Hammond Mfg. - Extruded Aluminum Enclosures (Channel Mount) - 1455NC Series
Page 1 of 3
Extruded Aluminum Enclosures - Channel
Mount
(1455NC Series)
Path: Home > Enclosure Index > Extruded Aluminum (Channel Mount)
(click to enlarge)
Open Bezel With Metal Endplate
Version
(Open View)
(click to enlarge)
Solid ABS Plastic Bezel Version
(Open View)
Key Features:
z
z
z
z
z
z
z
z
z
Designed to house P.C. boards or equipment - for easy enclosure mounting to aluminum channel.
Two versions to choose from (open bezel with metal endplates OR solid ABS plastic bezel ).
Sized for P.C. boards with 92mm (min.) to 98mm (max.) width. Enclosures will not accept & were not
designed for 100mm wide eurocard.
P.C. boards mount horizontally by sliding into internal slots extruded into the enclosure body.
Rugged one piece body - constructed from extruded aluminum with a minimum thickness of .09” (2.29
mm).
Extruded body & aluminum endplates (on metal endplate version) are clear anodized.
Open bezel - metal endplate version includes eight (8) clear zinc plated assembly screws. NOTE:
Recommended screw torque is 5 lbf/in
Solid bezel version includes eight (8) black assembly screws. NOTE: Recommended screw torque is 5
lbf/in.
See
"photo tables" for more visual details.
(click to enlarge)
http://www.hammondmfg.com/1455NC.htm
4/29/2011
Page 2 of 3
Open Front & Rear Bezels With Metal Endplates
Open Bezels with
Metal Endplates
Part Number
3D
AutoCAD
Solid Model
Units Length Width Height
.dwg Files
Reader (zipped) .igs & .stp
files (zipped)
File
Inches 4.72
4.06
2.09
120
103
53
Inches 6.30
4.06
2.09
160
103
53
Inches 8.66
4.06
2.09
103
53
1455NC1201
253K
153K
mm
194K
1455NC1601
253K
152K
mm
194K
1455NC2201
254K
154K
mm
193K
220
Link here to photo tables of each part number
(click to enlarge)
Solid ABS Plastic Front & Rear Bezels
Solid Plastic
Bezels
3D
AutoCAD
Solid Model
.dwg Files
files (zipped)
Part Number File
Inches 4.72
4.06
2.09
120
103
53
Inches 6.30
4.06
2.09
160
103
53
Inches 8.66
4.06
2.09
103
53
1455NC1202
239K
146K
mm
173K
1455NC1602
240K
146K
mm
173K
1455NC2202
235K
146K
173K
mm
220
Accessories
4/29/2011
Page 3 of 3
Channel Mounting Kits:
(click to enlarge)
Part
Number
Description
Thumbnail
1455TBOLT Quantity two (2) - 8mm X 20 "T" bolts, washers & hex nuts
1455TNUT
Quantity two (2) - 8mm "T" nuts
1455TSNUT Quantity two (2) - 8mm "T" nuts & springs
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check
and ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 2011 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
4/29/2011
很抱歉,暂时无法提供与“1455TSNUT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+116.917021+15.01471
- 5+99.307515+12.75327
- 10+93.1988710+11.96878
- 25+86.1913125+11.06886
- 50+81.5858450+10.47742
- 100+77.49732100+9.95236
- 250+72.77951250+9.34649
- 500+69.66189500+8.94612
- 1000+66.881531000+8.58906
