686
686
    KEYSTONE
    CONN HDR MINI/SMALL HSG 11-PIN
686 数据手册
R TI F I ED HOUSINGS & HEADERS 2 T Y CE 900 ISO Q I UAL PLUG-IN HOUSINGS Enhance the appearance and give a professional look to your products using these molded housings. Ideally suited for packaging relays, logic packages, networks and miniature circuitry. Durable, lightweight covers withstand vibrations and rough usage. HEADERS: Molded of G.P. black phenolic. Fits standard sockets. PINS: Brass, Nickel Plated. MATERIAL CHARACTERISTICS: • Variety of molded materials • Good chemical resistance. POLYSTYRENE: For general purpose use where high impact strength is not required and temperature would not exceed 170º F. LEXAN: 3 Times the impact strength of Polystyrene. Excellent electrical properties. Use wherever temperatures of 280º F exist Housing with Octal Header Housing Fig. & 4 Screws Only No. CAT. NO. CAT. NO. Type Material Color 660 661 662 641 670 671 672 675 1 1 1 1 Mini Mini Mini Mini Lexan Lexan Polystyrene Polystyrene Clear White Clear Opaque Black 663 664 665 643 673 674 676 647 2 2 2 2 Small Small Small Small Lexan Lexan Polystyrene Polystyrene Clear White Clear Opaque Black 650 668 677 649 679 666 3 3 3 Large Large Large Lexan Polystyrene Polystyrene Clear Clear Opaque Black 639 710 712 640 711 713 4 4 4 Xtra-L'ge Xtra-L'ge Xtra-L'ge Polystyrene Polystyrene Lexan Clear Opaque Black Clear MINI SMALL FIG. 1 FIG. 2 LARGE EXTRA LARGE FIG. 3 FIG. 4 HEADERS FOR THE ABOVE HOUSINGS HEADERS: Headers are available in a variety of pin configurations that fir standard sockets. Molded of general purpose phenolic with brass nickel plated pins sturdily staked. FIG. 1 1 3/8 Sq. Headers for Mini & Small Housing (Fig. 1 Above) CAT. NO. 681 682 683 102 Pin Configuration Octal Nine Pin Eleven Pin FIG. 2 1 15/16 Sq. Headers for Large Housing (Fig. 2 Above) CAT. NO. 1 3/4 x 2 3/8 Headers for Extra Large Housing (Fig. 3 Above) CAT. NO. 685 Not Available 686 690 Not Available 714 FIG. 3 SELF TAPPING SCREW CAT. NO. 689-For covers #4x3/8 Lg. 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com
686
物料型号: - 插件式外壳和插座有多种型号,包括不同尺寸(Mini, Small, Large, Xtra-L'ge)和材料(Lexan, Polystyrene)。
器件简介: - 这些外壳用于提升产品外观,适用于包装继电器、逻辑组件、网络和微型电路。它们耐用、轻便,能承受震动和粗暴使用。
引脚分配: - 提供了不同引脚配置的插座,包括八针、九针和十一针配置。
参数特性: - 材料特性包括多种模具材料选择和良好的化学抗性。例如,Lexan材料的耐冲击强度是聚苯乙烯的三倍,适合在高达280°F的温度下使用。
功能详解: - 外壳和插座的设计旨在提供专业外观,同时保护内部组件免受损害。
应用信息: - 适用于需要保护内部电子组件免受物理损害的各种应用场景。
封装信息: - 提供了不同尺寸和材料的外壳,以适应不同大小和类型的电子组件。
很抱歉,暂时无法提供与“686”相匹配的价格&库存,您可以联系我们找货
