1555F2F42GY
1555F2F42GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 4.72"L X 3.57"W
1555F2F42GY 数据手册
160.79 [6.33] 19.60 [.77] A 4.60 [.18] 140.79 [5.54] 8.50 .48 [.02] INLAY DEPTH 50.75 [2.00] 83.75 [3.30] INLAY WIDTH B B 42.50 [1.67] INNER BOX DEPTH A 88.80 [3.50] INLAY LENGTH 62.51 [2.46] 6.00 [.24] 12.00 [.47] INNER LID DEPTH SECTION A-A END VIEW 11.59 [.46] ENCLOSURE ASSEMBLY TOP VIEW 6.00 [.24] 3.00 [.12] 3.00 [.12] 90.79 [3.57] [.33] 4X 5.00 [4X .20] 6.50 [.26] 20.46 [.81] R10.00 [.39] POLYCARBONATE VERSION ONLY UL O C STEEL PANEL ORDER SEPARATELY 76.00 [2.99] ® US LISTED FILE #E65324 NEMA 4, 4X Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 6X 3.00 [6X .12] SECTION B-B SIDE VIEW (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 119.95 [4.72] NOTE 108.00 [4.25] 4M STAINLESS STEEL INSERT 107.00 [4.21] 15.50 [.61] 47.00 [1.85] Purchased assembly includes styled box, flanged lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 113.00 [4.45] 94.00 [3.70] 6X 2.25  6.00 [6X .09  .24] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 1555FF 1555FF Regular Enclosure 84.00 [3.31] 77.00 [3.03] 45.00 [1.77] 89.95 [3.54] 95.00 [3.74] 114.00 [4.49] INSIDE BOX VIEW 44.00 [1.73] 83.00 [3.27] 4X 3.50 THRU [4X .14 THRU] 3.00 [.12] 6.79 15.00 [.59] General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 ACCESSORIES [.27] 68.00 [2.68] 11.50 [.45] 77.00 [3.03] INSIDE LID VIEW 1555FF42GY 1555F2F42GY Steel Inner Panels Steel Panel / P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] 1555FFPL 1555TS100 SC1554 7.00 [.28] Dimensions: mm [inches] 1555FF42 www.hammondmfg.com ®
1555F2F42GY 价格&库存
很抱歉,暂时无法提供与“1555F2F42GY”相匹配的价格&库存,您可以联系我们找货
1555F2F42GY
    • 1+165.71539
    库存:1
