1455N1201
1455N1201
    HAMMONDMANUFACTURING
    BOX ALUM NATURAL 4.72"LX4.06"W
1455N1201 数据手册
1455 Extruded Aluminum Key Features: • Designed to house P.C. boards or for equipment interfacing. • Sized for standard Eurocards. • P.C. boards mount horizontally by sliding into internal slots extruded into the enclosure body. • Rugged body constructed from extruded aluminum with a minimum thickness of .06” (1.5 mm). • Extruded body includes a slide removable “belly” plate - except in smaller sizes “A” through “D” Includes: • Two aluminum end panels - finish matched to extruded aluminum body (or link here if you prefer our solid plastic end panel version) • Two black ABS plastic bezels (your option to install) • Extruded aluminum body - choice of clear, black, blue or red anodized finish • Self adhesive rubber feet. Replacements are available - order part number 1421T2CL (pack of 24). • All hardware - end panel screws are #6 x 3/8” TTT - thread rolling, steel screws with a #4 flat head phillips drive. Zinc plate finish - either clear or black (black screws are used on the black, blue & red models). • For black replacement screws (quantity 100) order part number 1455MS100BK • For clear replacement screws (quantity 100) order part number 1455MS100 • NOTE: Recommended screw torque is 5 lbf/in Extras Replacement Rubber Feet (24-pack) 1421T2CL Replacement Screws (100-pack) 1455MS100BK www.hammondmfg.com 1455MS100 USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 60 1455 Extruded Aluminum Most models feature a slide-in belly plate for easy access to the inside of the enclosure. All models feature internal PC board slots for easy mounting and assembly. Accessories Plastic bezels available in 5 colors: Yellow, Red, Transparent Red, Black, and Transparent Blue. Mix and match colors with extra end panels. Available in four anodized finishes: black, clear, red, and blue. Flanged end panels kits are available in clear or black anodize. Both come with black screws. Refer to accessories table for part numbers. www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 61 1455 Extruded Aluminum Part Number With Aluminum End Panels Part Number With Plastic End Panels 1455D601 1455D602 Clear 1455D601BK 1455D602BK Black Anodized Color 1455D601BU Blue 1455D601RD Red 1455D801 1455D802 Clear 1455D801BK 1455D802BK Black 1455D801BU Blue 1455D801RD Units Length Width Height Inches mm 2.36 60 1.76 45 0.99 25 Inches mm 3.15 80 1.76 45 0.99 25 Inches mm 3.15 80 2.76 70 0.47 12 Inches mm 3.15 80 2.82 71.7 0.75 19 Inches mm 3.15 80 2.13 54 0.91 23 Inches mm 3.94 100 2.76 70 0.47 12 Inches mm 3.94 100 2.82 71.7 0.75 19 Inches mm 4.72 120 2.76 70 0.47 12 Inches mm 4.72 120 2.82 71.7 0.75 19 Inches mm 4.72 120 2.13 54 0.91 23 Red 1455A802 Clear 1455A802BK Black 1455A802BU Blue 1455A802RD Red 1455B802 Clear 1455B802BK Black 1455B802BU Blue 1455B802RD Red 1455C801 1455C802 Clear 1455C801BK 1455C802BK Black 1455C801BU 1455C802BU Blue 1455C801RD 1455C802RD Red 1455A1002 Clear 1455A1002BK Black 1455A1002BU Blue 1455A1002RD Red 1455B1002 Clear 1455B1002BK Black 1455B1002BU Blue 1455B1002RD Red 1455A1202 Clear 1455A1202BK Black 1455A1202BU Blue 1455A1202RD Red 1455B1202 Clear 1455B1202BK Black 1455B1202BU Blue 1455B1202RD Red 1455C1201 1455C1202 Clear 1455C1201BK 1455C1202BK Black 1455C1201BU Blue 1455C1201RD Red www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 62 1455 Part Number With Aluminum End Panels Part Number With Plastic End Panels Extruded Aluminum Anodized Color 1455J1201 1455J1202 Clear 1455J1201BK 1455J1202BK Black 1455J1201BU Blue 1455J1201RD Units Length Width Height Inches mm 4.72 120 3.07 78 1.06 27 Inches mm 4.72 120 3.07 78 1.69 43 Inches mm 4.72 120 4.06 103 1.2 30.5 Inches mm 4.72 120 4.06 103 2.09 53 Inches mm 6.3 160 3.07 78 1.06 27 Inches mm 6.3 160 3.07 78 1.69 43 Inches mm 6.3 160 4.06 103 1.2 30.5 Inches mm 6.3 160 4.06 103 2.09 53 Inches mm 6.3 160 4.92 125 1.2 30.5 Inches mm 6.3 160 4.92 125 2.03 51.5 Red 1455K1201 1455K1202 Clear 1455K1201BK 1455K1202BK Black 1455K1201BU Blue 1455K1201RD Red 1455L1201 1455L1202 Clear 1455L1201BK 1455L1202BK Black 1455L1201BU Blue 1455L1201RD Red 1455N1201 1455N1202 Clear 1455N1201BK 1455N1202BK Black 1455N1201BU Blue 1455N1201RD Red 1455J1601 1455J1602 Clear 1455J1601BK 1455J1602BK Black 1455J1601BU Blue 1455J1601RD Red 1455K1601 1455K1602 Clear 1455K1601BK 1455K1602BK Black 1455K1601BU Blue 1455K1601RD Red 1455L1601 1455L1602 Clear 1455L1601BK 1455L1602BK Black 1455L1601BU Blue 1455L1601RD Red 1455N1601 1455N1602 Clear 1455N1601BK 1455N1602BK Black 1455N1601BU Blue 1455N1601RD Red 1455P1601 1455P1602 Clear 1455P1601BK 1455P1602BK Black 1455P1601BU Blue 1455P1601RD Red 1455Q1601 1455Q1602 Clear 1455Q1601BK 1455Q1602BK Black 1455Q1601BU Blue 1455Q1601RD Red www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 63 1455 Part Number With Aluminum End Panels Part Number With Plastic End Panels Extruded Aluminum Anodized Color 1455R1601 1455R1602 Clear 1455R1601BK 1455R1602BK Black 1455R1601BU Blue 1455R1601RD Units Length Width Height Inches mm 6.3 160 6.5 165 1.2 30.5 Inches mm 6.3 160 6.5 165 2.03 51.5 Inches mm 8.66 220 4.06 103 1.2 30.5 Inches mm 8.66 220 4.06 103 2.09 53 Inches mm 8.66 220 4.92 125 1.2 30.5 Inches mm 8.66 220 4.92 125 2.03 51.5 Inches mm 8.66 220 6.5 165 1.2 30.5 Inches mm 8.66 220 6.5 165 2.03 51.5 Red 1455T1601 1455T1602 Clear 1455T1601BK 1455T1602BK Black 1455T1601BU Blue 1455T1601RD Red 1455L2201 1455L2202 Clear 1455L2201BK 1455L2202BK Black 1455L2201BU Blue 1455L2201RD Red 1455N2201 1455N2202 Clear 1455N2201BK 1455N2202BK Black 1455N2201BU Blue 1455N2201RD Red 1455P2201 1455P2202 Clear 1455P2201BK 1455P2202BK Black 1455P2201BU Blue 1455P2201RD Red 1455Q2201 1455Q2202 Clear 1455Q2201BK 1455Q2202BK Black 1455Q2201BU Blue 1455Q2201RD Red 1455R2201 1455R2202 Clear 1455R2201BK 1455R2202BK Black 1455R2201BU Blue 1455R2201RD Red 1455T2201 1455T2202 Clear 1455T2201BK 1455T2202BK Black 1455T2201BU Blue 1455T2201RD Red www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 64 1455 For Part Number Starting With Extruded Aluminum Black 2-pack 10-pack Red Yellow 2-pack 10-pack 1455A 1455APLBK 1455APLBK-10 1455B 1455BPLBK 1455C 1455CPLBK 1455CPLBK-10 1455CPLY 1455D 1455DPLBK 1455DPLBK-10 2-pack Translucent Red 10-pack 2-pack 10-pack Translucent Blue 2-pack 10-pack 1455BPLBK-10 1455CPLY-10 1455CPLRED 1455CPLRED-10 1455CPLTRD 1455CPLTRD-10 1455CPLTBU 1455CPLTBU-10 1455J 1455JPLBK 1455JPLBK-10 1455JPLY 1455JPLY 1455JPLRED 1455JPLRED-10 1455K 1455KPLBK 1455KPLBK-10 1455KPLY 1455KPLY 1455KPLRED 1455KPLRED-10 1455KPLTRD 1455KPLTRD-10 1455KPLTBU 1455KPLTBU-10 1455L 1455LPLBK 1455LPLBK-10 1455LPLY 1455LPLRED 1455LPLRED-10 1455LPLTRD-10 1455LPLY 1455JPLTRD 1455LPLTRD 1455JPLTRD-10 1455JPLTBU 1455LPLTBU 1455JPLTBU-10 1455LPLTBU-10 1455N 1455NPLBK 1455NPLBK-10 1455NPLY 1455NPLY 1455NPLRED 1455NPLRED-10 1455NPLTRD 1455NPLTRD-10 1455NPLTBU 1455NPLTBU-10 1455P 1455PPLBK 1455PPLBK-10 1455PPLY 1455PPLY 1455PPLRED 1455Q 1455QPLBK 1455QPLBK-10 1455QPLY 1455QPLY 1455QPLRED 1455QPLRED-10 1455QPLTRD 1455QPLTRD-10 1455QPLTBU 1455QPLTBU-10 1455R 1455RPLBK 1455RPLBK-10 1455RPLY 1455RPLY 1455RPLRED 1455RPLRED-10 1455RPLTRD 1455RPLTRD-10 1455RPLTBU 1455RPLTBU-10 1455T 1455TPLBK 1455TPLBK-10 1455TPLY 1455TPLRED 1455TPLRED-10 1455TPLTRD-10 For Part Number Starting With 1455TPLY Yellow Black 2-pack 10-pack 1455C 1455CBBK 1455CBBK-10 1455D 1455DBBK 1455DBBK-10 1455J 1455JBBK 1455K 1455L 2-pack 1455PPLRED-10 1455PPLTRD 1455TPLTRD 1455PPLTRD-10 1455PPLTBU 1455PPLTBU-10 Translucent Red Red 1455TPLTBU 1455TPLTBU-10 Translucent Blue 10-pack 2-pack 10-pack 2-pack 10-pack 2-pack 10-pack 1455CBY 1455CBY-10 1455CBRED 1455CBRED-10 1455CBTRD 1455CBTRD-10 1455CBTBU 1455CBTBU-10 1455DBY 1455DBY-10 1455DBRED 1455DBRED-10 1455DBTRD 1455DBTRD-10 1455DBTBU 1455DBTBU-10 1455JBBK-10 1455JBY 1455JBY-10 1455JBRED 1455JBRED-10 1455JBTRD 1455JBTRD-10 1455JBTBU 1455JBTBU-10 1455KBBK 1455KBBK-10 1455KBY 1455KBY-10 1455KBRED 1455KBRED-10 1455KBTRD 1455KBTRD-10 1455KBTBU 1455KBTBU-10 1455LBBK 1455LBBK-10 1455LBY 1455LBY-10 1455LBRED 1455LBRED-10 1455LBTRD 1455LBTRD-10 1455LBTBU 1455LBTBU-10 1455N 1455NBBK 1455NBBK-10 1455NBY 1455NBY-10 1455NBRED 1455NBRED-10 1455NBTRD 1455NBTRD-10 1455NBTBU 1455NBTBU-10 1455P 1455PBBK 1455PBBK-10 1455PBY 1455PBY-10 1455PBRED 1455PBRED-10 1455PBTRD 1455PBTRD-10 1455PBTBU 1455PBTBU-10 1455Q 1455QBBK 1455QBBK-10 1455QBY 1455QBY-10 1455QBRED 1455QBRED-10 1455QBTRD 1455QBTRD-10 1455QBTBU 1455QBTBU-10 1455R 1455RBBK 1455RBBK-10 1455RBY 1455RBY-10 1455RBRED 1455RBRED-10 1455RBTRD 1455RBTRD-10 1455RBTBU 1455RBTBU-10 1455T 1455TBBK 1455TBK-10 1455TBY 1455TBY-10 1455TBRED 1455TBRED-10 1455TBTRD 1455TBTRD 1455TBTBU 1455TBTBU-10 www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 65 1455 Extruded Aluminum For Part Number Starting With Clear Anodize Black Anodize Blue Anodize Red Anodize 10-pack 10-pack 10-pack 10-pack 1455C 1455CAL-10 1455CALBK-10 1455CALBU-10 1455CALRD-10 1455D 1455DAL-10 1455DALBK-10 1455DALBU-10 1455DALRD-10 1455J 1455JAL-10 1455JALBK-10 1455JALBU-10 1455JALRD-10 1455K 1455KAL-10 1455KALBK-10 1455KALBU-10 1455KALRD-10 1455L 1455LAL-10 1455LALBK-10 1455LALBU-10 1455LALRD-10 1455N 1455NAL-10 1455NALBK-10 1455NALBU-10 1455NALRD-10 1455P 1455PAL-10 1455PALBK-10 1455PALBU-10 1455PALRD-10 1455Q 1455QAL-10 1455QALBK-10 1455QALBU-10 1455QALRD-10 1455R 1455RAL-10 1455RALBK-10 1455RALBU-10 1455RALRD-10 1455T 1455TAL-10 1455TALBK-10 1455TALBU-10 1455TALRD-10 For Part Number Starting With Black Anodize Clear Anodize 1455C 1455CF 1455CFBK 1455D 1455DF 1455DFBK 1455J 1455JF 1455JFBK 1455K 1455KF 1455KFBK 1455L 1455LF 1455LFBK 1455N 1455NF 1455NFBK 1455P 1455PF 1455PFBK 1455Q 1455QF 1455QFBK 1455R 1455RF 1455RFBK 1455T 1455TF 1455TFBK Critical Data, No Questions PDF Data Sheets, 2D AutoCAD, and 3D Models are available for download immediately from our web site. www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 66
1455N1201 价格&库存
很抱歉,暂时无法提供与“1455N1201”相匹配的价格&库存,您可以联系我们找货
1455N1201
  • 3+278.938283+36.19201
  • 5+234.001565+30.36151
  • 45+163.5987345+21.22680
库存:126
1455N1201
    • 1+204.36114
    库存:18
    1455N1201
    • 2+418.354822+54.28119
    • 5+323.871775+42.02210
    • 10+223.6777310+29.02200
    库存:14
