1555C2F22GY
1555C2F22GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 4.72"L X 2.59"W
1555C2F22GY 数据手册
150.79 [5.94] 19.60 [.77] 27.00 [1.06] 135.79 [5.35] A 4.60 [.18] 58.75 [2.31] INLAY WIDTH B 8.50 B 40.00 [1.57] 2.00 [.08] INLAY DEPTH 3.00 [.12] 65.79 [2.59] 3.00 [.12] 12.00 [.47] INNER LID DEPTH 22.50 [.89] INNER BOX DEPTH [.33] 4X 5.00 [4X .20] 15.50 [.61] A 88.35 [3.48] INLAY LENGTH SECTION A-A END VIEW ENCLOSURE ASSEMBLY TOP VIEW 21.57 [.85] 11.60 [.46] 6.00 [.24] 9.00 [.35] STEEL PANEL ORDER SEPARATELY 52.00 [2.05] SECTION B-B SDIE VIEW 107.00 [4.21] 119.95 [4.72] UL O C 42.50 [1.67] 6.00 [.24] POLYCARBONATE VERSION ONLY 10.59 [.42] 6X 3.00 [6X .12] 6.50 [.26] NOTE Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 95.00 [3.74] 4X 3.50 THRU [4X .14 THRU] 28.00 [1.10] 59.00 [2.32] 37.01 [1.46] 15.00 [.59] 85.01 114.00 [3.35] [4.49] INSIDE BOX VIEW 1555CF 1555CF Regular Enclosure General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 1555CF22GY 1555C2F22GY ACCESSORIES 64.95 [2.56] 52.00 [2.05] 40.01 [1.58] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. Purchased assembly includes styled box, flanged lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 4M STAINLESS STEEL INSERT [.28] US LISTED (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 108.00 [4.25] 7.00 ® FILE #E65324 NEMA 4, 4X 82.01 [3.23] 111.00 [4.37] INSIDE LID VIEW 56.00 [2.20] Steel Inner Panels Steel Panel / P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] 1555CFPL 1555TS100 SC1554 6X 2.25  6.00 [6X .09  .24] Dimensions: mm [inches] 1555CF22 www.hammondmfg.com ®
1555C2F22GY 价格&库存
很抱歉,暂时无法提供与“1555C2F22GY”相匹配的价格&库存,您可以联系我们找货
1555C2F22GY
  • 1+185.199611+23.07261
  • 5+158.318315+19.72368
  • 10+147.9709010+18.43457
  • 25+135.3276625+16.85945
  • 50+126.4880450+15.75819
  • 100+119.16528100+14.84590
库存:263
1555C2F22GY
