213 145.9 64 3 63 352.7 336.7 319.7 145.9 64 3 84 459.4 443.4 426.4 145.9 64 4 63 352.7 336.7 319.7 190.4 108.5 4 84 459.4 443.4 426.4 190.4 108.5 Foot for rear hood for case height 3 U, PU foam, black, PU 2 pieces Foot for rear hood for case height 4 U, PU foam, black, PU 2 pieces Part no. 24576-086 24576-087 24576-088 24576-091 24576-092 24576-393 24576-394 05806075 Note 쮿 To fit the rear hood, feet must be fitted to the rear panel; please order separately For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806076 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.63 5_2_propacPRO_e.fm Seite 64 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Mounting plates Order Information Mounting plate for fixing of heavy components Fixing strip for partial widths Mounting plate over full width: mounting is onto the side panels Mounting plate over partial width: mounting is onto one side panel and a fixing strip or onto 2 fixing strips 05812001 06102501 Al, 1.5 mm; for mounting over partial width, please order fixing strips separately Width W W Board lengths HP mm mm 42 217.99 160 42 217.99 220 63 324.67 160 63 324.67 220 84 431.35 160 84 431.35 220 84 431.35 340 Assembly kit for mounting plate, PU 1 kit (Torx countersunk screw M4 x 5, St, zinc-plated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for fixing strips for partial width mounting plates, Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces M2.5 × 5, St, zinc-plated, PU 100 pieces 05806100 St, 2 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates 1 piece 1 piece 34562-746 34562-750 34562-747 34562-751 34562-748 34562-752 34562-760 30840-021 30840-033 30840-021 30840-033 30840-021 30840-033 30840-057 24560-184 – – 24560-146 Note 쮿 쮿 쮿 쮿 Please order assembly kit for mounting plate separately Fixing strips required for partial width, please order separately Other versions on request Dimensions side panel with horizontal rail see page 5.53 06103057 propacPRO: D = board length - 47.5 mm; n = 1 for 160 mm board length; n = 2 for 220 mm board length; n=4 for 340 mm board length 5.64 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 65 Montag, 1. Oktober 2012 6:01 06 Desk-top enclosure – i EMC gasket, stainless steel, between front/rear panel and horizontal rail Main Catalogue 쮿 The EMC contact strip is clipped onto the horizontal rail and forms a conductive link to front or rear panel 쮿 Can be used for front/rear horizontal rails type VT (recessed) Delivery comprises Item 1 Qty 10/100 Description EMC gasket, St, stainless Order Information 05806109 Width HP 28 42 63 84 84 Length mm 131.78 202.9 304.5 416.56 416.56 Qty/PU pieces 10 10 10 10 100 Part no. 24560-229 24560-231 24560-233 24560-235 24560-236 GND/earthing kit Main Catalogue 쮿 Protective GND/earthing connections in accordance with: – DIN EN 50178/VDE 0160 – DIN EN 60950/VDE 0805 – DIN EN 61010-1/VDE 0411 part 1 – DIN EN 61010-1A2/VDE 0411 part 1A1 쮿 VDE tested Order Information Description GND/earthing kit, Cu wire 1.5 mm2, PVC sleeve, green/ yellow, links side panels, base and rear panel, 1 piece Part no. 21102-001 aza43284 Cable holder Main Catalogue Delivery comprises 02908053 46 19 Item 1 Qty 2 2 1 3 1 Description Cable holder, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drill holes each per holder are needed in rear panel Assembly kit Order Information Description Cable holder 9 Part no. 24575-800 26,5 For further information www.schroff.biz/oneclick oneClick search code = Part no. 14 17 Ø3 Ø4 ,4 Ø3 Ø 4,4 20,2 02908052 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.65 5_2_propacPRO_e.fm Seite 66 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Mounting position horizontal/central rails 2U Text H - VT H - VT H - VT H - VT 05806084 3U H - VT H-VT H-ST H-KD H-MZ H - VT ST H - ST H - VT H - MZ H - VT H - VT 05806085 4 U (3 + 1) 05809050 "Z" (EMC shielding with 2 horizontal rails) H - VT H - VT H - ST H - VT H - MZ 2 x H - KD H - VT H - VT 05806086 6U 06106051 6 U (2 x 3) H - VT H - VT H - VT H - VT H - ST H - VT H - MZ H - ST H - VT H - MZ “Z” “Z” 2 x H - KD ST H - ST H - VT H - MZ H - ST H - VT H - MZ H - VT H - VT H - VT 05806087 5.66 Main Catalogue E 10/2012 H - ST H - VT H - MZ H - VT 05806088 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 67 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Horizontal rails to front/centre/rear Main Catalogue Order Information For indiect For direct For direct fixing Front horizontal backplane fixing backplane fixing of connectors in rails with insulation accordance with strip EN 60603-2 (DIN 41612) 06197011 "heavy" Type H-ST standard 06197011 "heavy" Type H-VT long lip 06197011 Usable length HP Length mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx panhead screw , M4 × 14, St, zinc-plated, PU 100 pieces Torx panhead screw , M 4 × 10, St, zinc-plated, necessary if guide rail is screwed to slot 1, PU 100 pieces Perforated rail for connector mounting with insulation strip see page Z-rail for connector mounting without insulation strip see page Insulation strips see page Threaded inserts see page Stainless steel EMC gasket between horizontal rail and horizontal rail 06197011 "heavy" Type H-MZ with Z-rail 06197009 Horizontal rail type H-VT robust, with EMC gasket 06106052 bza45877 "heavy" Type H-KD short lip 06197015 06197008 Al extrusion, anodised finish, conductive surface, with printed HP markings Al extrusion, anodised finish, conductive surface, with printed HP markings Al extrusion, anodised finish, conductive surface, with printed HP markings Al extrusion, anodised finish, conductive surface, with printed HP markings item 1: metal strip, Al, 1 mm, item 2: EMC stainless steel gasket; for shielding of 2 horizontal rails positioned directly one above the other if assembly area is divided vertically horizontal rail: Al extrusion, anodised, conductive contact surface for cover plates on shielded cases 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) PU 1 kit 1 piece 34560-528 34560-542 34560-563 34560-584 34560-728 34560-742 34560-763 34560-784 34560-928 34560-942 34560-963 34560-984 34560-228 34560-242 34560-263 34560-284 24562-528 24562-542 24562-563 24562-584 24576-028 24576-042 24576-063 24576-084 24571-371 24571-371 24571-371 24571-371 – 24571-371 – – 24571-372 24571-372 – 24571-372 5.69 – – – – – 5.69 – – – – – – 5.68 5.68 5.68 – 5.68 – 5.68 – – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Note 쮿 Further horizontal rails see from page 6.27 쮿 Fitting options see page 5.66 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.67 5_2_propacPRO_e.fm Seite 68 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Horizontal rails, centre, type ST-C Main Catalogue 쮿 For indirect backplane mounting (with insulation strip) 쮿 For 6 U propacPRO case Delivery comprises (kit, item 1 to 4 are pre-mounted) Item Qty 1 1 2 3 4 5 2 2 2 4 Description Horizontal rail, Al extrusion, anodised, contact surfaces conductive Adaptor plate, Al Threaded insert, M2.5, St, zinc-plated Countersunk screw, M4 x 14 Pan head screw, M4 x 6 Order Information Usable width Length HP mm 84 431.8 Insulation strip 84 HP, PBT UL 94 V-0, grey, PU 10 pieces Part no. 24575-474 24560-884 For further information www.schroff.biz/oneclick oneClick search code = Part no. 05806089 Threaded inserts, perforated strips, insulation strips Order Information Threaded insert M2.5 M3 Perforated strip (item 1) Insulation strip 5 2 5,0 8 06103056 required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.64 Threaded insert Usable length Length HP mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) – – – BZA45853 BZ6749 for centring shielded plug-in units, Al, 1 mm, please order grub screw separately for insulated backplane mounting; PBT UL 94 V-0, grey Perforated strip Insulation strip Length Length mm 1 piece (SPQ 10)1) mm PU 10 pieces 28 146.82 147.12 144.20 34561-328 30845-197 24560-828 42 217.94 218.24 210.40 34561-342 30845-211 24560-842 63 324.62 324.92 316.88 34561-363 30845-232 24560-863 84 431.30 431.60 428.64 34561-384 34561-484 30845-253 24560-884 Accessories Grub screw M2.5 x 8, – – – 21100-276 PU 100 pieces Grub screw M2.5 x 9, – – – 21101-359 PU 100 pieces Grub screw M3 x 8, – – – 21100-646 PU 100 pieces 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU 5.68 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 69 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Z-rails, perforated rails Order Information Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 75 12, 5 9,7 BZA45850 BZA45848 5 7 12, 3,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Item 3, Torx panhead screw to fix connector to perforated rail,, M2.5 × 7, PU 100 pieces Item 2, Torx panhead screw, to fix perforated rail to horizontal rail, M2.5 × 10, PU 100 pieces Main Catalogue E 10/2012 06708051 for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on VT horizontal rails, please order threaded insert and screw separately 1 piece 1 piece – – PU 4 pieces 30822-033 30822-047 30822-065 30822-089 30819-783 30819-808 20822-049 20822-050 20822-047 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.69 5_2_propacPRO_e.fm Seite 70 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Combined mounting (6 U and 2 x 3 U one above the other) Order Information Combined mounting Horizontal and Unshielded vertical subdivision front panel, (incl. front panel for 6 U, 2 HP stainless steel EMC gasket) item 5 bza45819 Front panel for textile EMC gasket, 6 U, 2 HP item 5 06102501 Splitting extrusion for combined mounting item 2 06102501 06102501 05806108 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Torx countersunk screw M4 × 14, zinc-plated, PU 100 pieces for fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces for fixing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces item 1: 2 front horizontal rails (H-KD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zinc-plated; item 4: Zn die-cast support member; item 5: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket; 84:0 without items 4, 5 Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, Zn die-cast; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 (SPQ 5) 1 piece (SPQ 5)1) 1 piece 24562-420 24562-440 24562-442 24562-463 24562-484 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – 21101-855 – 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accept euroboards (100 mm high) and double euroboards (233.35 mm high) Note 쮿 Please order EMC gasketing kit for horizontal rails separately, see page 6.54 쮿 Please order perforated strips for horizontal rails separately, see page 5.68 쮿 Please order rear centre horizontal rail separately, see page 5.68 5.70 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 71 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Horizontal board mounting Order Information Horizontal board mounting Front frame for EMC gasketing Board cage 27 3.9 8= 54 Front frame, unshielded TE w 273 h =5 4T 05806091 E bpa45913 H ,98 bza43061 05806092 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 HP space required; please order front frame for EMC gasketing separately (1 TE = 1 HP, 1 HE = 1 U) Height H U Usable height h HP 3 Other dimensions and options 2 horizontal trims, Al, 2.5 mm, clear anodised; AI 2.5 mm, front anodised, front frame with cut-out, rear iridescent green chromated; clear internal width w = 266.35 mm 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the sub-assemblies PU 1 kit PU 1 kit 1 piece 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Assembly tool, for mounting the EMC gasket (stainless steel) Horizontal rail, rear * For direct backplane mounting Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.71 5_2_propacPRO_e.fm Seite 72 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Plastic tip-up feet Main Catalogue 쮿 Static load-carrying capacity 25 kg per foot 쮿 Tip-up feet can be used instead of the pre-mounted case feet 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description 05806093 anthracite, similar to Plastic tip-up foot RAL 7016, 4 pieces silver, similar to Plastic tip-up foot RAL 9006, 4 pieces Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 20603-002 20603-001 21101-211 21100-211 21100-207 For further information www.schroff.biz/oneclick oneClick search code = Part no. 02906050 Tip-up feet made of die-cast aluminium 쮿 Can be used instead of the round standard feet 쮿 Fixing holes provided in bottom of case 쮿 Secure case stance with slip-proof rubber inserts 쮿 Load carrying capacity: 50 kg per foot, max. case weight 40 kg Order Information 41 20 Ø3,1 15,5 Ø4,6 15 16,6 1 AZA43836 Description Qty Foot with tip-up, 1 piece (SPQ 10)1) Al die-cast, silver Foot without tip-up, 1 piece (SPQ 10)1) Al die-cast, silver Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-002 10603-001 21101-211 21100-211 21100-207 1) Part no. comprises 1 piece; delivery is in standard pack quantity (SPQ): please order a minimum of 10 feet or a multiple Ø7,8 Note 20 쮿 Delivery is in standard pack multiples; pricing is per individual item 02908051 5.72 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 73 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Guide rails for plug-in units and frame type plug-in units, one-piece, groove width 2 mm Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Standard For plug-in units and frame type plug-in units With DIN connector fixing as standard Storage temperature from -40 °C ... 130 °C 06102001 Board Groove Colour lengths width mm mm mm 70 2 red 70 2 grey 160 2 red 220 2 red 280 2 red 340 2 red Dimension drawings see page 06101501 up to 220 mm length, PBT, UL 94 V-0; multi-piece from 280 mm length, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards, 100 x 160 mm or 100 x 220 mm only PU 10 pieces – – 1 pair (SPQ 10)1) – – 24560-351 24560-353 24560-379 24560-380 64560-074 64560-075 6.40 – – 6.40 Retention screw, PU 100 pieces 24560-141 24560-141 ESD clip, PU 50 pieces description see page 6.41 24560-255 24560-255 Accessories 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.73 5_2_propacPRO_e.fm Seite 74 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Guide rails type "accessories", one-piece, groove width 2 mm and 2.5 mm Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plates Guide rails "Accessories" Guide rails "Accessories" strengthened Guide rails for heavy modules, Al extrusion, silver, robust version storage temperature from -40 °C ... +130 °C 06102002 Board lengths mm 100 160 160 220 220 Groove width mm 2 2 2 2 2 06102005 06102005 up to 280 mm length, PBT, UL 94 V-0; multi-piece from 280 mm length, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94 V-0, red support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces – 1 piece (SPQ 50) – 24560-373 Colour 64560-076 1 piece (SPQ 50)1) – – – – 34562-881 24560-374 64560-078 – – – 34562-882 24560-375 64560-080 34562-883 24560-376 – 34562-884 – – – – – 6.40 – – – – – – 6.40 34562-885 34564-881 34564-882 34564-883 34564-884 34564-885 Retention screw, PU 100 pieces 24560-141 24560-141 24560-157 ESD clip, PU 50 pieces description see page 6.41 Board locking, red, PU 10 pieces, description see page 6.41 Board handle, red, PU 10 pieces, description see page 6.41 Identification strips for board handle, red, PU 1 sheet = 438 pieces, description see page 6.41 Coding see page 24560-255 24560-255 – 24560-377 24560-377 – 24560-378 24560-378 – 60817-228 60817-228 – 6.41 6.41 – mm red red grey red grey red/ 280 2 silver red/ 340 2 silver 400 2 silver 160 2.5 silver 220 2.5 silver 280 2.5 silver 340 2.5 silver 400 2.5 silver Dimension drawings see page 6.40 Accessories 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 5.74 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_2_propacPRO_e.fm Seite 75 Montag, 17. September 2012 7:46 19 Desk-top enclosure – i Divider plate Order Information Divider plate Mounting position when Mounting position when stainless steel EMC gasket is used textile EMC gasket is used front rear front rear bpa45911 06105078 Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space requirement on component side 2 mm; mounting direction varies with shielding design (EMC stainless steel or textile gasket); retrofitting the divider plate in an already-assembled subrack/case will first require dismantling of the horizontal rails; where front panels are unshielded, both mounting directions are possible bpa45912 Height U 3 3 6 6 Depth mm 160 220 160 220 A mm 158.3 218.3 158.3 218.3 B mm 135.0 195.0 135.0 195.0 H mm 113.5 113.5 246.9 246.9 PU 10 pieces 34562-761 34562-762 34562-763 34562-764 Air baffle for slots Order Information Air baffle without front panel Air baffle with front panel U front panel for textile EMC gasket 06108085 Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06108088 Air deflector, Al, 1 mm, front panel, Al extrusion, 2.5 mm, front anodised, rear conductive; EMC textile gasket, fixing materials kit prevents an air short-circuit where slots are unoccupied; is pushed into the groove of the guide rails 06101507 Depth mm 160 160 160 160 160 160 220 220 220 220 220 220 Width HP 4 4 8 8 12 12 4 4 8 8 12 12 Main Catalogue E 10/2012 Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 1 piece 34562-823 34562-826 34562-833 34562-836 34562-843 34562-846 34562-824 34562-827 34562-834 34562-837 34562-844 34562-847 20848-728 20848-736 20848-730 20848-738 20848-732 20848-740 20848-729 20848-736 20848-731 20848-739 20848-733 20848-741 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.75 5_3_compacPRO_e.fm Seite 76 Montag, 17. September 2012 9:12 21 bMain Catalogue Overview . . . . . 0 Desk-top cases – b Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . 2 Accessories for cabinets and wall mounted cases 3 Climate control 4 Desk-top cases 5 02004009 Subracks/ 19" chassis . . . 6 Front panels, plug-in units . . 7 Systems . . . . . . 8 Power supply units . . . . . . . . . 9 02004079 Flexible expansion options, for 19" components e.g. plug-in unit units, or for individual expansion Backplanes . . 10 Standards  Interior dimensions in accordance with: IEC 60297-3-101  Type of protection IP 20 in accordance with IEC 60529 Connectors, front panel component system . . . . . . 11  GND/earth connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A12 Downloads and further important information can be found on the Internet under www.schroff.biz Appendix . . . . 12 5.76 Main Catalogue E 10/2012 MicroTCA 5_3_compacPRO_e.fm Seite 77 Montag, 17. September 2012 9:12 21 Desk-top cases – b Overview . . . 5.76 bMain Catalogue Robust desk-top case for 19" components in accordance with IEC 60297-3-10x or for individual electronics assemblies  Front and rear identical, depth-symmetrical construction  Highly robust thanks to die-cast frame (front/rear)  Side panel with integrated handle function Desk-top cases  Complete case – Pre-configured case, prepared for 19" components – Case height 3 U and 6 U compacPRO Complete cases 3, 6 U . . . . . . . . . . 5.78 Cases 2, 3, 4 U . . 5.79 6 U cases . . . . . . . 5.80 Accessories Filler angle . . . . . 5.81  Case – Case height 2 U, 3 U, 4 U and 6 U Cable holder . . . . 5.81 Front panel/rear panel . . . . . . . . . . 5.82 Rear feet . . . . . . . 5.83 Edge protection. 5.83 Hood . . . . . . . . . . 5.84 Front door . . . . . 5.85 Handle . . . . . . . . 5.86 GND/earthing . . . 5.86 Feet . . . . . . . . . . 5.87 Horizontal rail . 5.88 02009005 02004006 Threaded inserts 5.90 Extensive accessory range Guide rails and ESD clips . . . . . . . 5.92 Mounting plates . 5.94 Combined mounting . . . . . . 5.95 Horizontal board assembly . . . . . . 5.96 Air flow barrier . . 5.97 Dimensions . . . . . 5.98 02004002 ServicePLUS . . 5.4 ServicePLUS from page 5.4 e.g. modifications (special colours, special depths, cut-outs in top cover, base plate or side panels) e.g. assembly service from 1 piece www.schroff.biz/ServicePLUS 30407004 Main Catalogue E 10/2012 5.77 5_3_compacPRO_e.fm Seite 78 Montag, 17. September 2012 9:12 21 Desk-top cases – b Complete cases 3 and 6 U bMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days  Desk-top case with pre-configured components in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards  For backplane mounting with insulation strips  Ventilation slots in base plate  Ventilation slots in rear panel Delivery comprises (Kit, items 1, 2, 6, 8 fitted) Item 1 2 3 Qty 3U 2 2 1 6U 4 2 1 Description 4 1 1 5 6 4 2 4 7 8 2 2 2 2 9 2 2 10 - 1 11 1 1 12 10/ 20 1 1 10/ 20 1 1 02009005 20 20 5 h H D w W 02004054 13 14 Side panel, Al extrusion, powder-coated, RAL 7016 Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Side plate powder-coated, RAL 9006, Al, 0.8 mm Tip-up foot with anti-slip protection, PA, RAL 7016, UL 94 V-0 Cover bracket, Al extrusion, anodised, cut edges plain Horizontal rail, Al extrusion, with threaded insert, St, M2.5 Rear horizontal rail, Al extrusion, with threaded insert, St, M2.5 and insulation strip, PBT, UL 94 V-0 (for indirect backplane mounting) Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with 1 row of ventilation slots, Al, anodised, 2 mm for 28, 42 and 63 HP, 2.5 mm for 84 HP Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit, also allows the fitting of a full-width front panel 3 Order Information 9 Height H Usable width Part no. w w U mm mm HP mm 3 186 271 28 148 14575-114 3 186 331 28 148 14575-115 3 257 271 42 219 14575-134 3 257 331 42 219 14575-135 3 257 391 42 219 14575-136 3 364 271 63 326 14575-154 3 364 331 63 326 14575-155 3 364 391 63 326 14575-156 3 471 271 84 432 14575-174 3 471 331 84 432 14575-175 3 471 391 84 432 14575-176 3 471 511 84 432 14575-178 6 471 391 84 432 14575-476 6 471 451 84 432 14575-477 Maximum mounting depth = D - 21 (open space: front panel - rear panel) 1 10 2 11 5 12 8 4 7 6 Width W Depth D 02008050 Note  Dimensions of case, side panel see from page 5.98 ServicePLUS see page 5.4 5.78 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 79 Montag, 17. September 2012 9:12 21 Desk-top cases – b Cases 2, 3 and 4 U b  Desk-top case, pre-configures, for individual assembly  For backplane mounting with insulation strips  Ventilation slots in base plate Delivery comprises (Kit, items 1 and 2 fitted) Item 1 2 3 Qty 2 2 1 4 1 5 6 7 4 8 1 02004005 Description Side panel, Al extrusion, powder-coated, RAL 7016 Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing connection Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated RAL 9006, with earthing connection Case foot with anti-slip protection, PC, black Fixing adaptor for cover plate, prefitted Assembly kit, also allows the fitting of a full-width front panel, two cover brackets or a rear panel Order Information 20 20 5 h H D w W 02004054 3 2 1 Height Usable width U HP 2 42 2 42 2 42 2 84 2 84 2 84 3 28 3 28 3 42 3 42 3 42 3 63 3 63 3 63 3 84 3 84 3 84 3 84 3 84 4 42 4 42 4 63 4 63 4 63 4 84 4 84 4 84 4 84 Width W mm 257 257 257 471 471 471 186 186 257 257 257 364 364 364 471 471 471 471 471 257 257 364 364 364 471 471 471 471 Width w mm 219 219 219 432 432 432 148 148 219 219 219 326 326 326 432 432 432 432 432 219 219 326 326 326 432 432 432 432 Height H mm 102.6 102.6 102.6 102.6 102.6 102.6 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 191.6 191.6 191.6 191.6 191.6 191.6 191.6 191.6 191.6 Height h mm 84.4 84.4 84.4 84.4 84.4 84.4 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 Depth D mm 271 331 391 271 331 391 271 331 271 331 391 271 331 391 271 331 391 451 511 271 331 271 331 391 331 391 451 511 Part no. 14575-023 14575-025 14575-027 14575-063 14575-065 14575-067 14575-103 14575-105 14575-123 14575-125 14575-127 14575-143 14575-145 14575-147 14575-163 14575-165 14575-167 14575-169 14575-171 14575-223 14575-225 14575-243 14575-245 14575-247 14575-265 14575-267 14575-269 14575-271 6 For further information www.schroff.biz/oneclick 4 oneClick search code = Part no. 5 02004053 ServicePLUS see page 5.4 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.79 5_3_compacPRO_e.fm Seite 80 Montag, 17. September 2012 9:12 21 Desk-top cases – b 6 U cases b  Desk-top case, pre-configured, for individual assembly  For backplane mounting with insulation strips  Ventilation slots in base plate Delivery comprises (Kit items 1, 2 and 5 fitted) 02004006 Item 1 Qty 4 2 3 2 1 4 1 5 6 7 8 2 4 8 1 Description Side panel parts, Al extrusion, powder-coated, RAL 7016, 2 x 3 U Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Side plate, Al, 0.8 mm, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black Fixing adaptor for cover plate, prefitted Assembly kit also allows the fitting of a full-width front panel, two cover brackets or a rear panel Order Information Usable width HP 63 63 84 84 84 84 84 3 2 1 Width W mm 364 364 471 471 471 471 471 Width w mm 326 326 432 432 432 432 432 Height H mm 280.5 280.5 280.5 280.5 280.5 280.5 280.5 Height h mm 262.9 262.9 262.9 262.9 262.9 262.9 262.9 Depth D mm 331 391 271 331 391 451 511 Part no. 14575-445 14575-447 14575-463 14575-465 14575-467 14575-469 14575-471 5 For further information www.schroff.biz/oneclick oneClick search code = Part no. 7 4 6 02004055 20 20 5 h H D w W 02004056 ServicePLUS see page 5.4 5.80 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 81 Montag, 17. September 2012 9:12 21 Desk-top cases – b Filler angle b  To cover the sides of the frame and to create a continuous front plane with plug-in units and partial-width front panels  This filler angle is recommended when fitting horizontal rails Delivery comprises Item 1 Qty 2 Description Filler angle, Al extrusion, anodised, cut edges plain Order Information 02005002 Height U 2 3 4 6 Part no. 24575-019 24575-119 24575-219 24575-419 Note  Fixing material is supplied with case For further information www.schroff.biz/oneclick oneClick search code = Part no. 02004062 Cable holder AccessoriesI/B Delivery comprises (kit) Item 1 Qty 2 2 1 3 1 Description Cable bracket, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drill holes each per bracket are needed in rear panel Assembly kit Order Information 02908053 46 19 Description Cable holder Part no. 24575-800 9 For further information www.schroff.biz/oneclick 26,5 oneClick search code = Part no. 14 17 Ø3 Ø4 ,4 Ø3 Ø 4,4 20,2 02908052 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.81 5_3_compacPRO_e.fm Seite 82 Montag, 17. September 2012 9:12 21 Desk-top cases – b Front panel and rear panel b  Front panels and rear panels are screwed on front or rear frame of case Delivery comprises (kit) Item 1 Qty 1 2 1 Description Rear panel with 4 rows of ventilation slots, AI, anodised, cut edges plain; 28, 42, 63 HP = 2 mm thick; 84 HP = 2.5 mm thick Front panel, Al, anodised, cut edges plain, 3 mm thick Order Information Height Width Height Height Width H h B U HP mm mm mm 2 42 84 66 238.7 2 84 84 66 452.1 3 28 128.4 100 167.5 3 42 128.4 100 238.7 3 63 128.4 100 345.4 3 84 128.4 100 452.1 4 42 172.9 144.5 238.7 4 63 172.9 144.5 345.4 4 84 172.9 144.5 452.1 6 63 261.8 233.4 345.4 6 84 261.8 233.4 452.1 02005001 Rear panel/front panel Rear panel Front panel b mm 226.3 439.7 155.1 226.3 333.1 439.7 226.3 333.1 439.7 333.1 439.7 Part no. Part no. 30823-015 30823-512 30823-021 30823-024 30823-027 30823-515 30823-033 30823-036 30823-518 30823-045 30823-521 30823-209 30823-215 30823-254 30823-257 30823-224 30823-260 30823-269 30823-227 30823-272 30823-230 30823-284 Note CPA30656  Assembly kit to fix one rear and one front panel is included with the case  Cable holder and rear feet, see from page 5.81 Front panel/rear panel with hidden fixing b Delivery comprises (kit) Item Qty 1 1 2 4 Description Front panel, Al, anodised, cut edges plain, 2.5 mm Fixing bracket Order Information Height U 2 2 3 3 3 3 4 4 4 6 6 Width HP 42 84 28 42 63 84 42 63 84 63 84 Height H Height h mm 84.0 84.0 128.4 128.4 128.4 128.4 172.9 172.9 172.9 261.8 261.8 mm 66.0 66.0 100.0 100.0 100.0 100.0 144.5 144.5 144.5 233.4 233.4 Width B mm 238.7 452.1 167.5 238.7 345.4 452.1 238.7 345.4 452.1 345.4 452.1 Part no. b mm 226.3 439.7 155.1 226.3 333.1 439.7 226.3 333.1 439.7 333.1 439.7 24575-035 24575-075 24575-115 24575-135 24575-155 24575-175 24575-235 24575-255 24575-275 24575-455 24575-475 Note 02004061 5.82 Main Catalogue E 10/2012  Cable holder and rear feet see from page 5.81 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 83 Montag, 15. Oktober 2012 3:56 15 Desk-top cases – b Rear foot with rubber insert b Delivery comprises Item 1 2 Qty 2 1 Description Foot with rubber insert, PC, UL 94 V-0, RAL 7016 Fixing material Order Information For case height U 3 4 A mm 139 183.5 Part no. 24575-114 24575-214 For further information www.schroff.biz/oneclick oneClick search code = Part no. 02005004 A ø 4.2 23 8.5 16.5 02004063 Edge protection/rear foot b Delivery comprises Item 1 2 Qty 2 1 Description Edge protection, PU foam, black Assembly kit Order Information For case height U 3 4 A mm 159.1 203.6 B mm 114.0 159.0 C mm 100.0 144.5 Part no. 20823-675 20823-676 For further information www.schroff.biz/oneclick A 20,2 Ø8 C B oneClick search code = Part no. Ø 4,5 02005005 A A 5 27 27,5 35 A-A 02908054 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.83 5_3_compacPRO_e.fm Seite 84 Montag, 17. September 2012 9:12 21 Desk-top cases – b Rear foot for hood b Delivery comprises Item 1 2 Qty 2 1 Description Foot, PU foam, black, 75° shore Fixing material Order Information D B A M6 Height U 3 4 M6 45 30 02004065 A mm 133.5 177.8 B mm 95 139.5 D mm 65 95 Part no. 20823-668 20823-669  Rear panel, see page 5.82 Dimensions for modifying the rear panel For further information www.schroff.biz/oneclick B oneClick search code = Part no. 27.55 8 x 6.1 02004066 Hood b Delivery comprises Item 1 Qty 1 2 1 Description Hood, ABS, RAL 7016, wall thickness < 4 mm, fixing with knurled screws Assembly kit Order Information Height Width A U HP mm 3 42 267 3 63 373.5 3 84 480 Cable support PC, black, UL 94 V-0, PU 2 pieces 02005006 56 ø 5.5 41.6 41.6 A 10 10° 156.5 4 Part no. 24575-136 24575-156 24575-176 20823-674 Note  Cable support can only be fitted in conjunction with rear foot for hood  To fit the hood, the rear panel and the rear foot for hood must be mounted on the case  Rear panel, see page 5.82  Rear foot for hood see page 5.84 For further information www.schroff.biz/oneclick oneClick search code = Part no. 61.5 02004064 Cable support A4-512 5.84 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 85 Montag, 17. September 2012 9:12 21 Desk-top cases – b Front door, acrylic glass, hinged b  Assembly of the hinge to top or bottom  With snap-on latch  Lock retrofittable Delivery comprises (kit) Item 1 2 3 4 5 Qty 2 1 1 2 1 Description Side part, Al die-cast, powder-coated, RAL 7016 Front door, PMMA, tinted blue-grey, acrylic glass, 3 mm Snap-on latch, PC, UL 94 V-0, black Spacer plate, Al, 3 mm, passivated Assembly kit Order Information 02005003 Height Width U HP 3 42 3 63 3 84 Lock for front door cylinder, 2 keys, assembly parts Part no. 24575-137 24575-157 24575-177 21100-647 Dimensions table Height U 3 3 3 02004069 Front door, hinged b TE 42 63 84 H mm 139,50 139,50 139,50 h mm 128,40 128,40 128,40 B mm 229,60 336,40 443,00 For further information www.schroff.biz/oneclick oneClick search code = Part no. a4-2265 a4-225 1) Front panel Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.85 5_3_compacPRO_e.fm Seite 86 Montag, 17. September 2012 9:12 21 Desk-top cases – b Tip-up carrying handle b  With powder-coated handle bar  Handle bar adjustable in 30 degree increments by pressing button  Load-carrying capacity 20 kg Delivery comprises (kit) Item 1 2 Qty 1 2 3 4 2 1 Description Carrying bar, AI profile, powder-coated, RAL 7016 Lateral section of handle, Zn die-cast, powder coated, length 180 mm Safety insert, St, 1.5 mm, black Fixing material incl. drilling template for side panel Order Information 02004002 a 68.5 b 180 c For case height U 2 2 3, 4 3, 4 3, 4 3, 4 Width HP 42 84 28 42 63 84 Part no. 24575-038 24575-078 24575-118 24575-138 24575-158 24575-178 Dimensions Case width HP 28 42 63 84 a mm 249.32 320.44 427.12 533.80 b mm 180.32 251.44 358.12 464.80 c mm 202.72 273.84 380.52 487,20 For further information www.schroff.biz/oneclick 4x oneClick search code = Part no. 30° 4x 30° 02004080 GND/earthing kit Main Catalogue  Protective GND/earth connections in accordance with DIN EN 50178/VDE 0160, DIN EN 60950/VDE 0805, DIN EN 61010-1/VDE 0411 part 1, DIN EN 61010-1A2 /VDE 0411 part 1/A1 VDE inpection requested Order Information Description GND/earthing kit, CU wire 1.5 mm2, PVC covered, green/yellow, links side panel, base plate, cover and rear panel Qty/PU 1 Part no. 24575-801 aza43284 5.86 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 87 Montag, 17. September 2012 9:12 21 Desk-top cases – b Plastic tip-up feet  Static load-carrying capacity 25 kg per foot  Tip-up feet can be used instead of the case feet fitted as standard  Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 For further information www.schroff.biz/oneclick oneClick search code = Part no. 01802075 02006050 Al die-cast tip-up foot  Static load-carrying capacity 50 kg per foot  Tip-up feet can be used instead of the case feet fitted as standard  Fixing holes provided in bottom of case Order Information 41 20 Ø3,1 15,5 Ø4,6 Part no. 10603-001 10603-002 21101-211 21100-211 21100-207 1) Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 15 16,6 1 AZA43836 Description Qty Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Accessories Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Ø7,8 For further information www.schroff.biz/oneclick 20 oneClick search code = Part no. 02908051 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.87 5_3_compacPRO_e.fm Seite 88 Montag, 17. September 2012 9:12 21 Desk-top cases – b Mounting position horizontal/central rail Case, 2 U Case, 3 U + 4 U Text H-VT H-VT H-VT H-ST / H-VT / H-MZ H-ST / H-VT / H-MZ H-VT H-VT H-VT H-VT H-VT 02004073 Case, 6 U 02004074 Case 2 x 3 U (6 U) H-VT H-VT H-VT H-VT H-ST / H-VT / H-MZ ST-C H-KD H-ST / H-VT / H-MZ H-ST / H-VT / H-MZ H-VT H-VT H-VT 02004076 H-VT 02004077 Horizontal rails H-ST H-VT H-MZ 02004078 5.88 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 89 Montag, 17. September 2012 9:12 21 Desk-top cases – b Horizontal rails to front/centre/rear Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 "heavy" Type H-ST standard 04400002 "heavy" Type H-VT long lip 06197011 Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx countersunk screw, , M4 × 14, St, zinc-plated, PU 100 pieces Torx countersunk screw, , M4 × 10, St, zinc-plated, required if guide rail is screwed to slot 1, PU 100 pieces Z-rail for connector mounting without insulation strip see page Insulation strips see page Threaded inserts see page For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) Front horizontal rails 04400003 "heavy" Type H-MZ with Z-rail 06197013 "heavy" Type H-KD short lip 06197015 06197008 Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-528 34560-542 34560-563 34560-584 34560-728 34560-742 34560-763 34560-784 34560-928 34560-942 34560-963 34560-984 34560-228 34560-242 34560-263 34560-284 24571-371 24571-371 24571-371 24571-371 – – 24571-372 24571-372 5.91 – – – – 5.90 5.90 5.90 – 5.90 – 5.90 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Note  Further horizontal rails, see from page 6.27  Fitting options, see page 5.88 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.89 5_3_compacPRO_e.fm Seite 90 Montag, 17. September 2012 9:12 21 Desk-top cases – b Horizontal rail, centre, type ST-C b  For indirect backplane mounting (with insulation strip)  For 6 U compacPRO case Delivery comprises (Kit, items 1 to 4 are pre-mounted) Item Qty 1 1 2 3 4 5 1 3 Description Horizontal rail, Al extrusion, anodised, contact surfaces conductive Adaptor plate, Al Threaded insert, M2.5, St, zinc-plated Countersunk screw, M4 x 14 Panhead screw, M4 x 6 2 2 2 4 2 Order Information 4 Usable width HP 63 84 Length mm 325.1 431.8 Part no. 24575-454 24575-474 5 02005050 Threaded inserts, perforated strips, insulation strips Order Information Threaded insert Insulation strip M2.5 M3 5 2 5,0 8 06103056 required for fixing the front panel to the horizontal rail; St, zinc-plated; Use collar screw 12.3 mm, see page 6.64 BZ6749 for insulated mounting of backplane; PBT UL 94 V-0, grey Threaded insert Insulation strip Usable length Length Length 1 piece (SPQ 10)1) mm PU 10 pieces HP mm 1 piece (SPQ 10)1) 28 146.82 – 144.20 34561-328 24560-828 42 217.94 – 210.40 34561-342 24560-842 63 324.62 – 316.88 34561-363 24560-863 84 431.30 428.64 34561-384 34561-484 24560-884 Accessories Grub screw M2.5 x 8, PU 100 pieces – – 21100-276 Grub screw M3 x 8, PU 100 pieces – – 21100-646 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU 5.90 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 91 Montag, 17. September 2012 9:12 21 Desk-top cases – b Z-rails, perforated rails Order Information Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 BZA45850 BZA45848 5 12,7 5 9,7 5 7 12, 3,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Item 3, Torx panhead screw to fix connector to perforated rail,, M2.5 × 7, PU 100 pieces Item 2, Torx panhead screw, to fix perforated rails to horizontal rail, M2.5 × 10, PU 100 pieces Main Catalogue E 10/2012 06708051 for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on VT horizontal rails, please order threaded insert and screw separately 1 piece 1 piece – – PU 4 pieces 30822-033 30822-047 30822-065 30822-089 30819-783 30819-808 20822-049 20822-050 20822-047 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.91 5_3_compacPRO_e.fm Seite 92 Montag, 17. September 2012 9:12 21 Desk-top cases – b Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates standard For plug-in units and frame type plug-in units standard, with DIN connector fixing Storage temperature from -40 °C ... 130 °C 06102001 06101501 up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards, 100 x 160 mm or 100 x 220 mm only PU 10 pieces – – 1 pair (SPQ 10)1) – – 24560-351 24560-353 24560-379 24560-380 64560-074 64560-075 Board Groove Colour length width mm mm mm 70 2 red 70 2 grey 160 2 red 220 2 red 280 2 red 340 2 red 160 2.5 red 220 2.5 red Dimension drawings see page – – 6.40 – – – – 6.40 Retention screw, PU 100 pieces 24560-141 24560-141 ESD clip, PU 50 pieces 24560-255 24560-255 Accessories 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.41 5.92 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 93 Montag, 17. September 2012 9:12 21 Desk-top cases – b Guide rails type "accessory", one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plate Guide rails type accessory, strengthened accessory for heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... +130 °C 06102002 06102005 06102005 up to 280 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94 V?0, red support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces – 1 piece (SPQ 50) – 24560-373 Board Groove Colour length width mm mm mm 100 2 red 160 2 red 160 2 grey 220 2 red 220 2 grey 280 2 red/silver 340 2 red/silver 400 2 red/silver 160 2.5 silver 220 2.5 silver 280 2.5 silver 340 2.5 silver 400 2.5 silver Dimension drawings see page 64560-076 1 piece (SPQ 10)1) – – – – 34562-881 24560-374 64560-078 – – – 24560-375 24560-376 64560-080 34562-882 34562-883 34562-884 34562-885 34564-881 34564-882 34564-883 34564-884 34564-885 – – – – – – 6.40 – – – – – – – 6.40 Retention screw, PU 100 pieces 24560-141 24560-141 24560-157 ESD clip, PU 50 pieces Board locking, red, PU 10 pieces Board handle, red, PU 10 piecesdescription Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page 24560-255 24560-255 – 24560-377 24560-377 – 24560-378 24560-378 – 60817-228 60817-228 – 6.40 Accessories see page 6.41 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.93 5_3_compacPRO_e.fm Seite 94 Dienstag, 16. Oktober 2012 7:39 07 Desk-top cases – b Mounting plates Main Catalogue Order Information Mounting plate for fixing of heavy components Assembly strip for partial widths Mounting plate over full width: mounting is onto the side panels; mounting plate over partial width: mounting is onto one side panel and fixing strip or onto 2 fixing strips 06102501 Width W Board length mm HP W 28 146.88 160 28 146.88 220 28 146.88 280 28 146.88 340 42 217.99 160 42 217.99 220 42 217.99 280 42 217.99 340 63 324.67 160 63 324.67 220 63 324.67 280 63 324.67 340 84 431.35 160 84 431.35 220 84 431.35 280 84 431.35 340 Assembly kit for mounting plate PU 1 kit (Torx countersunk screw M4 x 5, St, zinc-plated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for assembly strips of mounting plate, Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces M2.5 × 5, St, zinc-plated, PU 100 pieces 05806100 Al, 1.5 mm; for mounting over partial width, please order assembly strips separately St, 2 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates 34562-745 34562-749 34562-753 34562-757 34562-746 34562-750 34562-754 34562-758 34562-747 34562-751 34562-755 34562-759 34562-748 34562-752 34562-756 34562-760 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 30840-021 30840-033 30840-045 30840-057 24560-184 – – 24560-146 Note 쮿 For installation and assembly of heavier components 쮿 The mounting plate is as wide as the case and is fixed to the side panels 쮿 A guide rail can be mounted on the first and last slot positions 쮿 4.4" and "strengthened" guide rails cannot be used 5.94 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 95 Montag, 17. September 2012 9:12 21 Desk-top cases – b Combined mountings (6 U and 2 x 3 U one above the other) Order Information Combined mounting: horizontal and vertical unshielded subdivision front panel, (incl. front panel for stainless 6 U, 2 HP steel EMC gasket) item 6 bza45819 front panel for textile EMC gasket, 6 U, 2 HP item 6 06102501 Splitting extrusion for combined mounting Item 2 06102501 06102501 05806108 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Torx countersunk screw M4 × 14, zinc-plated, PU 100 pieces fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces finxing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces item 1: 2 front horizontal rails (H-KD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zinc-plated; item 4: Zn die-cast support member; item 6: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket (84:0 without items 4, 6) Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, die-cast zinc; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 piece (SPQ 5) 1 piece (SPQ 5)1) 1 piece 24562-420 24562-440 24562-442 24562-463 24562-484 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 –  Subdivision of the 6 U assembly area into: – 2x3U – 1x6U  Designed to accept Euroboards (100 mm high) and double Euroboards (233.35 mm high) Note  Please order perforated strips for horizontal rails separately, see page 5.90  Please order rear centre horizontal rail separately, see page 5.89 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.95 5_3_compacPRO_e.fm Seite 96 Montag, 17. September 2012 9:12 21 Desk-top cases – b Horizontal board installation Order Information Horizontal board installation Front frame for EMC shielding Board cage 27 3.9 8= 54 Front frame, unshielded TE w 273 h =5 4T 05806091 E bpa45913 H ,98 bza43061 05806092 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 HP space required; please order front frame for EMC shielding separately H = usable height (1 TE = 1 HP, 1 HE = 1 U) Height U Usable height h HP 3 2 horizontal covers, AI 2.5 mm, Al, 2.5 mm, clear anodised; front anodised, front frame with cut-out, rear iridescent green chromated; clear internal width w = 266.35 mm 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the subassemblies Other dimensions and options PU 1 kit PU 1 kit 1 piece 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Assembly tool, for mounting the EMC gasket (stainless steel) Horizontal rail, rear * For direct backplane mounting 5.96 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 97 Montag, 17. September 2012 9:12 21 Desk-top cases – b Air baffle for slots Order Information Air baffle without front panel 06108085 Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06101507 Depth mm 160 160 160 160 160 160 220 220 220 220 220 220 Width HP 4 4 8 8 12 12 4 4 8 8 12 12 Main Catalogue E 10/2012 Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 34562-823 34562-826 34562-833 34562-836 34562-843 34562-846 34562-824 34562-827 34562-834 34562-837 34562-844 34562-847 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.97 5_3_compacPRO_e.fm Seite 98 Montag, 17. September 2012 9:12 21 Desk-top cases – b Dimensions Extruded side panel 2 U Extruded side panel 3 U Text 19.5 19.5 A Z 15 M4 Z Y N x 15 = B ø 8.5 3 N x 15 = B Z ø 8.5 Y 4.6 ø 4.6 Y M4 M4 4.6 Y 15 ø 4.6 Z M4 3 49 132.55 121.95 99.95 24 88.1 77.5 55.5 A 02004057 02004058 Extruded side panel 4 U Extruded side panel 6 U A 19.5 19.5 AA 49 49 93 49 177 166.4 144.4 132.55 132.55 121.95 121.95 99.95 99.95 19.5 15 M4 ZZ Y N x 15 = B ø 8.5 33 Y 15 15 Z M4 M4 YY NNxx15 15==BB YY 4.6 4.6 ø 4.6 M4 4.6 øø8.5 8.5 øø4.6 4.6 02004059 ZZ M 44 M 3 49 49 132.55 132.55 121.95 121.95 99.95 99.95 265.9 265.9 Z 02004060 Dimensions For case depth mm 271 331 391 451 511 Max. mounting depth mm 250 310 370 430 490 Dimensions A in mm 231 291 351 411 471 B in mm 15 15 = 225 19 15 = 285 23 15 = 345 27 15 = 405 31 15 = 465 Note Side panel for 6 U case consists of two 3 U extruded side panels 5.98 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_3_compacPRO_e.fm Seite 99 Montag, 17. September 2012 9:12 21 Desk-top cases – b Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.99 5_4_comptec_e.fm Seite 100 Dienstag, 18. September 2012 5:57 05 JMain Catalogue Overview . . . . . 0 Desk-top cases – J Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . 2 Accessories for cabinets and wall mounted cases 3 Climate control 4 Desk-top cases 5 02202003 Standards Subracks/ 19" chassis . . . 6 Front panels, plug-in units . . 7 쮿 Internal dimensions in accordance with IEC 60297-3-100 쮿 Type of protection IP 20 in accordance with IEC 60529 쮿 Protective ground connections in accordance with: DIN EN 50178/VDE 0160 DIN EN 60950/VDE 0805 DIN EN 61010-1/VDE 0411 part 1 DIN EN 61010-1A2/VDE 0411 part 1/A1 Systems . . . . . . 8 Power supply units . . . . . . . . . 9 Backplanes . . 10 Connectors, front panel component system . . . . . . 11 Downloads and further important information can be found on the Internet under www.schroff.biz Appendix . . . . 12 5.100 Main Catalogue E 10/2012 MicroTCA 5_4_comptec_e.fm Seite 101 Dienstag, 18. September 2012 5:57 05 Desk-top cases – J Overview . . . . 5.100 J Case to accept 19" subracks or 19" chassis 쮿 Internal assemblies of up to 40 kg 쮿 Up to six rows of ventilation slots in the base plate for optimal air inlet 쮿 High stability 쮿 Front and rear identical, depth-symmetrical construction 쮿 With handle strip or recessed grip Case comptec 쮿 Al die-cast frame front and rear 3, 4 U, St . . . . . . 5.102 쮿 Top cover and base plate can be subsequently removed 6, 7, 9 U, St . . . . 5.103 9, 12 U, Al . . . . . 5.104 쮿 Top cover and base plate fitted with hidden GND/earth connections 쮿 Case height 3, 4, 6, 7 and 9 U (cladding parts in steel) 쮿 Case height 9 U and 12 U (cladding parts in aluminium) Accessories Folding handle 5.105 Slide rails . . . . . . 5.105 Earthing kit . . . . 5.106 Assembly kit . . . . 5.106 Tip-up feet . . . . . 5.107 02202004 Text 02202005 ServicePLUS from page 5.4 ServicePLUS . . 5.4 e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) e.g. assembly service from 1 piece www.schroff.biz/ServicePLUS 30407004 E 10/2012 5.101 5_4_comptec_e.fm Seite 102 Dienstag, 18. September 2012 5:57 05 Desk-top cases – J 19" case, 3 U, 4 U JMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Desk-top case (pre-fitted) 쮿 Top cover, base plate and rear panel in steel 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slits in base plate 쮿 Ventilation gills in rear panel 쮿 Side panel with integral handle function Delivery comprises (kit) 02202001 7 9 1 Item 1 2 5 7 Qty 1 1 2 1 8 1 9 1 10 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side panel, Al extrusion, RAL 7016 Cover plate, Al, 1 mm, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, RAL 9006, with GND/earthing tag Rear panel, St, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Items 1, 2, 5 and 9 fitted. 2 Order Information 5 Height H h U 3 3 3 4 4 4 mm 13.0 13.0 13.0 13.0 13.0 13.0 8 10 CTTP0001 Front view mm 153 153 153 198 198 198 Depth D Usable depth d mm mm 300 276 400 376 500 476 300 276 400 376 500 476 Width B mm 520 520 520 520 520 520 Part no. 10225-601 10225-612 10225-623 10225-602 10225-613 10225-624 Note H HE 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page. 5.107 쮿 Please order slide rails separately, see page 5.105 h b B CTA30677 h = case foot height, HE = U, internal usable height For further information www.schroff.biz/oneclick oneClick search code = Part no. Side view CTA42313 Usable width b = B - 69 mm, h = height of case foot ServicePLUS see page 5.4 5.102 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_4_comptec_e.fm Seite 103 Dienstag, 18. September 2012 5:57 05 Desk-top cases – J 19" case, 6 U, 7 U, 9U J 쮿 Desk-top case (pre-fitted) 쮿 With handle shell 쮿 Top cover, base plate and rear panel in steel 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slits in rear panel and base Delivery comprises (kit) 02202002 7 9 Item 1 2 3 4 5 Qty 1 1 2 2 2 6 2 7 8 9 10 1 1 1 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side profile at top, Al extrusion, RAL 7016 Side profile at bottom, Al extrusion, RAL 7016 Side panel, St, 1.5 mm, RAL 9006, with GND/earthing tag Handle shell, PC, RAL 7016, UL 94 V-0, load-carrying capacity: 60 kg/pair Cover plate, St, 1 mm, RAL 9006, with GND/earthing tag Base plate, St, 1 mm, RAL 9006, with GND/earthing tag Rear panel, St, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit 3 1 6 Items 1, 2, 3, 4, 5, 6 and 9 fitted. 5 2 4 Order Information Height H h U 6 6 6 6 7 7 7 9 9 9 mm 13 13 13 13 13 13 13 13 13 13 8 10 CTTP0002 H HE Front view mm 286 286 286 286 331 331 331 420 420 420 Depth D Usable depth d mm mm 300 276 400 376 500 476 600 576 400 376 500 476 600 576 400 376 500 476 600 576 Width B mm 520 520 520 520 520 520 520 520 520 520 Part no. 10225-604 10225-615 10225-626 10225-637 10225-616 10225-627 10225-638 10225-618 10225-629 10225-640 h Note b B CTA30676 h = case foot height, HE = U, internal usable height Side view 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page 5.107 쮿 Please order slide rails separately, see page 5.105 쮿 Handle shell, item 6, can be replaced by a folding handle, see page 5.105 For further information www.schroff.biz/oneclick oneClick search code = Part no. CTA42312 Usable depth d = D - 24 mm ServicePLUS see page 5.4 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.103 5_4_comptec_e.fm Seite 104 Dienstag, 18. September 2012 5:57 05 Desk-top cases – J 19" cases 9 and 12 U, aluminium J 쮿 Desk-top case (pre-fitted) 쮿 With handle shell 쮿 Top cover, base plate and rear panel in Al 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slots in base plate 쮿 Air vents in rear panel Delivery comprises (kit) 02202006 Item 1 2 3 4 5 Qty 1 1 2 2 2 6 2 7 8 9 10 1 1 1 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side profile at top, Al extrusion, RAL 7016 Side profile at bottom, Al extrusion, RAL 7016 Side panel, Al, 1.5 mm, RAL 9006, with GND/earthing tag Handle shell, PC, RAL 7016, UL 94 V-0, load-carrying capacity: 60 kg/pair Cover plate, Al, 1 mm, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, RAL 9006, with GND/earthing tag Rear panel, Al, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit 7 9 3 6 1 5 2 Items 1, 2, 3, 4, 5, 6 and 9 fitted. 4 Order Information 8 10 CTTP0003 h Depth D U 9 9 9 12 12 12 mm 13 13 13 13 13 13 mm 400 500 600 400 500 600 mm 420 420 420 553 553 553 Usable depth d mm 376 476 576 376 476 576 Width B mm 520 520 520 520 520 520 Part no. 10225-667 10225-682 10225-693 10225-670 10225-685 10225-696 H HE Front view Height H h Note b B CTA30679 Usable width b = B - 69 mm, h = height of case foot Side view 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page 5.107 쮿 Please order slide rails separately, see page 5.105 쮿 Handle shell, item 6, can be replaced by a folding handle, see page 5.105 For further information www.schroff.biz/oneclick oneClick search code = Part no. CTA42314 Usable depth d = D - 24 mm ServicePLUS see page 5.4 5.104 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Desk-top cases – J Folding handle J 쮿 Folding handles can be used instead of the pre-fitted handle shells 쮿 Load-carrying capacity: 50 kg/pair Delivery comprises (kit) Item 1 2 Qty 2 1 Description Folding handle, AI die-cast, RAL 7016 Assembly kit Order Information Description Folding handle CTTP0006 Part no. 20225-439 For further information www.schroff.biz/oneclick oneClick search code = Part no. Slide rails J 쮿 Slide rails are suitable as support for 19" subracks and 19" chassis Delivery comprises Item 1 Qty 1 Description Slide rail, Al extrusion, anodised, cut edges plain, static load-carrying capacity 10 kg Order Information For case depth mm 300 400 500 600 Part no. 30225-089 30225-090 30225-091 30225-092 Note 쮿 2 slide rails are required per subrack or 19" chassis 쮿 Slide rail cannot be used for shielded 19" subracks; special slide rails available on request For further information www.schroff.biz/oneclick oneClick search code = Part no. CTTP0005 Main Catalogue E 10/2013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.105 5_4_comptec_e.fm Seite 106 Dienstag, 16. Oktober 2012 7:42 07 Desk-top cases – J GND/earthing kit J 쮿 The GND/earthing kit allows VDE compliant earthing of cases in accordance with: EN 50178/VDE 0160 EN 60950/VDE 0805 EN 61010-1/VDE 0411 part 1 EN 61010-1A2/VDE 0411 part 1/A 쮿 VDE tested Delivery comprises (kit) Item 1 Qty 1 Description GND/earthing kit, Cu wire, 1.5 mm2, PVC sheathing, green/yellow, connects side panels, cover, base plate and rear panel Order Information Description aza43284 GND/earthing kit for cases with steel covers GND/earthing kit for cases with aluminium covers Up to 4 U Part no. bigger than 4 U Part no. 21100-490 21100-448 – 21100-347 For further information www.schroff.biz/oneclick oneClick search code = Part no. 19" fixing J 쮿 For fitting subracks or 19" chassis in a comptec case 쮿 For fixing 19" front panels Delivery comprises Item 1 2 3 Description Screw M6 × 16, zinc-plated with Pozidrive Cage nut M6, zinc-plated Plastic washer, ABS, black Order Information SC128XXX Description PU = 8 × screw, washer, nut PU = 50 each of M6 screw, washer and cage nut PU = 100 each of M6 screw, washer and cage nut Part no. 21100-435 21101-809 21101-810 For further information www.schroff.biz/oneclick oneClick search code = Part no. 06108055 5.106 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_4_comptec_e.fm Seite 107 Dienstag, 18. September 2012 5:57 05 Desk-top cases – J Plastic tip-up feet J 쮿 Static load-carrying capacity 25 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 For further information www.schroff.biz/oneclick oneClick search code = Part no. 01802075 Tip-up foot in die-cast Al J 쮿 Static load-carrying capacity 50 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Order Information Description Qty Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-002 10603-001 21101-211 21100-211 21100-207 1) Part no. comprises 1 piece; delivery is in standard pack quantity (SPQ): please order a minimum of 10 feet or a multiple For further information www.schroff.biz/oneclick oneClick search code = Part no. AZA43836 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.107 5_5_Gehäusezubehör_e.fm Seite 108 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Contents AccessoriesMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 06002052 05895003 02992004 aza43835 02992003 32506001 쮿 쮿 쮿 쮿 쮿 쮿 쮿 쮿 Front handles see page 5.108 Strap handles see page 5.111 Tip-up carrying handles, see page 5.112 Folding handles see page 5.113 Tray handle see page 5.114 Feet, see page 5.115 Screwdriver (Torx) 5.117 Measuring tape, see page 5.117 Front handle, one-piece, width 7 mm AccessoriesMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Static load-carrying capacity 10 kg/pair 쮿 Bolted from rear Delivery comprises (kit) Item 1 Qty 1 Description Front handle, Al extrusion, anodised Order Information A mm 48 98 E mm 40 90 Part no. 10501-001 10501-002 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. BZA42318 For further information www.schroff.biz/oneclick oneClick search code = Part no. Front handle, one-piece, width 9 mm Accessories 쮿 Static load-carrying capacity 30 kg/pair 쮿 Bolted from rear Delivery comprises (kit) Item 1 Qty 1 Description Front handle, Al extrusion, anodised Order Information Description Front handle Pozidrive countersunk screw 14 × 10, zinc-plated, PU 100 pieces Part no. 10501-003 21101-381 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. BZA42330 For further information www.schroff.biz/oneclick oneClick search code = Part no. 5.108 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_5_Gehäusezubehör_e.fm Seite 109 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Front handle, one-piece, width 10 mm Main Catalogue 40 4 쮿 Static load-carrying capacity 30 kg/pair 10 h Delivery comprises (kit) Item 1 2 H Ø 8,4 Ø 4,4 10 쮿 Bolted from front Qty 2 1 Description Front handle, Al extrusion, anodised Assembly kit 8 02905050 H=1U Order Information Height H U 1 2 3 4 5 Height H mm 40 69 113 157.45 201.9 Height h mm 28 53 97.5 141.9 186.4 Part no. 20860-256 20860-257 20860-258 20860-259 20860-260 For further information www.schroff.biz/oneclick oneClick search code = Part no. H≥2U 02905051 Front handle, one-piece, width 12.2 mm 1U Main Catalogue 쮿 Static load-carrying capacity 30 kg/pair 쮿 Bolted from rear Delivery comprises Item 1 Qty 1 Description Front handle, AI extrusion, anodised Order Information BZA42316 2 U ... 6 U A E clear anodised black anodised mm mm Part no. Part no. 41 25 10501-116 – 57.5 44.5 10501-016 – 69 55 10501-004 10501-025 102 88 10501-005 10501-026 132 120 10501-006 10501-027 146.4 133.4 10501-018 – 194 180 10501-007 10501-028 249 235 10501-008 10501-029 Panhead pozidrive screw self-locking, M5 × 12, 21100-788 zinc-plated, PU 100 pieces Torx countersunk screw M5 × 12, zinc-plated, 24560-183 100 pieces Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. Note BZA42327 Main Catalogue E 10/2012 쮿 Please order panhead screws separately Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.109 5_5_Gehäusezubehör_e.fm Seite 110 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Front handle, multi-piece, width 12 mm 쮿 Static load-carrying capacity 10 kg/pair 쮿 In three parts, middle section in Al extrusion, end pieces in glass fibre reinforced plastic 쮿 Bolts on from front Delivery comprises (kit) Item 1 2 Qty 1 2 Description Front handle, Al extrusion, anodised End piece, PA, black Order Information A E mm mm 87.5 73.5 102.0 88 134.0 120 194.0 180 249 235 Panhead screw pozidrive self-locking, M5 × 12, zinc-plated, PU 100 pieces A3-227 Part no. 10502-050 10502-057 10502-059 10502-063 10502-065 21100-788 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. Note 쮿 Please order panhead screws separately For further information www.schroff.biz/oneclick oneClick search code = Part no. Front handle, multi-piece, width 12 mm Accessories 12 Order Information Description Qty/PU Item 1, front handle, Al extrusion, 1 anodised,1 m long Item 2, end piece, PA, black, 1 2 pieces each required Panhead pozidrive screw self-locking, M5 × 12, zinc-plated, PU 100 pieces 2 Part no. 30502-051 60502-003 21100-788 1000 1 40 02908050 Item 1: front handle; item 2: end piece 5.110 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_5_Gehäusezubehör_e.fm Seite 111 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Strap handle, width 25 mm Accessories 쮿 Static load-carrying capacity 20 kg Delivery comprises (kit) Item 1 Qty 1 2 3 2 1 Description Band, spring steel, handle, flexible plastic, grey, RAL 7016 Cover, grey, RAL 7016 Assembly kit Order Information Length mm 230 Part no. 20850-249 For further information www.schroff.biz/oneclick 05895003 oneClick search code = Part no. 02902050 Strap handle, width 22 mm Accessories 쮿 Static load-carrying capacity 20 kg Delivery comprises (kit) Item 1 2 3 Qty 1 2 1 Description Band, spring steel, plastic-coated, black Cover cap, St, chrome-plated Assembly kit Order Information 02992006 Length mm 170 240 Part no. 10504-002 10504-003 Length 240 mm/170 mm For further information www.schroff.biz/oneclick oneClick search code = Part no. BZA42368 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.111 5_5_Gehäusezubehör_e.fm Seite 112 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Tip-up carrying handle in separate parts AccessoriesMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 Static load-carrying capacity 25 kg (with handle bars of 450 mm length) 02992002 02992001 Lateral handle parts Accessories 쮿 Handle can be adjusted in 30° grid by pressing button Delivery comprises (kit) Item 1 2 3 4 Qty 2 2 2 1 Description Lateral parts, die-cast zinc, painted (chrome decor) Safety inserts, St, 1.5 mm, black Adaptor/locking brackets Assembly kit Order Information 02992002 Length mm 180 250 Part no. 10502-297 10502-296 For further information www.schroff.biz/oneclick oneClick search code = Part no. A4-2361 Handle bar Accessories Delivery comprises (kit) Item 1 Qty 1 Description Handle bar, AI, black anodised Order Information Length mm 1000 Part no. 30502-191 For further information www.schroff.biz/oneclick 02992001 oneClick search code = Part no. A4-2367 5.112 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_5_Gehäusezubehör_e.fm Seite 113 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Folding metal handle Accessories 쮿 Static load-carrying capacity 30 kg/pair 쮿 For case ingress protection to IP 40 쮿 Locks in folded and opened positions 쮿 Equal cut-out for fitting in front of or behind case wall Delivery comprises (kit) 02992004 Item 1 2 Qty 1 1 Description Handle, Al die-cast, RAL 9005, black Handle shell, Al die-cast, RAL 9006, silver Order Information Description Folding metal handle Part no. 20505-032 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. For further information www.schroff.biz/oneclick oneClick search code = Part no. A4-2369 A4-2370 Folding plastic handle Accessories 쮿 Static load-carrying capacity 20 kg/pair 쮿 For case ingress protection to IP 40 쮿 Locks in folded and opened positions 쮿 External mounting only Delivery comprises (kit) 02992005 Folding plastic handle Item 1 2 3 Qty 1 1 1 Description Handle, PA, light grey Handle shell, PA, dark grey Assembly kit Order Information Description Folding plastic handle Part no. 10505-014 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. For further information www.schroff.biz/oneclick oneClick search code = Part no. A2-123 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.113 5_5_Gehäusezubehör_e.fm Seite 114 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Tray handle Accessories 쮿 Static load-carrying capacity 30 kg/pair Delivery comprises Item 1 Qty 1 Description Handle shell, PC, UL 94 V-0 Order Information Colour 02992003 Size 1 for material Size 1 for material Size 2 for material thickness 1.5 mm thickness 2.5 mm thickness 1.5 mm Part no. Part no. Part no. grey60229-002 brown black 60229-004 RAL 7016 – Spring clip PU 20 pieces Spring clip PU 100 pieces 60229-001 60225-015 60229-003 – 60225-012 20225-167 21100-089 21100-093 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order a minimum of 10 tray handles or a multiple. Pricing is per individual item. Note A3-0670a 쮿 Please order spring clips for fixing to the case separately Required: – for handle size 1: 2 spring clips – for handle size 2: 3 spring clips Size 1, case cut-out 49 × 104 mm For further information www.schroff.biz/oneclick oneClick search code = Part no. A3-0670b Size 2, case cut-out 73 × 171 mm 5.114 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_5_Gehäusezubehör_e.fm Seite 115 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Plastic foot Accessories Delivery comprises Pos. 1 Menge 1 Beschreibung Plastic foot, PC, UL 94 V-0, black Order Information Description Dimensions A B C mm mm mm For material thickness 1 ... 3 16 7.2 4 For material thickness 1.5 ... 3 21 15 7 Hole diameter mm 7 7.7 Part no. 60224-009 60224-011 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 50 pieces or a multiple. Pricing is per individual item. Note A4-330 쮿 Foot is inserted into mounting hole and then fixed by pressing in the expanding pin For further information www.schroff.biz/oneclick oneClick search code = Part no. Rubber foot Accessories Order Information Dimensions Height Hole diameter mm mm 10 25 15 26 Material Colour Qty Rubber Rubber grey grey 1 1 Part no. 60200-001 60200-027 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 50 pieces or a multiple. Pricing is per individual item. For further information www.schroff.biz/oneclick A4-2315 Main Catalogue E 10/2012 oneClick search code = Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.115 5_5_Gehäusezubehör_e.fm Seite 116 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Plastic tip-up foot Accessories 쮿 Static load-carrying capacity 25 kg per foot 78,4 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case 47 Order Information Description 38,4 13,9 20 Ø3,1 Ø4,8 grey Part no. Foot with tip-up, PA, UL 94 HB 1 10603-023 Foot without tip-up, PA, UL 94 HB 1 10603-024 Pozidrive flathead screw M4 × 10, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces black Part no. 10603-025 10603-026 21100-513 21100-211 21100-207 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order a minimum of 10 feet or a multiple. Pricing is per individual item. 5 13,3 15,8 1 AZA43835 Qty/PU Note 쮿 Please order assembly kit separately. 14 For further information www.schroff.biz/oneclick oneClick search code = Part no. 02912050 Plastic tip-up feet Accessories 쮿 Static load-carrying capacity 25 kg per foot 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 For further information www.schroff.biz/oneclick oneClick search code = Part no. 0180207502906050 5.116 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5_5_Gehäusezubehör_e.fm Seite 117 Dienstag, 18. September 2012 10:04 10 Desk-top cases – Accessories Al die-cast tip-up foot Accessories 쮿 Static load-carrying capacity 50 kg per foot 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case Order Information Description Qty Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Accessories Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-001 10603-002 21101-211 21100-211 21100-207 1) Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. AZA43836 Screwdriver Retention partsMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working days 쮿 T8: For mounting guide rails to horizontal rails 쮿 T20: For mounting horizontal rails and rear hoods to side panels, cover plates, support brackets and front handles Order Information Torx screwdriver M2.5 M4 Qty/PU pieces 1 1 T 8 Torx T 20 Torx Part no. 64560-026 64560-027 For further information www.schroff.biz/oneclick AZA45925 oneClick search code = Part no. Measuring tape Main Catalogue 쮿 Measuring tape with cm, U-, HP-division (lenght 2 m) 쮿 Plastic cases, metal measuring tape with automatic collection Order Information Description Measuring tape Qty/PU 1 Part no. 89009-001 For further information www.schroff.biz/oneclick oneClick search code = Part no. 32506001 Main Catalogue E 10/2012 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.117 Main Catalog 24th Edition Main Catalog Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM Equipment Protection Solutions 24th Edition | October 2012 39601-641 © 2012 Pentair Equipment Protection 18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1 10.10.2012 11:15:02
24560157 价格&库存
很抱歉,暂时无法提供与“24560157”相匹配的价格&库存,您可以联系我们找货
    • 1+89.64000
    • 10+85.32000
    • 100+79.92000
    库存:60
    24560157
      库存:60
