EHLLSS
EHLLSS
    HAMMONDMANUFACTURING
    LATCH HANDLE LOCKING L BLACK
EHLLSS 数据手册
www.hammondmfg.com Eclipse Series - NEMA 4, 12 Accessories Eclipse Inner Panel • Larger than standard NEMA panel used in same sized enclosure. • 12 gauge steel construction (see chart, below). • Larger sizes have 2 or 4 formed flanges for added strength. Industrial Enclosures Wallmount Enclosures Mild Steel Part No. EP1212 EP1224 EP1612 EP1616 EP1620 EP2012 EP2016 EP2020 EP2024 EP2412 EP2416 EP2420 EP2424 EP2430 EP2442 EP2448 EP3012 EP3016 EP3020 EP3024 EP3030 Galvanized Part No. EPG1212 EPG1224 EPG1612 EPG1616 EPG1620 EPG2012 EPG2016 EPG2020 EPG2024 EPG2412 EPG2416 EPG2420 EPG2424 EPG2430 EPG2442 EPG2448 EPG3012 EPG3016 EPG3020 EPG3024 EPG3030 Size D E Gauge 10.2 10.2 12 10.2 22.2 12 14.2 10.2 12 14.2 14.2 12 14.2 18.2 12 18.2 10.2 12 18.2 14.2 12 18.2 18.2 12 18.2 22.2 12 22.2 10.2 12 22.2 14.2 12 22.2 18.2 12 22.2 22.2 12 22.2 28.2 12 22.2 40.2 12 22.2 46.2 12 28.2 10.2 12 28.2 14.2 12 28.2 18.2 12 28.2 22.2 12 28.2 28.2 12 Mild Steel Part No. EP3036 EP3042 EP3048 EP3060 EP3624 EP3630 EP3636 EP3642 EP3648 EP3660 EP4224 EP4230 EP4236 EP4824 EP4830 EP4836 EP4848 EP6036 EP7230 EP7236 Galvanized Part No. EPG3036 EPG3042 EPG3048 EPG3060 EPG3624 EPG3630 EPG3636 EPG3642 EPG3648 EPG3660 EPG4224 EPG4230 EPG4236 EPG4824 EPG4830 EPG4836 EPG4848 EPG6036 EPG7230 EPG7236 Size D E Gauge 28.2 34.2 12 28.2 40.2 12 28.2 46.2 12 28.2 58.2 12 34.2 22.2 12 34.2 28.2 12 34.2 34.2 12 34.2 40.2 12 34.2 46.2 12 34.2 58.2 12 40.2 22.2 12 40.2 28.2 12 40.2 34.2 12 46.2 22.2 12 46.2 28.2 12 46.2 34.2 12 46.2 46.2 12 58.2 34.2 12 70.2 28.2 12 70.2 34.2 12 Eclipse Swing Panel • • • • Hinged panel allows access to internally mounted equipment. 12 gauge steel construction. Slotted quarter turn latches provide closure. Adding optional locking quarter turn latches (Part Number EQTRL...see page 31) convert this to a dead front panel. • Complete with 4-6" depth adjustment channels. • Hardware kit maintains UL, CSA and NEMA ratings when field installed. • Finished in white. Part No. ESP1212 ESP1612 ESP1616 ESP1620 ESP2016 ESP2020 ESP2024 Fits Enclosure Size (A x B) 12 x 12 16 x 12 16 x 16 16 x 20 20 x 16 20 x 20 20 x 24 Part No. ESP2416 ESP2420 ESP2424 ESP3020 ESP3024 ESP3030 ESP3624 Fits Enclosure Size (A x B) 24 x 16 24 x 20 24 x 24 30 x 20 30 x 24 30 x 30 36 x 24 Part No. ESP3630 ESP3636 ESP4236 ESP4824 ESP4836 ESP6036 Fits Enclosure Size (A x B) 36 x 30 36 x 36 42 X 36 48 X 24 48 X 36 60 X 36 Eclipse Replacement Hinge Pins • These are supplied with enclosure but offered here as replacements should originals be Part No. misplaced. • Packaged in quantities of 5. EPINSS Technical references and CAD downloads available at www.hammondmfg.com 29 Material Stainless steel hinge pin All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Eclipse Series - NEMA 4, 12 Accessories Eclipse Swing Frame Part No. ESF2424 ESF3024 ESF3624 Fits Enclosure Size (A x B) 24 x 24 30 x 24 36 x 24 • Order package of 25 clip nuts separately (Part No. 1421N25…see page 430 ). • Hardware kit maintains UL, CSA and NEMA ratings when field installed. • Finished in black. Industrial Enclosures • Provides 19" rack mounting with full EIA spacing (punched holes). • Hinges allow easy equipment access. • Slotted quarter turn latches provide closure. • Adding optional locking quarter turn latches (EQTRL...see page 31 ) provides added security. • Complete with 4-6" depth adjustment channels. Rack Spacing Width Height (Units) 19 11 19 14 19 17 DIN Rail Mounting Kit Part No. 2DMK12 2DMK16 2DMK20 2DMK24 2DMK30 A 10 14 18 22 28 B 1.25 0.75 0.88 1.00 0.88 Wallmount Enclosures • Field installable. • Mounts directly to panel collar studs (panel not required). • Accepts optional DIN rails, see below. • DIN rails available separately. • Zinc plated. C 7 11 14 17 22 DIN Rails • Field installable. • Includes a set of 3 plated rails. • Available in 3 industry standard profiles DIN 1, DIN 3, and CENELEC. • DIN rail mounting kit required for installation (see above). • Rails have a 0.28 x 1.25 oblong slot on each end. • Zinc plated. Asymmetric Din 1 Symmetric Din 3 Cenelec Profile Profile Part No. Profile Part No. Part No. 2D1K12 2D2K12 2DCK12 2D1K16 2D2K16 2DCK16 2D1K20 2D2K20 2DCK20 2D1K24 2D2K24 2DCK24 2D1K30 2D2K30 2DCK30 For sizing, refer to master selection table...see page 20 Length 9.25 13.25 17.25 21.25 27.25 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 30 www.hammondmfg.com Eclipse Series- NEMA 4, 12 Accessories Quarter Turn Inserts and Keys Industrial Enclosures • Field installable inserts replace standard quarter turn slot. • Available in 7mm square and triangle formats, as well as slotted. • Square and triangle inserts provide extra security since standard screw drivers cannot open. • Keys sold separately from inserts. • Maintains NEMA, UL and CSA 12, 4 and 4X ratings. Part No. 2SQI7 2SQK7 2TRI7 2TRK7 2SLI Description 7mm square insert, black 7mm square key, fits 2SQI7 7mm triangle insert, black 7mm triangle key, fits 2TRI7 Slotted insert, black Replacement Quarter Turn Assemblies • Field installable. • Interchangeable with standard quarter turn latches. • Maintains NEMA, UL and CSA ratings as noted. 2QPL EQTRL 2WKL 2SSQTR Part No. EQTRL1 2QTR 2SSQTR 2WKL 2QPL 1 EHTL Material Zinc Die/Chrome Zinc Die/Black Stainless steel Zinc Die/Black Zinc Die/Black NEMA Rating n/a (internal use only) 12, 4 12, 4, 4X 12, 4 12, 4 For use with Swing Frame/Panel. ..see page 29. All others for use with enclosures. Handles EHLPL EHLPLSS Description Locking Qtr Turn Slotted Qtr Turn Slotted Qtr Turn Wing knob lock Padlockable quarter turn latch EHLNLSS EHLL • Field installable. • Interchangeable with standard quarter turn latches. • Maintain NEMA, UL and CSA ratings as noted. Part No. EHTL EHLL EHLPL EHLPLSS EHLNLSS EHLLSS Description Locking T Handle Locking L Handle Padlockable L Handle Padlockable L Handle Non Locking L Handle Locking L Handle Material Zinc Die/Black Zinc Die/Black Zinc Plated 316 Stainless Steel 316 Stainless Steel 316 Stainless Steel NEMA Rating 12, 4 12, 4 12 12, 4, 4X 12, 4, 4X 12, 4, 4X Eclipse Mounting Foot Kit • • • • • • Maintains UL, CSA and NEMA ratings. Field installable. New triangular flanges prevent the foot from rotating Foot can still be mounted sideways as well as top/bottom Available in mild, 304SS and 316SS Packaged in quantities of four Part No. EZPMFHD ESSMFHD ES16MFHD Material Clear Zinc Plated, mild steel Type 304 Stainless Type 316 Stainless Technical references and CAD downloads available at www.hammondmfg.com 31 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Eclipse Series- NEMA 4, 12 Accessories Eclipse Rear Mounting Hole Plugs Part No. Industrial Enclosures • Used to plug rear mounting holes for Eclipse series • Snap in plug designed for rear .50" mounting hole • Packaged in quantities of 40 EN4PLUG40 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 32
EHLLSS 价格&库存
很抱歉,暂时无法提供与“EHLLSS”相匹配的价格&库存,您可以联系我们找货
