R149-025-000
R149-025-000
    HAMMONDMANUFACTURING
    COUPLING ACCEPTS 48MM RND TUBE
R149-025-000 数据手册
www.hammondmfg.com Suspension Systems - NEMA 12, 13 Operator Interface Enclosure Tara Plus Suspension System Measurement Conversions 1 kg = 9.81 N 1 lb = 4.44 N e.g. 500 Newtons = 51 kg = 112.4 lbs 300 Newtons = 30.6 kg = 67.4 lbs 100 Newtons = 10.2 kg = 22.5 lbs 1 foot = 0.305 m Suspension System Application Construction Finish • Taraplus enclosure suspension systems are designed for light and medium loads. • The strength of tube and cast fittings provide a highly flexible robust system. • Enclosure coupling and elbow coupling fittings are die-cast from G AL SI 12 aluminum. • Suspension tubing is steel. • Fittings are finished in RAL 7040 window gray. • Suspension tubing is RAL 7035 light gray. Standards • Complies with • IEC 60529 IP54 Suspension Tube Part No. Round Tubes R144-301-000 R144-321-000 R144-321-500 Rectangular Tubes R144-311-000 R144-311-500 Outside mm Inside mm Tolerance 48 70 70 42 62 62 ±0.25 ±0.25 ±0.25 1 1 1.5 3.28 3.28 4.92 10 25 38 60 x 40 60 x 40 54 x 34 54 x 34 ±0.50 ±0.50 1 1.5 3.28 4.92 13 26 Technical references and CAD downloads available at www.hammondmfg.com 239 Length Metres Feet Ship Wt. lbs All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Suspension Systems - NEMA 12, 13 Bottom Mount Coupling • Attaches to enclosure. • Accepts 48mm round tube. perpendicular to enclosure top/bottom. • Die-cast Aluminum G Al Si 12. • Adjustable torque resistance. • Rotates 300°. Top Mount Part No. R149-025-500 R149-025-501 Mounting Position Top Bottom Tilt Coupling • • • • • Attaches to enclosure. Accepts 48mm round tube perpendicular to enclosure top/bottom. Die-cast Aluminum G Al Si 12. Rotates 300°. Features an adjustable tilt mechanism up to 35°. Suspension System Part No. R149-025-001 Elbow Coupling • • • • • • Part No. Operator Interface Enclosure Tara Plus Suspension System Attaches to enclosure. Accepts 60x40mm rectangular tube parallel to enclosure top/bottom. Die-cast Aluminum G Al Si 12. Adjustable torque resistance. Rotates 300°. Accessible from the top. R149-035-000 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 240 www.hammondmfg.com Suspension Systems - NEMA 12, 13 Operator Interface Enclosure Tara Plus Suspension System Tilt Elbow Coupling • • • • • Part No. Attaches to enclosure. Accepts 60x40mm rectangular tube parallel to enclosure top/bottom. Die-cast Aluminum G Al Si 12. Rotates 300°. Features an adjustable tilt. mechanism up to 35°. R149-035-001 Fixed Elbow 48 • • • • • • Suspension System Part No. For use with 48mm round tube and 60x40mm rectangular tube. Vertical 48mm tube connection for use with Couplings only (not Base 48). Die-cast Aluminum G Al Si 12. Large cover opening for easier cable pull through. No rotation. Accessible from the top. R149-020-000 Fixed Elbow 70 • • • • Part No. For use with 70mm round tube and 60x40mm rectangular tube. Die-cast Aluminum G Al Si 12. No rotation. Accessible from the top. R149-020-001 Technical references and CAD downloads available at www.hammondmfg.com 241 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Tara Plus Suspension System Rotating Elbow • • • • Part No. For use with 70mm round tube and 60x40mm rectangular tube. Die-cast Aluminum G Al Si 12. Rotates 300°. Accessible from the top. R149-040-000 Operator Interface Enclosure Suspension Systems - NEMA 12, 13 Base 48 • • • • • Suspension System Part No. For use with 48mm round tube. Not for use with any horizontal configurations. Compatible with tube up or tube down configurations. Die-cast Aluminum G Al Si 12. No rotation. R149-030-000 Base 70 • • • • • Part No. For use with 70 mm tube. Compatible with all vertical and horizontal configurations. Compatible with tube up or tube down configurations. Die-cast Aluminum G Al Si 12. No rotation. R149-030-001 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 242 www.hammondmfg.com Operator Interface Enclosure Suspension Systems - NEMA 12, 13 Tara Plus Suspension System Rotating Base 70 • • • • • • • Part No. For use with 70 mm tube. Compatible with all vertical and horizontal configurations. Compatible with tube up or tube down configurations. Die-cast Aluminum G Al Si 12. Rotates 300°. Integrated movement stop. Service free bearings. R149-005-001 Suspension System Socket Joint • • • • • • • Part No. Accepts 60x40mm rectangular tube parallel to its mounting surface. Die-cast Aluminum G Al Si 12. Integrated movement stop. Service free bearings. Rotates 300°. Adjustment screws (red screws). Accessible from the top. R149-005-000 Technical references and CAD downloads available at www.hammondmfg.com 243 All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice www.hammondmfg.com Suspension Systems - NEMA 12, 13 Wall Joint • • • • Part No. Accepts 60x40mm rectangular tube perpendicular to its mounting surface. Die-cast Aluminum G Al Si 12. Rotates 186°. Accessible from the top. R149-010-000 Vertical Wall Joint • Accepts 70mm tube parallel to its mounting surface. • Die-cast Aluminum G Al Si 12. • Rotates 316°. Suspension System Part No. R149-010-001 Intermediate Joint • • • • • Part No. Operator Interface Enclosure Tara Plus Suspension System Accepts 60x40mm rectangular tube. Die-cast Aluminum G Al Si 12. Integrated movement stop. One piece bellow. Rotates 300°. R149-015-000 Technical references and CAD downloads available at www.hammondmfg.com All dimensions in inches unless specified otherwise Quality Products. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.630.7030 Data Subject to change without notice 244
R149-025-000
物料型号:文档列出了多种悬挂系统的型号,例如R144-301-000、R144-321-000等,包括圆形和矩形管材。
器件简介:Tara Plus悬挂系统适用于轻到中等负载,设计灵活且结构牢固。符合NEMA 12和13标准,提供IP54防护等级。
引脚分配:文档中没有提到引脚分配,因为它是关于机械悬挂系统的。
参数特性:提供了悬挂系统的尺寸、公差、长度、重量等参数,例如圆形管材的外径、内径和长度。
功能详解:详细描述了各种组件的功能,如耦合器、倾斜耦合器、肘部耦合器等,以及它们的安装位置、可调节性和旋转角度。
应用信息:适用于操作界面外壳的悬挂系统,设计用于窗口灰色的轻和中等负载。
封装信息:提供了详细的安装孔模式和尺寸,以及技术参考和CAD下载链接。
R149-025-000 价格&库存
很抱歉,暂时无法提供与“R149-025-000”相匹配的价格&库存,您可以联系我们找货
