1591XXDBK
1591XXDBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 6"L X 3.25"W
1591XXDBK 数据手册
152.43 [6.00] B 46.50 [1.83] INSIDE HEIGHT 137.25 [5.40] A A 82.43 [3.25] 67.25 [2.65] B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 4.34 [.17] 75.40 [2.97] INSIDE WIDTH 50.50 [1.99] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 47.75 [1.88] BOX HEIGHT 145.00 [5.71] 59.00 [2.32] 75.00 [2.95] 145.40 [5.72] INSIDE LENGTH 4.50 [.18] 2.00 [.08] WALL THICKNESS 129.00 [5.08] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 114.75 [4.52] 54.25 [2.14] R4.50 [.18] 3.50 [.14] 149.96 [5.90] 145.55 [5.73] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 5.00 79.96 [3.15] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. [.20] 54.25 [2.14] 75.55 [2.97] 54.25 [2.14] 5.00 [.20] 114.75 [4.52] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 114.75 [4.52] 1591XXD Enclosure 1591XXDBK 1591XXDGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXD www.hammondmfg.com ®
1591XXDBK 价格&库存
很抱歉,暂时无法提供与“1591XXDBK”相匹配的价格&库存,您可以联系我们找货
1591XXDBK
  • 1+137.124821+17.74703
  • 5+115.266785+14.91811
  • 10+107.0700210+13.85726
  • 25+97.1807725+12.57737
  • 50+90.3523850+11.69363
  • 100+84.03437100+10.87594
  • 250+76.39422250+9.88713
  • 500+76.38724500+9.88623
库存:56
