1555HF42GY
1555HF42GY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 7.09"L X 4.72"W
1555HF42GY 数据手册
220.79 [8.69] 200.79 [7.90] 47.00 [1.85] A 19.60 [.77] 4.60 [.18] 2.00 [.08] INLAY DEPTH 70.75 [2.79] 113.78 [4.48] INLAY WIDTH B 8.50 B A 3.00 [.12] 3.00 [.12] 120.79 [4.76] 12.00 [.47] INNER LID DEPTH 42.50 [1.67] INNER BOX DEPTH [.33] 4X 5.00 [4X .20] 15.50 [.61] 148.87 [5.86] INLAY LENGTH SECTION A-A END VIEW ENCLOSURE ASSEMBLY TOP VIEW 8.33 [.33] 62.34 [2.45] 6.01 [.24] POLYCARBONATE VERSION ONLY 19.38 [.76] 6.00 [.24] SECTION B-B SIDE VIEW 167.00 [6.57] 179.97 [7.09] UL O C STEEL PANEL ORDER SEPARATELY 106.68 [4.20] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 167.13 [6.58] NOTE Purchased assembly includes styled box, flanged lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 173.00 [6.81] 154.00 [6.06] 6X 2.25  6.00 [6X .09  .24] US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 6X 3.57 [6X .14] 6.32 [.25] ® FILE #E65324 NEMA 4, 4X Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 1555HF 1555HF Regular Enclosure 75.00 [2.95] 4M STAINLESS STEEL INSERT 114.00 [4.49] 113.00 107.00 [4.45] [4.21] 119.97 74.00 [4.72] [2.91] 3.00 84.00 [.12] [3.31] 14.00 [.55] 6.79 74.00 [2.91] [.27] 7.00 INSIDE BOX VIEW 4X 3.50 THRU [4X .14 THRU] 132.00 [5.20] INSIDE LID VIEW 1555HF42GY 1555H2F42GY ACCESSORIES Steel Inner Panels Steel Panel / P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] [.28] 155.00 [6.10] 174.00 [6.85] General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 1555HFPL 1555TS100 SC1554 15.00 [.59] Dimensions: mm [inches] 1555HF42 www.hammondmfg.com ®
1555HF42GY 价格&库存
很抱歉,暂时无法提供与“1555HF42GY”相匹配的价格&库存,您可以联系我们找货
